    4. accuweather stürzt permanent ab
      australien last edited by australien
      Bei mir kommt jeden Tag die Meldung, dass der accuweather Adapter nicht mehr ordentlich funktioniert.
      Das Wetter wird nur für das NSPanel benötigt und wird nur von dem NSPanel Script verwendet.
      Anbei ist das aktuelle log des Adapters
      accuweather.0
      	2023-08-23 10:51:08.590	error	Forecast cannot be retrieved. Response: 503 Unauthorized
      accuweather.0
      	2023-08-23 10:51:08.437	error	Forecast cannot be retrieved. Response: 503 Unauthorized
      accuweather.0
      	2023-08-23 10:51:08.434	error	Forecast cannot be retrieved. Response: 503 Unauthorized
      accuweather.0
      	2023-08-23 10:51:07.429	info	starting. Version 1.2.4 in /opt/iobroker/node_modules/iobroker.accuweather, node: v18.17.0, js-controller: 4.0.24
      accuweather.0
      	2023-08-23 10:51:00.216	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      accuweather.0
      	2023-08-23 10:51:00.214	info	terminating
      accuweather.0
      	2023-08-23 10:51:00.066	info	cleaned everything up...
      accuweather.0
      	2023-08-23 10:51:00.063	info	Scheduled restart.
      accuweather.0
      	2023-08-23 10:50:14.146	error	Forecast cannot be retrieved. Response: 503 Unauthorized
      accuweather.0
      	2023-08-23 10:50:14.142	error	Forecast cannot be retrieved. Response: 503 Unauthorized
      accuweather.0
      	2023-08-23 10:50:14.129	error	Forecast cannot be retrieved. Response: 503 Unauthorized
      accuweather.0
      	2023-08-23 10:50:13.072	info	starting. Version 1.2.4 in /opt/iobroker/node_modules/iobroker.accuweather, node: v18.17.0, js-controller: 4.0.24
      accuweather.0
      	2023-08-23 10:50:00.142	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      accuweather.0
      	2023-08-23 10:50:00.140	info	terminating
      accuweather.0
      	2023-08-23 10:50:00.074	info	cleaned everything up...
      accuweather.0
      	2023-08-23 10:50:00.071	info	Scheduled restart.
      accuweather.0
      	2023-08-23 10:49:08.681	error	Forecast cannot be retrieved. Response: 503 Unauthorized
      accuweather.0
      	2023-08-23 10:49:08.677	error	Forecast cannot be retrieved. Response: 503 Unauthorized
      accuweather.0
      	2023-08-23 10:49:08.675	error	Forecast cannot be retrieved. Response: 503 Unauthorized
      accuweather.0
      	2023-08-23 10:49:07.660	info	starting. Version 1.2.4 in /opt/iobroker/node_modules/iobroker.accuweather, node: v18.17.0, js-controller: 4.0.24
      accuweather.0
      	2023-08-23 10:49:00.060	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      accuweather.0
      	2023-08-23 10:49:00.057	info	terminating
      accuweather.0
      	2023-08-23 10:49:00.033	info	cleaned everything up...
      accuweather.0
      	2023-08-23 10:49:00.029	info	Scheduled restart.
        Thomas Braun Most Active @australien last edited by
        @australien sagte in accuweather stürzt permanent ab:
        Muss man sich bei accuweather einloggen?
          australien @Thomas Braun last edited by
          ich hab dort ja die Registrierung gemacht, um die API zu bekommen, hat ja lange funktioniert.
          Wenn ich den Adapter neu starte kommt ja auch wieder das neue Wetter, nur dann ist es alsbald wieder erledigt, wie wenn er zu oft abfragen würde.
            @australien
            Das ist gut möglich. Wie oft fragst du denn an?
              ticaki Developer last edited by ticaki
              Once the application is created, you will have an API key generated. For free use, it is possible to make 50 requests to API per day. It was noted that to get the API working, the following settings are preferred (please choose your country!):
              Du rufst jede Minute die Daten ab? Das sind 1440 Abfragen obwohl du nur 50 frei hast.
              @thomas-braun sagte in accuweather stürzt permanent ab:
              @australien
              Der Fehler kommt jede Minute 🙂
                so oft das NSPanel Script das macht 🤷‍♂️
                  @australien
                  Dann macht es das offenbar für accuweather zu häufig.
                    offensichtlich, aber wo kann ich das abdrehen?
                      @australien
                      Ich kenne das Skript nicht.
                        Es ist das offizielle zur Bediehnung den NSPanels (https://forum.iobroker.net/topic/58170/sonoff-nspanel-mit-lovelace-ui/3478?_=1692781736585)
                        • Marc Berg
                          Marc Berg Most Active last edited by Marc Berg
                          @australien
                          Das NSPanel greift die Daten ja nicht direkt bei Accuweather ab, sondern greift auf die bestehenden Datenpunkte zu, die der Adapter liefert. Und der Adapter aktualisiert stündlich:
                          Das bedeutet für mich, dass ein Überschreiten der 50 Abfragen per Tag nur durch ständige Adapter-Restarts erreicht werden kann.
