    4. Installation
    5. Zigbee Sonoff 3.0 usb dongle fehler
      armin0676 last edited by
      Hallo habe auf neu installierten raspberry pi 4 8gb iobroker installiert schon 4 mal aber, immer wieder gleiche fehler. Habe foto gemacht hoffe kann mir jemand helfen. 20230712_005552.jpg 20230712_005630.jpg 20230712_005636.jpg 20230712_005653.jpg 20230712_010037.jpg
        @armin0676
        Keine verwackelte Schnappschüsse, Text aus dem Logfile in CodeTags eingebettet hier rein.
          armin0676 @Thomas Braun last edited by Homoran
          code_text
          2023-07-12 00:07:32.848 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 1599
          2023-07-12 00:07:35.236 - info: admin.0 (1599) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.1, js-controller: 4.0.24
          2023-07-12 00:07:35.295 - info: admin.0 (1599) requesting all states
          2023-07-12 00:07:35.296 - info: admin.0 (1599) requesting all objects
          2023-07-12 00:07:35.909 - info: admin.0 (1599) received all objects
          2023-07-12 00:07:36.380 - info: admin.0 (1599) http server listening on port 8081
          2023-07-12 00:07:36.381 - info: admin.0 (1599) Use link "http://localhost:8081" to configure.
          2023-07-12 00:07:36.391 - info: admin.0 (1599) socket.io server listening on port 8081
          2023-07-12 00:07:36.463 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120
          2023-07-12 00:07:36.510 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120 admin
          2023-07-12 00:07:37.894 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120
          2023-07-12 00:07:38.010 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120
          2023-07-12 00:07:39.686 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 1626
          2023-07-12 00:07:40.146 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120
          2023-07-12 00:07:40.866 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120
          2023-07-12 00:07:40.875 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120 admin
          2023-07-12 00:07:41.736 - info: discovery.0 (1626) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.16.1, js-controller: 4.0.24
          2023-07-12 00:07:43.968 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120 admin
          2023-07-12 00:07:43.976 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 1641
          2023-07-12 00:08:02.963 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120
          2023-07-12 00:08:03.689 - info: backitup.0 (1641) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.1, js-controller: 4.0.24
          2023-07-12 00:08:02.964 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120
          2023-07-12 00:08:02.990 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120
          2023-07-12 00:08:03.045 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120 admin
          2023-07-12 00:08:03.049 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120 admin
          2023-07-12 00:08:03.050 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120 admin
          2023-07-12 00:07:47.893 - info: zigbee.0 (1136) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}}
          2023-07-12 00:08:09.665 - info: zigbee.0 (1136) Unable to disable LED, unsupported function.
          2023-07-12 00:08:09.709 - info: zigbee.0 (1136) --> transmitPower : normal
          2023-07-12 00:08:09.724 - info: zigbee.0 (1136) Currently no devices.
          2023-07-12 00:08:09.726 - info: zigbee.0 (1136) Zigbee started
          2023-07-12 00:08:09.729 - error: zigbee.0 (1136) Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms
          2023-07-12 00:08:09.732 - error: zigbee.0 (1136) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2023-07-12 00:08:09.733 - error: zigbee.0 (1136) unhandled promise rejection: Cannot read properties of undefined (reading 'Error')
          2023-07-12 00:08:09.782 - error: zigbee.0 (1136) TypeError: Cannot read properties of undefined (reading 'Error')
          at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56
          at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1)
          at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1)
          at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32)
          at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30)
          2023-07-12 00:08:09.783 - error: zigbee.0 (1136) Cannot read properties of undefined (reading 'Error')
          2023-07-12 00:08:09.794 - info: zigbee.0 (1136) cleaned everything up...
          2023-07-12 00:08:09.797 - info: zigbee.0 (1136) Zigbee: disabling joining new devices.
