    4. Fehler /usr/lib/node_modules/npm/lib/cli.js:35 info-Adapter
      Bender275 last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi4
      Arbeitsspeicher: 8GB
      Festplattenart: SSD
      Betriebssystem: Ubuntu
      Node-Version: 18.17
      Nodejs-Version: 18.17
      NPM-Version: nicht auslesbar...
      Installationsart: Skript
      Image genutzt: JNein
      ich machte das normale Raspi-Update, bei dem Das Update von Node.js von 18.16.1 auf 18.17 durchgeführt wurde.
      Lief soweit alles einwandfrei, danach mag der Info-Adapter aber nicht mehr:
      host.Raspi4
      	2023-08-02 10:22:28.566	info	Restart adapter system.adapter.info.0 because enabled
      host.Raspi4
      	2023-08-02 10:22:28.566	error	instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.Raspi4
      	2023-08-02 10:22:28.566	error	Caught by controller[1]: Node.js v18.17.0
      host.Raspi4
      	2023-08-02 10:22:28.566	error	Caught by controller[1]: at node:internal/main/run_main_module:23:47
      host.Raspi4
      	2023-08-02 10:22:28.566	error	Caught by controller[1]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
      host.Raspi4
      	2023-08-02 10:22:28.565	error	Caught by controller[1]: at Module._load (node:internal/modules/cjs/loader:960:12)
      host.Raspi4
      	2023-08-02 10:22:28.565	error	Caught by controller[1]: at Module.load (node:internal/modules/cjs/loader:1119:32)
      host.Raspi4
      	2023-08-02 10:22:28.565	error	Caught by controller[1]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
      host.Raspi4
      	2023-08-02 10:22:28.565	error	Caught by controller[1]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
      host.Raspi4
      	2023-08-02 10:22:28.565	error	Caught by controller[1]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.info/main.js:58:18)
      host.Raspi4
      	2023-08-02 10:22:28.565	error	Caught by controller[1]: at getSystemVersions (/opt/iobroker/node_modules/iobroker.info/main.js:89:11)
      host.Raspi4
      	2023-08-02 10:22:28.565	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'log')
      host.Raspi4
      	2023-08-02 10:22:28.564	error	Caught by controller[1]: ^
      host.Raspi4
      	2023-08-02 10:22:28.564	error	Caught by controller[1]: adapter.log.error("Could not check npm version: " + e);
      host.Raspi4
      	2023-08-02 10:22:28.564	error	Caught by controller[1]: /opt/iobroker/node_modules/iobroker.info/main.js:89
      host.Raspi4
      	2023-08-02 10:22:28.564	error	Caught by controller[0]: Node.js v18.17.0
      host.Raspi4
      	2023-08-02 10:22:28.564	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
      host.Raspi4
      	2023-08-02 10:22:28.564	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
      host.Raspi4
      	2023-08-02 10:22:28.564	error	Caught by controller[0]: at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/cacache/lib/content/read.js:4:13)
      host.Raspi4
      	2023-08-02 10:22:28.563	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:110:18)
      host.Raspi4
      	2023-08-02 10:22:28.563	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
      host.Raspi4
      	2023-08-02 10:22:28.563	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
      host.Raspi4
      	2023-08-02 10:22:28.563	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
      host.Raspi4
      	2023-08-02 10:22:28.563	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
      host.Raspi4
      	2023-08-02 10:22:28.563	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
      host.Raspi4
      	2023-08-02 10:22:28.563	error	Caught by controller[0]: at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/fs-minipass/lib/index.js:136:4)
      host.Raspi4
      	2023-08-02 10:22:28.562	error	Caught by controller[0]: TypeError: Class extends value undefined is not a constructor or null
      host.Raspi4
      	2023-08-02 10:22:28.562	error	Caught by controller[0]: ^
      host.Raspi4
      	2023-08-02 10:22:28.562	error	Caught by controller[0]: throw err
      host.Raspi4
      	2023-08-02 10:22:28.562	error	Caught by controller[0]: /usr/lib/node_modules/npm/lib/cli.js:35
      host.Raspi4
      	2023-08-02 10:22:25.704	info	instance system.adapter.info.0 started with pid 2616
      Die anderen Instanzen laufen einwandfrei. Die NPM-Version kann nicht mehr angezeigt werden.
      iob diag:
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Model		: Raspberry Pi 4 Model B Rev 1.4
      Architecture    : aarch64
      Docker          : false
      Virtualization  : none
      Distributor ID:	Raspbian
      Description:	Raspbian GNU/Linux 11 (bullseye)
      Release:	11
      Codename:	bullseye
      PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      Systemuptime and Load:
       10:22:47 up 9 min,  0 users,  load average: 1.89, 1.64, 0.98
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=54.0'C
      volt=0.8600V
      *** Time and Time Zones ***
                     Local time: Wed 2023-08-02 10:22:47 CEST
                 Universal time: Wed 2023-08-02 08:22:47 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server: 	true
      Desktop: 	LXDE-pi
      Terminal: 	x11
      Boot Target: 	graphical.target
      *** MEMORY ***
      Mem:            7.8G        1.5G        5.4G         31M        925M        6.2G
      Swap:            99M          0B         99M
      Total:          7.9G        1.5G        5.5G
               7810 M total memory
               1464 M used memory
               1854 M active memory
                382 M inactive memory
               5420 M free memory
                 94 M buffer memory
                831 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4      470G   17G  434G   4% /
      devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     3.9G  2.9M  3.9G   1% /dev/shm
      tmpfs          tmpfs     1.6G  764K  1.6G   1% /run
      /dev/sda1      vfat      253M   52M  202M  21% /boot
      tmpfs          tmpfs     782M   20K  782M   1% /run/user/1000
      [Wed Aug  2 10:13:38 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:0C:5F:3D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=5d45f9a3-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Wed Aug  2 10:13:40 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Wed Aug  2 10:13:40 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Wed Aug  2 10:13:42 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
      Show mounted filesystems (real ones only):
      TARGET                       SOURCE       FSTYPE            OPTIONS
      /                            /dev/sda2    ext4              rw,noatime
      |-/boot                      /dev/sda1    vfat              rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      `-/home/pi/thinclient_drives xrdp-chansrv fuse.xrdp-chansrv rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
      /var:
      2.9G	/var/
      1.3G	/var/log/journal/d305c1d5b0964304901f0bf58ddc9f97
      1.3G	/var/log
      943M	/var/cache
      Archived and active journals take up 1.2G in the file system.
