    4. IOB startet nach Adapter-Update nicht mehr
      dragricola last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: RasPi4.
      Arbeitsspeicher: 3,7 GB
      Festplattenart: SSD M.2 über USB angeschlossen
      Betriebssystem: Raspberry Pi OS Bullseye 64 Bit
      Node-Version: 10.x.x
      Nodejs-Version: v16.18.1
      NPM-Version: 8.19.2
      Installationsart: Skript
      Image genutzt: Nein
      Beim Versuch einen Adapter zu aktualisieren ist das System abgestürzt und lässt sich nicht mehr starten. iob staus liefert folgendes:
      pi@raspberrypi4-iob:~ $ iob status
      node:internal/modules/cjs/loader:1024
        throw err;
      Error: Cannot find module './internal/re'
      Require stack:
      - /opt/iobroker/node_modules/semver/index.js
      - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
      - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
      - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
      - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1021:15)
          at Function.Module._load (node:internal/modules/cjs/loader:866:27)
          at Module.require (node:internal/modules/cjs/loader:1093:19)
          at require (node:internal/modules/cjs/helpers:108:18)
          at Object.<anonymous> (/opt/iobroker/node_modules/semver/index.js:2:20)
          at Module._compile (node:internal/modules/cjs/loader:1191:14)
          at Object.Module._extensions..js (node:internal/modules/cjs/loader:1245:10)
          at Module.load (node:internal/modules/cjs/loader:1069:32)
          at Function.Module._load (node:internal/modules/cjs/loader:904:12)
          at Module.require (node:internal/modules/cjs/loader:1093:19) {
        code: 'MODULE_NOT_FOUND',
        requireStack: [
          '/opt/iobroker/node_modules/semver/index.js',
          '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
          '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
          '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
          '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
      Wer kann mir helfen ioBroker wieder zum Laufen zu bringen?
        Thomas Braun Most Active @dragricola last edited by
        @dragricola
        Versuch mal
        cd /opt/iobroker && sudo -H -u iobroker npm install iobroker.js-controller
        iob restart
          dragricola @Thomas Braun last edited by
          @thomas-braun said in IOB startet nach Adapter-Update nicht mehr:
          Das liefert folgendes:
          pi@raspberrypi4-iob:~ $ cd /opt/iobroker && sudo -H -u iobroker npm install iobroker.js-controller
          npm ERR! code ENOTEMPTY
          npm ERR! syscall rename
          npm ERR! path /opt/iobroker/node_modules/fast-glob
          npm ERR! dest /opt/iobroker/node_modules/.fast-glob-suIaIPfF
          npm ERR! errno -39
          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/fast-glob' -> '/opt/iobroker/node_modules/.fast-glob-suIaIPfF'
          npm ERR!     /home/iobroker/.npm/_logs/2023-07-07T17_47_22_038Z-debug-0.log
          pi@raspberrypi4-iob:/opt/iobroker $
          Danach startet iob leider nicht.
            @dragricola
            Dann den Fixer versuchen.
            iob stop
            iob fix
            iob restart
              iob restart
              Es tut sich was! IOB startet gerade wieder. Vielen Dank für die schnelle Hilfe!
                @dragricola
                Dann kannst du jetzt mal
                iob diag
                anschauen.
                  iob diag
                  Bis auf den folgenden Abschnitt "OS-Repositories and Updates" schein alles in Ordnung zu sein:
                  W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                  W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                  W: Failed to fetch https://repos.influxdata.com/debian/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                  W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                  W: Some index files failed to download. They have been ignored, or old ones used instead.
                  Hit:1 http://deb.debian.org/debian bullseye InRelease
                  Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                  Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                  Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:5 https://cli.github.com/packages stable InRelease
                  Get:6 https://repos.influxdata.com/debian stable InRelease [6892 B]
                  Get:7 https://repos.influxdata.com/debian bullseye InRelease [7040 B]
                  Hit:8 https://deb.nodesource.com/node_16.x bullseye InRelease
                  Err:6 https://repos.influxdata.com/debian stable InRelease
                  Err:7 https://repos.influxdata.com/debian bullseye InRelease
                  Fetched 13.9 kB in 2s (5843 B/s)
                  Reading package lists...
