    4. Zigbee: TS0601_soil funktioniert, aber mit Warnings
    • Gaspode
      Gaspode last edited by Gaspode
      ich bin begeisterter Nutzer vom Zigbee Adapter von @arteck
      Funktioniert super und zuverlässig.
      Jetzt habe ich mir einen Bodenfeuchte-Sensor zugelegt: https://de.aliexpress.com/item/1005005388244280.html
      Das Pairing hat auch auf Anhieb geklappt und Feuchte und Temperatur werden mit plausiblen Werten aktualisiert. allerdings sind beim Pairing ein paar Warnings aufgetaucht, besteht da Handlungsbedarf?
      2023-08-12 10:55:05.228 - info: zigbee.0 (2228) Starting interview of '0xXXXXXXXXXXXXXXXX'
      2023-08-12 10:55:05.313 - warn: zigbee.0 (2228) Device '0xXXXXXXXXXXXXXXXX' announced itself
      2023-08-12 10:55:06.064 - error: zigbee.0 (2228) Device 0xXXXXXXXXXXXXXXXX "TS0601" not described in statesMapping.
      2023-08-12 10:55:08.474 - info: zigbee.0 (2228) Successfully interviewed '0xXXXXXXXXXXXXXXXX', device has successfully been paired
      2023-08-12 10:55:08.474 - info: zigbee.0 (2228) Device '0xXXXXXXXXXXXXXXXX' is supported, identified as: TuYa Soil sensor (TS0601_soil)
      2023-08-12 10:55:08.477 - info: zigbee.0 (2228) Configuring 0xXXXXXXXXXXXXXXXX TS0601
      2023-08-12 10:55:08.497 - warn: zigbee.0 (2228) download icon from https://www.zigbee2mqtt.io/images/devices/TS0601_soil.jpg saved into C:/ioBroker/node_modules/iobroker.zigbee/admin/img/TS0601_soil.png
      2023-08-12 10:55:08.530 - warn: zigbee.0 (2228) Object XXXXXXXXXXXXXXXX.temperature_unit is invalid: obj.common.states has an invalid type! Expected "object", received "string"
      2023-08-12 10:55:08.531 - warn: zigbee.0 (2228) This object will not be created in future versions. Please report this to the developer.
      2023-08-12 10:55:08.531 - warn: zigbee.0 (2228) Object XXXXXXXXXXXXXXXX.battery_state is invalid: obj.common.states has an invalid type! Expected "object", received "string"
      2023-08-12 10:55:08.573 - warn: zigbee.0 (2228) Object zigbee.0.XXXXXXXXXXXXXXXX.temperature_unit is invalid: obj.common.states has an invalid type! Expected "object", received "string"
      2023-08-12 10:55:08.573 - warn: zigbee.0 (2228) This object will not be created in future versions. Please report this to the developer.
      2023-08-12 10:55:08.573 - warn: zigbee.0 (2228) Object zigbee.0.XXXXXXXXXXXXXXXX.battery_state is invalid: obj.common.states has an invalid type! Expected "object", received "string"
      2023-08-12 10:55:08.850 - info: zigbee.0 (2228) DeviceConfigure successful 0xXXXXXXXXXXXXXXXX TS0601
      2023-08-12 10:55:54.441 - info: zigbee.0 (2228) Zigbee: stop joining
      2023-08-12 10:57:19.827 - warn: zigbee.0 (2228) Device '0xXXXXXXXXXXXXXXXX' announced itself
      Ich wäre auch gerne bereit per PR mit zu helfen, aber leider fehlt mir hier eine Menge Hintergrundwissen. Ich nehme mal an, es muss hier etwas angepasst werden: tuya.ts
      Nur was und wie?
        arteck Developer Most Active @Gaspode last edited by
        @gaspode sagte in Zigbee: TS0601_soil funktioniert, aber mit Warnings:
        TS0601
        kommen die jetzt auch noch oder nur einmalig bei pairing ?
        Gaspode 2 Replies Last reply Reply Quote 0
        • Gaspode
          Gaspode @arteck last edited by
          @arteck said in Zigbee: TS0601_soil funktioniert, aber mit Warnings:
          Kamen bisher nur einmalig beim Pairing. Gerade ist mir aber aufgefallen, dass etwa ein mal am Tag diese Meldung für das Gerät auftaucht:
          2023-08-14 08:41:02.527 - warn: zigbee.0 (2228) Device '0xXXXXXXXXXXXXXXXX' announced itself
          Hat das was zu sagen?
          Ansonsten sieht der Objektbaum für das Gerät so aus:
          Und die Kachel so:
            @gaspode der meldet sich vom Netz ab.. und kommt dan weider ... warum auch immer.. manche Geräte machen das
            Gaspode 1 Reply Last reply Reply Quote 1
            • Gaspode
              Gaspode @arteck last edited by Gaspode
              Danke, also nix ungewöhnliches.