      /opt/iobroker/backups:
      636M	/opt/iobroker/backups/
      704K	/opt/iobroker/backups/skripte
      688K	/opt/iobroker/backups/skripte/Räume
      252K	/opt/iobroker/backups/skripte/Räume/allgemein
      156K	/opt/iobroker/backups/skripte/Räume/Küche
      /opt/iobroker/iobroker-data:
      396M	/opt/iobroker/iobroker-data/
      215M	/opt/iobroker/iobroker-data/files
      127M	/opt/iobroker/iobroker-data/backup-objects
      52M	/opt/iobroker/iobroker-data/files/javascript.admin
      45M	/opt/iobroker/iobroker-data/files/devices.admin/static
      35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      27M	/opt/iobroker/iobroker-data/objects.jsonl
      19M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
      8.9M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
      8.7M	/opt/iobroker/iobroker-data/objects.json.migrated
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v18.17.0
      /usr/bin/node 		v18.17.0
          throw err
      Node.js v18.17.0
      /usr/bin/npm
          throw err
      Node.js v18.17.0
      /usr/bin/npx
          throw err
      Node.js v18.17.0
          throw err
      Node.js v18.17.0
      nodejs:
        Installed: 18.17.0-deb-1nodesource1
        Candidate: 18.17.0-deb-1nodesource1
        Version table:
       *** 18.17.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u4 500
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      MULTIHOSTSERVICE/enabled: false
      Core adapters versions
      js-controller: 	4.0.24
      admin: 		6.3.5
      javascript: 	7.0.3
          throw err
      Node.js v18.17.0
      Adapters from github: 	0
      Adapter State
      + system.adapter.admin.0                  : admin                 : Raspi4                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : Raspi4                                   -  enabled
      + system.adapter.bestway.0                : bestway               : Raspi4                                   -  enabled
      + system.adapter.bluelink.0               : bluelink              : Raspi4                                   -  enabled
      + system.adapter.cloud.0                  : cloud                 : Raspi4                                   -  enabled
        system.adapter.daswetter.0              : daswetter             : Raspi4                                   -  enabled
        system.adapter.devices.0                : devices               : Raspi4                                   -  enabled
      + system.adapter.discovery.0              : discovery             : Raspi4                                   -  enabled
        system.adapter.dwd.0                    : dwd                   : Raspi4                                   -  enabled
      + system.adapter.email.0                  : email                 : Raspi4                                   -  enabled
        system.adapter.feiertage.0              : feiertage             : Raspi4                                   -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : Raspi4                                   -  enabled
      + system.adapter.fronius-wattpilot.0      : fronius-wattpilot     : Raspi4                                   -  enabled
      + system.adapter.fronius.0                : fronius               : Raspi4                                   -  enabled
      + system.adapter.hs100.0                  : hs100                 : Raspi4                                   -  enabled
        system.adapter.info.0                   : info                  : Raspi4                                   -  enabled
      + system.adapter.iot.0                    : iot                   : Raspi4                                   -  enabled
      + system.adapter.jarvis.0                 : jarvis                : Raspi4                                   -  enabled
      + system.adapter.javascript.0             : javascript            : Raspi4                                   -  enabled
      + system.adapter.klf200.0                 : klf200                : Raspi4                                   -  enabled
      + system.adapter.lgtv.0                   : lgtv                  : Raspi4                                   -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : Raspi4                                   -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.net-tools.0              : net-tools             : Raspi4                                   -  enabled
      + system.adapter.nuki.0                   : nuki                  : Raspi4                                   -  enabled
      + system.adapter.ping.0                   : ping                  : Raspi4                                   -  enabled
      + system.adapter.sayit.0                  : sayit                 : Raspi4                                   -  enabled
      + system.adapter.sayit.1                  : sayit                 : Raspi4                                   -  enabled
      + system.adapter.sayit.2                  : sayit                 : Raspi4                                   -  enabled
      + system.adapter.scenes.0                 : scenes                : Raspi4                                   -  enabled
      + system.adapter.shelly.0                 : shelly                : Raspi4                                   -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shelly.1                 : shelly                : Raspi4                                   -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sprinklecontrol.0        : sprinklecontrol       : Raspi4                                   -  enabled
      + system.adapter.sql.0                    : sql                   : Raspi4                                   -  enabled, port: 3306
      + system.adapter.tuya.0                   : tuya                  : Raspi4                                   -  enabled
        system.adapter.vis.0                    : vis                   : Raspi4                                   -  enabled
      + system.adapter.web.0                    : web                   : Raspi4                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Installed ioBroker-Instances
      Adapter    "admin"        : 6.3.5    , installed 6.3.5
      Adapter    "backitup"     : 2.6.23   , installed 2.6.23
      Adapter    "bestway"      : 0.0.4    , installed 0.0.4
      Adapter    "bluelink"     : 2.3.2    , installed 2.3.2
      Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Adapter    "email"        : 1.2.0    , installed 1.2.0
      Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
      Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
      Adapter    "fronius"      : 1.1.3    , installed 1.1.3
      Adapter    "fronius-wattpilot": 4.6.0, installed 4.6.0
      Adapter    "hs100"        : 2.1.2    , installed 2.1.6
      Adapter    "info"         : 1.9.26   , installed 1.9.26
      Adapter    "iot"          : 1.14.5   , installed 1.14.5
      Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