                  Pending Updates: 108
                  Das bezieht sich wohl alles auf Influx. Die Datenbank hatte ich früher mal installiert, nun verwende ich sie jedoch nicht mehr. Wie werde ich diese Fehlermeldungen wieder los?
                    @dragricola
                    Vollständig bitte.
                      Hier ist der vollständige Auszug:
                      Skript v.2023-04-16
                      *** BASE SYSTEM ***
                      Model           : Raspberry Pi 4 Model B Rev 1.1
                      Architecture    : aarch64
                      Docker          : false
                      Virtualization  : none
                      Distributor ID: Debian
                      Description:    Debian GNU/Linux 11 (bullseye)
                      Release:        11
                      Codename:       bullseye
                      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                      NAME="Debian GNU/Linux"
                      VERSION_ID="11"
                      VERSION="11 (bullseye)"
                      VERSION_CODENAME=bullseye
                      ID=debian
                      HOME_URL="https://www.debian.org/"
                      SUPPORT_URL="https://www.debian.org/support"
                      BUG_REPORT_URL="https://bugs.debian.org/"
                      Systemuptime and Load:
                       20:13:19 up  1:13,  1 user,  load average: 1.75, 1.64, 1.33
                      CPU threads: 4
                      Raspberry only:
                      throttled=0x0
                      Other values than 0x0 hint to temperature/voltage problems
                      temp=47.7'C
                      volt=0.8438V
                      *** Time and Time Zones ***
                                     Local time: Fri 2023-07-07 20:13:19 CEST
                                 Universal time: Fri 2023-07-07 18:13:19 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      *** User and Groups ***
                      pi
                      /home/pi
                      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                      *** X-Server-Setup ***
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            3.8G        2.4G         85M        4.0M        1.3G        1.3G
                      Swap:            99M        3.0M         96M
                      Total:          3.9G        2.4G        182M
                               3793 M total memory
                               2428 M used memory
                                677 M active memory
                               2776 M inactive memory
                                 85 M free memory
                                134 M buffer memory
                               1144 M swap cache
                                 99 M total swap
                                  3 M used swap
                                 96 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /dev/root      ext4      118G   12G  101G  11% /
                      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                      tmpfs          tmpfs     1.9G  752K  1.9G   1% /dev/shm
                      tmpfs          tmpfs     759M  1.2M  758M   1% /run
                      /dev/sda1      vfat      255M   31M  225M  12% /boot
                      tmpfs          tmpfs     380M     0  380M   0% /run/user/999
                      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                      [Fri Jul  7 18:59:30 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:32:93:63 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=a1185881-02 rootfstype=ext4 fsck.repair=yes rootwait fsck.mode=force
                      [Fri Jul  7 18:59:31 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Fri Jul  7 18:59:31 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                      [Fri Jul  7 18:59:47 2023] EXT4-fs (sda2): re-mounted. Opts: (null). Quota mode: none.
                      Show mounted filesystems (real ones only):
                      TARGET  SOURCE    FSTYPE OPTIONS
                      /       /dev/sda2 ext4   rw,noatime
                      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                      /var:
                      6.0G    /var/
                      4.5G    /var/lib
                      2.3G    /var/lib/mysql
                      2.1G    /var/lib/mysql/iobroker
                      1.9G    /var/lib/redis
                      Archived and active journals take up 992.3M in the file system.