                            australien @Marc Berg last edited by
                            @marc-berg
                            so denk ich mir das auch.
                            Ich habe jetzt den Adapter nocheinmal gelöscht und neu installiert, bis jetzt läuft es.
                            Melde mich wieder wenn es nochmals auftritt.
                            Danke einstweilen!
                            • mcm1957
                              mcm1957 @australien last edited by
                              @australien
                              Mach aber jedenfalls einen Adapter Issue auf und gibt unbedingt die im Einsatz stehenden Versionen an. (Adapter, admin, js-controller, node)
                              Der Adapter sollte keinesfalls sich so unsauber beenden das controller um Hilfe schreit.
                                australien @mcm1957 last edited by
                                @mcm57
                                mach ich, kam gerade wieder an. Ohne Eintrag ins LOG.
                                • Marc Berg
                                  Hmmm, wenn ich diesen Eintrag im Log richtig lese, scheint der Adapter über einen Cron-Eintrag ständig neu zu starten. Könnte es ein, dass du da was versehentlich aktiviert hast?
                                  • mcm1957
                                    mcm1957 @Marc Berg last edited by mcm1957
                                    @marc-berg
                                    Ich hab mal in den Adapter geschaut.
                                    Der läuft als daemon.
                                    ABER nach einem ersten Blick pollt er alle 5 Minuten 3 Datenpakete. Das geht sich nie mit 40 / Tag aus !?!?
                                    Wenn hier wer mitliest der den Adapter verwendet könnte er bitte sagen ob er bei ihm/ihr läuft und ob das mit einem kommerziellen Key oder einem "free" key ist ?
                                    • Marc Berg
                                      Marc Berg Most Active @mcm1957 last edited by Marc Berg
                                      @mcm57 sagte in accuweather stürzt permanent ab:
                                      Also ich benutze den "Free" key. Ich hatte vorhin mal das Log auf "debug" gestellt. Hier sehe ich nur stündlich einen Eintrag.
                                      accuweather.0
                                      	2023-08-23 15:02:39.861	debug	Date Wed Aug 23 2023 14:52:00 GMT+0200 (Mitteleuropäische Sommerzeit), dow: Mi
                                      accuweather.0
                                      	2023-08-23 14:02:43.323	debug	Date Wed Aug 23 2023 13:52:00 GMT+0200 (Mitteleuropäische Sommerzeit), dow: Mi
                                      accuweather.0
                                      	2023-08-23 13:02:33.927	debug	Date Wed Aug 23 2023 12:52:00 GMT+0200 (Mitteleuropäische Sommerzeit), dow: Mi
                                      accuweather.0
                                      	2023-08-23 12:02:39.410	debug	Date Wed Aug 23 2023 11:52:00 GMT+0200 (Mitteleuropäische Sommerzeit), dow: Mi
                                      accuweather.0
                                      	2023-08-23 11:07:33.450	debug	Date Wed Aug 23 2023 10:52:00 GMT+0200 (Mitteleuropäische Sommerzeit), dow: Mi
                                      Müssen die Pakete denn echte Abfragen sein?
                                      EDIT: Und um das nochmals klarzustellen: bei mir läuft der Adapter ohne Probleme.
                                      • mcm1957
                                        @marc-berg
                                        OK danke mal für die Info.
                                        Version 1.3.1 ?
                                        Marc Berg A 2 Replies Last reply Reply Quote 0
                                        • Marc Berg
                                          Version 1.3.1 ?
                                          Ja.
                                          • mcm1957
                                            @marc-berg
                                            Ok, der code ist complexer.
                                            Der Adapter scannt zwar alle 5 Minuten ABER
                                            • die 5 Tagesvorschau wir nur abgerufen wenn es zwischen 7:00 und 7:05 oder 20:00 und 20:05 ist, also 2x täglich
                                            • die current Werte werden nur jede Stunde zwischn Minute 0 un d 5 abgerufen, also 24x Tag
                                            • die 6h Vorschau wird um 0:xx, 6:xx, 12:xx, 18:xx jeweils nur wenn Minute zwischn 0 und 5 ist, abgerufen - also 4 mal
                                            macht 30 Abfragen
                                            Dazu kommen noch 3 Abfragen jedesmal wenn der Adapter startet.
                                            Damit sollte alles OK sein - außer der Adapter startet mehr als 6 mal am Tag neu.
                                            Man könnte prüfen ob man die restart polls wegläßt wenn bereits gültige Daten existieren. Hab dazu ein Issue erstellt.
                                            Was die js-controller Meldung im ersten Post betrifft: Da fehlt im Adapter definitiv ein try/catch 8Fehlerbehandlung). Hab dazu schon mal issue erstellt. Kann es aber sicher nicht in den nächsten 3 Wochen bearbeiten (Urlaub)
                                            1313