      Adapter    "javascript"   : 7.0.3    , installed 7.0.3
      Controller "js-controller": 4.0.24   , installed 4.0.24
      Adapter    "klf200"       : 1.0.1    , installed 1.0.1
      Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
      Adapter    "nuki"         : 1.6.0    , installed 1.6.0
      Adapter    "ping"         : 1.5.3    , installed 1.5.3
      Adapter    "sayit"        : 3.0.5    , installed 3.0.0  [Updatable]
      Adapter    "shelly"       : 6.4.1    , installed 6.4.1
      Adapter    "socketio"     : 4.2.0    , installed 4.2.0
      Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
      Adapter    "sql"          : 2.2.0    , installed 2.2.0
      Adapter    "tuya"         : 3.14.2   , installed 3.14.2
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "web"          : 4.3.0    , installed 4.3.0
      Adapter    "ws"           : 1.3.0    , installed 1.3.0
      Objects and States
      Objects: 	8180
      States: 	6493
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       21535      1595/io.jarvis.0
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          13041      589/lighttpd
      tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        16528      557/pihole-FTL
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14246      576/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       19671      1287/io.shelly.1
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      117        14197      549/mosquitto
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14228      520/cupsd
      tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        16534      557/pihole-FTL
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15108      521/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15121      521/iobroker.js-con
      tcp6       0      0 :::80                   :::*                    LISTEN      0          13042      589/lighttpd
      tcp6       0      0 :::53                   :::*                    LISTEN      999        16530      557/pihole-FTL
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14248      576/sshd: /usr/sbin
      tcp6       0      0 ::1:3350                :::*                    LISTEN      0          14835      569/xrdp-sesman
      tcp6       0      0 :::1883                 :::*                    LISTEN      117        14198      549/mosquitto
      tcp6       0      0 :::3306                 :::*                    LISTEN      116        15838      809/mysqld
      tcp6       0      0 :::3389                 :::*                    LISTEN      115        13162      639/xrdp
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14227      520/cupsd
      tcp6       0      0 ::1:4711                :::*                    LISTEN      999        16535      557/pihole-FTL
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17848      1353/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16369      971/io.admin.0
      udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        16527      557/pihole-FTL
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13280      439/dhcpcd
      udp        0      0 0.0.0.0:57780           0.0.0.0:*                           108        12236      373/avahi-daemon: r
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14950      608/cups-browsed
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12234      373/avahi-daemon: r
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       17701      1211/io.shelly.0
      udp        0      0 0.0.0.0:47153           0.0.0.0:*                           1001       18536      1044/io.javascript.
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       17755      1274/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       17756      1274/io.tuya.0
      udp6       0      0 :::53                   :::*                                999        16529      557/pihole-FTL
      udp6       0      0 :::5353                 :::*                                108        12235      373/avahi-daemon: r
      udp6       0      0 :::48079                :::*                                108        12237      373/avahi-daemon: r
      2023-08-02 10:23:35.447  - error: host.Raspi4 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
      2023-08-02 10:23:35.447  - error: host.Raspi4 Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
      2023-08-02 10:23:35.447  - error: host.Raspi4 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
      2023-08-02 10:23:35.447  - error: host.Raspi4 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:960:12)
      2023-08-02 10:23:35.447  - error: host.Raspi4 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1143:19)
      2023-08-02 10:23:35.447  - error: host.Raspi4 Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:110:18)
      2023-08-02 10:23:35.448  - error: host.Raspi4 Caught by controller[0]:     at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/cacache/lib/content/read.js:4:13)
      2023-08-02 10:23:35.448  - error: host.Raspi4 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
      2023-08-02 10:23:35.448  - error: host.Raspi4 Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
      2023-08-02 10:23:35.448  - error: host.Raspi4 Caught by controller[0]: Node.js v18.17.0
      2023-08-02 10:23:35.448  - error: host.Raspi4 Caught by controller[0]: /opt/iobroker/node_modules/iobroker.info/main.js:89
      2023-08-02 10:23:35.448  - error: host.Raspi4 Caught by controller[0]: 		adapter.log.error("Could not check npm version: " + e);
      2023-08-02 10:23:35.449  - error: host.Raspi4 Caught by controller[0]: 		        ^
      2023-08-02 10:23:35.449  - error: host.Raspi4 Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'log')
      2023-08-02 10:23:35.449  - error: host.Raspi4 Caught by controller[0]:     at getSystemVersions (/opt/iobroker/node_modules/iobroker.info/main.js:89:11)
      2023-08-02 10:23:35.449  - error: host.Raspi4 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.info/main.js:58:18)
      2023-08-02 10:23:35.449  - error: host.Raspi4 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
      2023-08-02 10:23:35.449  - error: host.Raspi4 Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
      2023-08-02 10:23:35.450  - error: host.Raspi4 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
      2023-08-02 10:23:35.450  - error: host.Raspi4 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:960:12)
      2023-08-02 10:23:35.450  - error: host.Raspi4 Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
      2023-08-02 10:23:35.450  - error: host.Raspi4 Caught by controller[0]:     at node:internal/main/run_main_module:23:47
      2023-08-02 10:23:35.450  - error: host.Raspi4 Caught by controller[0]: Node.js v18.17.0
      2023-08-02 10:23:35.450  - error: host.Raspi4 instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2023-08-02 10:23:35.451  - info: host.Raspi4 Restart adapter system.adapter.info.0 because enabled
      Kann mir jemand helfen?
