    4. Einbindung von Geräten
    5. [gelöst] Zigbee Problem - Coordinator per Ethernet
    • Meister Mopper
      Meister Mopper last edited by Meister Mopper
      ich habe gerade eine neue iobroker VM in Proxmox mit Debian 12 aufgesetzt und den ioBroker mit dem Einzeiler erfolgreich aufgesetzt.
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Architecture    : x86_64
      Docker          : false
      Virtualization  : kvm
      Distributor ID: Debian
      Description:    Debian GNU/Linux 12 (bookworm)
      Release:        12
      Codename:       bookworm
      PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
      NAME="Debian GNU/Linux"
      VERSION_ID="12"
      VERSION="12 (bookworm)"
      VERSION_CODENAME=bookworm
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      Systemuptime and Load:
      17:13:10 up 9 days, 21:24,  3 users,  load average: 0.00, 0.04, 0.06
      CPU threads: 2
      *** Time and Time Zones ***
                    Local time: Thu 2023-07-06 17:13:10 CEST
                Universal time: Thu 2023-07-06 15:13:10 UTC
                      RTC time: Thu 2023-07-06 15:13:10
                   NTP service: active
               RTC in local TZ: no
      *** User and Groups ***
      nils
      /home/nils
      nils cdrom floppy audio dip video plugdev users netdev iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            4.1G        916M        2.7G        544K        736M        3.2G
      Swap:           1.0G          0B        1.0G
      Total:          5.1G        916M        3.7G
              3915 M total memory
               873 M used memory
               281 M active memory
               882 M inactive memory
              2568 M free memory
               104 M buffer memory
               598 M swap cache
               974 M total swap
                 0 M used swap
               974 M free swap
      *** FILESYSTEM ***
      udev           devtmpfs  1.9G     0  1.9G   0% /dev
      tmpfs          tmpfs     392M  536K  392M   1% /run
      /dev/sda1      ext4       15G  3.1G   11G  23% /
      tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     392M     0  392M   0% /run/user/1000
      [Mon Jun 26 19:49:09 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
      [Mon Jun 26 19:49:10 2023] EXT4-fs (sda1): re-mounted. Quota mode: none.
      Show mounted filesystems (real ones only):
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      459M    /var/
      245M    /var/cache
      238M    /var/cache/apt
      167M    /var/lib
      162M    /var/cache/apt/archives
      Archived and active journals take up 11.6M in the file system.
      /opt/iobroker/backups:
      8.8M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      127M    /opt/iobroker/iobroker-data/
      94M     /opt/iobroker/iobroker-data/files
      52M     /opt/iobroker/iobroker-data/files/javascript.admin
      34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
      33M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.312d98a8.chunk.js.map
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      5.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/44.59b48e42.chunk.js.map
      4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
      4.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/2.b1d56998.chunk.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.16.1
      /usr/bin/node           v18.16.1
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
       Installed: 18.16.1-deb-1nodesource1
       Candidate: 18.16.1-deb-1nodesource1
       Version table:
      *** 18.16.1-deb-1nodesource1 500
             500 https://deb.nodesource.com/node_18.x bookworm/main amd64 Packages
             100 /var/lib/dpkg/status
          18.13.0+dfsg1-1 500
             500 http://deb.debian.org/debian bookworm/main amd64 Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      MULTIHOSTSERVICE/enabled: false
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     7.0.3
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
       system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
       system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled, port: tcp://192.168.178.6:20108
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.3.5    , installed 6.3.5
      Adapter    "backitup"     : 2.6.23   , installed 2.6.23
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Adapter    "javascript"   : 7.0.3    , installed 7.0.3
      Controller "js-controller": 4.0.24   , installed 4.0.24
      Adapter    "socketio"     : 4.2.0    , installed 4.2.0
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "web"          : 4.3.0    , installed 4.3.0
      Adapter    "ws"           : 1.3.0    , installed 1.3.0
      Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
      Objects and States
      Objects:        240
      States:         186
      Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:4 https://deb.nodesource.com/node_18.x bookworm InRelease
      Reading package lists...