          2023-07-12 00:08:09.832 - info: backitup.0 (1641) [iobroker] backup will be activated at 02:40 every 1 day(s)
          2023-07-12 00:08:10.296 - info: zigbee.0 (1136) terminating
          2023-07-12 00:08:10.298 - warn: zigbee.0 (1136) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2023-07-12 00:08:10.855 - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
          2023-07-12 00:08:10.856 - error: host.raspberrypi Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'Error')
          2023-07-12 00:08:10.856 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56
          2023-07-12 00:08:10.856 - error: host.raspberrypi Caught by controller[1]: at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1)
          2023-07-12 00:08:10.857 - error: host.raspberrypi Caught by controller[1]: at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1)
          2023-07-12 00:08:10.857 - error: host.raspberrypi Caught by controller[1]: at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32)
          2023-07-12 00:08:10.858 - error: host.raspberrypi Caught by controller[1]: at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30)
          2023-07-12 00:08:10.858 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          2023-07-12 00:08:10.861 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
          2023-07-12 00:08:17.946 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120
          2023-07-12 00:08:32.643 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120
          2023-07-12 00:08:40.897 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1670
          2023-07-12 00:08:41.277 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120
          2023-07-12 00:08:45.170 - info: zigbee.0 (1670) starting. Version 1.8.12 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24
          2023-07-12 00:08:45.298 - info: zigbee.0 (1670) delete old Backup files. keep only last 10
          2023-07-12 00:08:45.300 - info: zigbee.0 (1670) Starting Zigbee npm ...
          2023-07-12 00:08:45.970 - info: zigbee.0 (1670) Installed Version: iobroker.zigbee@1.8.12
          2023-07-12 00:08:46.354 - info: zigbee.0 (1670) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}}
          2023-07-12 00:08:46.364 - info: zigbee.0 (1670) Unable to disable LED, unsupported function.
          2023-07-12 00:08:46.382 - info: zigbee.0 (1670) --> transmitPower : normal
          2023-07-12 00:08:46.392 - info: zigbee.0 (1670) Currently no devices.
          2023-07-12 00:08:46.394 - info: zigbee.0 (1670) Zigbee started
          2023-07-12 00:08:46.397 - error: zigbee.0 (1670) Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms
          2023-07-12 00:08:46.400 - error: zigbee.0 (1670) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2023-07-12 00:08:46.401 - error: zigbee.0 (1670) unhandled promise rejection: Cannot read properties of undefined (reading 'Error')
          2023-07-12 00:08:46.441 - error: zigbee.0 (1670) TypeError: Cannot read properties of undefined (reading 'Error')
          2023-07-12 00:08:46.441 - error: zigbee.0 (1670) Cannot read properties of undefined (reading 'Error')
          2023-07-12 00:08:46.450 - info: zigbee.0 (1670) cleaned everything up...
          2023-07-12 00:08:46.452 - info: zigbee.0 (1670) Zigbee: disabling joining new devices.
          2023-07-12 00:08:46.951 - info: zigbee.0 (1670) terminating
          2023-07-12 00:08:46.952 - warn: zigbee.0 (1670) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2023-07-12 00:08:47.521 - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
          2023-07-12 00:08:47.522 - error: host.raspberrypi Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'Error')
          2023-07-12 00:08:47.522 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56
          2023-07-12 00:08:47.523 - error: host.raspberrypi Caught by controller[1]: at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1)
          2023-07-12 00:08:47.523 - error: host.raspberrypi Caught by controller[1]: at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1)
          2023-07-12 00:08:47.523 - error: host.raspberrypi Caught by controller[1]: at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32)
          2023-07-12 00:08:47.523 - error: host.raspberrypi Caught by controller[1]: at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30)
          2023-07-12 00:08:47.523 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          2023-07-12 00:08:47.524 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
          2023-07-12 00:09:17.581 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1686
          2023-07-12 00:09:21.850 - info: zigbee.0 (1686) starting. Version 1.8.12 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24
          2023-07-12 00:09:21.979 - info: zigbee.0 (1686) delete old Backup files. keep only last 10
          2023-07-12 00:09:21.982 - info: zigbee.0 (1686) Starting Zigbee npm ...
          2023-07-12 00:09:22.653 - info: zigbee.0 (1686) Installed Version: iobroker.zigbee@1.8.12
          2023-07-12 00:09:23.114 - info: zigbee.0 (1686) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}}
          2023-07-12 00:09:23.123 - info: zigbee.0 (1686) Unable to disable LED, unsupported function.
          2023-07-12 00:09:23.142 - info: zigbee.0 (1686) --> transmitPower : normal
          2023-07-12 00:09:23.153 - info: zigbee.0 (1686) Currently no devices.
          2023-07-12 00:09:23.154 - info: zigbee.0 (1686) Zigbee started
          2023-07-12 00:09:23.157 - error: zigbee.0 (1686) Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms
          2023-07-12 00:09:23.160 - error: zigbee.0 (1686) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2023-07-12 00:09:23.161 - error: zigbee.0 (1686) unhandled promise rejection: Cannot read properties of undefined (reading 'Error')
          2023-07-12 00:09:23.200 - error: zigbee.0 (1686) TypeError: Cannot read properties of undefined (reading 'Error')
          2023-07-12 00:09:23.201 - error: zigbee.0 (1686) Cannot read properties of undefined (reading 'Error')
          2023-07-12 00:09:23.212 - info: zigbee.0 (1686) cleaned everything up...
