    4. Gelöst: radar2 Adapter läuft seit einiger Zeit auf Fehler
    • crepp1967
      crepp1967 last edited by crepp1967
                           v.2023-04-16
      Operatingsystem:        Debian GNU/Linux 10 (buster)
      Kernel:                 4.19.0-25-amd64
      Installation:           kvm
      User-ID:                1000
      X-Server:               false
      Pending OS-Updates:     0
      Pending iob updates:    1
      Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                              /usr/bin/node           v18.17.1
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:            11G        4.7G        4.7G         11M        2.3G        6.7G
      Swap:          974M          0B        974M
      Total:          12G        4.7G        5.6G
      Active iob-Instances:   41
      ioBroker Core:          js-controller           4.0.24
                              admin                   6.7.1
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : iob-test1-proxmox                        -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : iob-test1-proxmox                        -  enabled, port: 8082, bind: 192.168.1.203, run as: admin
      Objects:                26800
      States:                 24777
      Size of iob-Database:
      36M     /opt/iobroker/iobroker-data/objects.jsonl
      18M     /opt/iobroker/iobroker-data/objects.json.migrated
      18M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      16M     /opt/iobroker/iobroker-data/objects.json.broken
      111M    /opt/iobroker/iobroker-data/states.jsonl
      11M     /opt/iobroker/iobroker-data/states.json.migrated
      11M     /opt/iobroker/iobroker-data/states.json.bak.migrated
      0       /opt/iobroker/iobroker-data/states.json.broken
      Seit einiger Zeit startet der Adapter alle paar Minuten neu u. wirft diesen Fehler ins Protokoll:
      host.iob-test1-proxmox
      2023-08-10 12:47:16.184	warn	Do not restart adapter system.adapter.radar2.0 because restart loop detected
      2023-08-10 12:47:16.183	error	instance system.adapter.radar2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      radar2.0
      2023-08-10 12:47:14.586	warn	Adapter not running as root or iobroker has no sudo right, cannot use arp-scan!
      radar2.0
      2023-08-10 12:47:14.572	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      radar2.0
      2023-08-10 12:47:14.566	warn	Uncaught Exception: bind EACCES 0.0.0.0:67
      radar2.0
      2023-08-10 12:47:14.565	error	Exception-Code: EACCES: bind EACCES 0.0.0.0:67
      radar2.0
      2023-08-10 12:47:14.564	error	Error: bind EACCES 0.0.0.0:67 at node:dgram:362:20 at process.processTicksAndRejections (node:internal/process/task_queues:83:21)
      radar2.0
      2023-08-10 12:47:14.562	error	uncaught exception: bind EACCES 0.0.0.0:67
      Ich habe die hier empfohlenen Befehle ausgeführt.
      Manche bringen aber diesen Fehler bei der Ausführung:
      z.B.
      sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f which arp-scan)
      readlink: fehlender Operand
      „readlink --help“ liefert weitere Informationen.
      [sudo] Passwort für pi:
      usage: setcap [-q] [-v] (-r|-|<caps>) <filename> [ ... (-r|-|<capsN>) <filenameN> ]
       Note <filename> must be a regular (non-symlink) file.
      pi@iob-test1-proxmox:~$
      Da ich kein Linux Profi bin stehe ich auf dem Schlauch, irgend jemand eine Idee oder sehe ich den Wald vor lauter Bäumen nicht?
      Torsten
      DJMarc75 Thomas Braun 2 Replies Last reply Reply Quote 0
      • DJMarc75
        DJMarc75 @crepp1967 last edited by
        @crepp1967 sagte in radar2 Adapter läuft seit einiger Zeit auf Fehler:
        eine Idee
        Vielleicht hängt es ja mit Deiner BetatesterVersion vom AdminAdapter zusammen ?!
        crepp1967 1 Reply Last reply Reply Quote 0
          Thomas Braun Most Active @crepp1967 last edited by
          @crepp1967
          sudo -Hu iobroker which readlink arp-scan
          sagt?
          • crepp1967
            crepp1967 @DJMarc75 last edited by
            @djmarc75
            Das Problem war schon vorher.
            • crepp1967
              crepp1967 @Thomas Braun last edited by
              /usr/bin/readlink
              /usr/sbin/arp-scan
                @crepp1967
                Bitte vollständig Ein- wie Ausgaben inkl. Login prompts.
                sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f /usr/sbin/arp-scan)
                Und dein 'Buster / Debian 10' ist auch abgekündigt, installier da was lebendiges.
                • crepp1967
                  @thomas-braun sagte in radar2 Adapter läuft seit einiger Zeit auf Fehler:
                  ok - mach ich
                  Hier die Ein- u. Ausgaben:
                  pi@iob-test1-proxmox:~$ sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f /usr/sbin/arp-scan)
                  seltsam, jetzt kommt plötzlich kein Fehler mehr...