      Pending Updates: 1
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       62329      8477/iobroker.js-co
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       62336      8477/iobroker.js-co
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14820      487/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12832      1/init
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       62565      8495/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       62701      8582/io.web.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14822      487/sshd: /usr/sbin
      tcp6       0      0 :::111                  :::*                    LISTEN      0          12834      1/init
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12833      1/init
      udp6       0      0 :::111                  :::*                                0          12835      1/init
      2023-07-06 17:06:22.809  - error: zigbee.0 (8726) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2023-07-06 17:06:22.810  - error: zigbee.0 (8726) unhandled promise rejection: Cannot read properties of undefined (reading 'Error')
      2023-07-06 17:06:22.841  - error: zigbee.0 (8726) TypeError: Cannot read properties of undefined (reading 'Error')
         at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56
         at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1)
         at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1)
         at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32)
         at Zigbee.doConnect (/opt/iobroker/node_modules/iobroker.zigbee/main.js:345:18)
      2023-07-06 17:06:22.841  - error: zigbee.0 (8726) Cannot read properties of undefined (reading 'Error')
      2023-07-06 17:06:22.848  - info: zigbee.0 (8726) cleaned everything up...
      2023-07-06 17:06:22.851  - info: zigbee.0 (8726) Zigbee: disabling joining new devices.
      2023-07-06 17:06:22.868  - warn: zigbee.0 (8726) Failed to stop zigbee during startup
      2023-07-06 17:06:22.868  - info: zigbee.0 (8726) terminating
      2023-07-06 17:06:22.869  - warn: zigbee.0 (8726) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2023-07-06 17:06:23.414  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2023-07-06 17:06:23.414  - error: host.iobroker Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'Error')
      2023-07-06 17:06:23.414  - error: host.iobroker Caught by controller[1]:     at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56
      2023-07-06 17:06:23.414  - error: host.iobroker Caught by controller[1]:     at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1)
      2023-07-06 17:06:23.414  - error: host.iobroker Caught by controller[1]:     at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1)
      2023-07-06 17:06:23.415  - error: host.iobroker Caught by controller[1]:     at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32)
      2023-07-06 17:06:23.415  - error: host.iobroker Caught by controller[1]:     at Zigbee.doConnect (/opt/iobroker/node_modules/iobroker.zigbee/main.js:345:18)
      2023-07-06 17:06:23.415  - error: host.iobroker instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2023-07-06 17:06:23.415  - info: host.iobroker Restart adapter system.adapter.zigbee.0 because enabled
      2023-07-06 17:06:23.415  - warn: host.iobroker Do not restart adapter system.adapter.zigbee.0 because restart loop detected
      2023-07-06 17:07:42.731  - info: host.iobroker "system.adapter.zigbee.0" disabled
      Als Coordinator nutze ich ein TI-CC26X2R1, als TCP-Modul das USR-TCP232-T2 TTL. Es befindet sich im richtigen Netzwerksegment und ist vom ioBroker pingbar.
      Das Modul habe ich (mehrfach überprüft) mit 3 V, GND und gedrehtem TX/RX angeschlossen.
      Den Coordinator habe ich mit der neuesten Firmware von Koenkk mittlerweile dreimal mit erfolgreichem log und Verifizierung mit UniFlash gesflashed (aktuelle Firmware CC2652R_coordinator_20230507.hex).
      Im ioBroker habe ich das Gerät wie folgt testweise eingebunden:
      Es hilft nichts, ich bekomme keine Verbindung zum Koordinator.
      Hier das debug log, hoffentlich hat jemand eine Idee, wo die Ursache zu finden ist:
      host.iobroker	2023-07-06 17:07:42.731	info	"system.adapter.zigbee.0" disabled
      host.iobroker	2023-07-06 17:17:32.502	info	"system.adapter.zigbee.0" enabled
      host.iobroker	2023-07-06 17:17:32.535	info	instance system.adapter.zigbee.0 started with pid 9619
      zigbee.0	2023-07-06 17:17:35.193	info	starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24
      zigbee.0	2023-07-06 17:17:35.288	info	delete old Backup files. keep only last 10
      zigbee.0	2023-07-06 17:17:35.290	info	Starting Zigbee npm ...