                      /opt/iobroker/backups:
                      333M    /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      506M    /opt/iobroker/iobroker-data/
                      342M    /opt/iobroker/iobroker-data/files
                      116M    /opt/iobroker/iobroker-data/backup-objects
                      55M     /opt/iobroker/iobroker-data/files/material
                      53M     /opt/iobroker/iobroker-data/files/material/static
                      41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
                      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                      32M     /opt/iobroker/iobroker-data/objects.jsonl
                      18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
                      15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v16.19.1
                      /usr/bin/node           v16.19.1
                      /usr/bin/npm            8.19.3
                      /usr/bin/npx            8.19.3
                      nodejs:
                        Installed: 16.19.1-deb-1nodesource1
                        Candidate: 16.20.1-deb-1nodesource1
                        Version table:
                           16.20.1-deb-1nodesource1 500
                              500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                       *** 16.19.1-deb-1nodesource1 100
                              100 /var/lib/dpkg/status
                           12.22.12~dfsg-1~deb11u4 500
                              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                           12.22.12~dfsg-1~deb11u3 500
                              500 http://deb.debian.org/debian bullseye/main arm64 Packages
                      No problems detected
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      MULTIHOSTSERVICE/enabled: false
                      Core adapters versions
                      js-controller:  4.0.24
                      admin:          6.3.5
                      javascript:     7.0.3
                      Adapters from github:   2
                      Adapter State
                      + system.adapter.admin.0                  : admin                 : raspberrypi4-iob                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        system.adapter.alias-manager.0          : alias-manager         : raspberrypi4-iob                         -  enabled
                      + system.adapter.alpha2.0                 : alpha2                : raspberrypi4-iob                         -  enabled
                      + system.adapter.backitup.0               : backitup              : raspberrypi4-iob                         -  enabled
                        system.adapter.coronavirus-statistics.0 : coronavirus-statistics: raspberrypi4-iob                         - disabled
                        system.adapter.daswetter.0              : daswetter             : raspberrypi4-iob                         -  enabled
                        system.adapter.denon.0                  : denon                 : raspberrypi4-iob                         - disabled
                        system.adapter.devices.0                : devices               : raspberrypi4-iob                         -  enabled
                        system.adapter.discovery.0              : discovery             : raspberrypi4-iob                         - disabled
                        system.adapter.dwd.0                    : dwd                   : raspberrypi4-iob                         -  enabled
                      + system.adapter.energiefluss.0           : energiefluss          : raspberrypi4-iob                         -  enabled
                        system.adapter.feiertage.0              : feiertage             : raspberrypi4-iob                         -  enabled
                        system.adapter.flot.0                   : flot                  : raspberrypi4-iob                         -  enabled
                      + system.adapter.fritzdect.0              : fritzdect             : raspberrypi4-iob                         -  enabled
                      + system.adapter.homeconnect.0            : homeconnect           : raspberrypi4-iob                         -  enabled
                        system.adapter.ical.0                   : ical                  : raspberrypi4-iob                         -  enabled
                        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi4-iob                         -  enabled
                      + system.adapter.info.0                   : info                  : raspberrypi4-iob                         -  enabled
                      + system.adapter.javascript.0             : javascript            : raspberrypi4-iob                         -  enabled
                        system.adapter.javascript.1             : javascript            : raspberrypi4-iob                         - disabled
                        system.adapter.luftdaten.0              : luftdaten             : raspberrypi4-iob                         -  enabled
                        system.adapter.material.0               : material              : raspberrypi4-iob                         -  enabled
                      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi4-iob                         -  enabled, port: 1884, bind: 0.0.0.0
                      + system.adapter.net-tools.0              : net-tools             : raspberrypi4-iob                         -  enabled
                      + system.adapter.nuki-extended.0          : nuki-extended         : raspberrypi4-iob                         -  enabled
                      + system.adapter.octoprint.0              : octoprint             : raspberrypi4-iob                         -  enabled
                        system.adapter.panasonic-viera.0        : panasonic-viera       : raspberrypi4-iob                         - disabled
