    4. (Gelöst) OpenHab : Adapter crash bei aenderung einen dimm wertes
    • Dutchman
      In OpenHab habe ich ein item dimmer, dieses laesst sich auch steuern.
      Aenderungen der werten in OpenHab kommen im iobroker an, aenderen das wertes laesst den adapater crashes.
      Nach adapter neustart wird dan wieder der wert aus OpenHab uebernommen:
      Debug log:
      openhab.0	2017-07-03 09:51:12.764	debug	inMem message openhab.0.* openhab.0.items.Dimmer_Test val=0, ack=true, ts=1499068241521, q=64, from=system.adapter.openhab.0, lc=1499068241494
      openhab.0	2017-07-03 09:51:12.573	debug	inMem message openhab.0.* openhab.0.info.connection val=true, ack=true, ts=1499068272566, q=0, from=system.adapter.openhab.0, lc=1499068272566
      openhab.0	2017-07-03 09:51:12.542	info	connected
      openhab.0	2017-07-03 09:51:12.507	info	starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.openhab, node: v4.8.3
      openhab.0	2017-07-03 09:51:12.479	debug	statesDB connected
      openhab.0	2017-07-03 09:51:12.446	debug	objectDB connected
      host.HomeControl	2017-07-03 09:51:11.623	info	instance system.adapter.openhab.0 started with pid 4535
      host.HomeControl	2017-07-03 09:50:41.584	info	Restart adapter system.adapter.openhab.0 because enabled
      host.HomeControl	2017-07-03 09:50:41.584	error	instance system.adapter.openhab.0 terminated with code 0 (OK)
      openhab.0	2017-07-03 09:50:41.558	info	terminating
      openhab.0	2017-07-03 09:50:41.546	debug	inMem message openhab.0.* openhab.0.info.connection val=false, ack=true, ts=1499068241539, q=0, from=system.adapter.openhab.0, lc=1499068241539
      openhab.0	2017-07-03 09:50:41.540	debug	inMem message openhab.0.* openhab.0.items.Dimmer_Test val=10, ack=true, ts=1499068241521, q=64, from=system.adapter.openhab.0, lc=1499068241494
      openhab.0	2017-07-03 09:50:41.537	info	cleaned everything up...
      openhab.0	2017-07-03 09:50:41.536	error	at processImmediate [as _immediateCallback] (timers.js:396:17)
      openhab.0	2017-07-03 09:50:41.536	error	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.openhab/node_modules/request/request.js:581:7)
      openhab.0	2017-07-03 09:50:41.536	error	at end (/opt/iobroker/node_modules/iobroker.openhab/node_modules/request/request.js:552:18)
      openhab.0	2017-07-03 09:50:41.536	error	at Request.write (/opt/iobroker/node_modules/iobroker.openhab/node_modules/request/request.js:1514:27)
      openhab.0	2017-07-03 09:50:41.536	error	at ClientRequest.OutgoingMessage.write (_http_outgoing.js:459:11)
      openhab.0	2017-07-03 09:50:41.536	error	TypeError: first argument must be a string or Buffer
      openhab.0	2017-07-03 09:50:41.533	error	uncaught exception: first argument must be a string or Buffer
      openhab.0	2017-07-03 09:50:41.518	warn	Cannot write "openhab.0.items.Dimmer_Test": Error: Argument error, options.body.
      openhab.0	2017-07-03 09:50:41.509	debug	http://192.168.1.243:8080/rest/items/Dimmer_Test
      openhab.0	2017-07-03 09:50:41.506	debug	inMem message openhab.0.* openhab.0.items.Dimmer_Test val=10, ack=false, ts=1499068241494, q=0, from=system.adapter.admin.0, lc=1499068241494
      openhab.0	2017-07-03 09:50:02.701	debug	inMem message openhab.0.* openhab.0.info.connection val=true, ack=true, ts=1499068202691, q=0, from=system.adapter.openhab.0, lc=1499068202691
      openhab.0	2017-07-03 09:50:02.690	info	connected
      openhab.0	2017-07-03 09:50:02.419	info	starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.openhab, node: v4.8.3
      openhab.0	2017-07-03 09:50:02.380	debug	statesDB connected
      openhab.0	2017-07-03 09:50:02.300	debug	objectDB connected
      host.HomeControl	2017-07-03 09:50:00.419	info	instance system.adapter.openhab.0 started with pid 4501
      host.HomeControl	2017-07-03 09:49:58.197	info	instance system.adapter.openhab.0 terminated with code 0 (OK)
        @Dutchman:
        Debug log:
        Bitte die Version 0.1.4 testen.
        • Dutchman
          fixed mit version 1.0.4 ! Danke dir !!!
          81.0k