      zigbee.0	2023-07-06 17:17:35.679	info	Installed Version: iobroker.zigbee@1.8.10
      zigbee.0	2023-07-06 17:17:39.991	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}}
      zigbee.0	2023-07-06 17:17:39.999	info	Unable to disable LED, unsupported function.
      zigbee.0	2023-07-06 17:17:40.013	info	--> transmitPower : normal
      zigbee.0	2023-07-06 17:17:40.020	info	Currently no devices.
      zigbee.0	2023-07-06 17:17:40.021	info	Zigbee started
      zigbee.0	2023-07-06 17:17:40.024	error	Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms
      zigbee.0	2023-07-06 17:17:40.025	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      zigbee.0	2023-07-06 17:17:40.026	error	unhandled promise rejection: Cannot read properties of undefined (reading 'Error')
      zigbee.0	2023-07-06 17:17:40.052	error	TypeError: Cannot read properties of undefined (reading 'Error') at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30)
      zigbee.0	2023-07-06 17:17:40.052	error	Cannot read properties of undefined (reading 'Error')
      zigbee.0	2023-07-06 17:17:40.060	info	cleaned everything up...
      zigbee.0	2023-07-06 17:17:40.062	info	Zigbee: disabling joining new devices.
      zigbee.0	2023-07-06 17:17:40.561	info	terminating
      zigbee.0	2023-07-06 17:17:40.563	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      host.iobroker	2023-07-06 17:17:41.108	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      host.iobroker	2023-07-06 17:17:41.108	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'Error')
      host.iobroker	2023-07-06 17:17:41.109	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56
      host.iobroker	2023-07-06 17:17:41.109	error	Caught by controller[1]: at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1)
      host.iobroker	2023-07-06 17:17:41.109	error	Caught by controller[1]: at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1)
      host.iobroker	2023-07-06 17:17:41.109	error	Caught by controller[1]: at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32)
      host.iobroker	2023-07-06 17:17:41.111	error	Caught by controller[1]: at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30)
      host.iobroker	2023-07-06 17:17:41.111	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.iobroker	2023-07-06 17:17:41.111	info	Restart adapter system.adapter.zigbee.0 because enabled
      host.iobroker	2023-07-06 17:18:11.135	info	instance system.adapter.zigbee.0 started with pid 9637
      zigbee.0	2023-07-06 17:18:13.742	info	starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24
      zigbee.0	2023-07-06 17:18:13.839	info	delete old Backup files. keep only last 10
      zigbee.0	2023-07-06 17:18:13.841	info	Starting Zigbee npm ...
      zigbee.0	2023-07-06 17:18:14.269	info	Installed Version: iobroker.zigbee@1.8.10
      zigbee.0	2023-07-06 17:18:15.595	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}}
      zigbee.0	2023-07-06 17:18:15.608	info	Unable to disable LED, unsupported function.
      zigbee.0	2023-07-06 17:18:15.622	info	--> transmitPower : normal
      zigbee.0	2023-07-06 17:18:15.808	info	Currently no devices.
      zigbee.0	2023-07-06 17:18:15.809	info	Zigbee started
      zigbee.0	2023-07-06 17:18:15.812	error	Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms
      zigbee.0	2023-07-06 17:18:15.814	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      zigbee.0	2023-07-06 17:18:15.815	error	unhandled promise rejection: Cannot read properties of undefined (reading 'Error')
      zigbee.0	2023-07-06 17:18:15.849	error	TypeError: Cannot read properties of undefined (reading 'Error') at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30)
      zigbee.0	2023-07-06 17:18:15.849	error	Cannot read properties of undefined (reading 'Error')
      zigbee.0	2023-07-06 17:18:15.865	info	cleaned everything up...
      zigbee.0	2023-07-06 17:18:15.866	info	Zigbee: disabling joining new devices.
