    4. Instanz javascript - Fehler im log
    • bahnuhr
      bahnuhr Forum Testing Most Active last edited by bahnuhr
      installiert ist js 7.0.3
      Bei start kommt im log:
      host.iobroker
      2023-06-25 10:10:35.640	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      2023-06-25 10:10:35.640	error	Caught by controller[0]: Node.js v18.16.1
      host.iobroker
      2023-06-25 10:10:35.640	error	Caught by controller[0]: }
      host.iobroker
      2023-06-25 10:10:35.640	error	Caught by controller[0]: requestPath: 'coffeescript'
      host.iobroker
      2023-06-25 10:10:35.639	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/package.json',
      host.iobroker
      2023-06-25 10:10:35.639	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.iobroker
      2023-06-25 10:10:35.639	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32) {
      host.iobroker
      2023-06-25 10:10:35.639	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
      host.iobroker
      2023-06-25 10:10:35.639	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
      host.iobroker
      2023-06-25 10:10:35.638	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:21:23)
      host.iobroker
      2023-06-25 10:10:35.638	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
      host.iobroker
      2023-06-25 10:10:35.638	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
      host.iobroker
      2023-06-25 10:10:35.637	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
      host.iobroker
      2023-06-25 10:10:35.637	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1063:27)
      host.iobroker
      2023-06-25 10:10:35.637	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:680:18)
      host.iobroker
      2023-06-25 10:10:35.637	error	Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:438:19)
      host.iobroker
      2023-06-25 10:10:35.637	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script'. Please verify that the package.json has a valid "main" entry
      host.iobroker
      2023-06-25 10:10:35.637	error	Caught by controller[0]: ^
      host.iobroker
      2023-06-25 10:10:35.636	error	Caught by controller[0]: throw err;
      host.iobroker
      2023-06-25 10:10:35.636	error	Caught by controller[0]: node:internal/modules/cjs/loader:446
      host.iobroker
      2023-06-25 10:10:35.150	info	instance system.adapter.javascript.0 started with pid 3790
      iob diag zeigt:
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Architecture    : x86_64
      Docker          : false
      Virtualization  : kvm
      Distributor ID: Debian
      Description:    Debian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
      NAME="Debian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      Systemuptime and Load:
       09:49:16 up 1 min,  1 user,  load average: 3.56, 1.05, 0.37
      CPU threads: 8
      *** Time and Time Zones ***
                     Local time: Sun 2023-06-25 09:49:17 CEST
                 Universal time: Sun 2023-06-25 07:49:17 UTC
                       RTC time: Sun 2023-06-25 07:49:18
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      dieter
      /home/dieter
      dieter cdrom floppy sudo audio dip video plugdev netdev iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            5.9G        1.9G        3.7G        0.0K        376M        3.9G
      Swap:           974M          0B        974M
      Total:          6.9G        1.9G        4.7G
               5928 M total memory
               1854 M used memory
                140 M active memory
               1945 M inactive memory
               3698 M free memory
                 49 M buffer memory
                327 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      *** FILESYSTEM ***
      Filesystem                Type      Size  Used Avail Use% Mounted on
      udev                      devtmpfs  2.9G     0  2.9G   0% /dev
      tmpfs                     tmpfs     593M  508K  593M   1% /run
      /dev/sda1                 ext4       31G  7.1G   22G  25% /
      tmpfs                     tmpfs     2.9G     0  2.9G   0% /dev/shm
      tmpfs                     tmpfs     5.0M     0  5.0M   0% /run/lock
      //192.168.243.100/1_Sound cifs      238G  128G  110G  54% /mnt
      tmpfs                     tmpfs     593M     0  593M   0% /run/user/1000
      [Sun Jun 25 09:47:48 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
      [Sun Jun 25 09:47:52 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
      Show mounted filesystems (real ones only):
      TARGET SOURCE                    FSTYPE OPTIONS
      /      /dev/sda1                 ext4   rw,relatime,errors=remount-ro
      `-/mnt //192.168.243.100/1_Sound cifs   rw,relatime,vers=3.1.1,cache=strict,username=dieter,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.243.100,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1
      /var:
      860M    /var/
      371M    /var/cache
      364M    /var/cache/apt
      322M    /var/log
      305M    /var/log/journal/dd59139b4ae040898d227e04f86103f0
      Archived and active journals take up 56.0M in the file system.
