    4. "Adapter already running" nach Serverneustart (Windows)
    • surfer09
      surfer09 last edited by surfer09
      leider habe ich sei Längerem immer wieder nach einem Serverneustart das Problem, dass im LOG bei fast allen Adaptern die Meldung "Adapter already running" auftaucht. Ich habe den IO-Broker auf einem Master (Windows 10) und einem Slave (ebenfalls Windows 10) installiert. Bei beiden erscheint die Meldung im LOG.
      Master
      2023-07-17 19:41:09.738 - info: host.IOBroker-Server instance system.adapter.discovery.0 started with pid 8664
      2023-07-17 19:41:09.742 - info: host.IOBroker-Server instance system.adapter.sql.0 started with pid 8784
      2023-07-17 19:41:09.747 - info: host.IOBroker-Server instance system.adapter.deconz.0 started with pid 8652
      2023-07-17 19:41:09.752 - info: host.IOBroker-Server instance system.adapter.hm-rega.0 started with pid 8612
      2023-07-17 19:41:09.758 - info: host.IOBroker-Server instance system.adapter.info.0 started with pid 8728
      2023-07-17 19:41:11.015 - error: discovery.0 (8664) discovery.0 already running
      2023-07-17 19:41:11.017 - warn: discovery.0 (8664) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-07-17 19:41:11.345 - error: deconz.0 (8652) deconz.0 already running
      2023-07-17 19:41:11.425 - info: host.IOBroker-Server instance system.adapter.hm-rpc.0 started with pid 8016
      2023-07-17 19:41:11.771 - error: host.IOBroker-Server instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-07-17 19:41:11.771 - info: host.IOBroker-Server Restart adapter system.adapter.discovery.0 because enabled
      2023-07-17 19:41:12.109 - error: host.IOBroker-Server instance system.adapter.deconz.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-07-17 19:41:12.110 - info: host.IOBroker-Server Restart adapter system.adapter.deconz.0 because enabled
      2023-07-17 19:41:13.068 - info: host.IOBroker-Server instance system.adapter.simple-api.0 started with pid 9108
      2023-07-17 19:41:13.796 - error: info.0 (8728) info.0 already running
      2023-07-17 19:41:13.797 - warn: info.0 (8728) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-07-17 19:41:14.234 - error: simple-api.0 (9108) simple-api.0 already running
      2023-07-17 19:41:14.235 - warn: simple-api.0 (9108) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-07-17 19:41:14.333 - error: host.IOBroker-Server instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-07-17 19:41:14.333 - info: host.IOBroker-Server Restart adapter system.adapter.info.0 because enabled
      2023-07-17 19:41:14.380 - info: admin.0 (5912) <== Disconnect system.user.admin from ::ffff:192.168.1.230 admin
      2023-07-17 19:41:14.770 - error: host.IOBroker-Server instance system.adapter.simple-api.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-07-17 19:41:14.770 - info: host.IOBroker-Server Restart adapter system.adapter.simple-api.0 because enabled
      2023-07-17 19:41:15.586 - info: host.IOBroker-Server instance system.adapter.hm-rpc.1 started with pid 3304
      2023-07-17 19:41:15.794 - info: host.IOBroker-Server instance system.adapter.simple-api.0 started with pid 6560
      2023-07-17 19:41:16.129 - info: host.IOBroker-Server instance system.adapter.squeezeboxrpc.0 started with pid 8840
      2023-07-17 19:41:16.145 - warn: host.IOBroker-Server too delayed answer for system.host.IOBROKER-SLAVE-WINDOWS
      2023-07-17 19:41:16.673 - info: admin.0 (5912) ==> Connected system.user.admin from ::ffff:192.168.1.230
      2023-07-17 19:41:17.422 - error: squeezeboxrpc.0 (8840) squeezeboxrpc.0 already running
      2023-07-17 19:41:17.423 - warn: squeezeboxrpc.0 (8840) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-07-17 19:41:17.864 - warn: node-red.0 (8616) 17 Jul 19:41:17 - [warn] Projects disabled : editorTheme.projects.enabled=false