                    Der Befehl wurde ja auch leicht abgeändert... 😉
                    crepp1967 3 Replies Last reply Reply Quote 0
                    • crepp1967
                      OK, das ist mir nicht aufgefallen - jetzt kommt jedenfalls kein Fehler mehr.
                      Ich hoffe dass sich das Prob damit erledigt hat.
                      Vielen Dank für Eure Hilfe.
                      Wenn alles funktioniert werde ich den Thread auf gelöst setzen...
                      • crepp1967
                        Leider zu früh gefreut.
                        Nach dem Neustart des Servers kommt diese Protokollmeldung:
                        radar2.0
                        2023-08-10 14:23:00.882	warn	Promise failed @ 'main in /opt/iobroker/node_modules/iobroker.radar2/radar2.js @744:13; onReady in /opt/iobroker/node_modules/iobroker.radar2/fjadapter-core.js @212:3' error: Error: DB closed at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24) at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25) at ObjectsInRedisClient._getObject (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:2663:37) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:2709:33) at process.processImmediate (node:internal/timers:478:21) { [stack]: 'Error: DB closed\n' + ' at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)\n' + ' at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)\n' + ' at ObjectsInRedisClient._getObject (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:2663:37)\n' + ' at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:2709:33)\n' + ' at process.processImmediate (node:internal/timers:478:21)', [message]: 'DB closed'}
                        Aber ich benutze Redis gar nicht.
                        • crepp1967
                          Bei jedem Scan (alle 60s) kommen diese Fehlermeldungen:
                          radar2.0
                          2023-08-10 14:33:00.555	warn	redis get radar2.0.ping_AVM_ENYA._here, error - Connection is closed.
                          radar2.0
                          2023-08-10 14:33:00.554	warn	Error {} is setState for ping_AVM_ENYA._here with {"val":true,"ack":true,"from":"system.adapter.radar2.0","user":"system.user.admin"}
                          radar2.0
                          2023-08-10 14:33:00.554	warn	get state error: Connection is closed.
                          radar2.0
                          2023-08-10 14:33:00.553	warn	Could not perform strict object check of state radar2.0.ping_AVM_ENYA._here: DB closed
                          radar2.0
                          2023-08-10 14:33:00.552	warn	redis get radar2.0.ping_AVM_ENYA._here, error - Connection is closed.
                          radar2.0
                          2023-08-10 14:33:00.551	warn	redis get radar2.0.ping_AVM_ENYA, error - Connection is closed.
                          radar2.0
                          2023-08-10 14:33:00.550	warn	Error {} is setState for ping_AVM_ENYA with {"val":true,"ack":true,"from":"system.adapter.radar2.0","user":"system.user.admin"}
                          radar2.0
                          2023-08-10 14:33:00.548	warn	get state error: Connection is closed.
                          radar2.0
                          2023-08-10 14:33:00.533	warn	redis get radar2.0.ping_AVM_ENYA, error - Connection is closed.
                          radar2.0
                          2023-08-10 14:32:00.651	warn	error {} extend object radar2.0.ping_SamsungHD._whatHere
                          radar2.0
                          2023-08-10 14:32:00.645	warn	error {} extend object radar2.0.ping_SamsungHD._nHere
                          radar2.0
                          2023-08-10 14:29:00.586	warn	error {} extend object radar2.0._uIPs.192-168-1-25
                          radar2.0
                          2023-08-10 14:29:00.582	warn	redis get radar2.0._uIPs.192-168-1-24, error - Connection is closed.
                          radar2.0
                          2023-08-10 14:29:00.581	warn	Error {} is setState for radar2.0._uIPs.192-168-1-24 with {"val":"{ ipAddress: '192.168.1.24', macAddress: '98:d8:63:31:5b:46', by: 'arp', hosts: [], getMacVendor: 'Shanghai High-Flying Electronics Tech Co, Ltd'\n}","ack":true,"from":"system.adapter.radar2.0","user":"system.user.admin"}
                          • crunchip
                            crunchip Forum Testing Most Active @crepp1967 last edited by crunchip
                            bezieht sich wohl aufs interne redis was iobroker nutzt
                            eigentlich sollten die "cups" im fixer inbegriffen sein, also normal nur ein iob fix ausführen
                              Kommen alle vom Adapter. Kann ich aber nix zu sagen.
                              • crepp1967
                                Habe nun den Adapter deinstalliert u nach Reboot neu installiert.
                                Seitdem ohne Fehler...
                                Torsten
                                  @crepp1967 sagte in Gelöst: radar2 Adapter läuft seit einiger Zeit auf Fehler:
                                  Hast du auch in Zuge des Reboots dein Betriebssystem aktualisiert?
                                  • crepp1967
                                    Ja, ich habe gleich im Anschluss auf bullseye hochgezogen.
                                    Torsten
                                    364