                        system.adapter.panasonic-viera.1        : panasonic-viera       : raspberrypi4-iob                         - disabled
                      + system.adapter.pi-hole.0                : pi-hole               : raspberrypi4-iob                         -  enabled
                      + system.adapter.ping.0                   : ping                  : raspberrypi4-iob                         -  enabled
                        system.adapter.pushover.0               : pushover              : raspberrypi4-iob                         - disabled
                        system.adapter.rpi2.0                   : rpi2                  : raspberrypi4-iob                         - disabled
                      + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi4-iob                         -  enabled
                      + system.adapter.simple-api.0             : simple-api            : raspberrypi4-iob                         -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                        system.adapter.socketio.0               : socketio              : raspberrypi4-iob                         - disabled, port: 8085, bind: 0.0.0.0, run as: admin
                      + system.adapter.sonoff.0                 : sonoff                : raspberrypi4-iob                         -  enabled, port: 1883, bind: 0.0.0.0
                        system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi4-iob                         - disabled
                      + system.adapter.sql.0                    : sql                   : raspberrypi4-iob                         -  enabled, port: 3306
                        system.adapter.synology.0               : synology              : raspberrypi4-iob                         - disabled, port: 5000
                      + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi4-iob                         -  enabled
                      + system.adapter.telegram.0               : telegram              : raspberrypi4-iob                         -  enabled, port: 8443, bind: 0.0.0.0
                      + system.adapter.text2command.0           : text2command          : raspberrypi4-iob                         -  enabled
                      + system.adapter.tr-064.0                 : tr-064                : raspberrypi4-iob                         -  enabled
                        system.adapter.tr-064.1                 : tr-064                : raspberrypi4-iob                         - disabled
                        system.adapter.tr-064.2                 : tr-064                : raspberrypi4-iob                         - disabled
                      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi4-iob                         -  enabled
                        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi4-iob                         -  enabled
                        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi4-iob                         -  enabled
                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi4-iob                         -  enabled
                        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi4-iob                         -  enabled
                        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi4-iob                         -  enabled
                        system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi4-iob                         -  enabled
                        system.adapter.vis-metro.0              : vis-metro             : raspberrypi4-iob                         -  enabled
                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi4-iob                         -  enabled
                        system.adapter.vis-weather.0            : vis-weather           : raspberrypi4-iob                         -  enabled
                        system.adapter.vis.0                    : vis                   : raspberrypi4-iob                         -  enabled
                        system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi4-iob                         -  enabled
                      + system.adapter.web.0                    : web                   : raspberrypi4-iob                         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + system.adapter.web.1                    : web                   : raspberrypi4-iob                         -  enabled, port: 20002, bind: 0.0.0.0, run as: admin
                      + system.adapter.ws.0                     : ws                    : raspberrypi4-iob                         -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                      + system.adapter.zigbee.0                 : zigbee                : raspberrypi4-iob                         -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                      + instance is alive
                      ioBroker-Repositories
                      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                      Active repo(s): stable
                      Installed ioBroker-Instances
                      Used repository: stable
                      Adapter    "admin"        : 6.3.5    , installed 6.3.5
                      Adapter    "alias-manager": 1.2.4    , installed 1.2.4
                      Adapter    "alpha2"       : 1.0.0    , installed 1.0.4
                      Adapter    "backitup"     : 2.6.23   , installed 2.6.23
                      Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                      Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
                      Adapter    "denon"        : 1.15.2   , installed 1.15.0 [Updatable]