      /opt/iobroker/backups:
      381M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.1G    /opt/iobroker/iobroker-data/
      627M    /opt/iobroker/iobroker-data/files
      298M    /opt/iobroker/iobroker-data/files/vis.0
      248M    /opt/iobroker/iobroker-data/files/vis.0/wav
      235M    /opt/iobroker/iobroker-data/sqlite
      235M    /opt/iobroker/iobroker-data/sqlite/sqlite.db
      154M    /opt/iobroker/iobroker-data/files/vis.0/wav/starker-regen-mit-gewitter-im.wav
      36M     /opt/iobroker/iobroker-data/objects.jsonl
      34M     /opt/iobroker/iobroker-data/files/vis.0/wav/hagelschauer-im-sommer.wav
      31M     /opt/iobroker/iobroker-data/states.jsonl
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.16.1
      /usr/bin/node           v18.16.1
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Installed: 18.16.1-deb-1nodesource1
        Candidate: 18.16.1-deb-1nodesource1
        Version table:
       *** 18.16.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u4 500
              500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://deb.debian.org/debian bullseye/main amd64 Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      MULTIHOSTSERVICE/enabled: false
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     7.0.3
      Adapters from github:   11
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
      + system.adapter.asterisk.0               : asterisk              : iobroker                                 -  enabled, port: 5038
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      + system.adapter.bmw.0                    : bmw                   : iobroker                                 -  enabled
        system.adapter.bosch-ebike.0            : bosch-ebike           : iobroker                                 - disabled
      + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
      + system.adapter.contact.0                : contact               : iobroker                                 -  enabled, port: 8096
      + system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
        system.adapter.doorio.0                 : doorio                : iobroker                                 - disabled, port: 4444
      + system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
      + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
      + system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
        system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
      + system.adapter.komoot.0                 : komoot                : iobroker                                 -  enabled
      + system.adapter.libre.0                  : libre                 : iobroker                                 -  enabled
        system.adapter.linux-control.0          : linux-control         : iobroker                                 - disabled
      + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
      + system.adapter.mbus.0                   : mbus                  : Pi-Strom-Wasser                          -  enabled, port: 3493
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
        system.adapter.mihome.0                 : mihome                : iobroker                                 - disabled, port: 9898, bind: 192.168.243.12
      + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
      + system.adapter.musiccast.0              : musiccast             : iobroker                                 -  enabled
      + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
      + system.adapter.openligadb.0             : openligadb            : iobroker                                 -  enabled
      + system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
      + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
      + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
        system.adapter.rest-api.0               : rest-api              : iobroker                                 - disabled, port: 8093, bind: 0.0.0.0, run as: admin
      + system.adapter.rssfeed.0                : rssfeed               : iobroker                                 -  enabled
      + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
      + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled
      + system.adapter.sayit.4                  : sayit                 : iobroker                                 -  enabled
        system.adapter.sayit.5                  : sayit                 : iobroker                                 - disabled, port: 0
        system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.smartmeter.0             : smartmeter            : Pi-Strom-Wasser                          -  enabled
      + system.adapter.smartmeter.1             : smartmeter            : Pi-Strom-Wasser                          -  enabled
        system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
      + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
      + system.adapter.sql.1                    : sql                   : iobroker                                 -  enabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
      + system.adapter.viessmann.0              : viessmann             : iobroker                                 -  enabled, port: 3002
        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
