    4. [gelöst] Zigbee stürzt beim schalten ab
    • David G.
      seit heute stürzt mein Zigbee Adapter ab, sobald ich eine Birne etc schalte.
      Hatte ich so bisher noch nicht.
      Heute vormittag habe ich dem HAM Adapter installiert, kann das zusammen hängen?
      Anbei der log beim Absturz:
      zigbee.0
      2023-07-26 21:42:56.472	info	terminating
      zigbee.0
      2023-07-26 21:42:56.032	info	Zigbee: disabling joining new devices.
      zigbee.0
      2023-07-26 21:42:55.969	info	cleaned everything up...
      zigbee.0
      2023-07-26 21:42:55.937	error	Cannot read properties of undefined (reading 'Error')
      zigbee.0
      2023-07-26 21:42:55.936	error	TypeError: Cannot read properties of undefined (reading 'Error') at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) at Zigbee.filterError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:150:18) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:703:26
      zigbee.0
      2023-07-26 21:42:55.860	error	unhandled promise rejection: Cannot read properties of undefined (reading 'Error')
      zigbee.0
      2023-07-26 21:42:55.860	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      zigbee.0
      2023-07-26 21:42:55.857	error	Error 225 on send command to 0x60a423fffeed446c. Error: Error: Command 0x60a423fffeed446c/1 genOnOff.on({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:415:23) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
      Iob diag:
      *** BASE SYSTEM ***                                              Model           : Raspberry Pi 4 Model B Rev 1.2
      Architecture    : aarch64
      Docker          : false
      Virtualization  : none
      Distributor ID: Raspbian                                         Description:    Raspbian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      Systemuptime and Load:
       21:48:02 up 20 min,  2 users,  load average: 1.35, 1.71, 1.61
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=46.2'C
      volt=0.8563V
      *** Time and Time Zones ***
                     Local time: Wed 2023-07-26 21:48:02 CEST
                 Universal time: Wed 2023-07-26 19:48:02 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            3.8G        2.1G        1.0G        0.0K        707M        1.6G
      Swap:            99M          0B         99M
      Total:          3.9G        2.1G        1.1G
               3793 M total memory
               2084 M used memory
               2213 M active memory
                398 M inactive memory
               1001 M free memory
                 75 M buffer memory
                632 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4      229G   14G  207G   7% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     759M  896K  758M   1% /run
      /dev/sda1      vfat      253M   51M  202M  20% /boot
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Wed Jul 26 21:27:19 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:AC:7B:45 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=7faabd4d-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Wed Jul 26 21:27:21 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Wed Jul 26 21:27:21 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Wed Jul 26 21:27:23 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
      Show mounted filesystems (real ones only):
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      3.6G    /var/
      3.0G    /var/log
      2.9G    /var/log/journal/bd463378997f44f088b185e90db76a13
      448M    /var/lib
      Archived and active journals take up 2.8G in the file system.
      /opt/iobroker/backups:
      1.7G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      824M    /opt/iobroker/iobroker-data/
      577M    /opt/iobroker/iobroker-data/files
      149M    /opt/iobroker/iobroker-data/backup-objects
      111M    /opt/iobroker/iobroker-data/files/0_userdata.0/SqlBackup
      111M    /opt/iobroker/iobroker-data/files/0_userdata.0/SqlBackup/sql.sql
      51M     /opt/iobroker/iobroker-data/states.jsonl
      47M     /opt/iobroker/iobroker-data/objects.jsonl
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.715a7530.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.16.0
      /usr/bin/node           v18.16.0
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Installed: 18.16.0-deb-1nodesource1
        Candidate: 18.17.0-deb-1nodesource1
        Version table:
           18.17.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
       *** 18.16.0-deb-1nodesource1 100
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u4 500
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      MULTIHOSTSERVICE/enabled: false
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.7
      javascript:     7.0.3
      Adapters from github:   16
      Adapter State
      + system.adapter.accuweather.0            : accuweather           : pi                                       -  enabled
      + system.adapter.adb.0                    : adb                   : pi                                       -  enabled
      + system.adapter.admin.0                  : admin                 : pi                                       -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        system.adapter.alexa2.0                 : alexa2                : pi                                       - disabled
        system.adapter.alias-manager.0          : alias-manager         : pi                                       - disabled
      + system.adapter.backitup.0               : backitup              : pi                                       -  enabled
        system.adapter.birthdays.0              : birthdays             : pi                                       -  enabled
        system.adapter.bosesoundtouch.0         : bosesoundtouch        : pi                                       - disabled
        system.adapter.bring.0                  : bring                 : pi                                       - disabled
      + system.adapter.cloud.0                  : cloud                 : pi                                       -  enabled
      + system.adapter.countdown.0              : countdown             : pi                                       -  enabled