      Danke und Grüße
      Bender275
      • crunchip
        crunchip Forum Testing Most Active @Bender275 last edited by
        @bender275 probier es mit einem reinstall von nodejs
          Bender275 @crunchip last edited by
          @crunchip
          Danke, hat geholfen. Eine De- und Installation hat noch nicht gereicht.
          Ich musste
          • deinstallieren,
          • rebooten,
          • den Ordner /usr/lib/node_modules/npm löschen
          • dann installieren und wieder
          • rebooten.
          So ging es dann.
          Viele Grüße
            Thomas Braun Most Active @Bender275 last edited by
            @bender275
            Und wie schaut das nun aus in
            iob diag
            Und schalt den Desktop aus.
            • Smizi
              Smizi last edited by
              Hallo Zusammen,
              auch ich habe mal wieder ein Problem - sieht ggfs ähnlich wie oben aus.
              Der IOBroker lief jetzt echt ne ganze Zeit stabil und gut - ich war zufrieden. Jetzt ware aber 4 neue AdapterUpdates verfügbar und die gingen nicht zu installieren und irgendwie zeigt alles auf diesen NPM.
              iob diag zeigt Folgendes:
              		     v.2023-04-16
              Operatingsystem: 	Debian GNU/Linux 11 (bullseye)
              Kernel: 		6.1.21-v8+
              Installation: 		Native
              Timezone: 		Europe/Berlin (CEST, +0200)
              User-ID: 		1000
              X-Server: 		false
              Boot Target: 		multi-user.target
              Pending OS-Updates: 	1
              Pending iob updates: 	4
              Nodejs-Installation: 	/usr/bin/nodejs 	v18.17.0
                  throw err
              Node.js v18.17.0
              			/usr/bin/npm
                  throw err
              Node.js v18.17.0
              			/usr/bin/npx
              Recommended versions are nodejs 18.x.y and npm 9.x.y
              MEMORY:
              Mem:            7.8G        2.6G        289M         14M        5.0G        5.1G
              Swap:            99M        3.0M         96M
              Total:          7.9G        2.6G        386M
              Active iob-Instances: 	34
              Active repo(s): stable
              ioBroker Core: 		js-controller 		4.0.24
              			admin 			6.3.5
              ioBroker Status: 	iobroker is running on this host.
              Objects type: jsonl
              States  type: jsonl
              Objects: 		16124
              States: 		14037
              Size of iob-Database:
              24M	/opt/iobroker/iobroker-data/objects.jsonl
              4.4M	/opt/iobroker/iobroker-data/states.jsonl
              Habt ihr ne Idee, was hier schiefgelaufen ist, bestenfalls wie ich das korrigiert bekommen (habe bereits Backups zurückgespielt von vor 2 Monaten und hätte noch Ältere...).
              Selbstverständlich habe ich natürlich NIX gemacht 😬
              Liebe Grüße
              Markus
                Thomas Braun Most Active @Smizi last edited by
                @smizi sagte in Fehler /usr/lib/node_modules/npm/lib/cli.js:35 info-Adapter:
                Dein nodejs bzw. npm hat 'nen Schuß.
                apt policy nodejs
                sagt?
                Smizi 1 Reply Last reply Reply Quote 0
                • Smizi
                  Smizi @Thomas Braun last edited by
                  @thomas-braun sagte in Fehler /usr/lib/node_modules/npm/lib/cli.js:35 info-Adapter:
                  apt policy nodejs
                  das hier:
                  nodejs:
                    Candidate: 18.17.1-deb-1nodesource1
                    Version table:
                       18.17.1-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                   *** 18.17.0-deb-1nodesource1 100
                          500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                       12.22.12~dfsg-1~deb11u3 500
                          500 http://deb.debian.org/debian bullseye/main arm64 Packages
                    Thomas Braun Most Active @Smizi last edited by Thomas Braun
                    @smizi
                    iob stop
                    sudo apt update
                    sudo apt full-upgrade
                    sudo reboot
                    • Smizi
                      sudo reboot
                      Lieben Dank,
                      das hatte ich eigentlich (aus meiner Unwissenheit heraus) sogar auch schon mal gemacht, bring aber (meine ich) nix
                      pi@raspberrypi:~ $ npm -v
                          throw err
                          at require (node:internal/modules/cjs/helpers:121:18)
                      Node.js v18.17.1
                        @smizi
                        Bitte immer alles zeigen.
                        Hier wäre die Ausgabe vom 'apt full-upgrade' wichtig gewesen.
                        • Smizi
                          @thomas-braun sorry...warte...