                      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                      Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                      Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                      Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
                      Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
                      Adapter    "info"         : 1.9.26   , installed 1.9.26
                      Adapter    "javascript"   : 7.0.3    , installed 7.0.3
                      Controller "js-controller": 4.0.24   , installed 4.0.24
                      Adapter    "luftdaten"    : 2.2.4    , installed 2.2.4
                      Adapter    "material"     : 1.3.1    , installed 1.3.1
                      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                      Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
                      Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
                      Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
                      Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
                      Adapter    "ping"         : 1.5.3    , installed 1.5.3
                      Adapter    "pushover"     : 3.0.3    , installed 3.0.3
                      Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
                      Adapter    "shuttercontrol": 1.5.0   , installed 1.5.0
                      Adapter    "socketio"     : 4.2.0    , installed 4.2.0
                      Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
                      Adapter    "sql"          : 2.2.0    , installed 2.2.0
                      Adapter    "synology"     : 2.1.13   , installed 2.1.13
                      Adapter    "telegram"     : 1.15.6   , installed 1.15.6
                      Adapter    "text2command" : 3.0.2    , installed 3.0.2
                      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                      Adapter    "vis"          : 1.4.16   , installed 1.4.16
                      Adapter    "vis-icontwo"  : 0.96.0   , installed 0.94.0 [Updatable]
                      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                      Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                      Adapter    "web"          : 4.3.0    , installed 4.3.0
                      Adapter    "ws"           : 1.3.0    , installed 1.3.0
                      Adapter    "zigbee"       : 1.8.12   , installed 1.8.12
                      Objects and States
                      Objects:        17507
                      States:         14866
                      *** Listening Ports ***
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       88332      14458/iobroker.js-c
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       89214      14458/iobroker.js-c
                      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          14106      872/lighttpd
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14504      570/sshd: /usr/sbin
                      tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        14164      910/pihole-FTL
                      tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        14662      910/pihole-FTL
                      tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          13119      414/python2
                      tcp        0      0 127.0.0.1:7999          0.0.0.0:*               LISTEN      0          14562      711/motion
                      tcp        0      0 0.0.0.0:1080            0.0.0.0:*               LISTEN      1000       151901     26854/nc
                      tcp        0      0 0.0.0.0:8089            0.0.0.0:*               LISTEN      0          14561      711/motion
                      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       89867      14735/io.mqtt.0
                      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       89868      14735/io.mqtt.0
                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       89693      14769/io.sonoff.0
                      tcp6       0      0 :::80                   :::*                    LISTEN      0          14107      872/lighttpd
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          11932      570/sshd: /usr/sbin
                      tcp6       0      0 :::53                   :::*                    LISTEN      999        14166      910/pihole-FTL
                      tcp6       0      0 :::3306                 :::*                    LISTEN      111        13756      636/mariadbd
                      tcp6       0      0 :::20002                :::*                    LISTEN      1001       96535      15501/io.web.1
                      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       96552      15518/io.ws.0
                      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       97786      15426/io.simple-api
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       86656      14614/io.admin.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       98376      15477/io.web.0
                      tcp6       0      0 ::1:4711                :::*                    LISTEN      999        14663      910/pihole-FTL
                      udp        0      0 192.168.178.126:5353    0.0.0.0:*                           1001       90039      14825/io.tr-064.0
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11639      396/avahi-daemon: r
                      udp        0      0 0.0.0.0:55204           0.0.0.0:*                           108        11641      396/avahi-daemon: r
                      udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        14163      910/pihole-FTL
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12000      840/dhcpcd
                      udp6       0      0 :::546                  :::*                                0          12013      840/dhcpcd