          2023-07-12 00:09:23.214 - info: zigbee.0 (1686) Zigbee: disabling joining new devices.
          2023-07-12 00:09:23.718 - info: zigbee.0 (1686) terminating
          2023-07-12 00:09:23.719 - warn: zigbee.0 (1686) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2023-07-12 00:09:24.283 - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
          2023-07-12 00:09:24.283 - error: host.raspberrypi Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'Error')
          2023-07-12 00:09:24.284 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56
          2023-07-12 00:09:24.284 - error: host.raspberrypi Caught by controller[1]: at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1)
          2023-07-12 00:09:24.284 - error: host.raspberrypi Caught by controller[1]: at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1)
          2023-07-12 00:09:24.284 - error: host.raspberrypi Caught by controller[1]: at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32)
          2023-07-12 00:09:24.285 - error: host.raspberrypi Caught by controller[1]: at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30)
          2023-07-12 00:09:24.285 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          2023-07-12 00:09:24.288 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
          2023-07-12 00:09:24.289 - warn: host.raspberrypi Do not restart adapter system.adapter.zigbee.0 because restart loop detected
          2023-07-12 00:09:34.177 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120
          2023-07-12 00:16:33.798 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120
          2023-07-12 00:16:37.274 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120
          2023-07-12 00:16:55.757 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120
          2023-07-12 00:18:34.317 - info: host.raspberrypi "system.adapter.zigbee.0" disabled
          2023-07-12 00:22:49.826 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120
          2023-07-12 00:50:16.524 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120 admin
          2023-07-12 00:50:16.595 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120
          2023-07-12 00:55:36.055 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120
          2023-07-12 00:56:04.451 - info: host.raspberrypi "system.adapter.zigbee.0" enabled
          2023-07-12 00:56:04.560 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 2527
          2023-07-12 00:56:08.682 - info: zigbee.0 (2527) starting. Version 1.8.12 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24
          2023-07-12 00:56:08.809 - info: zigbee.0 (2527) delete old Backup files. keep only last 10
          2023-07-12 00:56:08.811 - info: zigbee.0 (2527) Starting Zigbee npm ...
          2023-07-12 00:56:09.489 - info: zigbee.0 (2527) Installed Version: iobroker.zigbee@1.8.12
          2023-07-12 00:56:12.182 - info: zigbee.0 (2527) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}}
          2023-07-12 00:56:12.191 - info: zigbee.0 (2527) Unable to disable LED, unsupported function.
          2023-07-12 00:56:12.209 - info: zigbee.0 (2527) --> transmitPower : normal
          2023-07-12 00:56:12.218 - info: zigbee.0 (2527) Currently no devices.
          2023-07-12 00:56:12.221 - info: zigbee.0 (2527) Zigbee started
          2023-07-12 00:56:12.224 - error: zigbee.0 (2527) Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms
          2023-07-12 00:56:12.226 - error: zigbee.0 (2527) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2023-07-12 00:56:12.228 - error: zigbee.0 (2527) unhandled promise rejection: Cannot read properties of undefined (reading 'Error')
          2023-07-12 00:56:12.267 - error: zigbee.0 (2527) TypeError: Cannot read properties of undefined (reading 'Error')
          2023-07-12 00:56:12.267 - error: zigbee.0 (2527) Cannot read properties of undefined (reading 'Error')
          2023-07-12 00:56:12.276 - info: zigbee.0 (2527) cleaned everything up...
          2023-07-12 00:56:12.279 - info: zigbee.0 (2527) Zigbee: disabling joining new devices.
          2023-07-12 00:56:12.981 - info: zigbee.0 (2527) terminating
          2023-07-12 00:56:12.983 - warn: zigbee.0 (2527) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2023-07-12 00:56:13.624 - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
          2023-07-12 00:56:13.625 - error: host.raspberrypi Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'Error')
          2023-07-12 00:56:13.626 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56
          2023-07-12 00:56:13.626 - error: host.raspberrypi Caught by controller[1]: at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1)
          2023-07-12 00:56:13.626 - error: host.raspberrypi Caught by controller[1]: at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1)
          2023-07-12 00:56:13.626 - error: host.raspberrypi Caught by controller[1]: at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32)
          2023-07-12 00:56:13.627 - error: host.raspberrypi Caught by controller[1]: at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30)
          2023-07-12 00:56:13.627 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          2023-07-12 00:56:13.627 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
          2023-07-12 00:56:43.688 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 2547
          2023-07-12 00:56:47.886 - info: zigbee.0 (2547) starting. Version 1.8.12 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24
          2023-07-12 00:56:48.021 - info: zigbee.0 (2547) delete old Backup files. keep only last 10
          2023-07-12 00:56:48.023 - info: zigbee.0 (2547) Starting Zigbee npm ...