        system.adapter.daswetter.0              : daswetter             : pi                                       -  enabled
        system.adapter.daswetter.1              : daswetter             : pi                                       -  enabled
        system.adapter.device-reminder.0        : device-reminder       : pi                                       - disabled
      + system.adapter.device-watcher.0         : device-watcher        : pi                                       -  enabled
        system.adapter.devices.0                : devices               : pi                                       - disabled
        system.adapter.discovery.0              : discovery             : pi                                       - disabled
      + system.adapter.echarts.0                : echarts               : pi                                       -  enabled
      + system.adapter.email.0                  : email                 : pi                                       -  enabled
        system.adapter.feiertage.0              : feiertage             : pi                                       -  enabled
        system.adapter.flot.0                   : flot                  : pi                                       -  enabled
        system.adapter.fullybrowser.0           : fullybrowser          : pi                                       - disabled
      + system.adapter.google-sharedlocations.0 : google-sharedlocations: pi                                       -  enabled
        system.adapter.ham.0                    : ham                   : pi                                       - disabled
      + system.adapter.hm-rega.0                : hm-rega               : pi                                       -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : pi                                       -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : pi                                       -  enabled, port: 0
      + system.adapter.hmip.0                   : hmip                  : pi                                       -  enabled
        system.adapter.ical.0                   : ical                  : pi                                       -  enabled
        system.adapter.ical.1                   : ical                  : pi                                       -  enabled
        system.adapter.iceroad.0                : iceroad               : pi                                       - disabled
      + system.adapter.imap.0                   : imap                  : pi                                       -  enabled
      + system.adapter.info.0                   : info                  : pi                                       -  enabled
      + system.adapter.iot.0                    : iot                   : pi                                       -  enabled
      + system.adapter.javascript.0             : javascript            : pi                                       -  enabled
      + system.adapter.linux-control.0          : linux-control         : pi                                       -  enabled
        system.adapter.logparser.0              : logparser             : pi                                       - disabled
      + system.adapter.lovelace.0               : lovelace              : pi                                       -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
      + system.adapter.lovelace.1               : lovelace              : pi                                       -  enabled, port: 8092, bind: 0.0.0.0, run as: admin
        system.adapter.lovelace.2               : lovelace              : pi                                       - disabled, port: 8093, bind: 0.0.0.0, run as: admin
      + system.adapter.mqtt.0                   : mqtt                  : pi                                       -  enabled, port: 1884, bind: 0.0.0.0
        system.adapter.mytime.0                 : mytime                : pi                                       - disabled
        system.adapter.nctalk.0                 : nctalk                : pi                                       - disabled, port: 443  system.adapter.net-tools.0              : net-tools             : pi                                       - disabled
        system.adapter.nina.0                   : nina                  : pi                                       - disabled
        system.adapter.notification-manager.0   : notification-manager  : pi                                       - disabled
      + system.adapter.nut.0                    : nut                   : pi                                       -  enabled
        system.adapter.parcel.0                 : parcel                : pi                                       - disabled
        system.adapter.parcel.1                 : parcel                : pi                                       - disabled
        system.adapter.parser.0                 : parser                : pi                                       - disabled
      + system.adapter.ping.0                   : ping                  : pi                                       -  enabled
      + system.adapter.places.0                 : places                : pi                                       -  enabled
        system.adapter.proxy.0                  : proxy                 : pi                                       -  enabled
        system.adapter.pushover.0               : pushover              : pi                                       - disabled
        system.adapter.rest-api.0               : rest-api              : pi                                       - disabled, port: 8093, bind: 0.0.0.0, run as: admin
        system.adapter.roborock.0               : roborock              : pi                                       - disabled
        system.adapter.rpi2.0                   : rpi2                  : pi                                       - disabled
        system.adapter.sayit.0                  : sayit                 : pi                                       - disabled, port: 0
      + system.adapter.shelly.0                 : shelly                : pi                                       -  enabled, port: 1888, bind: 192.168.99.33
