    2. English
    3. ioBroker general
    4. Shelly doesn't connect to ioBroker anymore
    • Alexandra
      Alexandra last edited by
      Hello everyone!
      I just started using ioBroker and Shelly recently and I thought that maybe more experienced people could help me. I am using a Raspberry Pi 4 Model B and Shelly Plus 1PM and the Shelly doesn't connect to ioBroker anymore. Just earlier today it worked, because I tested turning it off and on from Vis, but after that I installed InfluxDB and Grafana. Everything went well as I connected everything together and the shelly was still displaying the data, but then I enabled Influx on the datapoints I wanted to make a graph with, I selected them in the Data Explorer from Influx and submitted them and after that the Shelly was not working anymore. Does Influx have anything to do with that or was it just bad timing?
      Shelly is connected to the same wi-fi as the Raspberry, MQTT is enabled and configured correctly for the shelly as well as in the shelly adapter for ioBroker.
      Thank you! 😁
        Homoran Global Moderator Administrators @Alexandra last edited by
        @alexandra sagte in Shelly doesn't connect to ioBroker anymore:
        guess so!
        unfortunately I do not work with any of your components. So I cannot help you. sorry
        Alexandra 1 Reply Last reply Reply Quote 0
        • Alexandra
          Alexandra @Homoran last edited by
          @homoran Thank you anyway!
