    4. Grafana reagiert nicht mehr auf Port 3000
    • werner2000x
      werner2000x last edited by werner2000x
      |Systemdata| raspberrypi
      Plattform
      linux
      Betriebssystem
      linux
      Architektur
      arm
      CPUs
      Geschwindigkeit
      1500 MHz
      Modell
      unknown
      RAM
      7.63 GB
      System-Betriebszeit
      58 T. 03:39:14
      Node.js
      v16.20.2 (Empfohlene Version v18.17.1)
      time
      1692978529143
      timeOffset
      -120
      Anzahl der Adapter
      492
      NPM
      8.19.4
      Datenträgergröße
      116.9 GB
      freier Festplattenspeicher
      85.51 GB
      Betriebszeit
      9 T. 23:56:49
      Aktive Instanzen
      41
      Weg
      /opt/iobroker/
      Hostname
      raspberrypi
      Ro75 1 Reply Last reply Reply Quote 0
      • Ro75
        Ro75 @werner2000x last edited by Ro75
        @werner2000x
        was sagt denn
        sudo systemctl status grafana-server
        Ro75.
        werner2000x 1 Reply Last reply Reply Quote 0
        • werner2000x
          werner2000x @Ro75 last edited by werner2000x
          * grafana-server.service - Grafana instance
               Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
               Active: active (running) since Fri 2023-08-25 17:55:17 CEST; 7s ago
                 Docs: http://docs.grafana.org
             Main PID: 5812 (grafana)
                Tasks: 8 (limit: 4915)
                  CPU: 7.235s
               CGroup: /system.slice/grafana-server.service
                       `-5812 /usr/share/grafana/bin/grafana server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb cfg:default.paths.logs=/var/log/grafana cfg:defau>
          Aug 25 17:55:19 raspberrypi grafana[5812]: logger=migrator t=2023-08-25T17:55:19.010307297+02:00 level=info msg="Starting DB migrations"
          Aug 25 17:55:19 raspberrypi grafana[5812]: logger=migrator t=2023-08-25T17:55:19.078297824+02:00 level=info msg="migrations completed" performed=0 skipped=493 duration=4.953881ms
          Aug 25 17:55:19 raspberrypi grafana[5812]: logger=secrets t=2023-08-25T17:55:19.083680032+02:00 level=info msg="Envelope encryption state" enabled=true currentprovider=secretKey.v1
          Aug 25 17:55:19 raspberrypi grafana[5812]: logger=plugin.loader t=2023-08-25T17:55:19.302744623+02:00 level=warn msg="Plugin missing module.js" pluginID=input warning="Missing module.js, If you loade>
          Aug 25 17:55:19 raspberrypi grafana[5812]: logger=plugin.loader t=2023-08-25T17:55:19.302928768+02:00 level=info msg="Plugin registered" pluginID=input
          Aug 25 17:55:20 raspberrypi grafana[5812]: logger=plugin.loader t=2023-08-25T17:55:20.585287158+02:00 level=info msg="Plugin registered" pluginID=cloudspout-button-panel
          Aug 25 17:55:20 raspberrypi grafana[5812]: logger=plugin.loader t=2023-08-25T17:55:20.585597079+02:00 level=info msg="Plugin registered" pluginID=grafana-clock-panel
          Aug 25 17:55:20 raspberrypi grafana[5812]: logger=query_data t=2023-08-25T17:55:20.598718456+02:00 level=info msg="Query Service initialization"
          Aug 25 17:55:20 raspberrypi grafana[5812]: logger=live.push_http t=2023-08-25T17:55:20.611838647+02:00 level=info msg="Live Push Gateway initialization"
          Aug 25 17:55:20 raspberrypi grafana[5812]: logger=ngalert t=2023-08-25T17:55:20.743301201+02:00 level=warn msg="Unexpected number of rows updating alert configuration history" rows=0 org=1 hash=not-y>
          lines 1-20/20 (END)
          Ro75 Thomas Braun 2 Replies Last reply Reply Quote 0
          • Ro75
            @werner2000x
            schon mal
            sudo systemctl restart grafana-server
            versucht?
            • werner2000x
              @ro75 Ja, aber half nicht.
              Hatte heute ein Update von Grafana auf 10.1.0
                Thomas Braun Most Active @werner2000x last edited by
                @werner2000x
                Und wenn das wieder laufen sollte bringst du das System in Gänze auf einen aktuellen Stand. Das sieht mir nach Update-Stau aus.
                • Ro75
                  @werner2000x
                  Welches Linux läuft eigentlich bei dir?