                          • Smizi
                            Smizi @Smizi last edited by
                             sudo apt update
                            Hit:2 http://deb.debian.org/debian bullseye InRelease
                            Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                            Hit:4 http://repository.picockpit.com/raspbian bullseye InRelease
                            Hit:5 http://deb.debian.org/debian bullseye-updates InRelease
                            Get:6 https://repos.influxdata.com/debian bullseye InRelease [7,040 B]
                            Get:7 https://packages.grafana.com/oss/deb stable InRelease [5,984 B]
                            Hit:8 https://deb.nodesource.com/node_18.x bullseye InRelease
                            Err:6 https://repos.influxdata.com/debian bullseye InRelease
                              The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                            Err:7 https://packages.grafana.com/oss/deb stable InRelease
                              The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
                            Fetched 7,040 B in 2s (3,618 B/s)
                            Reading package lists... Done
                            Building dependency tree... Done
                            1 package can be upgraded. Run 'apt list --upgradable' to see it.
                            W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list.d/picockpit.list:1 and /etc/apt/sources.list.d/picockpit.list:2
                            W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/picockpit.list:1 and /etc/apt/sources.list.d/picockpit.list:2
                            W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/picockpit.list:1 and /etc/apt/sources.list.d/picockpit.list:2
                            W: Target Translations (main/i18n/Translation-en_GB) is configured multiple times in /etc/apt/sources.list.d/picockpit.list:1 and /etc/apt/sources.list.d/picockpit.list:2
                            W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/picockpit.list:1 and /etc/apt/sources.list.d/picockpit.list:2
                            N: Skipping acquire of configured file 'main/binary-arm64/Packages' as repository 'http://repository.picockpit.com/raspbian bullseye InRelease' doesn't support architecture 'arm64'
                            W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                            W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
                            W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
                            W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                            W: Some index files failed to download. They have been ignored, or old ones used instead.
                            pi@raspberrypi:~ $ sudo apt full-upgrade
                            Calculating upgrade... Done
                            The following packages will be upgraded:
                              nodejs
                            1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                            Need to get 28.1 MB of archives.
                            After this operation, 3,072 B of additional disk space will be used.
                            Do you want to continue? [Y/n] Y
                            Get:1 https://deb.nodesource.com/node_18.x bullseye/main arm64 nodejs arm64 18.17.1-deb-1nodesource1 [28.1 MB]
                            Fetched 28.1 MB in 3s (10.1 MB/s)
                            Reading changelogs... Done
                            (Reading database ... 59608 files and directories currently installed.)
                            Preparing to unpack .../nodejs_18.17.1-deb-1nodesource1_arm64.deb ...
                            Unpacking nodejs (18.17.1-deb-1nodesource1) over (18.17.0-deb-1nodesource1) ...
                            Setting up nodejs (18.17.1-deb-1nodesource1) ...
                            Processing triggers for man-db (2.9.4-2) ...
                            pi@raspberrypi:~ $
                            pi@raspberrypi:~ $ sudo reboot
                            Connection to 192.168.1.129 closed by remote host.
                            Connection to 192.168.1.129 closed.
                            Mac-mini:~ schmitzmark$ ssh pi@192.168.1.129
                            pi@192.168.1.129's password:
                            Linux raspberrypi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
                            The programs included with the Debian GNU/Linux system are free software;
                            the exact distribution terms for each program are described in the
                            individual files in /usr/share/doc/*/copyright.
                            Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                            permitted by applicable law.
                            Last login: Mon Aug 14 10:46:51 2023 from 192.168.1.10
                            Wi-Fi is currently blocked by rfkill.
                            Use raspi-config to set the country before use.
                              @smizi
                              Wassen das wieder für Chaos?
                              picockpit rauswerfen, gibt es offenbar eh nicht für arm64.
                              Mindestens aber die Doubletten in der /etc/apt/sources.list.d/picockpit.list rauskicken.
                              influxdata und grafana müssen angepackt werden. Und zwar schon seit Monaten.
                              https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
                              • Smizi
                                @thomas-braun OK, danke und kann ich gerne angehen. PiCockpit hatte ich seinerzeit mal installiert, weil der Raspi mir zu warm geworden war...InfluxDB und Grafana habe ich schon was länger nicht mehr benutzt (keine wirkliche Zeit und Motivation momentan).
                                Kannst du mir bitte sagen (bin kein Linux Experte) , wie ich das "rauskicke"? und löst das aber doch nicht wirklich das npm Thema?
                                  Komische Logik... Das Ding wird zu warm, dann werfe ich noch zusätzliche Software drauf, die die Last noch weiter hochtreibt?
                                  Dann lösch picockpit und auch die .list-Datei danach.
                                  Um influxdb und grafana musst du dich aber unabhänigig davon kümmern, ob das im Moment verwendet wird. Oder du deinstallierst auch alles dazu, auch wiederum inkl. der .list-Dateien.
                                  Nö, trägt aber auch nicht zu einem sauberen System bei. Basiert picockpit auch auf nodejs und schleppt ggf. da was eigenes an? Kann ja alles sein...
                                  • Smizi
                                    @thomas-braun OK, danke dir!
                                    piCockpit war ich bis dato auch nicht motiviert genug, das Thema zu eliminieren, aber das ist schon 1 oder 2 Jahre drauf und hat eigentlich nichts wirklich beeinflusst..., warum aber npm für mich versionslos in der Übersicht dargestellt erklärt sich mir immer noch nicht.
