    4. BLE Adapter lässt sich nicht installieren. gelöst(Nodev18)
      LarryXXL last edited by LarryXXL
      Systemdata Proxmox VM
      Hardwaresystem: intel i5
      Arbeitsspeicher: 8GB
      Festplattenart: virtuell
      Betriebssystem: Ubuntu
      Node-Version: 20.4.0
      Nodejs-Version: 20.4.0
      NPM-Version: 9.7.2
      Installationsart: Skript
      Image genutzt: Nein
        LarryXXL last edited by Homoran
        $ iobroker add ble --host iob-server
        NPM version: 9.7.2
        Installing iobroker.ble@0.13.4... (System call)
        npm ERR! code 7npm ERR! path /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! gyp ERR! UNCAUGHT EXCEPTION npm ERR! gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'npm ERR! gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)npm ERR! gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9npm ERR! gyp ERR! stack at FSReqCallback.oncomplete (node:fs:189:23)npm ERR! gyp ERR! System Linux 5.15.0-76-genericnpm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.ble/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v20.4.0npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! Node-gyp failed to build your package.npm ERR! gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-07-16T16_55_15_625Z-debug-0.log
        host.iob-server Cannot install iobroker.ble@0.13.4: 7
        ERROR: Process exited with code 25
        alle anderen adapter laufen und sind grün.
        DJMarc75 Thomas Braun 2 Replies Last reply Reply Quote 0
        • DJMarc75
          DJMarc75 @LarryXXL last edited by
          @larryxxl sagte in BLE Adapter lässt sich nicht installieren.:
          NPM version: 9.7.2
          absolut schräg....
          bitte mal die Ausgabe (Langfassung) von
          iob diag
          zeigen
            Thomas Braun Most Active @LarryXXL last edited by Thomas Braun
            @larryxxl
            Mit nodejs@20 gibt es noch verschiedene Probleme.
            Setz die empfohlene v18 ein.
              LarryXXL @Thomas Braun last edited by
              Skript v.2023-04-16
              *** BASE SYSTEM ***
              Architecture    : x86_64
              Docker          : false
              Virtualization  : kvm
              Distributor ID: Ubuntu
              Description:    Ubuntu 22.04.2 LTS
              Release:        22.04
              Codename:       jammy
              PRETTY_NAME="Ubuntu 22.04.2 LTS"
              NAME="Ubuntu"
              VERSION_ID="22.04"
              VERSION="22.04.2 LTS (Jammy Jellyfish)"
              VERSION_CODENAME=jammy
              ID=ubuntu
              ID_LIKE=debian
              HOME_URL="https://www.ubuntu.com/"
              SUPPORT_URL="https://help.ubuntu.com/"
              BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
              PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
              UBUNTU_CODENAME=jammy
              Systemuptime and Load:
               19:06:54 up 14 min,  2 users,  load average: 0.89, 0.32, 0.19
              CPU threads: 8
              *** Time and Time Zones ***
                             Local time: Sun 2023-07-16 19:06:54 CEST
                         Universal time: Sun 2023-07-16 17:06:54 UTC
                               RTC time: Sun 2023-07-16 17:06:54
                            NTP service: active
                        RTC in local TZ: no
              *** User and Groups ***
              root
              /root
              root
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            7.9G        217M        6.9G        1.0M        818M        7.5G
              Swap:             0B          0B          0B
              Total:          7.9G        217M        6.9G
                       7937 M total memory
                        217 M used memory
                        380 M active memory
                        426 M inactive memory
                       6901 M free memory
                         55 M buffer memory
                        762 M swap cache
                          0 M total swap
                          0 M used swap
                          0 M free swap
              *** FILESYSTEM ***
              Filesystem                        Type   Size  Used Avail Use% Mounted on
              tmpfs                             tmpfs  794M  1.1M  793M   1% /run
              /dev/mapper/ubuntu--vg-ubuntu--lv ext4   9.8G  7.5G  1.8G  81% /
              tmpfs                             tmpfs  3.9G     0  3.9G   0% /dev/shm
              tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
              /dev/sda2                         ext4   1.7G  240M  1.4G  15% /boot
              tmpfs                             tmpfs  794M  4.0K  794M   1% /run/user/0
              [Sun Jul 16 18:52:11 2023] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