        system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
        system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
        system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
        system.adapter.vis-players.0            : vis-players           : iobroker                                 -  enabled
        system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
        system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.wiobrowser.0             : wiobrowser            : iobroker                                 - disabled, port: 5000
      + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.yamaha.0                 : yamaha                : iobroker                                 -  enabled
      + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.243.114:6638
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.3.5    , installed 6.3.5
      Adapter    "alias-manager": 1.2.4    , installed 1.2.4
      Adapter    "asterisk"     : 1.0.6    , installed 1.0.6
      Adapter    "backitup"     : 2.6.23   , installed 2.6.23
      Adapter    "bmw"          : 2.5.7    , installed 2.5.7
      Adapter    "bosch-ebike"  : 0.0.3    , installed 0.0.3
      Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
      Adapter    "doorio"       : 2.1.4    , installed 2.1.4
      Adapter    "dwd"          : 2.8.3    , installed 2.8.5
      Adapter    "email"        : 1.2.0    , installed 1.2.0
      Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
      Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
      Adapter    "fritzdect"    : 2.2.6    , installed 2.2.6
      Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
      Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
      Adapter    "ical"         : 1.13.2   , installed 1.13.2
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "info"         : 1.9.26   , installed 1.9.26
      Adapter    "javascript"   : 7.0.3    , installed 7.0.3
      Controller "js-controller": 4.0.24   , installed 4.0.24
      Adapter    "libre"        : 0.0.4    , installed 0.0.5
      Adapter    "linux-control": 1.1.3    , installed 1.1.3
      Adapter    "logparser"    : 2.2.0    , installed 2.2.0
      Adapter    "mihome"       : 1.4.0    , installed 1.4.0
      Adapter    "mihome-vacuum": 3.11.0   , installed 3.11.0
      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
      Adapter    "musiccast"    : 0.1.5    , installed 1.1.2
      Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
      Adapter    "openligadb"   : 1.2.4    , installed 1.2.4
      Adapter    "parser"       : 1.3.2    , installed 1.3.2
      Adapter    "ping"         : 1.5.3    , installed 1.5.3
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
      Adapter    "rest-api"     : 1.1.0    , installed 1.1.0
      Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
      Adapter    "shelly"       : 6.4.1    , installed 6.4.1
      Adapter    "socketio"     : 4.2.0    , installed 6.3.5
      Adapter    "sql"          : 2.2.0    , installed 2.2.0
      Adapter    "telegram"     : 1.15.6   , installed 1.15.6
      Adapter    "tuya"         : 3.14.2   , installed 3.14.2
      Adapter    "viessmann"    : 1.4.3    , installed 1.4.3
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
      Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "web"          : 4.3.0    , installed 6.0.1
      Adapter    "wiobrowser"   : 2.0.1    , installed 2.0.1
      Adapter    "ws"           : 1.3.0    , installed 2.3.6
      Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
      Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
      Objects and States
      Objects:        23819
      States:         19603
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       13637      406/iobroker.js-con
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       13628      406/iobroker.js-con
      tcp        0      0 0.0.0.0:5038            0.0.0.0:*               LISTEN      108        13608      403/asterisk
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          55         1/init
      tcp        0      0 192.168.243.15:2001     0.0.0.0:*               LISTEN      1001       15096      771/io.hm-rpc.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11871      443/sshd: /usr/sbin
      tcp        0      0 192.168.243.15:2010     0.0.0.0:*               LISTEN      1001       15957      949/io.hm-rpc.2
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       21822      1025/io.mqtt.0
      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       19426      1031/io.mqtt.2
      tcp        0      0 192.168.243.15:8701     0.0.0.0:*               LISTEN      1001       16497      886/io.hm-rpc.1
      tcp6       0      0 :::111                  :::*                    LISTEN      0          1232       1/init
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13739      582/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20964      2595/io.web.0
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       21774      2599/io.ws.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          11873      443/sshd: /usr/sbin
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       20152      2227/io.simple-api.