                                    Macht es Sinn im Backup weiter zurückzugehen (ginge bis Feb. 2023 zurück) oder hat das keine Einfluss (weiss nicht genau, was da alles ge-backupt wird).
                                    Oder hast du noch ne andere Idee, wie man das wieder hinbiegen kann?
                                    Grüßle
                                    Markus
                                      @smizi
                                      Gib mal die Langfassung von iob diag
                                      Hast du die überflüssigen Quellen dann jetzt entsorgt?
                                      • Smizi
                                        iob diag
                                        Ohh, cool, du bist noch da.
                                        jaein, ich versuche es ja, aber bin schaffs nicht, weil zu kein Linux Erfahrung (Mist!)
                                        anbei zumindest die Long-Version
                                        • Smizi
                                          iob diag
                                          Skript v.2023-04-16
                                          *** BASE SYSTEM ***
                                          Docker          : false
                                          Distributor ID:	Debian
                                          Description:	Debian GNU/Linux 11 (bullseye)
                                          Release:	11
                                          Codename:	bullseye
                                          PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                                          NAME="Debian GNU/Linux"
                                          VERSION_ID="11"
                                          ID=debian
                                          HOME_URL="https://www.debian.org/"
                                          SUPPORT_URL="https://www.debian.org/support"
                                          BUG_REPORT_URL="https://bugs.debian.org/"
                                           15:04:55 up  2:44,  1 user,  load average: 3.70, 3.98, 3.92
                                          CPU threads: 4
                                          Raspberry only:
                                          throttled=0x0
                                          temp=64.7'C
                                          volt=0.9160V
                                                         Local time: Mon 2023-08-14 15:04:56 CEST
                                                     Universal time: Mon 2023-08-14 13:04:56 UTC
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          pi
                                          /home/pi
                                          pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                          X-Server: 	false
                                          Desktop:
                                          Terminal: 	tty
                                          *** MEMORY ***
                                          Mem:            7.8G        2.6G        2.9G        4.0M        2.4G        5.1G
                                          Swap:            99M          0B         99M
                                          Total:          7.9G        2.6G        3.0G
                                                   7811 M total memory
                                                   2582 M used memory
                                                   4259 M active memory
                                                    515 M inactive memory
                                                   2863 M free memory
                                                    101 M buffer memory
                                                   2263 M swap cache
                                                     99 M total swap
                                                      0 M used swap
                                                     99 M free swap
                                          Raspberry only:
                                          oom events: 0
                                          *** FILESYSTEM ***
                                          Filesystem                     Type      Size  Used Avail Use% Mounted on
                                          /dev/root                      ext4      459G   31G  410G   7% /
                                          tmpfs                          tmpfs     3.9G  736K  3.9G   1% /dev/shm
                                          tmpfs                          tmpfs     1.6G  1.2M  1.6G   1% /run
                                          tmpfs                          tmpfs     5.0M  4.0K  5.0M   1% /run/lock
                                          /dev/sdb1                      exfat      29G   32M   29G   1% /mnt/usb0
                                          /dev/sda1                      vfat      255M   32M  224M  13% /boot
                                          //192.168.1.46/Backup/ioBroker cifs      3.5T  1.9T  1.6T  55% /opt/iobroker/backups
                                          tmpfs                          tmpfs     782M     0  782M   0% /run/user/1000
                                          [Mon Aug 14 12:20:39 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:BF:9F:66 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=6d6cae10-02 rootfstype=ext4 fsck.repair=yes rootwait
                                          [Mon Aug 14 12:20:41 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                                          [Mon Aug 14 12:20:41 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                          [Mon Aug 14 12:20:43 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                                          |-/mnt/usb0             /dev/sdb1                      exfat  rw,nosuid,nodev,noexec,relatime,fmask=0000,dmask=0000,allow_utime=0022,iocharset=utf8,errors=remount-ro
                                          |-/boot                 /dev/sda1                      vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                          `-/opt/iobroker/backups //192.168.1.46/Backup/ioBroker cifs   rw,relatime,vers=1.0,cache=strict,username=Backup,uid=1001,noforceuid,gid=1001,noforcegid,addr=192.168.1.46,soft,unix,posixpaths,serverino,mapposix,acl,rsize=1048576,wsize=1048576,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5
                                          /var:
                                          25G	/var/
                                          20G	/var/lib/influxdb/engine/data/82a2a7778d484ffc/autogen
                                          Archived and active journals take up 4.0G in the file system.
