    4. Installation
    5. Sonoff Zigbee Stick unter Proxmox läuft nicht
      Pert last edited by Pert
      ich möchte von einer Raspi-Installation auf einen Proxmox Container wechseln.
      Leider funktioniert die Anbindung eines Sonoff Zigbee 3.0 Sticks nicht fehlerfrei.
      USB wird durchgereicht und die Rechte scheinen zu stimmen:
      root@iobroker:~# ls -l /dev/ttyUSB0
      crw-rw-rw- 1 nobody nogroup 188, 0 Aug  1 12:36 /dev/ttyUSB0
      Es kommt aber leider immer zu folgender Fehlermeldung:
      host.iobroker
      2023-08-01 12:36:59.177	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.iobroker
      2023-08-01 12:36:59.177	error	Caught by controller[0]: at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30)
      host.iobroker
      2023-08-01 12:36:59.177	error	Caught by controller[0]: at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32)
      host.iobroker
      2023-08-01 12:36:59.177	error	Caught by controller[0]: at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1)
      host.iobroker
      2023-08-01 12:36:59.177	error	Caught by controller[0]: at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1)
      host.iobroker
      2023-08-01 12:36:59.177	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56
      host.iobroker
      2023-08-01 12:36:59.177	error	Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'Error')
      host.iobroker
      2023-08-01 12:36:59.177	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      zigbee.0
      2023-08-01 12:36:58.653	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      zigbee.0
      2023-08-01 12:36:58.652	info	terminating
      zigbee.0
      2023-08-01 12:36:58.152	info	Zigbee: disabling joining new devices.
      zigbee.0
      2023-08-01 12:36:58.151	info	cleaned everything up...
      zigbee.0
      2023-08-01 12:36:58.010	error	Cannot read properties of undefined (reading 'Error')
      zigbee.0
      2023-08-01 12:36:58.010	error	TypeError: Cannot read properties of undefined (reading 'Error') at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 at Hub.configureScope (/opt/iobroker/node_modules/@sentry/src/hub.ts:340:1) at Object.configureScope (/opt/iobroker/node_modules/@sentry/src/exports.ts:76:1) at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) at Zigbee.onZigbeeAdapterReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:415:30)
      zigbee.0
      2023-08-01 12:36:57.996	error	unhandled promise rejection: Cannot read properties of undefined (reading 'Error')
      zigbee.0
      2023-08-01 12:36:57.996	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      zigbee.0
      2023-08-01 12:36:57.995	error	Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms
      zigbee.0
      2023-08-01 12:36:57.993	info	Zigbee started
      Interessanterweise funktionert der Stick auf dem Raspi mit der gleichen Zigbee Adapter Konfiguration tadellos.
      Hat jemand eine Idee?
      Pert
      Thomas Braun crunchip arteck 3 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Pert last edited by
        @pert sagte in Sonoff Zigbee Stick unter Proxmox läuft nicht:
        Dann mach es gleich richtig, root login ist jedenfalls auch im Container falsch.
        • crunchip
          crunchip Forum Testing Most Active @Pert last edited by
          @pert schau in die Doku, da ist es beschrieben
            arteck Developer Most Active @Pert last edited by
            installier die GIT version