      udp        0      0 0.0.0.0:5060            0.0.0.0:*                           108        13622      403/asterisk
      udp        0      0 192.168.243.15:50249    0.0.0.0:*                           1001       23569      1093/io.yamaha.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       23570      1093/io.yamaha.0
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       19402      1078/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       19403      1078/io.tuya.0
      udp        0      0 0.0.0.0:36196           0.0.0.0:*                           108        14431      403/asterisk
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1425       371/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13276      1/init
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       17502      983/io.mihome-vacuu
      udp        0      0 0.0.0.0:4569            0.0.0.0:*                           108        13621      403/asterisk
      udp6       0      0 :::52485                :::*                                108        14432      403/asterisk
      udp6       0      0 :::111                  :::*                                0          13281      1/init
      2023-06-25 09:54:47.447  - info: mqtt.2 (1031) Client [Wemos_Philipp_Klima] publishOnSubscribe send all known states
      2023-06-25 09:54:47.590  - info: mqtt.2 (1031) Client [Wemos_Beamer-Wz] publishOnSubscribe send all known states
      2023-06-25 09:55:00.348  - info: host.iobroker instance system.adapter.dwd.0 started with pid 4197
      2023-06-25 09:55:08.710  - info: dwd.0 (4197) starting. Version 2.8.5 (non-npm: ioBroker/ioBroker.dwd) in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.1, js-controller: 4.0.24
      2023-06-25 09:55:09.473  - info: sql.0 (636) enabled logging of tankerkoenig.0.stations.0.diesel.feed, Alias=false, WriteNulls=false
      2023-06-25 09:55:17.239  - info: sql.0 (636) enabled logging of tankerkoenig.0.stations.1.diesel.feed, Alias=false, WriteNulls=false
      2023-06-25 09:55:22.539  - info: dwd.0 (4197) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-06-25 09:55:23.292  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-06-25 09:55:23.622  - info: sql.0 (636) enabled logging of tankerkoenig.0.stations.2.diesel.feed, Alias=false, WriteNulls=false
      2023-06-25 09:55:29.920  - info: sql.0 (636) enabled logging of tankerkoenig.0.stations.3.diesel.feed, Alias=false, WriteNulls=false
      2023-06-25 09:55:31.183  - info: octoprint.0 (1958) error EHOSTUNREACH from /api/version: connect EHOSTUNREACH 192.168.243.139:80
      2023-06-25 09:55:35.180  - info: sql.0 (636) enabled logging of tankerkoenig.0.stations.4.diesel.feed, Alias=false, WriteNulls=false
      2023-06-25 09:55:36.736  - error: daswetter.0 (1304) force terminate
      2023-06-25 09:55:36.740  - warn: daswetter.0 (1304) Terminated (UNKNOWN_ERROR): Without reason
      2023-06-25 09:55:37.264  - error: daswetter.0 (1304) exception in await insertIntoList [Error: DB closed]
      2023-06-25 09:55:37.287  - error: daswetter.0 (1304) exception in await insertIntoList [Error: DB closed]
      2023-06-25 09:55:37.292  - error: daswetter.0 (1304) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_2.wind_value": Connection is closed.
      2023-06-25 09:55:37.309  - error: daswetter.0 (1304) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_2.wind_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_2.wind_value": Connection is closed.]
      2023-06-25 09:55:37.312  - error: daswetter.0 (1304) Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_2.windIconURL": Connection is closed.
      2023-06-25 09:55:37.319  - error: daswetter.0 (1304) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_2.windIconURL: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_2.windIconURL": Connection is closed.]
      2023-06-25 09:55:37.530  - error: host.iobroker instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
      2023-06-25 09:55:40.651  - info: sql.0 (636) enabled logging of tankerkoenig.0.stations.5.diesel.feed, Alias=false, WriteNulls=false
      2023-06-25 09:55:43.058  - info: octoprint.0 (1958) error ECONNABORTED from /api/version: timeout of 2000ms exceeded
      2023-06-25 09:55:43.537  - info: sql.0 (636) enabled logging of tankerkoenig.0.stations.6.diesel.feed, Alias=false, WriteNulls=false
      2023-06-25 09:55:46.648  - info: sql.0 (636) enabled logging of tankerkoenig.0.stations.7.diesel.feed, Alias=false, WriteNulls=false
      iob diag has finished.