          2023-07-12 00:56:48.705 - info: zigbee.0 (2547) Installed Version: iobroker.zigbee@1.8.12
          2023-07-12 00:56:49.075 - info: zigbee.0 (2547) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}}
          2023-07-12 00:56:49.085 - info: zigbee.0 (2547) Unable to disable LED, unsupported function.
          2023-07-12 00:56:49.103 - info: zigbee.0 (2547) --> transmitPower : normal
          2023-07-12 00:56:49.114 - info: zigbee.0 (2547) Currently no devices.
          2023-07-12 00:56:49.115 - info: zigbee.0 (2547) Zigbee started
          2023-07-12 00:56:49.119 - error: zigbee.0 (2547) Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms
          2023-07-12 00:56:49.121 - error: zigbee.0 (2547) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2023-07-12 00:56:49.122 - error: zigbee.0 (2547) unhandled promise rejection: Cannot read properties of undefined (reading 'Error')
          2023-07-12 00:56:49.166 - error: zigbee.0 (2547) TypeError: Cannot read properties of undefined (reading 'Error')
          2023-07-12 00:56:49.166 - error: zigbee.0 (2547) Cannot read properties of undefined (reading 'Error')
          2023-07-12 00:56:49.176 - info: zigbee.0 (2547) cleaned everything up...
          2023-07-12 00:56:49.178 - info: zigbee.0 (2547) Zigbee: disabling joining new devices.
          2023-07-12 00:56:49.678 - info: zigbee.0 (2547) terminating
          2023-07-12 00:56:49.680 - warn: zigbee.0 (2547) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2023-07-12 00:56:50.241 - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
          2023-07-12 00:56:50.241 - error: host.raspberrypi Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'Error')
          2023-07-12 00:56:50.242 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56
          2023-07-12 00:56:50.242 - error: host.raspberrypi Caught by controller[1]: at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1)
          2023-07-12 00:56:50.242 - error: host.raspberrypi Caught by controller[1]: at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1)
          2023-07-12 00:56:50.242 - error: host.raspberrypi Caught by controller[1]: at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32)
          2023-07-12 00:56:50.242 - error: host.raspberrypi Caught by controller[1]: at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30)
          2023-07-12 00:56:50.242 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          2023-07-12 00:56:50.243 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
          2023-07-12 00:57:20.300 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 2564
          2023-07-12 00:57:24.478 - info: zigbee.0 (2564) starting. Version 1.8.12 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.16.1, js-controller: 4.0.24
          2023-07-12 00:57:24.604 - info: zigbee.0 (2564) delete old Backup files. keep only last 10
          2023-07-12 00:57:24.607 - info: zigbee.0 (2564) Starting Zigbee npm ...
          2023-07-12 00:57:25.273 - info: zigbee.0 (2564) Installed Version: iobroker.zigbee@1.8.12
          2023-07-12 00:57:25.646 - info: zigbee.0 (2564) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}}
          2023-07-12 00:57:25.656 - info: zigbee.0 (2564) Unable to disable LED, unsupported function.
          2023-07-12 00:57:25.674 - info: zigbee.0 (2564) --> transmitPower : normal
          2023-07-12 00:57:25.684 - info: zigbee.0 (2564) Currently no devices.
          2023-07-12 00:57:25.685 - info: zigbee.0 (2564) Zigbee started
          2023-07-12 00:57:25.689 - error: zigbee.0 (2564) Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms
          2023-07-12 00:57:25.691 - error: zigbee.0 (2564) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2023-07-12 00:57:25.692 - error: zigbee.0 (2564) unhandled promise rejection: Cannot read properties of undefined (reading 'Error')
          2023-07-12 00:57:25.730 - error: zigbee.0 (2564) TypeError: Cannot read properties of undefined (reading 'Error')
          2023-07-12 00:57:25.731 - error: zigbee.0 (2564) Cannot read properties of undefined (reading 'Error')
          2023-07-12 00:57:25.742 - info: zigbee.0 (2564) cleaned everything up...