                                          2.0G	/opt/iobroker/backups/
                                          0	/opt/iobroker/backups/yahka_1.hapdata
                                          592M	/opt/iobroker/iobroker-data/
                                          418M	/opt/iobroker/iobroker-data/files
                                          129M	/opt/iobroker/iobroker-data/backup-objects
                                          88M	/opt/iobroker/iobroker-data/files/echarts.admin
                                          72M	/opt/iobroker/iobroker-data/files/telegram.admin
                                          30M	/opt/iobroker/iobroker-data/objects.jsonl
                                          23M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
                                          23M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
                                          23M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
                                          /usr/bin/nodejs 	v18.17.1
                                          /usr/bin/node 		v18.17.1
                                              throw err
                                          Node.js v18.17.1
                                          /usr/bin/npm
                                              throw err
                                          Node.js v18.17.1
                                          /usr/bin/npx
                                              throw err
                                          Node.js v18.17.1
                                              throw err
                                          Node.js v18.17.1
                                          nodejs:
                                            Installed: 18.17.1-deb-1nodesource1
                                            Version table:
                                           *** 18.17.1-deb-1nodesource1 500
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          admin: 		6.3.5
                                          javascript: 	7.0.3
                                              throw err
                                          Node.js v18.17.1
                                          Adapter State
                                          + system.adapter.alarm.0                  : alarm                 : raspberrypi                              -  enabled
                                            system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
                                          + system.adapter.bmw.0                    : bmw                   : raspberrypi                              -  enabled
                                          + system.adapter.bshb.0                   : bshb                  : raspberrypi                              -  enabled
                                            system.adapter.daswetter.0              : daswetter             : raspberrypi                              - disabled
                                          + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
                                            system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
                                            system.adapter.doorbird.0               : doorbird              : raspberrypi                              -  enabled
                                          + system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                                          + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
                                            system.adapter.envertech-pv.0           : envertech-pv          : raspberrypi                              -  enabled
                                            system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
                                          + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
                                          + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                                          + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                                            system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                                          + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                                            system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
                                          + system.adapter.mihome-vacuum.1          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
                                          + system.adapter.mihome.0                 : mihome                : raspberrypi                              -  enabled, port: 9898, bind: 0.0.0.0
                                          + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                                            system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspberrypi                              -  enabled
                                          + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
                                          + system.adapter.nuki.0                   : nuki                  : raspberrypi                              -  enabled
                                            system.adapter.oilfox.1                 : oilfox                : raspberrypi                              -  enabled
                                          + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
                                          + system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
                                          + system.adapter.pvoutputorg.0            : pvoutputorg           : raspberrypi                              -  enabled
                                          + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
                                          + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, bind: 0.0.0.0
                                            system.adapter.smartgarden.0            : smartgarden           : raspberrypi                              -  enabled
                                          + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
                                          + system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5000
                                          + system.adapter.tado.0                   : tado                  : raspberrypi                              -  enabled
                                          + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                                          + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                                            system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                                          + system.adapter.withings.0               : withings              : raspberrypi                              -  enabled
                                          + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
                                          + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                                          + instance is alive
                                          default       : http://download.iobroker.net/sources-dist.json
                                          repro         : http://iobroker.live/repo/sources-dist.json
                                          Used repository: stable
                                          Adapter    "alarm"        : 3.3.12   , installed 3.3.12
                                          Adapter    "ble"          : 0.13.4   , installed 0.13.4
                                          Adapter    "bmw"          : 2.5.7    , installed 2.5.7
                                          Adapter    "bshb"         : 0.2.4    , installed 0.2.4
                                          Adapter    "daswetter"    : 3.1.10   , installed 3.1.8  [Updatable]
                                          Adapter    "denon"        : 1.15.3   , installed 1.15.2 [Updatable]
                                          Adapter    "doorbird"     : 1.0.5    , installed 1.0.5
                                          Adapter    "echarts"      : 1.5.1    , installed 1.5.1
                                          Adapter    "envertech-pv" : 1.0.2    , installed 0.1.0-alpha.0 [Updatable]
                                          Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
                                          Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
                                          Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                                          Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
                                          Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                                          Adapter    "mihome-vacuum": 3.11.0   , installed 3.11.0
                                          Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                                          Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                                          Adapter    "oilfox"       : 4.1.2    , installed 4.1.2
                                          Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                                          Adapter    "pvforecast"   : 2.7.1    , installed 2.7.1
                                          Adapter    "pvoutputorg"  : 1.8.9    , installed 1.8.8  [Updatable]
                                          Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
                                          Adapter    "sonos"        : 2.3.1    , installed 2.3.1
                                          Adapter    "synology"     : 2.1.13   , installed 2.1.13
                                          Adapter    "tado"         : 0.4.8    , installed 0.4.8
                                          Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                                          Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                                          Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                                          Adapter    "withings"     : 0.0.13   , installed 0.0.13
                                          Adapter    "wled"         : 0.6.7    , installed 0.6.7
                                          Adapter    "yahka"        : 0.17.0   , installed 0.17.0
                                          Objects and States
                                          Objects: 	16124
