    4. Node-Red
    5. Auerswald API mit node-red
      fuchs1978 last edited by
      Ich musste bislang meine Telefonanlage immer umständlich mit dem Handy oder PC umstellen. Für schnell mal aus dem Haus unpraktisch. Ich habe nun den Zugriff auf die API mit node-red realisiert. Vielleicht nützlich für den einen
      ! { "id": "b58a0c9.94de77", "type": "function", "z": "3d518e20.c6acaa", "name": "Session ID", "func": "msg.payload = \"POST /login_json HTTP/1.1\\r\\nHost: 192.168.123.175\\r\\nUser-Agent: Mozilla/5.0 (Windows NT 6.1; WOW64; rv:50.0) Gecko/20100101 Firefox/50.0\\r\\nAccept: text/javascript, text/html, application/xml, text/xml, */*\\r\\nAccept-Language: de,en-US;q=0.7,en;q=0.3\\r\\nAccept-Encoding: gzip, deflate\\r\\nReferer: http://192.168.123.175/statics/page_portal.htm\\r\\nX-Requested-With: XMLHttpRequest\\r\\nX-Prototype-Version: 1.7\\r\\nContent-Type: application/x-www-form-urlencoded; charset=UTF-8\\r\\nContent-Length: 71\\r\\nConnection: keep-alive\\r\\n\\r\\nLOGIN_NOW=&eksservernumber=&eksname=&LOGIN_NAME=admin&LOGIN_PASS=111111\\r\\n\"\nreturn msg;", "outputs": 1, "noerr": 0, "x": 250, "y": 40, "wires": [ [ "e1ac8aa0.a5f5e8" ] ] }, { "id": "e1ac8aa0.a5f5e8", "type": "tcp request", "z": "3d518e20.c6acaa", "server": "192.168.123.175", "port": "80", "out": "time", "splitc": "1000", "name": "GET Portal", "x": 430, "y": 40, "wires": [ [ "33712088.9dac8" ] ] }, { "id": "33712088.9dac8", "type": "function", "z": "3d518e20.c6acaa", "name": "Antwort", "func": "var String = msg.payload.toString('utf8');\nvar Position = String.indexOf(\"AUERSessionID=\");\nvar ID = String.substr(Position+14,15);\nglobal.set(\"SessionID\",ID);\nmsg = {};\nmsg.payload = ID;\nreturn msg", "outputs": "1", "noerr": 0, "x": 600, "y": 40, "wires": [ [ "e7707375.6f7538" ] ] }, { "id": "a18c1474.2a34b8", "type": "function", "z": "3d518e20.c6acaa", "name": "Ausloggen", "func": "var ID = global.get(\"SessionID\");\nmsg.payload = \"POST /appclose HTTP/1.1\\r\\nHost: 192.168.123.175\\r\\nUser-Agent: Mozilla/5.0 (Windows NT 6.1; WOW64; rv:50.0) Gecko/20100101 Firefox/50.0\\r\\nAccept: text/javascript, text/html, application/xml, text/xml, */*\\r\\nAccept-Language: de,en-US;q=0.7,en;q=0.3\\r\\nAccept-Encoding: gzip, deflate\\r\\nReferer: http://192.168.123.175/statics/page_portal.htm\\r\\nX-Requested-With: XMLHttpRequest\\r\\nX-Prototype-Version: 1.7\\r\\nContent-Type: application/x-www-form-urlencoded; charset=UTF-8\\r\\nContent-Length: 0\\r\\nCookie: AUERSessionID=\"+ID+\"; AUERWEB_COOKIE=admin\\r\\nConnection: keep-alive\\r\\n\\r\\n\"\nreturn msg;", "outputs": 1, "noerr": 0, "x": 250, "y": 160, "wires": [ [ "eb567a90.5d013" ] ] }, { "id": "eb567a90.5d013", "type": "tcp request", "z": "3d518e20.c6acaa", "server": "192.168.123.175", "port": "80", "out": "time", "splitc": "1000", "name": "GET Portal", "x": 430, "y": 160, "wires": [ [ "2b351f8.6a13ae" ] ] }, { "id": "2b351f8.6a13ae", "type": "function", "z": "3d518e20.c6acaa", "name": "Antwort", "func": "msg.payload=msg.payload.toString('utf8')\nreturn msg;", "outputs": 1, "noerr": 0, "x": 600, "y": 160, "wires": [ [ "d03526fd.e0a41" ] ] }, { "id": "d03526fd.e0a41", "type": "debug", "z": "3d518e20.c6acaa", "name": "Ausloggen", "active": true, "console": "false", "complete": "payload", "x": 