              [Sun Jul 16 18:52:12 2023] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
              [Sun Jul 16 18:52:12 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
              Show mounted filesystems (real ones only):
              TARGET              SOURCE                            FSTYPE   OPTIONS
              /                   /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
              |-/snap/core20/1950 /dev/loop0                        squashfs ro,nodev,relatime,errors=continue
              |-/snap/core20/1974 /dev/loop1                        squashfs ro,nodev,relatime,errors=continue
              |-/snap/lxd/24061   /dev/loop2                        squashfs ro,nodev,relatime,errors=continue
              |-/snap/snapd/19361 /dev/loop3                        squashfs ro,nodev,relatime,errors=continue
              |-/snap/snapd/19457 /dev/loop4                        squashfs ro,nodev,relatime,errors=continue
              `-/boot             /dev/sda2                         ext4     rw,relatime
              /var:
              2.1G    /var/
              1.1G    /var/log
              992M    /var/log/journal/8716649619c849e1a3f7aa18f9c78966
              651M    /var/lib
              Archived and active journals take up 991.7M in the file system.
              /opt/iobroker/backups:
              /opt/iobroker/iobroker-data:
              185M    /opt/iobroker/iobroker-data/
              86M     /opt/iobroker/iobroker-data/files
              65M     /opt/iobroker/iobroker-data/backup-objects
              51M     /opt/iobroker/iobroker-data/files/javascript.admin
              33M     /opt/iobroker/iobroker-data/files/javascript.admin/static
              14M     /opt/iobroker/iobroker-data/objects.jsonl
              7.2M    /opt/iobroker/iobroker-data/files/ham.admin/static/js/main.8080bc0b.js.map
              6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/910.e1389bdb.chunk.js.map
              6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
              5.3M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/472.d73f9bde.chunk.js.map
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v20.4.0
              /usr/bin/node           v20.4.0
              /usr/bin/npm            9.7.2
              /usr/bin/npx            9.7.2
              nodejs:
                Installed: 20.4.0-deb-1nodesource1
                Candidate: 20.4.0-deb-1nodesource1
                Version table:
               *** 20.4.0-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_20.x jammy/main amd64 Packages
                      100 /var/lib/dpkg/status
                   12.22.9~dfsg-1ubuntu3 500
                      500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
              No problems detected
              *** ioBroker-Installation ***
              ioBroker Status
              iobroker is not running on this host.
              Objects type: jsonl
              States  type: jsonl
              MULTIHOSTSERVICE/enabled: false
              Core adapters versions
              js-controller:  5.0.8
              admin:          6.6.0
              javascript:     7.1.1
              Adapters from github:   4
              Adapter State
                system.adapter.accuweather.0            : accuweather           : iob-server                               -  enabled
                system.adapter.admin.0                  : admin                 : iob-server                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                system.adapter.alexa2.0                 : alexa2                : iob-server                               -  enabled
                system.adapter.backitup.0               : backitup              : iob-server                               -  enabled
                system.adapter.discovery.0              : discovery             : iob-server                               -  enabled
                system.adapter.ham.0                    : ham                   : iob-server                               -  enabled
                system.adapter.history.0                : history               : iob-server                               -  enabled
                system.adapter.hue-extended.0           : hue-extended          : iob-server                               -  enabled
                system.adapter.javascript.0             : javascript            : iob-server                               -  enabled
                system.adapter.mihome.0                 : mihome                : iob-server                               -  enabled, port: 9898, bind: 0.0.0.0
                system.adapter.nina.0                   : nina                  : iob-server                               -  enabled
                system.adapter.radar2.0                 : radar2                : iob-server                               -  enabled