      + system.adapter.simple-api.0             : simple-api            : pi                                       -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : pi                                       -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sony-bravia.0            : sony-bravia           : pi                                       -  enabled
      + system.adapter.sourceanalytix.0         : sourceanalytix        : pi                                       -  enabled
      + system.adapter.sql.0                    : sql                   : pi                                       -  enabled, port: 0
      + system.adapter.tankerkoenig.0           : tankerkoenig          : pi                                       -  enabled
        system.adapter.telegram-menu.0          : telegram-menu         : pi                                       - disabled
      + system.adapter.telegram.0               : telegram              : pi                                       -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.telegram.1               : telegram              : pi                                       - disabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : pi                                       -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : pi                                       -  enabled
        system.adapter.tvspielfilm.0            : tvspielfilm           : pi                                       - disabled
      + system.adapter.upnp.0                   : upnp                  : pi                                       -  enabled
        system.adapter.vis.0                    : vis                   : pi                                       -  enabled
        system.adapter.vw-connect.0             : vw-connect            : pi                                       - disabled
      + system.adapter.web.0                    : web                   : pi                                       -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.web.1                    : web                   : pi                                       -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
        system.adapter.webcal.0                 : webcal                : pi                                       - disabled
        system.adapter.windows-control.0        : windows-control       : pi                                       - disabled
      + system.adapter.wireguard.0              : wireguard             : pi                                       -  enabled
      + system.adapter.zigbee.0                 : zigbee                : pi                                       -  enabled, port: /dev/ttyUSB0
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Installed ioBroker-Instances
      Adapter    "accuweather"  : 1.2.4    , installed 1.2.4
      Adapter    "adb"          : 0.0.7    , installed 0.0.7
      Adapter    "admin"        : 6.3.5    , installed 6.3.7
      Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
      Adapter    "alias-manager": 1.2.4    , installed 1.2.4
      Adapter    "backitup"     : 2.6.23   , installed 2.6.23
      Adapter    "birthdays"    : 2.3.1    , installed 2.3.1
      Adapter    "bosesoundtouch": 0.10.3  , installed 0.10.3
      Adapter    "bring"        : 1.8.1    , installed 1.8.1
      Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
      Adapter    "countdown"    : 2.0.1    , installed 2.0.1
      Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
      Adapter    "device-reminder": 1.2.9  , installed 1.2.9
      Adapter    "device-watcher": 2.9.2   , installed 2.9.1  [Updatable]
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Adapter    "echarts"      : 1.5.1    , installed 1.5.1
      Adapter    "email"        : 1.2.0    , installed 1.2.0
      Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
      Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
      Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
      Adapter    "hmip"         : 1.20.0   , installed 1.20.0
      Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
      Adapter    "info"         : 1.9.26   , installed 1.9.26
      Adapter    "iot"          : 1.14.5   , installed 2.0.0
      Adapter    "javascript"   : 7.0.3    , installed 7.0.3
      Controller "js-controller": 4.0.24   , installed 4.0.24
      Adapter    "linux-control": 1.1.3    , installed 1.1.5
      Adapter    "logparser"    : 2.2.0    , installed 2.2.0
      Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "operating-hours": 1.0.4  , installed 1.0.4
      Adapter    "parcel"       : 0.0.27   , installed 0.0.27
      Adapter    "parser"       : 1.3.2    , installed 1.3.2
      Adapter    "ping"         : 1.5.3    , installed 1.5.3
      Adapter    "places"       : 1.1.2    , installed 1.1.2
      Adapter    "proxy"        : 1.3.2    , installed 1.3.2
      Adapter    "puppeteer"    : 0.2.7    , installed 0.2.7
      Adapter    "pushover"     : 3.0.3    , installed 3.0.3
      Adapter    "rest-api"     : 1.1.0    , installed 1.1.0
      Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
      Adapter    "shelly"       : 6.4.1    , installed 6.4.1
      Adapter    "socketio"     : 4.2.0    , installed 4.2.0
      Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
      Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.9
      Adapter    "sql"          : 2.2.0    , installed 2.2.0
      Adapter    "telegram"     : 1.16.0   , installed 1.16.0
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.4
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
      Adapter    "web"          : 4.3.0    , installed 4.3.0
      Adapter    "windows-control": 0.1.5  , installed 0.1.5
      Adapter    "wireguard"    : 1.3.1    , installed 1.5.0
      Adapter    "ws"           : 1.3.0    , installed 1.3.0
      Adapter    "zigbee"       : 1.8.16   , installed 1.8.16
      Objects and States
      Objects:        27357
      States:         25287
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InReleaseHit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
      Hit:4 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
      Reading package lists...