770, "y": 160, "wires": [] }, { "id": "cfb18941.485ab8", "type": "function", "z": "3d518e20.c6acaa", "name": "Umleitung AN", "func": "var ID = global.get(\"SessionID\");\nmsg.payload = \"GET /app_msn_aws_set?msnId=5610&msnTyp=0&switchOnOff=1 HTTP/1.1\\r\\nHost: 192.168.123.175\\r\\nCookie: AUERSessionID=\"+ID+\"; AUERWEB_COOKIE=admin\\r\\nConnection: keep-alive\\r\\nUpgrade-Insecure-Requests: 1\\r\\n\\r\\n\"\nreturn msg;", "outputs": 1, "noerr": 0, "x": 260, "y": 100, "wires": [ [ "7d854c6b.38d854" ] ] }, { "id": "7d854c6b.38d854", "type": "tcp request", "z": "3d518e20.c6acaa", "server": "192.168.123.175", "port": "80", "out": "time", "splitc": "1000", "name": "GET Portal", "x": 430, "y": 100, "wires": [ [ "d915774.7215d88" ] ] }, { "id": "d915774.7215d88", "type": "function", "z": "3d518e20.c6acaa", "name": "Antwort", "func": "msg.payload=msg.payload.toString('utf8')\nreturn msg;", "outputs": 1, "noerr": 0, "x": 600, "y": 100, "wires": [ [ "3a5ed3f6.35ce84" ] ] }, { "id": "3a5ed3f6.35ce84", "type": "debug", "z": "3d518e20.c6acaa", "name": "Umleitung", "active": true, "console": "false", "complete": "payload", "x": 770, "y": 100, "wires": [] }, { "id": "e7707375.6f7538", "type": "debug", "z": "3d518e20.c6acaa", "name": "AUERSessionID", "active": true, "console": "false", "complete": "payload", "x": 790, "y": 40, "wires": [] }, { "id": "aec9e6c8.ae9d98", "type": "function", "z": "3d518e20.c6acaa", "name": "Umleitung AUS", "func": "var ID = global.get(\"SessionID\");\nmsg.payload = \"GET /app_msn_aws_set?msnId=5610&msnTyp=0&switchOnOff=0 HTTP/1.1\\r\\nHost: 192.168.123.175\\r\\nCookie: AUERSessionID=\"+ID+\"; AUERWEB_COOKIE=admin\\r\\nConnection: keep-alive\\r\\nUpgrade-Insecure-Requests: 1\\r\\n\\r\\n\"\nreturn msg;", "outputs": 1, "noerr": 0, "x": 260, "y": 300, "wires": [ [ "70b50c6e.747844" ] ] }, { "id": "70b50c6e.747844", "type": "tcp request", "z": "3d518e20.c6acaa", "server": "192.168.123.175", "port": "80", "out": "time", "splitc": "1000", "name": "GET Portal", "x": 430, "y": 300, "wires": [ [ "5c4977de.6f3de8" ] ] }, { "id": "5c4977de.6f3de8", "type": "function", "z": "3d518e20.c6acaa", "name": "Antwort", "func": "msg.payload=msg.payload.toString('utf8')\nreturn msg;", "outputs": 1, "noerr": 0, "x": 600, "y": 300, "wires": [ [ "33c95ac7.804076" ] ] }, { "id": "33c95ac7.804076", "type": "debug", "z": "3d518e20.c6acaa", "name": "Umleitung", "active": true, "console": "false", "complete": "payload", "x": 770, "y": 300, "wires": [] }, { "id": "c987d40c.2a564", "type": "delay", "z": "3d518e20.c6acaa", "name": "", "pauseType": "delay", "timeout": "2", "timeoutUnits": "seconds", "rate": "1", "nbRateUnits": "1", "rateUnits": "second", "randomFirst": "1", "randomLast": "5", "randomUnits": "seconds", "drop": false, "x": 80, "y": 100, "wires": [ [ "cfb18941.485ab8" ] ] }, { "id": "2ea254ce.1a1ffc", "type": "delay", "z": "3d518e20.c6acaa", "name": "", "pauseType": "delay", "timeout": "5", "timeoutUnits": "seconds", "rate": "1", "nbRateUnits": "1", "rateUnits": "second", "randomFirst": "1", "randomLast": "5", "randomUnits": "seconds", "drop": false, "x": 80, "y": 160, "wires": [ [ "a18c1474.2a34b8" ] ] }, { "id": "632ad43b.5cd71c", "type": "function", "z": "3d518e20.c6acaa", "name": "Session