                    @werner2000x
                    iob diag
                    in der Langfassung sagt?
                    • werner2000x
                      werner2000x @Thomas Braun last edited by werner2000x
                                           v.2023-04-16
                      Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
                      Kernel:                 6.1.21-v8+
                      Installation:           Native
                      User-ID:                1000
                      X-Server:               true
                      Pending OS-Updates:     0
                      Pending iob updates:    0
                      Nodejs-Installation:    /usr/bin/nodejs         v16.20.2
                                              /usr/bin/node           v16.20.2
                                              /usr/bin/npm            8.19.4
                                              /usr/bin/npx            8.19.4
                      Recommended versions are nodejs 18.x.y and npm 9.x.y
                      MEMORY:
                      Mem:            7.8G        4.8G        874M        9.0M        2.2G        3.2G
                      Swap:            99M         99M        0.0K
                      Total:          7.9G        4.8G        875M
                      Active iob-Instances:   42
                      Active repo(s): stable
                      ioBroker Core:          js-controller           4.0.24
                                              admin                   6.8.0
                      Objects type: jsonl
                      States  type: jsonl
                      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 192.168.198.39, run as: admin
                      Objects:                22821
                      States:                 19488
                      Size of iob-Database:
                      36M     /opt/iobroker/iobroker-data/objects.jsonl
                      15M     /opt/iobroker/iobroker-data/objects.json.migrated
                      15M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                      28M     /opt/iobroker/iobroker-data/states.jsonl
                      3.4M    /opt/iobroker/iobroker-data/states.json.migrated
                      3.4M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                        @werner2000x
                        Das ist nicht die Langfassung.
                        Aber bis auf den mitrumpelnden Desktop in Ordnung. Schalt den aus.
                        • werner2000x
                          Raspi Desktop Ein:
                          sudo systemctl set-default multi-user.target
                          Raspi Desktop Aus:
                          sudo systemctl set-default graphical.target
                          iob diag
                                               v.2023-04-16
                          Kernel:                 6.1.21-v8+
                          User-ID:                1000
                          X-Server:               true
                                                  /usr/bin/npm            8.19.4
                                                  /usr/bin/npx            8.19.4
                          MEMORY:
                          Mem:            7.8G        4.8G        421M        9.0M        2.6G        3.2G
                          Swap:            99M         99M        0.0K
                          Total:          7.9G        4.9G        421M
                                                  admin                   6.8.0
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                22821
                          States:                 19488
                          33M     /opt/iobroker/iobroker-data/states.jsonl
                          passiert ...
                            @werner2000x sagte in Grafana reagiert nicht mehr auf Port 3000:
                            X-Server: true
                            Der läuft noch. Einmal neustarten oder mit isolate das boot target setzen.
                            • werner2000x
                                                   v.2023-04-16
                              Kernel:                 6.1.21-v8+
                              User-ID:                1000
                              X-Server:               false
                                                      /usr/bin/npm            8.19.4
                                                      /usr/bin/npx            8.19.4
                              MEMORY:
                              Mem:            7.8G        2.5G        3.9G        0.0K        1.4G        5.8G
                              Swap:            99M          0B         99M
                              Total:          7.9G        2.5G        4.0G
                                                      admin                   6.8.0
                              Objects type: jsonl
                              States  type: jsonl
                              Objects:                22540
                              States:                 19332
                              39M     /opt/iobroker/iobroker-data/objects.jsonl
                              39M     /opt/iobroker/iobroker-data/states.jsonl
                              passiert...
                              • crunchip
                                https://github.com/grafana/grafana/issues/73781
                                BMerz created this issue in grafana/grafana
                                closed Grafana-Server crashes with SIGILL after update from 10.0.3 to 10.1.0 on RaspberryPi #73781
                                werner2000x 1 Reply Last reply Reply Quote -1
                                • werner2000x
                                  werner2000x @crunchip last edited by
                                  @crunchip Danke für den Link. Dann bin ich ja nicht alleine mit dem Fehler...
                                    darkblu last edited by
                                    @werner2000x ,
                                    alleine bist du nicht, mich hat es auch erwischt.
                                    Könnte man Grafana nicht einfach deinstallieren und wieder neu installieren, anschliessend per Backitup wieder auf den letzten stand bringen ?
                                    Im neuen Grafana sollten ja nur die Dashboards fehlen und die werden dann ja wieder hergestellt ?
