    4. Raspi Installation läuft nicht durch
    • E
      EkkiB last edited by
      Weil das fertige Raspi-ioBroker Image auf dem Raspi 2B mit dem OWFS-Adapter nicht funktioniert, habe ich ein "frisches" Betriebssystem abgegriffen :
      2017-06-21-raspbian-jessie.img
      Node ausgetauscht zu :
      pi@ras2:~ $ node -v
      v8.1.3
      pi@ras2:~ $ npm -v
      5.0.3
      Das Kommando "$ sudo npm install iobroker –unsafe-perm" läuft ziemlich lange, um dann so abzustürzen :
      (bekannt ?)
      Write "./iobroker start" to start the ioBroker
      : No such file or directory
      Auto-start was enabled. Write "update-rc.d -f iobroker.sh remove" to disable auto-start
      iobroker is started. Go to "http://ip-addr:8081" to open the admin UI.
      mdns@2.3.3 install /opt/iobroker/node_modules/mdns
      node-gyp rebuild
      make: Entering directory '/opt/iobroker/node_modules/mdns/build'
      CXX(target) Release/obj.target/dns_sd_bindings/src/dns_sd.o
      In file included from ../src/dns_sd.cpp:1:0:
      ../src/mdns.hpp:32:20: fatal error: dns_sd.h: No such file or directory
      #include <dns_sd.h>^
      compilation terminated.
      dns_sd_bindings.target.mk:150: recipe for target 'Release/obj.target/dns_sd_bindings/src/dns_sd.o' failed
      make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
      make: Leaving directory '/opt/iobroker/node_modules/mdns/build'
      gyp ERR! build error
      gyp ERR! stack Error: make failed with exit code: 2
      gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:258:23)
      gyp ERR! stack at emitTwo (events.js:125:13)
      gyp ERR! stack at ChildProcess.emit (events.js:213:7)
      gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:197:12)
      gyp ERR! System Linux 4.9.28-v7+
      gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/mdns
      gyp ERR! node -v v8.1.3
      gyp ERR! node-gyp -v v3.6.2
      gyp ERR! not ok
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
      npm WARN iobroker No description
      npm WARN iobroker No repository field.
      npm WARN iobroker No README data
      npm WARN iobroker No license field.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.3.3 (node_modules/mdns):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.3.3 install: node-gyp rebuild
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      • iobroker@1.0.0
      added 48 packages, removed 53 packages and updated 1 package in 765.723s
      pi@ras2:/opt/iobroker $</dns_sd.h>
      • Dutchman
        Probier Mal mit node 6 und nicht 8!
        Send from mobile device
        • E
          Auf dem fertigen Image ist ja nodejs 6.10.0
          Und da funktioniert der OWFS Adapter nicht. Deswegen der Versuch mit einer neueren Node Version.
          • Dutchman
            Dan besser da weiter troubleshooten, es ist bekannt dass node 8 noch einige Probleme verursacht node 6 ist ok für ioBroker und seine Adapter.
              tesso last edited by
              Mein System wurde mit node8 installiert und es läuft alles.