                system.adapter.tapo.0                   : tapo                  : iob-server                               -  enabled
                system.adapter.tuya.0                   : tuya                  : iob-server                               -  enabled
                system.adapter.yeelight-2.0             : yeelight-2            : iob-server                               -  enabled
                system.adapter.zigbee.0                 : zigbee                : iob-server                               -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
              + instance is alive
              ioBroker-Repositories
              Active repo(s): beta
              Installed ioBroker-Instances
              Used repository: beta
              Adapter    "accuweather"  : 1.2.4    , installed 1.2.4
              Adapter    "admin"        : 6.6.0    , installed 6.6.0
              Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
              Adapter    "backitup"     : 2.6.23   , installed 2.6.23
              Adapter    "discovery"    : 3.2.0    , installed 3.2.0
              Adapter    "ham"          : 5.3.1    , installed 5.3.1
              Adapter    "history"      : 2.2.4    , installed 2.2.4
              Adapter    "hue-extended" : 2.0.0    , installed 2.0.1
              Adapter    "javascript"   : 7.1.1    , installed 7.1.1
              Controller "js-controller": 5.0.8    , installed 5.0.8
              Adapter    "mihome"       : 1.4.0    , installed 1.4.0
              Adapter    "nina"         : 0.0.25   , installed 0.0.25
              Adapter    "radar2"       : 2.0.7    , installed 2.0.7
              Adapter    "tapo"         : 0.0.8    , installed 0.0.8
              Adapter    "tuya"         : 3.14.2   , installed 3.14.2
              Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
              Adapter    "zigbee"       : 1.8.18   , installed 1.8.14 [Updatable]
              Objects and States
              Objects:        6156
              States:         5431
              Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
              Hit:2 https://deb.nodesource.com/node_20.x jammy InRelease
              Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
              Get:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease [108 kB]
              Hit:5 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
              Fetched 108 kB in 1s (193 kB/s)
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          22849      748/sshd: /usr/sbin
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          20024      1/init
              tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        22689      677/systemd-resolve
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          21133      694/cupsd
              tcp        0      0 0.0.0.0:47307           0.0.0.0:*               LISTEN      115        33007      3269/rpc.statd
              tcp6       0      0 :::22                   :::*                    LISTEN      0          22861      748/sshd: /usr/sbin
              tcp6       0      0 :::111                  :::*                    LISTEN      0          15771      1/init
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          21132      694/cupsd
              tcp6       0      0 :::52297                :::*                    LISTEN      115        33011      3269/rpc.statd
              udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        22688      677/systemd-resolve
              udp        0      0 192.168.1.166:68        0.0.0.0:*                           100        16195      675/systemd-network
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          20025      1/init
              udp        0      0 0.0.0.0:49712           0.0.0.0:*                           115        33005      3269/rpc.statd
              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          23649      756/cups-browsed
              udp        0      0 127.0.0.1:901           0.0.0.0:*                           0          33001      3269/rpc.statd
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        22281      689/avahi-daemon: r
              udp        0      0 0.0.0.0:51718           0.0.0.0:*                           116        22283      689/avahi-daemon: r
              udp6       0      0 :::35688                :::*                                116        22284      689/avahi-daemon: r
              udp6       0      0 :::44404                :::*                                115        33009      3269/rpc.statd
              udp6       0      0 :::111                  :::*                                0          15772      1/init
              udp6       0      0 fe80::4401:1ff:fe01:546 :::*                                100        22714      675/systemd-network