      2023-07-17 19:41:17.884 - warn: node-red.0 (8616) 17 Jul 19:41:17 - [warn] Encrypted credentials not found
      2023-07-17 19:41:18.023 - error: host.IOBroker-Server instance system.adapter.squeezeboxrpc.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-07-17 19:41:18.023 - info: host.IOBroker-Server Restart adapter system.adapter.squeezeboxrpc.0 because enabled
      2023-07-17 19:41:20.126 - info: host.IOBroker-Server instance system.adapter.upnp.0 started with pid 8008
      2023-07-17 19:41:20.996 - error: upnp.0 (8008) upnp.0 already running
      2023-07-17 19:41:20.997 - warn: upnp.0 (8008) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-07-17 19:41:21.536 - error: host.IOBroker-Server instance system.adapter.upnp.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-07-17 19:41:21.536 - info: host.IOBroker-Server Restart adapter system.adapter.upnp.0 because enabled
      2023-07-17 19:41:22.581 - warn: host.IOBroker-Server too delayed answer for system.host.IOBROKER-SLAVE-WINDOWS
      2023-07-17 19:41:24.135 - info: host.IOBroker-Server instance system.adapter.web.0 started with pid 1240
      2023-07-17 19:41:25.396 - error: web.0 (1240) web.0 already running
      2023-07-17 19:41:25.397 - warn: web.0 (1240) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-07-17 19:41:26.006 - error: host.IOBroker-Server instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-07-17 19:41:26.007 - info: host.IOBroker-Server Restart adapter system.adapter.web.0 because enabled
      2023-07-17 19:41:27.472 - info: host.IOBroker-Server instance system.adapter.synology.0 started with pid 9312
      2023-07-17 19:41:28.129 - info: host.IOBroker-Server instance system.adapter.yahka.0 started with pid 5628
      2023-07-17 19:41:29.292 - error: yahka.0 (5628) yahka.0 already running
      2023-07-17 19:41:29.294 - warn: yahka.0 (5628) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-07-17 19:41:29.849 - error: host.IOBroker-Server instance system.adapter.yahka.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-07-17 19:41:29.849 - info: host.IOBroker-Server Restart adapter system.adapter.yahka.0 because enabled
      2023-07-17 19:41:32.120 - info: host.IOBroker-Server instance system.adapter.yahka.2 started with pid 6192
      2023-07-17 19:41:32.979 - error: yahka.2 (6192) yahka.2 already running
      2023-07-17 19:41:32.980 - warn: yahka.2 (6192) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-07-17 19:41:33.528 - error: host.IOBroker-Server instance system.adapter.yahka.2 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-07-17 19:41:33.528 - info: host.IOBroker-Server Restart adapter system.adapter.yahka.2 because enabled
      2023-07-17 19:41:36.152 - info: host.IOBroker-Server instance system.adapter.jarvis.0 started with pid 10020
      2023-07-17 19:41:37.477 - error: jarvis.0 (10020) jarvis.0 already running
      2023-07-17 19:41:37.478 - warn: jarvis.0 (10020) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-07-17 19:41:38.026 - error: host.IOBroker-Server instance system.adapter.jarvis.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-07-17 19:41:38.026 - info: host.IOBroker-Server Restart adapter system.adapter.jarvis.0 because enabled
      2023-07-17 19:41:40.155 - info: host.IOBroker-Server instance system.adapter.socketio.0 started with pid 9624
      2023-07-17 19:41:40.805 - error: socketio.0 (9624) socketio.0 already running
      2023-07-17 19:41:40.806 - warn: socketio.0 (9624) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-07-17 19:41:41.363 - error: host.IOBroker-Server instance system.adapter.socketio.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-07-17 19:41:41.364 - info: host.IOBroker-Server Restart adapter system.adapter.socketio.0 because enabled
      2023-07-17 19:41:41.812 - info: host.IOBroker-Server instance system.adapter.discovery.0 started with pid 9824