ID", "func": "msg.payload = \"POST /login_json HTTP/1.1\\r\\nHost: 192.168.123.175\\r\\nUser-Agent: Mozilla/5.0 (Windows NT 6.1; WOW64; rv:50.0) Gecko/20100101 Firefox/50.0\\r\\nAccept: text/javascript, text/html, application/xml, text/xml, */*\\r\\nAccept-Language: de,en-US;q=0.7,en;q=0.3\\r\\nAccept-Encoding: gzip, deflate\\r\\nReferer: http://192.168.123.175/statics/page_portal.htm\\r\\nX-Requested-With: XMLHttpRequest\\r\\nX-Prototype-Version: 1.7\\r\\nContent-Type: application/x-www-form-urlencoded; charset=UTF-8\\r\\nContent-Length: 71\\r\\nConnection: keep-alive\\r\\n\\r\\nLOGIN_NOW=&eksservernumber=&eksname=&LOGIN_NAME=admin&LOGIN_PASS=111111\\r\\n\"\nreturn msg;", "outputs": 1, "noerr": 0, "x": 250, "y": 240, "wires": [ [ "da533816.5ad09" ] ] }, { "id": "da533816.5ad09", "type": "tcp request", "z": "3d518e20.c6acaa", "server": "192.168.123.175", "port": "80", "out": "time", "splitc": "1000", "name": "GET Portal", "x": 430, "y": 240, "wires": [ [ "883e7370.d4efe" ] ] }, { "id": "883e7370.d4efe", "type": "function", "z": "3d518e20.c6acaa", "name": "Antwort", "func": "var String = msg.payload.toString('utf8');\nvar Position = String.indexOf(\"AUERSessionID=\");\nvar ID = String.substr(Position+14,15);\nglobal.set(\"SessionID\",ID);\nmsg = {};\nmsg.payload = ID;\nreturn msg", "outputs": "1", "noerr": 0, "x": 600, "y": 240, "wires": [ [ "c35174b2.6c5858" ] ] }, { "id": "72d50e57.9fc7f", "type": "function", "z": "3d518e20.c6acaa", "name": "Ausloggen", "func": "var ID = global.get(\"SessionID\");\nmsg.payload = \"POST /appclose HTTP/1.1\\r\\nHost: 192.168.123.175\\r\\nUser-Agent: Mozilla/5.0 (Windows NT 6.1; WOW64; rv:50.0) Gecko/20100101 Firefox/50.0\\r\\nAccept: text/javascript, text/html, application/xml, text/xml, */*\\r\\nAccept-Language: de,en-US;q=0.7,en;q=0.3\\r\\nAccept-Encoding: gzip, deflate\\r\\nReferer: http://192.168.123.175/statics/page_portal.htm\\r\\nX-Requested-With: XMLHttpRequest\\r\\nX-Prototype-Version: 1.7\\r\\nContent-Type: application/x-www-form-urlencoded; charset=UTF-8\\r\\nContent-Length: 0\\r\\nCookie: AUERSessionID=\"+ID+\"; AUERWEB_COOKIE=admin\\r\\nConnection: keep-alive\\r\\n\\r\\n\"\nreturn msg;", "outputs": 1, "noerr": 0, "x": 250, "y": 360, "wires": [ [ "255f0d77.e1e64a" ] ] }, { "id": "255f0d77.e1e64a", "type": "tcp request", "z": "3d518e20.c6acaa", "server": "192.168.123.175", "port": "80", "out": "time", "splitc": "1000", "name": "GET Portal", "x": 430, "y": 360, "wires": [ [ "1f31fe5a.ecf152" ] ] }, { "id": "1f31fe5a.ecf152", "type": "function", "z": "3d518e20.c6acaa", "name": "Antwort", "func": "msg.payload=msg.payload.toString('utf8')\nreturn msg;", "outputs": 1, "noerr": 0, "x": 600, "y": 360, "wires": [ [ "3478dd2e.1d0942" ] ] }, { "id": "3478dd2e.1d0942", "type": "debug", "z": "3d518e20.c6acaa", "name": "Ausloggen", "active": true, "console": "false", "complete": "payload", "x": 770, "y": 360, "wires": [] }, { "id": "c35174b2.6c5858", "type": "debug", "z": "3d518e20.c6acaa", "name": "AUERSessionID", "active": true, "console": "false", "complete": "payload", "x": 790, "y": 240, "wires": [] }, { "id": "77487479.ad3bfc", "type": "delay", "z": "3d518e20.c6acaa", "name": "", "pauseType": "delay", "timeout": "5", "timeoutUnits": "seconds", "rate": "1", "nbRateUnits": "1", "rateUnits": "second", "randomFirst": "1", "randomLast": "5", "randomUnits": "seconds", "drop": false, "x": 