          2023-07-12 00:57:25.744 - info: zigbee.0 (2564) Zigbee: disabling joining new devices.
          2023-07-12 00:57:26.257 - info: zigbee.0 (2564) terminating
          2023-07-12 00:57:26.258 - warn: zigbee.0 (2564) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2023-07-12 00:57:26.822 - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
          2023-07-12 00:57:26.823 - error: host.raspberrypi Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'Error')
          2023-07-12 00:57:26.823 - error: host.raspberrypi Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56
          2023-07-12 00:57:26.823 - error: host.raspberrypi Caught by controller[1]: at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1)
          2023-07-12 00:57:26.823 - error: host.raspberrypi Caught by controller[1]: at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1)
          2023-07-12 00:57:26.823 - error: host.raspberrypi Caught by controller[1]: at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32)
          2023-07-12 00:57:26.823 - error: host.raspberrypi Caught by controller[1]: at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30)
          2023-07-12 00:57:26.824 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          2023-07-12 00:57:26.825 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
          2023-07-12 00:57:26.825 - warn: host.raspberrypi Do not restart adapter system.adapter.zigbee.0 because restart loop detected
          2023-07-12 01:00:20.538 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120
          2023-07-12 01:09:11.133 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120 admin
          2023-07-12 01:09:15.621 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120
          2023-07-12 10:02:33.406 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120
          2023-07-12 10:02:34.509 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120
          2023-07-12 10:02:34.539 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120
          2023-07-12 10:02:34.587 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120
          2023-07-12 10:02:38.058 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120
          2023-07-12 10:02:52.942 - info: admin.0 (1599) ==> Connected system.user.admin from ::ffff:192.168.68.120
          2023-07-12 10:02:57.542 - info: admin.0 (1599) <== Disconnect system.user.admin from ::ffff:192.168.68.120
            Thomas Braun Most Active @armin0676 last edited by Thomas Braun
            @armin0676
            ls -lAh /dev/serial/by-id
            sagt was zu dem Stick?
            Und schalte Sentry für den zigbee-Adapter aus.
            Und verwende die aktulle Version des Adapters.
              @thomas-braun Ls: cannot access ‘/dev/serial/by-id’: No such file or directory
              Ist alles aktuell
              arteck Thomas Braun 2 Replies Last reply Reply Quote 0
                arteck Developer Most Active @armin0676 last edited by
                @armin0676 installier die GIT version
                https://github.com/ioBroker/ioBroker.zigbee/wiki/GIT-install
                  @armin0676
                  udev?
                  sudo apt update
                  apt policy udev
                    @thomas-braun said in Zigbee Sonoff 3.0 usb dongle fehler:
                    apt policy udev
                    pi@raspberrypi:~ $ apt policy udev
                    udev:
                      Installed: 247.3-7+deb11u2
                      Candidate: 247.3-7+deb11u2
                      Version table:
                     *** 247.3-7+deb11u2 500
                            500 http://deb.debian.org/debian bullseye/main arm64 Packages
                            100 /var/lib/dpkg/status
                      @armin0676
                      Das ist die kaputte Version.
                      Such das HowTo von @mickym zu dem Thema.
                      Edit:
                      Schau hier:
                      https://forum.iobroker.net/topic/65017/zigbee-conbee2-funktioniert-nach-update-nicht-mehr-udev?_=1689152138257
                        Thomas und Arteck ich danke euch beide. Direkt über git zu installieren hat geholfen. Thomas habe das letzte aktualisiert jetzt läuft alles "noch"😊 .
                          @armin0676
                          Musste mal schauen, ob es mit dem defekten udev-Paket funktioniert.
                          Die Meldungen gingen aber durch die Bank dahin, dass damit die Anbindung von usb-Sticks kaputt ist.
                            @thomas-braun Ja dachte schon mein adapter ist defekt😧
                              @armin0676
                              Hast du jetzt udev angepackt oder nicht?
                              sudo apt update
                              apt policy udev
                              sagt nun?
                                udev:
                                  Installed: 247.3-7+deb11u4
                                  Candidate: 247.3-7+deb11u4
                                  Version table:
                                 *** 247.3-7+deb11u4 500
                                        500 http://deb.debian.org/debian bullseye-proposed-updates/main arm64 Packages
                                     247.3-7+deb11u2 500
                                  @armin0676
                                  Ja, das passt nun.
                                  81.0k
                                  sonoff zigbee 3.0 plus
                                  546
