    3. Entwicklung
    4. [GELÖST] Unterstützung bei Fehlermeldung
    • blauholsten
      blauholsten Developer last edited by blauholsten
      seit dem Update des JS-Controllers auf 5.x, berichten Leute, dass "mein" Viessmann Adapter nicht mehr startet.
      Ich habe dann heute mein System auch geupdatet, leider musste ich das Gleiche feststellen. Komisch, im Dev-Server läuft der Adapter???
      Ich bin definitiv kein Profi Coder und komme mit der Fehlermeldung nicht weiter! Kann mir jemand einen Tip geben?
      2023-06-21 22:19:55.343 - info: viessmann.0 (3174217) starting. Version 1.4.3 (non-npm: misanorot/ioBroker.viessmann) in /opt/iobroker/node_modules/iobroker.viessmann, node: v18.16.0, js-controller: 5.0.5
      2023-06-21 22:19:55.376 - error: viessmann.0 (3174217) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2023-06-21 22:19:55.377 - error: viessmann.0 (3174217) unhandled promise rejection: Parameter "options" needs to be a real object but type "boolean" has been passed
      2023-06-21 22:19:55.380 - error: viessmann.0 (3174217) Error: Parameter "options" needs to be a real object but type "boolean" has been passed
      at Validator.assertObject (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/validator.js:215:19)
      at Viessmann.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5335:35)
      at Viessmann.main (/opt/iobroker/node_modules/iobroker.viessmann/main.js:584:8)
      at Viessmann.start (/opt/iobroker/node_modules/iobroker.viessmann/main.js:112:15)
      at Viessmann.onReady (/opt/iobroker/node_modules/iobroker.viessmann/main.js:54:8)
      at Viessmann.emit (node:events:513:28)
      at Viessmann._callReadyHandler (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:9013:18)
      at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8991:26
      2023-06-21 22:19:55.380 - error: viessmann.0 (3174217) Parameter "options" needs to be a real object but type "boolean" has been passed
      2023-06-21 22:19:55.401 - info: viessmann.0 (3174217) cleaned everything up...
        Homoran Global Moderator Administrators @blauholsten last edited by Homoran
        @blauholsten bitte im Beta-Tester Thread posten.
        edit:
        sorry, da warte ich wohl noch was
        blauholsten 1 Reply Last reply Reply Quote 0
        • blauholsten
          blauholsten Developer @Homoran last edited by
          Hallo Homoran,
          finde das eigentlich in dem Thread nicht passend. Das muss ja nicht zwangsläufig ein JS Controller Problem sein. Ich sehe nur die Lösung in meinem Code nicht. Daher im Entwickler Forum die Frage.
            @blauholsten alles gut.
            ich hatte den Thread reflexartig gesperrt und den Satz reingeschrieben um den Wildwuchs an Threads zu controller v5 zu begrenzen.
            Hab erst später realisiert, dass du Hilfe für die Entwicklung brauchst und den Thread wieder geöffnet.
            • blauholsten
              Fehler doch selbst gefunden, danke trotzdem...
              • BananaJoe
                BananaJoe Most Active @blauholsten last edited by
                @blauholsten sagte in [GELÖST] Unterstützung bei Fehlermeldung:
                Und? Ich lese interessiert mit und nun will ich es auch wissen 😀
                • blauholsten
                  blauholsten Developer @BananaJoe last edited by
                  @bananajoe
                  Habe bei einen setState , ein Argument Zuviel übergeben, dass scheint der neue Controller nicht zu mögen….??