                                    crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
                                    • crunchip
                                      crunchip Forum Testing Most Active @darkblu last edited by
                                      @darkblu sagte in Grafana reagiert nicht mehr auf Port 3000:
                                      so einfach ist das nicht, denn dann installierst du ja wieder die version😜
                                      guck ins issue, da ist es beschrieben
                                        Thomas Braun Most Active @darkblu last edited by
                                        @darkblu
                                        Freie Auswahl bezüglich der Version:
                                        echad@chet:~ $ apt policy grafana
                                        grafana:
                                          Installed: (none)
                                          Candidate: 10.1.0
                                          Version table:
                                             10.1.0 500
                                                500 https://apt.grafana.com stable/main arm64 Packages
                                             10.0.4 500
                                             10.0.3 500
                                             10.0.2 500
                                             10.0.1 500
                                             10.0.0 500
                                                100 /var/lib/dpkg/status
                                             9.5.8 500
                                             9.5.7 500
                                             9.5.6 500
                                             9.5.5 500
                                             9.5.3 500
                                             9.5.2 500
                                             9.5.1 500
                                             9.5.0 500
                                             9.4.13 500
                                             9.4.12 500
                                             9.4.10 500
                                             9.4.9 500
                                             9.4.7 500
                                             9.4.3 500
                                             9.4.2 500
                                             9.4.1 500
                                             9.4.0 500
                                             9.3.16 500
                                             9.3.15 500
                                             9.3.14 500
                                             9.3.13 500
                                             9.3.11 500
                                             9.3.8 500
                                             9.3.6 500
                                             9.3.4 500
                                             9.3.2 500
                                             9.3.1 500
                                             9.3.0 500
                                             9.2.20 500
                                             9.2.19 500
                                             9.2.18 500
                                             9.2.17 500
                                             9.2.15 500
                                             9.2.13 500
                                             9.2.10 500
                                             9.2.8 500
                                             9.2.7 500
                                             9.2.6 500
                                             9.2.5 500
                                             9.2.4 500
                                             9.2.3 500
                                             9.2.2 500
                                             9.2.1 500
                                             9.2.0 500
                                             9.1.8 500
                                             9.1.7 500
                                             9.1.6 500
                                             9.1.5 500
                                             9.1.4 500
                                             9.1.3 500
                                             9.1.2 500
                                             9.1.1 500
                                             9.1.0 500
                                             9.0.9 500
                                             9.0.8 500
                                             9.0.7 500
                                             9.0.6 500
                                             9.0.5 500
                                             9.0.4 500
                                             9.0.3 500
                                             9.0.2 500
                                             9.0.1 500
                                             9.0.0 500
                                             8.5.27 500
                                             8.5.26 500
                                             8.5.25 500
                                             8.5.24 500
                                             8.5.22 500
                                             8.5.21 500
                                             8.5.20 500
                                             8.5.16 500
                                             8.5.15 500
                                             8.5.14 500
                                             8.5.13 500
                                             8.5.12 500
                                             8.5.10 500
                                             8.5.9 500
                                             8.5.6 500
                                             8.5.5 500
                                             8.5.4 500
                                             8.5.3 500
                                             8.5.2 500
                                             8.5.1 500
                                             8.5.0 500
                                             8.4.11 500
                                             8.4.10 500
                                             8.4.7 500
                                             8.4.6 500
                                             8.4.5 500
                                             8.4.4 500
                                             8.4.3 500
                                             8.4.2 500
                                             8.4.1 500
                                             8.4.0 500
                                             8.3.11 500
                                             8.3.10 500
                                             8.3.7 500
                                             8.3.6 500
                                             8.3.5 500
                                             8.3.4 500
                                             8.3.3 500
                                             8.3.2 500
                                             8.3.1 500
                                             8.3.0 500
                                             8.2.7 500
                                             8.2.6 500
                                             8.2.5 500
                                             8.2.4 500
                                             8.2.3 500
                                             8.2.2 500
                                             8.2.1 500
                                             8.2.0 500
                                             8.1.8 500
                                             8.1.7 500
                                             8.1.6 500
                                             8.1.5 500
                                             8.1.4 500
                                             8.1.3 500
                                             8.1.2 500
                                             8.1.1 500
                                             8.1.0 500
                                             8.0.7 500
                                             8.0.6 500
                                             8.0.5 500
                                             8.0.4 500
                                             8.0.3 500
                                             8.0.2 500