              Und es funktioniert ja alles, abgesehen von der temperature_unit und den Meldungen beim Pairing.
              • Gaspode
                @arteck
                Darf ich nochmal vorsichtig nachfragen? 🙂
                Besteht Handlungsbedarf? Kann ich was beisteuern (da bräuchte ich aber etwas Starthilfe)? Soll ich irgendwo ein Issue anlegen?
                Im Tree im Admin fehlt auch das Symbol für das Device, obwohl es auf der Kachel angezeigt wird. Hat das damit zu tun?
                  arteck Developer Most Active @Gaspode last edited by arteck
                  also
                  https://github.com/ioBroker/ioBroker.zigbee/wiki/Missing-icons-after-adatapter-Update
                  was hast du für coordinator ?? welche Fimrmwareversion ?
                  • Gaspode
                    Oh, Danke. Hatte ich übersehen. Das Symbol ist jetzt schon mal da. 🙂
                    Den hier: https://www.amazon.de/gp/product/B09KXTCMSC
                    type: zStack3x0
                    version: 2-1.2.7.1.
                    revision: 20210708
                    AtomicIX 1 Reply Last reply Reply Quote 0
                    • AtomicIX
                      AtomicIX @Gaspode last edited by
                      @arteck
                      Ich habe den selber Fühler.
                      Bei mir wird er aber gar nicht erkannt.
                      Also erkannt schon, aber nicht verbunden.
                      Hab ihn schon 2 mal gelöscht und neu gekoppelt.
                      Jedes mal das selbe. Was kann ich da noch machen.?
                      Ich nutze einen sonoff zigbee Stick.
                      type:zStack3x0
                      version:2-1.2.7.1.
                      revision:20211217
                      Der Zigbee adapter hat die Version 1.10.3
                      • Asgothian
                        Asgothian Developer @AtomicIX last edited by Asgothian
                        @atomicix
                        Versuch mal bitte die 1.10.5 von github.
                        Da sollte auch deine Variante erkannt werden.
                        A.
                        P.s. Willkommen in der Hölle von TuYa. Was gleich aussieht ist nicht gleich. Dafür sind Dinge gleich die unterschiedlich aussehen. Du hast also nicht den selben Fühler, sondern nur einen der genau so aussieht,
                        AtomicIX 1 Reply Last reply Reply Quote 2
                        • AtomicIX
                          AtomicIX @Asgothian last edited by
                          @asgothian danke, läuft. Musste das nicht einmal neu einrichten.
                            bastler @AtomicIX last edited by
                            @Asgothian Moin, grätsche mal dazwischen :-). Bei mir ist heute der gleiche Fühler aufgeschlagen. Habe ihn angemeldet bekommen, allerdings ohne irgend welche Messwerte? dcc2382d-02ea-452f-8eaa-f327919bc183-image.jpeg
                            Hinten Steht noch die Bezeichnung QT-07S.
                            Unter dem Punkt msg_from_zigbee in den Objekten gibt es diesen Eintrag
                            {"type":"commandDataReport","data":{"seq":25856,"dpValues":[{"dp":14,"datatype":4,"data":{"type":"Buffer","data":[2]}}]},"linkquality":255,"groupID":null,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":228,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
                            Nutze den Conbee2 Koordinator für meine Zigbee Geräte.
                            Gibt es eine Möglichkeit den Sensor irgendwie zum Laufen zu bekommen?
                            • Asgothian
                              Asgothian Developer @bastler last edited by
                              @bastler
                              • welche Adapter Version nutzt du ?
                              • was steht auf der „Info“ Kachel ?
                              A.
                                bastler @Asgothian last edited by
                                @asgothian Der Adapter hat die Version 1.10.3 und das steht unter Info auf der Kachel IMG_7385.jpeg
                                • Asgothian
                                  @bastler dann hast du 2 Möglichkeiten
                                  • warten
                                  • meine Test-Version von hier installieren und berichten was passiert
                                  A.
                                    @asgothian Wow er funktioniert!! Vielen Dank für deine Bemühungen!
                                    B Asgothian 2 Replies Last reply Reply Quote 0
                                      bastler @bastler last edited by
                                      @Asgothian Er sendet etwa alle 24 Minuten neue Werte.
                                      • Asgothian
                                        @bastler sagte in Zigbee: TS0601_soil funktioniert, aber mit Warnings:
                                        welche Version hast du installiert ?
                                        A.
                                          @asgothian 1.10.5 die von Github
                                            A Former User @bastler last edited by
                                            Hallo @bastler ,
                                            welche Firmware hat Dein Stick?
                                            zigbee sensor
                                            2304