      zigbee.0	2023-07-06 17:18:16.365	info	terminating
      zigbee.0	2023-07-06 17:18:16.366	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      host.iobroker	2023-07-06 17:18:16.910	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      host.iobroker	2023-07-06 17:18:16.910	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'Error')
      host.iobroker	2023-07-06 17:18:16.911	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56
      host.iobroker	2023-07-06 17:18:16.911	error	Caught by controller[1]: at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1)
      host.iobroker	2023-07-06 17:18:16.911	error	Caught by controller[1]: at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1)
      host.iobroker	2023-07-06 17:18:16.911	error	Caught by controller[1]: at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32)
      host.iobroker	2023-07-06 17:18:16.911	error	Caught by controller[1]: at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30)
      host.iobroker	2023-07-06 17:18:16.911	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.iobroker	2023-07-06 17:18:16.912	info	Restart adapter system.adapter.zigbee.0 because enabled
      host.iobroker	2023-07-06 17:18:46.936	info	instance system.adapter.zigbee.0 started with pid 9652
      zigbee.0	2023-07-06 17:18:49.562	info	starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24
      zigbee.0	2023-07-06 17:18:49.657	info	delete old Backup files. keep only last 10
      zigbee.0	2023-07-06 17:18:49.659	info	Starting Zigbee npm ...
      zigbee.0	2023-07-06 17:18:50.051	info	Installed Version: iobroker.zigbee@1.8.10
      zigbee.0	2023-07-06 17:18:51.367	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}}
      zigbee.0	2023-07-06 17:18:51.375	info	Unable to disable LED, unsupported function.
      zigbee.0	2023-07-06 17:18:51.390	info	--> transmitPower : normal
      zigbee.0	2023-07-06 17:18:51.397	info	Currently no devices.
      zigbee.0	2023-07-06 17:18:51.398	info	Zigbee started
      zigbee.0	2023-07-06 17:18:51.400	error	Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms
      zigbee.0	2023-07-06 17:18:51.401	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      zigbee.0	2023-07-06 17:18:51.402	error	unhandled promise rejection: Cannot read properties of undefined (reading 'Error')
      zigbee.0	2023-07-06 17:18:51.430	error	TypeError: Cannot read properties of undefined (reading 'Error') at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30)
      zigbee.0	2023-07-06 17:18:51.431	error	Cannot read properties of undefined (reading 'Error')
      zigbee.0	2023-07-06 17:18:51.443	info	cleaned everything up...
      zigbee.0	2023-07-06 17:18:51.444	info	Zigbee: disabling joining new devices.
      zigbee.0	2023-07-06 17:18:51.945	info	terminating
      zigbee.0	2023-07-06 17:18:51.946	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      host.iobroker	2023-07-06 17:18:52.488	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      host.iobroker	2023-07-06 17:18:52.488	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'Error')
      host.iobroker	2023-07-06 17:18:52.488	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56
      host.iobroker	2023-07-06 17:18:52.489	error	Caught by controller[1]: at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1)
      host.iobroker	2023-07-06 17:18:52.489	error	Caught by controller[1]: at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1)
      host.iobroker	2023-07-06 17:18:52.489	error	Caught by controller[1]: at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32)
      host.iobroker	2023-07-06 17:18:52.489	error	Caught by controller[1]: at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30)
      host.iobroker	2023-07-06 17:18:52.489	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.iobroker	2023-07-06 17:18:52.490	info	Restart adapter system.adapter.zigbee.0 because enabled
      host.iobroker	2023-07-06 17:18:52.490	warn	Do not restart adapter system.adapter.zigbee.0 because restart loop detected
      Schönen Gruß
      Thomas
      • crunchip
        crunchip Forum Testing Most Active @Meister Mopper last edited by
        @meister-mopper was zeigt dein Stick unter current Status?
        was mir noch auffällt, dein Stick hat die 192.168.178.6, deine Remote Server Adresse ist 192.168.0.201
        bei mir hat der Stick die 10.1.20.7 und der Remote ist eins höher, sprich 10.1.20.8
        • Meister Mopper
          Meister Mopper @crunchip last edited by
          @crunchip
          An der Remote Server Adresse kann ich nichts ändern, weil ich das Ding ja als tcp-server eingestellt habe. Daran sollte es aus meiner Sicht nicht liegen.