      Pending Updates: 1
      *** Listening Ports ***
      tcp        0      0 192.168.99.33:42010     0.0.0.0:*               LISTEN      1001       17111      1141/io.hm-rpc.0
      tcp        0      0 192.168.99.33:3493      0.0.0.0:*               LISTEN      0          15127      1075/upsd
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16561      542/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15523      542/iobroker.js-con
      tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1001       20532      1505/adb
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       17985      1325/io.mqtt.0
      tcp        0      0 192.168.99.33:1888      0.0.0.0:*               LISTEN      1001       17274      1226/io.shelly.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       17893      1233/io.sonoff.0
      tcp        0      0 192.168.99.33:49292     0.0.0.0:*               LISTEN      1001       17133      1143/io.hm-rpc.1
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14737      574/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:3493          0.0.0.0:*               LISTEN      0          15128      1075/upsd
      tcp6       0      0 :::3306                 :::*                    LISTEN      109        831        633/mariadbd
      tcp6       0      0 :::8092                 :::*                    LISTEN      1001       22006      1664/io.lovelace.1
      tcp6       0      0 :::8091                 :::*                    LISTEN      1001       19064      1647/io.lovelace.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       21546      1672/io.simple-api.
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16719      966/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22811      2016/io.web.0
      tcp6       0      0 :::8083                 :::*                    LISTEN      1001       22349      2030/io.web.1
      tcp6       0      0 :::8000                 :::*                    LISTEN      1001       27406      2086/io.upnp.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14739      574/sshd: /usr/sbin
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       24893      2086/io.upnp.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       24892      2086/io.upnp.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12157      870/dhcpcd
      udp        0      0 0.0.0.0:59682           0.0.0.0:*                           1001       23821      2086/io.upnp.0
      udp        0      0 0.0.0.0:51820           0.0.0.0:*                           0          15004      -
      udp        0      0 0.0.0.0:43871           0.0.0.0:*                           108        14592      400/avahi-daemon: r
      udp        0      0 0.0.0.0:37783           0.0.0.0:*                           1001       23820      2086/io.upnp.0
      udp        0      0 10.137.192.1:5353       0.0.0.0:*                           1001       17365      1263/io.tr-064.0
      udp        0      0 192.168.99.33:5353      0.0.0.0:*                           1001       17364      1263/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14590      400/avahi-daemon: r
      udp6       0      0 :::34969                :::*                                108        14593      400/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          12170      870/dhcpcd
      udp6       0      0 :::51820                :::*                                0          15005      -
      udp6       0      0 :::5353                 :::*                                108        14591      400/avahi-daemon: r
        Thomas Braun Most Active @David G. last edited by
        @david-g
        Sentry für die Instanz ausgeschaltet?
          @david-g sagte in Zigbee stürzt. Rom schalten ab:
          Und die alpha-testest du alle?
          • David G.
            David G. @Thomas Braun last edited by David G.
            @thomas-braun sagte in Zigbee stürzt beim schalten ab:
            Hab ich gerade deaktiviert.
            Adapter bleibt nun grün, jedoch schaltet kein Gerät.
            Es kommt immer:
            zigbee.0
            2023-07-26 21:59:02.505	error	Error 225 on send command to 0x60a423fffeed446c. Error: Error: Command 0x60a423fffeed446c/1 genOnOff.off({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:336:23) at async Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/queue.js:19:32)
            In der Tat.
            Gibt ja so die üblichen.
            MyTime, Roborock etc.
            Alles Adapter die noch nicht im offiziellen Repro sind.
            (Wobei ich ehrlich gesagt spontan nicht wüsste, welche es alle sind. Laufen alle schon Ewigkeiten)
            • David G.
              Habs wieder am laufen.
              Es war garnichts Softwaretechnisches.
              Ich habe meine Fritzbox und den Zigbee Stick neu positioniert.
              Habe heute ein Update auf der FritzBox durchgeführt.
              Evtl hat die den Kanal geändert, was an der Sendeleistung geschraubt oder sonst was.....