      Press any key for a summary
                           v.2023-04-16
      Operatingsystem:        Debian GNU/Linux 11 (bullseye)
      Kernel:                 5.10.0-23-amd64
      Installation:           kvm
      User-ID:                1000
      X-Server:               false
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v18.16.1
                              /usr/bin/npm            9.5.1
                              /usr/bin/npx            9.5.1
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:            5.9G        3.3G        1.5G        0.0K        1.1G        2.4G
      Swap:           974M          0B        974M
      Total:          6.9G        3.3G        2.5G
      Active iob-Instances:   51
      ioBroker Core:          js-controller           4.0.24
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      Objects:                23819
      States:                 19601
      Size of iob-Database:
      37M     /opt/iobroker/iobroker-data/objects.jsonl
      38M     /opt/iobroker/iobroker-data/states.jsonl
      • bahnuhr
        weiterhin kam im log:
        Rebuild for adapter system.adapter.javascript.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
        Das habe ich ausprobiert im Verzeichnis: /opt/iobroker/node_modules/iobroker.javascript
        In der Konsole kommt:
        dieter@iobroker:/opt/iobroker/node_modules/iobroker.javascript$ npm install --production
        [sudo] Passwort für dieter:
        npm WARN config production Use `--omit=dev` instead.
        up to date, audited 169 packages in 5s
        9 packages are looking for funding
          run `npm fund` for details
        1 moderate severity vulnerability
        Some issues need review, and may require choosing
        a different dependency.
        Run `npm audit` for details.
        Gebracht hat es nichts. Weiterhin instance rot !
        • bahnuhr
          So, habe javascript über npm neu drüber installiert.
          Instanz wird grün !
          Im log kommt aber noch sowas:
          javascript.0
          2023-06-25 10:24:50.847	error	WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
          javascript.0
          2023-06-25 10:24:50.844	error	npm
          javascript.0
          2023-06-25 10:24:50.649	error	WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
          javascript.0
          2023-06-25 10:24:50.647	error	npm
          javascript.0
          2023-06-25 10:24:50.263	error	WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
          javascript.0
          2023-06-25 10:24:50.261	error	npm
          javascript.0
          2023-06-25 10:24:49.796	error	WARN deprecated har-validator@5.1.5: this library is no longer supported
          javascript.0
          2023-06-25 10:24:49.792	error	npm
          smartmeter.0
          2023-06-25 10:24:40.074	info	Received 7 values, 3 updated
          javascript.0
          2023-06-25 10:24:37.365	info	npm install basic-ftp --omit=dev (System call)
          javascript.0
          2023-06-25 10:24:37.295	info	starting. Version 7.0.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v18.16.1, js-controller: 4.0.24
          mikeal created this issue in request/request
          open Request’s Past, Present and Future #3142
          • crunchip
            crunchip Forum Testing Most Active @bahnuhr last edited by
            @bahnuhr das kannst ignorieren
            • bahnuhr
              bahnuhr Forum Testing Most Active @crunchip last edited by
              @crunchip sagte in Instanz javascript - Fehler im log:
              Ja, hab ich mir schon gedacht.
              Die Frage ist nur, warum kam der ursprüngliche Fehler mit dem "coffee"
              Vorher hatte ich mit update und upgrade alles aktualisiert.
              Und dann war js rot.
              • crunchip
                @bahnuhr sagte in Instanz javascript - Fehler im log:
                kann ich dir nicht sagen, aber ich glaube mich zu erinnern, das du schon den ein oder anderen Thread eröffnet hattest, wegen diesem coffeescript
                • bahnuhr
                  ja, aber danach hatte ich komplett neu aufgesetzt.
                  Komisch.
                  error javascript log