          • crunchip
            crunchip Forum Testing Most Active @Meister Mopper last edited by crunchip
            @meister-mopper sagte in Zigbee Problem - Coordinator per Ethernet:
            mich wunder nur das es ein anderer Adressbereich ist. Aber bei dir sieht es so aus, als wenn nicht gesendet/empfangen wird, somit logisch das dein zigbee nicht funktioniert
            hast du es mal mit 5V probiert?
            ich selbst hab ein anderes Model, ein USR-TCP232-T2
            • Meister Mopper
              @crunchip sagte in Zigbee Problem - Coordinator per Ethernet:
              Da habe ich eher die Befürchtung, das Ding zu bruzzeln.
              Ich blicke so langsam bei den Modulen nicht mehr durch. Ich dachte, das USR-TCP232-T2 TTL ist baugleich zum USR-TCP232-T2.
              Wenn ich mir die Bilder im Netz anschaue, zweifle ich. Auf meinem steht die Bezeichnung nicht aufgedruckt, lediglich ein Aufkleber "QC-PASS 34" (vmtl. Quality check).
              Es ist dieses,
              Hast Du vielleicht einen Link für Dein Modul, dann würde ich es nochmal mit dem versuchen.
              • crunchip
                https://www.amazon.de/gp/product/B01GPMFXB2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
                vllt findest du da Info`s
                https://forum.iobroker.net/post/647127
                  arteck Developer Most Active @Meister Mopper last edited by arteck
                  @meister-mopper installier mal die 1.8.13 von GIT..und schau nochmal
                  und mach Sentry aus bitte..
                  drauf klicken.. sollte dann grau werden
                  dann..
                  welche IP rufst du auf um auf das Interface zu kommen ??
                  crunchip Meister Mopper 2 Replies Last reply Reply Quote 1
                  • crunchip
                    crunchip Forum Testing Most Active @arteck last edited by
                    @arteck aber bei ihm kommen ja gar keine Daten, siehe https://forum.iobroker.net/post/1013377
                    müssten da nicht bei Count schon paar bytes zu sehen sein, ohne zigbee Instanz?
                    • Meister Mopper
                      Meister Mopper @arteck last edited by Meister Mopper
                      @arteck
                      v1.8.13
                      Läääääääääuuuuuuuuft!!!
                      host.iobroker	2023-07-07 11:33:35.878	info	"system.adapter.zigbee.0" enabled
                      host.iobroker	2023-07-07 11:33:35.908	info	instance system.adapter.zigbee.0 started with pid 10418
                      zigbee.0	2023-07-07 11:33:38.449	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                      zigbee.0	2023-07-07 11:33:38.480	debug	Objects client ready ... initialize now
                      zigbee.0	2023-07-07 11:33:38.482	debug	Objects create System PubSub Client
                      zigbee.0	2023-07-07 11:33:38.483	debug	Objects create User PubSub Client
                      zigbee.0	2023-07-07 11:33:38.496	debug	Objects client initialize lua scripts
                      zigbee.0	2023-07-07 11:33:38.502	debug	Objects connected to redis: 127.0.0.1:9001
                      zigbee.0	2023-07-07 11:33:38.518	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                      zigbee.0	2023-07-07 11:33:38.525	debug	States create System PubSub Client
                      zigbee.0	2023-07-07 11:33:38.526	debug	States create User PubSub Client
                      zigbee.0	2023-07-07 11:33:38.536	debug	States connected to redis: 127.0.0.1:9000
                      zigbee.0	2023-07-07 11:33:38.561	debug	Plugin sentry Do not initialize Plugin (enabled=false)
                      zigbee.0	2023-07-07 11:33:38.568	debug	Plugin sentry destroyed because not initialized correctly
                      zigbee.0	2023-07-07 11:33:38.721	info	starting. Version 1.8.13 (non-npm: ioBroker/ioBroker.zigbee#0bf06ed15a6da66f653c04bacda2231b51b2e310) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24
                      zigbee.0	2023-07-07 11:33:38.759	debug	Using zigbee-herdsman with settings: {"network":{"panID":6754,"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"extenedPanID":[221,221,221,221,221,221,221,221]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"tcp://192.168.178.6:20108","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}}
                      zigbee.0	2023-07-07 11:33:38.816	info	delete old Backup files. keep only last 10
                      zigbee.0	2023-07-07 11:33:38.818	info	Starting Zigbee npm ...