80, "y": 360, "wires": [ [ "72d50e57.9fc7f" ] ] }, { "id": "a8b0a81f.1a8bb8", "type": "ioBroker in", "z": "3d518e20.c6acaa", "name": "Umleitung", "topic": "knx.0.Geräte.Steckdosen.Handysteckdose", "payloadType": "value", "onlyack": "", "func": "all", "gap": "", "x": 140, "y": 440, "wires": [ [ "41f3a5b8.cee4fc", "e5ea983e.cb02f8" ] ] }, { "id": "fd5a40ac.3559", "type": "debug", "z": "3d518e20.c6acaa", "name": "AN", "active": true, "console": "false", "complete": "payload", "x": 630, "y": 440, "wires": [] }, { "id": "41f3a5b8.cee4fc", "type": "switch", "z": "3d518e20.c6acaa", "name": "", "property": "payload", "propertyType": "msg", "rules": [ { "t": "eq", "v": "1", "vt": "str" } ], "checkall": "true", "outputs": 1, "x": 450, "y": 440, "wires": [ [ "fd5a40ac.3559", "b58a0c9.94de77", "c987d40c.2a564", "2ea254ce.1a1ffc" ] ] }, { "id": "e5ea983e.cb02f8", "type": "switch", "z": "3d518e20.c6acaa", "name": "", "property": "payload", "propertyType": "msg", "rules": [ { "t": "eq", "v": "0", "vt": "str" } ], "checkall": "true", "outputs": 1, "x": 450, "y": 500, "wires": [ [ "881e0d14.16a9c", "5b9c1036.dd2748", "632ad43b.5cd71c", "77487479.ad3bfc" ] ] }, { "id": "881e0d14.16a9c", "type": "debug", "z": "3d518e20.c6acaa", "name": "AUS", "active": true, "console": "false", "complete": "payload", "x": 630, "y": 500, "wires": [] }, { "id": "5b9c1036.dd2748", "type": "delay", "z": "3d518e20.c6acaa", "name": "", "pauseType": "delay", "timeout": "2", "timeoutUnits": "seconds", "rate": "1", "nbRateUnits": "1", "rateUnits": "second", "randomFirst": "1", "randomLast": "5", "randomUnits": "seconds", "drop": false, "x": 80, "y": 300, "wires": [ [ "aec9e6c8.ae9d98" ] ] } !
      Edit by Dutchman 05-07: Code in code block gesetz zur besseren erkennbarkeit
      • t.omalley
        t.omalley last edited by
        ICH BIN BEGEISTERT!!!
        Wir sind Auerswald Premium Partner und das ist für mich ein echter Mehrwert, den ich damit erzielen kann. Als erstes werde ich die Echtzeit-Anzeige der Amtsbelegung an unserem Zentralen-Monitor realisieren. Die Funktionstasten sind mir dazu zu ungenau. Über die SQL-History/Flow kann ich damit dann die Auslastung der Ämter zeitabhängig darstellen! Das ist ein Feature, das ich ansonsten nur mit sauteurer CTI-Anbindung und Auswertesoftware erzielt hätte.
        Danke für den Ansatz und die Arbeit, die uns hier ordentlich weiterbringt beim Ausbau unserer Sonderlösungen.
        T.Omalley
          Schön das es gefällt. Es wäre schön, wenn ihr auch euren Code veröffentlicht. Oder vielleicht erstellt ihr ja einen eigenen Adapter. Dafür reichte es bei mir leider nicht 😉
          Inzwischen habe ich noch die verpassten Anrufe auf dem ioBroker.
            joesilver9 last edited by
            Könntest du deinen jetzigen Stand bitte noch mal posten?
            joesilver
              snuflex last edited by
              Ich lese mal mit. Wir sind selber im Besitz einer Auerswald Telefonanlage mit dem Modul Türöffner über das Telefon.
              Gibt es vielleicht eine Möglichkeit den Türöffner auf den iobroker zu legen ?
              Grüße. 😄
              81.1k