                                             8.0.1 500
                                             8.0.0 500
                                             7.5.16 500
                                             7.5.15 500
                                             7.5.13 500
                                             7.5.12 500
                                             7.5.11 500
                                             7.5.10 500
                                             7.5.9 500
                                             7.5.8 500
                                             7.5.7 500
                                             7.5.6 500
                                             7.5.5 500
                                             7.5.4 500
                                             7.5.3 500
                                             7.5.2 500
                                             7.5.1 500
                                             7.5.0 500
                                             7.4.5 500
                                             7.4.3 500
                                             7.4.2 500
                                             7.4.1 500
                                             7.4.0 500
                                             7.3.10 500
                                             7.3.7 500
                                             7.3.6 500
                                             7.3.5 500
                                             7.3.4 500
                                             7.3.3 500
                                             7.3.2 500
                                             7.3.1 500
                                             7.3.0 500
                                             7.2.2 500
                                             7.2.1 500
                                             7.2.0 500
                                             7.1.5 500
                                             7.1.4 500
                                             7.1.3 500
                                             7.1.2 500
                                             7.1.1 500
                                             7.1.0 500
                                             7.0.6 500
                                             7.0.5 500
                                             7.0.4 500
                                             7.0.3 500
                                             7.0.2 500
                                             7.0.1 500
                                             7.0.0 500
                                             6.7.6 500
                                             6.7.5 500
                                             6.7.4 500
                                             6.7.3 500
                                             6.7.2 500
                                             6.7.1 500
                                             6.7.0 500
                                             6.6.2 500
                                             6.6.1 500
                                             6.6.0 500
                                             6.5.3 500
                                             6.5.2 500
                                             6.5.1 500
                                             6.5.0 500
                                             6.4.5 500
                                             6.4.4 500
                                             6.4.3 500
                                             6.4.2 500
                                             6.4.1 500
                                             6.4.0 500
                                             6.3.7 500
                                             6.3.6 500
                                             6.3.5 500
                                             6.3.4 500
                                             6.3.3 500
                                             6.3.2 500
                                             6.3.1 500
                                             6.3.0 500
                                             6.2.5 500
                                             6.2.4 500
                                             6.2.3 500
                                             6.2.2 500
                                             6.2.1 500
                                             6.2.0 500
                                             6.1.6 500
                                             6.1.5 500
                                             6.1.4 500
                                             6.1.3 500
                                             6.1.2 500
                                             6.1.1 500
                                             6.1.0 500
                                             6.0.2 500
                                             6.0.1 500
                                             6.0.0 500
                                             5.4.5 500
                                             5.4.4 500
                                             5.4.3 500
                                             5.4.2 500
                                             5.4.1 500
                                             5.4.0 500
                                             5.3.4 500
                                             5.3.3 500
                                             5.3.2 500
                                             5.3.1 500
                                             5.3.0 500
                                             5.2.5 500
                                             5.2.4 500
                                             5.2.3 500
                                             5.2.2 500
                                             5.2.1 500
                                             5.2.0 500
                                             0.0.0~test 500
                                        sudo apt install grafana=WUNSCHVERSION
                                        Vielleicht grafana vorerst auf hold setzen, fertig:
                                        sudo apt-mark hold grafana
                                        • Meister Mopper
                                          Meister Mopper last edited by
                                          Im von @crunchip beschriebenen issue steht es doch, einfach tun:
                                          For those who have a similar issue and want to downgrade:
                                              Backup /etc/grafana and /var/lib/grafana
                                              apt-get remove grafana
                                              apt-get install grafana=10.0.3
                                          Re-Enable/Start Grafana daemon
                                              sudo /bin/systemctl daemon-reload
                                              sudo /bin/systemctl enable grafana-server
                                              sudo /bin/systemctl start grafana-server
                                          After that Grafana works like before ;-)
                                            darkblu last edited by darkblu
                                            @crunchip
                                            @Meister-Mopper ,
                                            wollte ich eben nachmachen, scheinbar bin ich zu doof: 🤷‍♂️
                                            also die ersten beiden funktionieren schon nicht.
                                            pi@raspberrypi:~ $ Backup /etc/grafana and /var/lib/grafana
                                            -bash: Backup: Kommando nicht gefunden.
                                            pi@raspberrypi:~ $ apt-get remove grafana
                                            E: Sperrdatei /var/lib/dpkg/lock-frontend konnte nicht geöffnet werden. - open (13: Keine Berechtigung)
                                            E: Erlangen der Sperre für die Dpkg-Oberfläche (/var/lib/dpkg/lock-frontend) nicht möglich; sind Sie root?
                                            pi@raspberrypi:~ $
                                            könnt ihr mir den schubs in die richtige Richtung geben ?
                                            1.0k
                                            3000 grafana port
                                            2384
