    4. [gelöst] Fehler bei 'iobroker clean yes' - TypeError: undefi
      frankie last edited by
      beim Aufruf von
      iobroker clean yes
      gibt es folgende Fehlermeldung:
      root@raspberrypi:/opt/iobroker# iobroker clean
      Command "clean" clears all Objects and States. To execute it write "iobroker clean yes"
      root@raspberrypi:/opt/iobroker# iobroker clean yes
      /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:1677
              objects.destroyDB(function () {
      TypeError: undefined is not a function
          at cleanDatabase (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:1677:17)
          at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:882:21
          at Object.States.connected (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2284:70)
          at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/statesInMemClient.js:80:68)
          at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
          at Socket.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:129:10)
          at Socket.onconnect (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:308:8)
          at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:208:12)
          at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
          at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
      root@raspberrypi:/opt/iobroker#</anonymous></anonymous>
      Gibt es noch eine Einstellung, welche ich übersehen habe, oder handelt es sich um einen "echten" Fehler.
      Frank
        Es ist ein echter Fehler. Muss schauen. Danke.
          Falls du ioBroker vorher stoppst, dann kriegst diese Fehlermeldung nicht. Habe gefixt. Danke.
            @Bluefox:
            Falls du ioBroker vorher stoppst, dann kriegst diese Fehlermeldung nicht. Habe gefixt. Danke. `
            Super schnelle Antwort!!!!!!!!!!!!!!
            Wie komme ich denn Deinen Fix? Denn ich würde den Befehl "iobroker clean yes" gerne im Zusammenhang mit http://forum.iobroker.org/viewtopic.php?f=22&t=1129 testen wollen.
              cd /opt/iobroker
              npm install https://github.com/ioBroker/ioBroker.js-controller/tarball/master --production
              Du kannst aber einfach /opt/iobroker/iobroker-data Verzeichnis löschen und dann
              cd /opt/iobroker
              iobroker setup
              aufrufen.
                Habe heute nach einem erfolgreichem Update die Funktion testen können.
                Stop ioBroker first!
                root@raspberrypi:/opt/iobroker# iobroker stop
                Stopping ioBroker controller daemon...
                ioBroker controller daemon stopped.
                Deleted 219 states
                Starting node restart.js
                Restarting ioBroker...