                      zigbee.0	2023-07-07 11:33:38.819	debug	Starting zigbee-herdsman...
                      zigbee.0	2023-07-07 11:33:39.334	info	Installed Version: ioBroker/ioBroker.zigbee#0bf06ed15a6da66f653c04bacda2231b51b2e310
                      zigbee.0	2023-07-07 11:33:39.340	debug	Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2023_07_07-11_33_38.tar.gz success
                      zigbee.0	2023-07-07 11:33:43.912	debug	zigbee-herdsman started
                      zigbee.0	2023-07-07 11:33:43.913	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}}
                      zigbee.0	2023-07-07 11:33:43.920	debug	Zigbee network parameters: panID=6754 channel=11 extendedPanID=4966e526004b1200
                      zigbee.0	2023-07-07 11:33:43.921	info	Unable to disable LED, unsupported function.
                      zigbee.0	2023-07-07 11:33:43.922	info	--> transmitPower : normal
                      zigbee.0	2023-07-07 11:33:43.928	info	Currently no devices.
                      zigbee.0	2023-07-07 11:33:43.929	info	Zigbee started
                      zigbee.0	2023-07-07 11:33:43.929	debug	Config value 0xdddddddddddddddd : Network value 0x00124b0026e56649
                      zigbee.0	2023-07-07 11:33:43.932	error	Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms
                      zigbee.0	2023-07-07 11:33:43.932	debug	Fix without changes. And restart adapter.
                      zigbee.0	2023-07-07 11:33:43.937	debug	getGroups result: {}
                      host.iobroker	2023-07-07 11:33:43.997	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
                      zigbee.0	2023-07-07 11:33:44.002	info	Got terminate signal TERMINATE_YOURSELF
                      zigbee.0	2023-07-07 11:33:44.003	info	cleaned everything up...
                      zigbee.0	2023-07-07 11:33:44.005	info	Zigbee: disabling joining new devices.
                      zigbee.0	2023-07-07 11:33:44.020	info	debug devices set to []
                      host.iobroker	2023-07-07 11:33:44.041	info	stopInstance system.adapter.zigbee.0 send kill signal
                      zigbee.0	2023-07-07 11:33:44.504	info	terminating
                      zigbee.0	2023-07-07 11:33:44.505	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      host.iobroker	2023-07-07 11:33:45.042	info	stopInstance system.adapter.zigbee.0 killing pid 10418
                      host.iobroker	2023-07-07 11:33:45.060	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      host.iobroker	2023-07-07 11:33:47.066	info	instance system.adapter.zigbee.0 started with pid 10433
                      zigbee.0	2023-07-07 11:33:49.574	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                      zigbee.0	2023-07-07 11:33:49.609	debug	Objects client ready ... initialize now
                      zigbee.0	2023-07-07 11:33:49.611	debug	Objects create System PubSub Client
                      zigbee.0	2023-07-07 11:33:49.612	debug	Objects create User PubSub Client
                      zigbee.0	2023-07-07 11:33:49.625	debug	Objects client initialize lua scripts
                      zigbee.0	2023-07-07 11:33:49.631	debug	Objects connected to redis: 127.0.0.1:9001
                      zigbee.0	2023-07-07 11:33:49.646	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                      zigbee.0	2023-07-07 11:33:49.651	debug	States create System PubSub Client
                      zigbee.0	2023-07-07 11:33:49.652	debug	States create User PubSub Client
                      zigbee.0	2023-07-07 11:33:49.660	debug	States connected to redis: 127.0.0.1:9000
                      zigbee.0	2023-07-07 11:33:49.689	debug	Plugin sentry Do not initialize Plugin (enabled=false)
                      zigbee.0	2023-07-07 11:33:49.738	debug	Plugin sentry destroyed because not initialized correctly
                      zigbee.0	2023-07-07 11:33:49.887	info	starting. Version 1.8.13 (non-npm: ioBroker/ioBroker.zigbee#0bf06ed15a6da66f653c04bacda2231b51b2e310) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24
                      zigbee.0	2023-07-07 11:33:49.929	debug	Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"tcp://192.168.178.6:20108","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}}
                      zigbee.0	2023-07-07 11:33:49.986	info	delete old Backup files. keep only last 10
                      zigbee.0	2023-07-07 11:33:49.988	info	Starting Zigbee npm ...