              udp6       0      0 :::5353                 :::*                                116        22282      689/avahi-daemon: r
              2023-07-16 19:06:34.474  - info: accuweather.0 (3331) terminating
              2023-07-16 19:06:34.478  - info: mihome.0 (3019) terminating
              2023-07-16 19:06:34.479  - info: javascript.0 (3000) terminating
              2023-07-16 19:06:34.478  - info: alexa2.0 (3078) terminating
              2023-07-16 19:06:34.496  - info: tapo.0 (3380) terminating
              2023-07-16 19:06:34.496  - info: backitup.0 (3232) terminating
              2023-07-16 19:06:34.496  - info: admin.0 (2946) terminating
              2023-07-16 19:06:34.676  - info: host.iob-server instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
              2023-07-16 19:06:34.676  - info: host.iob-server instance system.adapter.yeelight-2.0 terminated with code 0 (NO_ERROR)
              2023-07-16 19:06:34.770  - info: host.iob-server instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
              2023-07-16 19:06:34.770  - info: host.iob-server instance system.adapter.nina.0 terminated with code 0 (NO_ERROR)
              2023-07-16 19:06:34.789  - info: host.iob-server instance system.adapter.accuweather.0 terminated with code 0 (NO_ERROR)
              2023-07-16 19:06:34.809  - info: host.iob-server instance system.adapter.alexa2.0 terminated with code 0 (NO_ERROR)
              2023-07-16 19:06:34.852  - info: host.iob-server instance system.adapter.mihome.0 terminated with code 0 (NO_ERROR)
              2023-07-16 19:06:34.853  - info: host.iob-server instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
              2023-07-16 19:06:34.853  - info: host.iob-server instance system.adapter.hue-extended.0 terminated with code 0 (NO_ERROR)
              2023-07-16 19:06:34.881  - info: host.iob-server instance system.adapter.radar2.0 terminated with code 0 (NO_ERROR)
              2023-07-16 19:06:34.881  - info: host.iob-server instance system.adapter.tapo.0 terminated with code 0 (NO_ERROR)
              2023-07-16 19:06:34.903  - info: host.iob-server instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
              2023-07-16 19:06:34.903  - info: host.iob-server instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
              2023-07-16 19:06:34.956  - info: host.iob-server instance system.adapter.ham.0 terminated with code 0 (NO_ERROR)
              2023-07-16 19:06:35.041  - info: host.iob-server instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
              2023-07-16 19:06:37.502  - info: host.iob-server instance system.adapter.tuya.0 terminated with code 0 (NO_ERROR)
              2023-07-16 19:06:37.502  - info: host.iob-server All instances are stopped.
              2023-07-16 19:06:37.657  - info: host.iob-server terminated
              iob diag has finished.
                @larryxxl
                Nicht als root herumhampeln, SWAP aktivieren, nodejs@18 verwenden.
                Dein / ist so gut wie voll, das fällt dir als nächstes auf die Füße.
                  StefanH 0 @Thomas Braun last edited by StefanH 0
                  Hallo in die Runde, vielleicht kann mir jemand helfen.
                  Habe auf dem Raspi 4 erfolgreich Bluetooth aktiviert und im iobroker ebenfalls den BLE-Adapter erfolgreich zum Laufen gebracht. Leider wird mein XIAOMI Helligkeitssensor nicht vom Adapter erkannt.
                  Habe im Adapter das xiaomi - Plugin aktiviert.
                  Beim Starten des Adapter erscheint folgendes im Log:
                  ble.0
                  2023-08-09 07:32:40.655	info	starting scan for services ["fe95"]
                  ble.0
                  2023-08-09 07:32:40.083	info	starting scanner process...
                  ble.0
                  2023-08-09 07:32:40.053	info	monitored services: fe95
                  ble.0
                  2023-08-09 07:32:40.052	info	enabled plugins: Xiaomi, _default
                  ble.0
                  2023-08-09 07:32:40.050	info	loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
                  ble.0
                  2023-08-09 07:32:39.979	info	starting. Version 0.13.4 in /opt/iobroker/node_modules/iobroker.ble, node: v18.16.1, js-controller: 4.0.24
                  host.Raspberry-PI4
                  2023-08-09 07:32:37.294	info	instance system.adapter.ble.0 started with pid 3879
                  Hier noch die Daten im Objektknoten des BLE-Adapters:
                  Habe auch schon das Objekt: allowNewDevices auf true gesetzt und dann den Pairing-Modus auf dem Helligkeitssensor aktiviert. Hat bisher leider alles nichts gebracht.
                  Ich gehen davon aus, dass ich für die Anbindung des Sensors an IOBroker keinen Zigbee-Hub benötige.