                      udp6       0      0 :::54157                :::*                                108        11642      396/avahi-daemon: r
                      udp6       0      0 :::5353                 :::*                                108        11640      396/avahi-daemon: r
                      udp6       0      0 :::53                   :::*                                999        14165      910/pihole-FTL
                      2023-07-07 20:13:14.829  - info: weatherunderground.0 (24042) State value to set for "weatherunderground.0.forecastHourly.29h.precipitation" has to be type "value.precipitation" but received type "number"
                      2023-07-07 20:13:14.942  - info: weatherunderground.0 (24042) State value to set for "weatherunderground.0.forecastHourly.30h.precipitation" has to be type "value.precipitation" but received type "number"
                      2023-07-07 20:13:15.090  - info: weatherunderground.0 (24042) State value to set for "weatherunderground.0.forecastHourly.31h.precipitation" has to be type "value.precipitation" but received type "number"
                      2023-07-07 20:13:15.213  - info: weatherunderground.0 (24042) State value to set for "weatherunderground.0.forecastHourly.32h.precipitation" has to be type "value.precipitation" but received type "number"
                      2023-07-07 20:13:15.325  - info: weatherunderground.0 (24042) State value to set for "weatherunderground.0.forecastHourly.33h.precipitation" has to be type "value.precipitation" but received type "number"
                      2023-07-07 20:13:15.433  - info: weatherunderground.0 (24042) State value to set for "weatherunderground.0.forecastHourly.34h.precipitation" has to be type "value.precipitation" but received type "number"
                      2023-07-07 20:13:15.542  - info: weatherunderground.0 (24042) State value to set for "weatherunderground.0.forecastHourly.35h.precipitation" has to be type "value.precipitation" but received type "number"
                      2023-07-07 20:13:16.025  - info: javascript.0 (14656) script.js.common.Energie.Badheizung_PI-Regler_OK: Automaticmode: Reglerinput:  -0.072, Output: 74.69296708860759, Eingeschaltet:  true, Temperatur:  22.19
                      2023-07-07 20:13:17.900  - info: weatherunderground.0 (24042) Terminated (NO_ERROR): Without reason
                      2023-07-07 20:13:18.435  - info: host.raspberrypi4-iob instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
                      2023-07-07 20:13:26.088  - info: javascript.0 (14656) script.js.common.Energie.Badheizung_PI-Regler_OK: Automaticmode: Reglerinput:  -0.073, Output: 72.82246329113924, Eingeschaltet:  true, Temperatur:  22.19
                      2023-07-07 20:13:35.996  - info: javascript.0 (14656) script.js.common.Energie.Badheizung_PI-Regler_OK: Automaticmode: Reglerinput:  -0.028, Output: 73.01828101265822, Eingeschaltet:  true, Temperatur:  22.19
                      2023-07-07 20:13:40.636  - info: javascript.0 (14656) script.js.common.Sicherheit.Bewegungserkennung: 20:13:40.635 empfangen: 680
                      2023-07-07 20:13:46.138  - info: javascript.0 (14656) script.js.common.Energie.Badheizung_PI-Regler_OK: Automaticmode: Reglerinput:  0.019, Output: 74.44742278481012, Eingeschaltet:  true, Temperatur:  22.19
                      2023-07-07 20:13:56.026  - info: javascript.0 (14656) script.js.common.Energie.Badheizung_PI-Regler_OK: Automaticmode: Reglerinput:  -0.071, Output: 70.87619746835442, Eingeschaltet:  true, Temperatur:  22.19
                      2023-07-07 20:14:00.203  - info: host.raspberrypi4-iob instance system.adapter.luftdaten.0 started with pid 25159
                      2023-07-07 20:14:05.233  - info: luftdaten.0 (25159) starting. Version 2.2.4 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v16.19.1, js-controller: 4.0.24
                      2023-07-07 20:14:06.078  - info: luftdaten.0 (25159) Terminated (NO_ERROR): Without reason
                      2023-07-07 20:14:06.118  - info: javascript.0 (14656) script.js.common.Energie.Badheizung_PI-Regler_OK: Automaticmode: Reglerinput:  -0.064, Output: 69.37909367088606, Eingeschaltet:  true, Temperatur:  22.19
                      2023-07-07 20:14:07.809  - info: host.raspberrypi4-iob instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
                      2023-07-07 20:14:18.803  - info: javascript.0 (14656) script.js.common.Energie.Badheizung_PI-Regler_OK: Automaticmode: Reglerinput:  -0.032, Output: 68.99695696202531, Eingeschaltet:  true, Temperatur:  22.19
                      2023-07-07 20:14:21.858  - info: javascript.0 (14656) script.js.common.Sicherheit.Bewegungserkennung: 20:14:21.858 empfangen: ABB_Alarmanlage_aus
                      2023-07-07 20:14:25.988  - info: javascript.0 (14656) script.js.common.Energie.Badheizung_PI-Regler_OK: Automaticmode: Reglerinput:  -0.018, Output: 68.94539240506329, Eingeschaltet:  true, Temperatur:  22.19
                      2023-07-07 20:14:36.084  - info: javascript.0 (14656) script.js.common.Energie.Badheizung_PI-Regler_OK: Automaticmode: Reglerinput:  -0.071, Output: 66.07803797468354, Eingeschaltet:  true, Temperatur:  22.19
                      2023-07-07 20:14:46.139  - info: javascript.0 (14656) script.js.common.Energie.Badheizung_PI-Regler_OK: Automaticmode: Reglerinput:  -0.014, Output: 66.86034683544304, Eingeschaltet:  true, Temperatur:  22.19
                        @dragricola
                        sudo rm /etc/apt/sources.list.d/influx*
                        sudo apt-mark hold udev
                        iob stop
                        sudo apt update
                        sudo apt full-upgrade
                        sudo reboot
                        fehler beim start startet nicht update absturz update von instanzen
                        478