                      zigbee.0	2023-07-07 11:33:49.989	debug	Starting zigbee-herdsman...
                      zigbee.0	2023-07-07 11:33:50.475	info	Installed Version: ioBroker/ioBroker.zigbee#0bf06ed15a6da66f653c04bacda2231b51b2e310
                      zigbee.0	2023-07-07 11:33:50.484	debug	Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2023_07_07-11_33_49.tar.gz success
                      zigbee.0	2023-07-07 11:33:51.797	debug	zigbee-herdsman started
                      zigbee.0	2023-07-07 11:33:51.798	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}}
                      zigbee.0	2023-07-07 11:33:51.805	debug	Zigbee network parameters: panID=6754 channel=11 extendedPanID=4966e526004b1200
                      zigbee.0	2023-07-07 11:33:51.806	info	Unable to disable LED, unsupported function.
                      zigbee.0	2023-07-07 11:33:51.806	info	--> transmitPower : normal
                      zigbee.0	2023-07-07 11:33:51.818	info	Currently no devices.
                      zigbee.0	2023-07-07 11:33:51.819	info	Zigbee started
                      zigbee.0	2023-07-07 11:33:51.823	debug	getGroups result: {}
                      zigbee.0	2023-07-07 11:33:51.872	info	debug devices set to []
                      zigbee.0	2023-07-07 11:34:25.820	debug	getGroups result: {}
                      zigbee.0	2023-07-07 11:34:25.838	debug	LQI succeeded for 'Coordinator'
                      zigbee.0	2023-07-07 11:34:25.849	debug	Routing for 'Coordinator': {"table":[]}
                      zigbee.0	2023-07-07 11:34:25.849	debug	Routing table succeeded for 'Coordinator'
                      zigbee.0	2023-07-07 11:34:25.850	debug	Get map succeeded []
                      zigbee.0	2023-07-07 11:34:25.850	debug	getMap result: {"lqis":[],"routing":[]}
                      zigbee.0	2023-07-07 11:34:25.870	debug	getCoordinatorInfo result: {"installSource":"ioBroker/ioBroker.zigbee#0bf06ed15a6da66f653c04bacda2231b51b2e310","channel":"11","port":"tcp://192.168.178.6:20108","type":"zStack3x0","revision":20230507,"version":"2-1.2.7.1."}
                      zigbee.0	2023-07-07 11:34:25.980	debug	getDevices result: [{"_id":"0x00124b0026e56649","icon":"img/unknown.png","paired":true,"info":{"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00124b0026e56649","_networkAddress":0,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"profileID":257,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":4,"profileID":263,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":5,"profileID":264,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":6,"profileID":265,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":8,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":10,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":11,"profileID":260,"deviceID":1024,"inputClusters":[1281,10],"outputClusters":[1280,1282],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":12,"profileID":49246,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":13,"profileID":260,"deviceID":5,"inputClusters":[25],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":47,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":110,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false}],"_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":null,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0},"mapped":null,"endpoint":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},"endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"profileID":257,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":4,"profileID":263,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":5,"profileID":264,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":6,"profileID":265,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":8,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":10,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":11,"profileID":260,"deviceID":1024,"inputClusters":[1281,10],"outputClusters":[1280,1282],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":12,"profileID":49246,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":13,"profileID":260,"deviceID":5,"inputClusters":[25],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":47,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":110,"profileID":260,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":5,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00124b0026e56649","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{},"sendInProgress":false}],"name":"0x00124b0026e56649"},"common":{},"native":{}}]
                      zigbee.0	2023-07-07 11:34:26.061	info	List of port: [{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"}]
                      zigbee.0	2023-07-07 11:34:26.163	debug	getExclude result: []
                      2023-07-07 11:34:26.166	debug	getBinding result: []
                      Bisschen Daten sind auch geflossen:
                      Vielen Dank @arteck
                      Edit:
                      Ach ja, auch an @haus-automatisierung für die Inspiration!
                      1.0k
                      tcp zigbee cc26x2r1
