    4. json nach iobroker übertragen
      ich hätte hier mal eine kleine herausforderung
      zur verfügung steht nur die bash
      {"health":{"status":"HEALTH_WARN","checks":{"OSD_DOWN":{"severity":"HEALTH_WARN","summary":{"message":"1 osds down","count":1},"muted":false},"OSD_HOST_DOWN":{"severity":"HEALTH_WARN","summary":{"message":"1 host (1 osds) down","count":1},"muted":false},"PG_DEGRADED":{"severity":"HEALTH_WARN","summary":{"message":"Degraded data redundancy: 6511/32556 objects degraded (19.999%), 19 pgs degraded","count":19},"muted":false}},"mutes":[]}}
      dieser string soll rüber per simpleAPI in eine Variable reingeschrieben
      sagen wir mal hier
      0_userdata.0.System.proxmox.cephJSON
      probiert es aber aus bevor ihr meint die Lösung zur haben..
      hier das Script was nicht geht
      #!/bin/bash
      iobroker_url="http://192.168.3.137:8888/set/0_userdata.0.System.proxmox.cephXML?value="
      text='{"health":{"status":"HEALTH_WARN","checks":{"OSD_DOWN":{"severity":"HEALTH_WARN","summary":{"message":"1 osds down","count":1},"muted":false},"OSD_HOST_DOWN":{"severity":"HEALTH_WARN","summary":{"message":"1 host (1 osds) down","count":1},"muted":false},"PG_DEGRADED":{"severity":"HEALTH_WARN","summary":{"message":"Degraded data redundancy: 6511/32556 objects degraded (19.999%), 19 pgs degraded","count":19},"muted":false}},"mutes":[]}}'
      url_ruber=$iobroker_url$text
      curl -X POST $url_ruber
      #curl -s $url_ruber > /dev/null 2>&1
      exit 0
      • haus-automatisierung
        haus-automatisierung Developer Most Active @arteck last edited by haus-automatisierung
        @arteck
        Mit url encoding läuft's
        http://172.16.0.51:8087/set/0_userdata.0.test?value=%7B%22health%22%3A%7B%22status%22%3A%22HEALTH_WARN%22%2C%22checks%22%3A%7B%22OSD_DOWN%22%3A%7B%22severity%22%3A%22HEALTH_WARN%22%2C%22summary%22%3A%7B%22message%22%3A%221%20osds%20down%22%2C%22count%22%3A1%7D%2C%22muted%22%3Afalse%7D%2C%22OSD_HOST_DOWN%22%3A%7B%22severity%22%3A%22HEALTH_WARN%22%2C%22summary%22%3A%7B%22message%22%3A%221%20host%20%281%20osds%29%20down%22%2C%22count%22%3A1%7D%2C%22muted%22%3Afalse%7D%2C%22PG_DEGRADED%22%3A%7B%22severity%22%3A%22HEALTH_WARN%22%2C%22summary%22%3A%7B%22message%22%3A%22Degraded%20data%20redundancy%3A%206511%2F32556%20objects%20degraded%20%2819.999%25%29%2C%2019%20pgs%20degraded%22%2C%22count%22%3A19%7D%2C%22muted%22%3Afalse%7D%7D%2C%22mutes%22%3A%5B%5D%7D%7D
          arteck Developer Most Active @haus-automatisierung last edited by arteck
          nicht einfach aufrufen.... aus der bash raus.. ich brauch es im script
            #!/bin/bash
            curl --get --data-urlencode "value=$text" http://172.16.0.51:8087/set/0_userdata.0.test
            exit 0
            EDIT: Scheinbar hat die Simple-API aber einen Bug. Zumindest werden nicht alle Zeichen korrekt dekodiert. %3A sollte eigentlich wieder ein : werden...
            Per rest-api (als Web-Plugin) läuft es jedenfalls so:
            curl --get --data-urlencode "value=$text" http://172.16.0.51:8082/rest-api/v1/state/0_userdata.0.test
              @haus-automatisierung auf die idee bin ich nicht gekomen.. guck isch mal
                @arteck Ah, wenn man es als POST-Request mit setValueFromBody macht klappts auch per simple-api
                #!/bin/bash
                curl -X POST -d "$text" http://172.16.0.51:8087/setValueFromBody/0_userdata.0.test
                exit 0
                arteck 1 Reply Last reply Reply Quote 1
                  @haus-automatisierung sagte in json nach iobroker übertragen:
                  die doku ist falsch
                  http://172.16.0.51:8087/help
                  "setValueFromBody":    http://172.16.0.51:8087/setValueFromBody?stateID1
                    @arteck Das kann sein, der Adapter wird ja auch nicht mehr so richtig gepflegt soweit ich weiß. Ich nutze zumindest nur noch rest-api.
