    4. Iobroker - Update / Adapter installieren (Fertig Images)
    • N
      noxx last edited by
      Hallo
      ich nutze gerade das fertig Image von iOBroker (14.05)
      Wollte gerade einen Adapter installieren, bekomme aber einen Fehler.
      Images und ioBroker habe ich über die Konsole inzwischen upgedatet, Fehler bleibt.
      $ ./iobroker add rflink
      host.ioBroker-RasPi install adapter rflink
      npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.rflink"
      node-pre-gyp
       ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v48-linux-arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@6.10.3 (node-v48 ABI) (falling back to source compile with node-gyp)
      gyp
      WARN
      EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.10.3"
      gyp
      WARN
      EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/.node-gyp"
      make: *** No rule to make target '../.node-gyp/6.10.3/include/node/common.gypi', needed by 'Makefile'.  Schluss.
      gyp
      ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/opt/iobroker/node_modules/npm/node_modules/node-gyp/lib/build.js:285:23)gyp ERR! stack     at emitTwo (events.js:106:13)
      gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
      gyp
       ERR!
       System Linux 4.9.24-v7+gyp ERR!
      command
       "/usr/bin/nodejs" "/opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/build/Release"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport
      gyp ERR! node -v v6.10.3
      gyp ERR! node-gyp -v v3.6.0
      gyp ERR! not ok
      node-pre-gyp ERR! build error
      node-pre-gyp
      ERR!
       stack Error: Failed to execute '/usr/bin/nodejs /opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/build/Release' (1)
      node-pre-gyp ERR! stack     at ChildProcess. <anonymous>(/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp
      ERR!
      stack     at emitTwo (events.js:106:13)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
      node-pre-gyp
      ERR! stack     at maybeClose (internal/child_process.js:886:16)node-pre-gyp
       ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
      node-pre-gyp ERR! System Linux 4.9.24-v7+node-pre-gyp ERR! command "/usr/bin/nodejs" "/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
      node-pre-gyp ERR! cwd /opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport
      node-pre-gyp ERR! node -v v6.10.3
      node-pre-gyp ERR! node-pre-gyp -v v0.6.32
      node-pre-gyp ERR! not ok</anonymous>
      • kmxak
        schau mal hier:
        http://forum.iobroker.net/viewtopic.php?t=6572