      2023-07-17 19:41:42.153 - info: host.IOBroker-Server instance system.adapter.deconz.0 started with pid 7808
      2023-07-17 19:41:44.150 - info: host.IOBroker-Server instance system.adapter.ws.0 started with pid 6360
      2023-07-17 19:41:44.378 - info: host.IOBroker-Server instance system.adapter.info.0 started with pid 3184
      2023-07-17 19:41:44.840 - error: ws.0 (6360) ws.0 already running
      2023-07-17 19:41:44.841 - warn: ws.0 (6360) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-07-17 19:41:45.386 - error: host.IOBroker-Server instance system.adapter.ws.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-07-17 19:41:45.386 - info: host.IOBroker-Server Restart adapter system.adapter.ws.0 because enabled
      2023-07-17 19:41:48.075 - info: host.IOBroker-Server instance system.adapter.squeezeboxrpc.0 started with pid 8828
      2023-07-17 19:41:48.124 - info: host.IOBroker-Server instance system.adapter.echarts.0 started with pid 9400
      2023-07-17 19:41:48.925 - error: echarts.0 (9400) echarts.0 already running
      2023-07-17 19:41:48.926 - warn: echarts.0 (9400) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2023-07-17 19:41:49.477 - error: host.IOBroker-Server instance system.adapter.echarts.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2023-07-17 19:41:49.478 - info: host.IOBroker-Server Restart adapter system.adapter.echarts.0 because enabled
      2023-07-17 19:41:51.590 - info: host.IOBroker-Server instance system.adapter.upnp.0 started with pid 6768
      2023-07-17 19:41:52.199 - info: host.IOBroker-Server instance system.adapter.windows-control.0 started with pid 3580
      Slave
      Ich weiß nicht ganz, wonach ich suchen soll. Nach Neustart startet der IO-Broker Windows Dienst und somit auch die Adapter. Ich kann nicht nachvollziehen, warum die Adapter parallel schon laufen sollen.
      Systemdata Bitte Ausfüllen
      Hardwaresystem: NUC
      Arbeitsspeicher: 12GB
      Festplattenart: SSD
      Betriebssystem: Windows 10
      Nodejs-Version: 18.16.1
      NPM-Version: 9.5.1
      crunchip sigi234 2 Replies Last reply Reply Quote 0
      • crunchip
        crunchip Forum Testing Most Active @surfer09 last edited by
        @surfer09 sagte in "Adapter already running" nach Serverneustart (Windows):
        Weil
        Iobroker nicht beendet wurde
        • surfer09
          surfer09 @crunchip last edited by surfer09
          @crunchip Aber wenn ich Windows neustarte, wird der IO-Broker doch auch beendet?! Und wenn Windows wieder startet, dann startet ja auch der Dienst wieder. Also wird doch alles richtig beendet/gestartet 🤔
          Oder muss ich vor dem Windows Neustart den Dienst beenden?
          crunchip arteck 2 Replies Last reply Reply Quote 0
          • crunchip
            Das sollte eigentlich automatisch passieren, allerdings hab ich kein windows, kann dir somit auch nicht weiterhelfen
              arteck Developer Most Active @surfer09 last edited by arteck
              nein.. was wech ist ist wech
              schau evtl. nicht das der 2 dienste angelegt hat.. oder du noch was im autostart hast..
              oder ist der schaumal ob der Dienst nicht verzögert startet.. wenn nein dann probier damit aus..
              • sigi234
                sigi234 Forum Testing Most Active @surfer09 last edited by
                Das habe ich schon lange so bei mir.
                • surfer09
                  surfer09 @arteck last edited by
                  @arteck Ne, der Dienst ist nur einmal da und der startet auch nicht verzögert...
                  • surfer09
                    surfer09 @sigi234 last edited by
                    @sigi234 Okay, dann ist das vielleicht auch normal, wenn du das auch hast. Ich dachte erst bei meiner Installation sei irgendwas krumm. Aber wenn ich das jetzt lese, bin ich irgendwie beruhigter 🙂