                                          States: 	14042
                                          W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://repository.picockpit.com/raspbian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 778C2E78CFB9A731
                                          W: Failed to fetch http://repository.picockpit.com/raspbian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 778C2E78CFB9A731
                                          Hit:1 http://repository.picockpit.com/raspbian bullseye InRelease
                                          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                                          Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
                                          Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
                                          Hit:6 https://apt.grafana.com stable InRelease
                                          Get:7 https://repos.influxdata.com/debian bullseye InRelease [7040 B]
                                          Err:1 http://repository.picockpit.com/raspbian bullseye InRelease
                                          Err:7 https://repos.influxdata.com/debian bullseye InRelease
                                          Fetched 7040 B in 3s (2296 B/s)
                                          Pending Updates: 1
                                          tcp        0      0 127.0.0.1:1883          0.0.0.0:*               LISTEN      111        12465      540/mosquitto
                                          tcp        0      0 0.0.0.0:33695           0.0.0.0:*               LISTEN      1001       28854      1732/io.yahka.0
                                          tcp        0      0 192.168.1.129:42001     0.0.0.0:*               LISTEN      1001       14000      1011/io.hm-rpc.0
                                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15329      776/iobroker.js-con
                                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       13746      776/iobroker.js-con
                                          tcp        0      0 0.0.0.0:41185           0.0.0.0:*               LISTEN      1001       28852      1732/io.yahka.0
                                          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          15669      694/lighttpd
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12482      543/sshd: /usr/sbin
                                          tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      998        15647      637/pihole-FTL
                                          tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      998        15653      637/pihole-FTL
                                          tcp        0      0 127.0.0.1:39059         0.0.0.0:*               LISTEN      1001       30083      1732/io.yahka.0
                                          tcp        0      0 127.0.0.1:43917         0.0.0.0:*               LISTEN      1001       30078      1732/io.yahka.0
                                          tcp6       0      0 :::80                   :::*                    LISTEN      0          15670      694/lighttpd
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          12484      543/sshd: /usr/sbin
                                          tcp6       0      0 :::53                   :::*                    LISTEN      998        15649      637/pihole-FTL
                                          tcp6       0      0 ::1:4711                :::*                    LISTEN      998        15654      637/pihole-FTL
                                          tcp6       0      0 :::8086                 :::*                    LISTEN      999        12590      619/influxd
                                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       27758      1672/io.web.0
                                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15784      833/io.admin.0
                                          tcp6       0      0 :::3500                 :::*                    LISTEN      1001       16682      1134/io.sonos.0
                                          tcp6       0      0 ::1:1883                :::*                    LISTEN      111        12466      540/mosquitto
                                          tcp6       0      0 :::3000                 :::*                    LISTEN      110        15703      614/grafana-server
                                          udp        0      0 0.0.0.0:53              0.0.0.0:*                           998        15646      637/pihole-FTL
                                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15485      613/dhcpcd
                                          udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       14052      1049/io.mihome-vacu
                                          udp        0  13824 0.0.0.0:54058           0.0.0.0:*                           1001       2015355    1119/io.shelly.0
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       26484      1716/io.wled.0
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12437      396/avahi-daemon: r
                                          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       12847      1119/io.shelly.0
                                          udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       2391631    1072/io.mihome.0
                                          udp        0      0 0.0.0.0:55521           0.0.0.0:*                           108        12439      396/avahi-daemon: r
                                          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       16723      1164/io.tuya.0
                                          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       16724      1164/io.tuya.0
                                          udp6       0      0 :::53                   :::*                                998        15648      637/pihole-FTL
                                          udp6       0      0 :::45488                :::*                                108        12440      396/avahi-daemon: r
                                          udp6       0      0 :::5353                 :::*                                108        12438      396/avahi-daemon: r
                                          2023-08-14 15:06:54.622  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:121:18)
                                          2023-08-14 15:06:54.623  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/cacache/lib/content/read.js:4:13)
                                          2023-08-14 15:06:54.623  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
                                          2023-08-14 15:06:54.623  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
                                          2023-08-14 15:06:54.623  - error: host.raspberrypi Caught by controller[0]: Node.js v18.17.1
                                          2023-08-14 15:06:54.628  - error: host.raspberrypi Caught by controller[0]: /opt/iobroker/node_modules/iobroker.info/main.js:89
                                          2023-08-14 15:06:54.628  - error: host.raspberrypi Caught by controller[0]: 		adapter.log.error("Could not check npm version: " + e);
                                          2023-08-14 15:06:54.628  - error: host.raspberrypi Caught by controller[0]: 		        ^
                                          2023-08-14 15:06:54.628  - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'log')
                                          2023-08-14 15:06:54.629  - error: host.raspberrypi Caught by controller[0]:     at getSystemVersions (/opt/iobroker/node_modules/iobroker.info/main.js:89:11)
                                          2023-08-14 15:06:54.629  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.info/main.js:58:18)
                                          2023-08-14 15:06:54.629  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
                                          2023-08-14 15:06:54.629  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
                                          2023-08-14 15:06:54.629  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
                                          2023-08-14 15:06:54.629  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:960:12)
                                          2023-08-14 15:06:54.630  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                                          2023-08-14 15:06:54.630  - error: host.raspberrypi Caught by controller[0]:     at node:internal/main/run_main_module:23:47
                                          2023-08-14 15:06:54.630  - error: host.raspberrypi Caught by controller[0]: Node.js v18.17.1
                                          2023-08-14 15:06:54.630  - error: host.raspberrypi instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                          2023-08-14 15:06:54.630  - info: host.raspberrypi Restart adapter system.adapter.info.0 because enabled
                                          2023-08-14 15:07:00.974  - info: bshb.0 (1270) Check if client with identifier: ioBroker.bshb_f8e1effa-de6e-4e9f-9f4e-8447b26c0efd is already paired.
                                          2023-08-14 15:07:00.993  - info: bshb.0 (1270) Client with identifier: ioBroker.bshb_f8e1effa-de6e-4e9f-9f4e-8447b26c0efd was not paired yet.
                                          2023-08-14 15:07:00.994  - info: bshb.0 (1270) Start pairing. Activate pairing on Bosch Smart Home Controller by pressing button until flashing.
                                          2023-08-14 15:07:01.012  - warn: bshb.0 (1270) Could not pair client. Did you press the paring button? Error details: BshbError: [ERROR] error during call to BSHC:
                                          2023-08-14 15:07:01.013  - warn: bshb.0 (1270) Could not pair client. Did you press the paring button on Bosch Smart Home Controller? Error details: BshbError: [ERROR] error during call to BSHC:
                                            @smizi
                                            Spricht dein gemountetes NAS wirklich nur CIFS v1.0?
                                            Das ist späte Kreidezeit und sollte tunlichst vermieden werden.
                                            Stell das auf das höchstmögliche Protokoll ein.
                                            sudo apt install --reinstall nodejs
                                            sagt?
                                            3466
