    2. Русский
    3. ioBroker
    4. ioBroker установка и конфигурация
    5. Ошибки hqwidgets и metro
    • V
      vonStaller last edited by
      Следующея проблема не работают hqwidgets и metro хотя все отальные widget's работают
      ! ![](</s><URL url=)https://image.ibb.co/f0ephk/hqwidget.png" /> ~~ioBroker стоит на raspberry pi
      ! system.adapter.admin.0 : admin - enabled, port: 8081, bind: 0.0.0.0, run as: admin
      ! system.adapter.history.0 : history - enabled
      ! system.adapter.hm-rega.0 : hm-rega - enabled
      ! system.adapter.hm-rpc.0 : hm-rpc - enabled, port: 0
      ! system.adapter.icons-mfd-png.0 : icons-mfd-png - enabled
      ! system.adapter.icons-mfd-svg.0 : icons-mfd-svg - enabled
      ! system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png - enabled
      ! system.adapter.javascript.0 : javascript - enabled
      ! system.adapter.mqtt-client.0 : mqtt-client - disabled, port: 1883
      ! system.adapter.mqtt.0 : mqtt - disabled, port: 1883
      ! system.adapter.parser.0 : parser - disabled
      ! system.adapter.vis-hqwidgets.0 : vis-hqwidgets - enabled
      ! system.adapter.vis.0 : vis - enabled
      ! system.adapter.weatherunderground.0 : weatherunderground - enabled
      ! system.adapter.web.0 : web - enabled, port: 8082, bind: 192.168.178.179, run as: admin
      ! system.adapter.admin : admin - 1.7.6
      ! system.adapter.hm-rpc : hm-rpc - 1.4.14
      ! system.adapter.hm-rega : hm-rega - 1.4.8
      ! system.adapter.hmm : hmm - 1.0.1
      ! system.adapter.parser : parser - 0.2.1
      ! system.adapter.history : history - 1.6.2
      ! system.adapter.mysensors : mysensors - 1.0.9
      ! system.adapter.javascript : javascript - 3.3.8
      ! system.adapter.mqtt : mqtt - 1.3.2
      ! system.adapter.mqtt-client : mqtt-client - 0.3.0
      ! system.adapter.weatherunderground : weatherunderground - 1.0.6
      ! system.adapter.web : web - 2.0.5
      ! system.adapter.vis : vis - 0.15.0
      ! system.adapter.nut : nut - 1.1.1
      ! system.adapter.vis-hqwidgets : vis-hqwidgets - 1.0.8
      ! system.adapter.icons-mfd-png : icons-mfd-png - 1.0.2
      ! system.adapter.icons-open-icon-library-png: icons-open-icon-library-png - 0.1.3
      ! system.adapter.icons-mfd-svg : icons-mfd-svg - 1.0.2
      В логах ioBroker никаких ошибок невидно.
      В какую сторону дальше копать есть идеи?
      edit: Вопрос снят
      нужно было просто через консоль прегрузить ioBroker
      sudo iobroker stop
      sudo iobroker upload all
      sudo iobroker start~~
      1.0k