                  Gruss Stefan
                    StefanH 0 @StefanH 0 last edited by StefanH 0
                    @stefanh-0
                    bin jetzt etwas weiter gekommen.
                    Nachdem ich den Haken mal bei:
                    gesetzt habe, hat er schon mal Devices gefunden, das ist sehr schön und sagt mir, dass mein Bluetooth auf dem Rasp und der BLE-Adapter in IOBroker funktionieren.
                    Es können jedoch von den Devices keine Daten ausgelesen werden.
                    Das kann aber normal sein, da der XIAOMI Lichtsensor möglicher vom Plugin noch garnicht unterstützt wird und die restlichen gefundenen Bluetooth-Devices ohne geeignete Plugins sowieso nicht ausgelesen werden können.
                    • crunchip
                      crunchip Forum Testing Most Active @StefanH 0 last edited by
                      @stefanh-0 sagte in BLE Adapter lässt sich nicht installieren. gelöst(Nodev18):
                      XIAOMI Lichtsensor
                      bluetooth? wohl eher zigbee
                        StefanH 0 @crunchip last edited by
                        @crunchip
                        Ist mir schon klar dass zigbee als Protokoll verwendet wird, aber das sollten die Plugins ja hoffentlich können.
                        • crunchip
                          crunchip Forum Testing Most Active @StefanH 0 last edited by crunchip
                          @stefanh-0 scheinbar ist dir nicht ganz klar was der ble Adapter macht, das hat nichts mit zigbee zu tun, nur weil xiaomi als plugin drin steht.
                          es gibt Geräte von xiaomi die mit bluetooth funken, wie z.b der Xiaomi Temperature and humidity sensor
                            @crunchip
                            Ok , danke für die Info und Klarstellung. Dachte bisher, dass zigbee auf Bluetooth aufsetzt. War mir nicht klar, dass zigbee ein eigenständiger Funkstandard ist.
                            • crunchip
                              @stefanh-0 auf die schnelle https://www.libe.net/smart-home-funk
                              Walter.O. 1 Reply Last reply Reply Quote 0
                              • Walter.O.
                                Walter.O. @crunchip last edited by
                                Hänge mich hier noch mal an.
                                Ich kann BLE _0.13.4 nicht Instalieren.
                                Plattform: linux
                                Betriebssystem: linux
                                Architektur: x64
                                Geschwindigkeit: 1496 MHz
                                Modell: Intel(R) Celeron(R) CPU 1007U @ 1.50GHz
                                RAM: 7.5 GB
                                Node.js: v18.19.0
                                NPM: 10.2.3
                                Freier Festplattenspeicher: 453.0 GB
                                $ iobroker add ble --host Mini-pc-Master
                                npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:17520) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:517:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:292:12)npm ERR! gyp ERR! System Linux 6.1.0-17-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.19.0npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-23T18_42_08_732Z-debug-0.loghost.Mini-pc-Master Cannot install iobroker.ble@0.13.4: 1
                                Kann jemand weiterhelfen?
                                  Thomas Braun Most Active @Walter.O. last edited by
                                  @walter-o sagte in BLE Adapter lässt sich nicht installieren. gelöst(Nodev18):
                                  Wie bist du da ansonsten so unterwegs?
                                  iob diag
                                  anschauen.
                                    Homoran Global Moderator Administrators @Walter.O. last edited by
                                    hast du die notwendigen Zusatzpakete installiert?
                                    • Walter.O.
                                      Walter.O. @Thomas Braun last edited by
                                      @thomas-braun sagte in BLE Adapter lässt sich nicht installieren. gelöst(Nodev18):
                                      iob diag
                                      Wie kann ich das denn alles kopieren?
                                      Bekomme nicht mal die hälfte kopiert...
                                      • Walter.O.
                                        Walter.O. @Homoran last edited by
                                        @homoran welche währen das?
                                          Markieren, kopieren, hier rein hauen.
                                            steht in der Adapterbeschreibung, hab ich nicht im Kopf
                                            2397
