    5. Shelly Button soll LED streifen steuern (gelöst)
      docsnyder7 last edited by docsnyder7
        <variables>
          <variable id="nFcEizAJ`~6mN4i{7SX6">Status Nachtlicht</variable>
        </variables>
        <block type="on" id="|NsJdRxK6h)wTk*ol9|:" x="113" y="-262">
          <field name="OID">shelly.1.SHBTN-2#C45BBE6BA637#1.Button.EventCount</field>
          <field name="CONDITION">gt</field>
            <block type="variables_set" id="OBBdVD|/tyUtavo7%o}S">
              <field name="VAR" id="nFcEizAJ`~6mN4i{7SX6">Status Nachtlicht</field>
                <block type="get_value" id="})$3{E;UV6ngLg#Mz#}l">
                  <field name="OID">homee.0.DimmableExtendedColorLight-20.OnOff-88</field>
                <block type="controls_if" id="YX5aE~!w_iwnga.?Jy7h">
                    <block type="logic_operation" id="%^nF!Iufh#j2*SxOTP`*" inline="false">
                      <field name="OP">AND</field>
                        <block type="logic_compare" id="la-;}`SABps,[9^S$TX.">
                          <field name="OP">EQ</field>
                            <block type="field_oid" id="u!HjZ~E)lQ9)6]aqYN.3">
                              <field name="oid">shelly.1.SHBTN-2#C45BBE6BA637#1.Button.Event</field>
                            <block type="text" id="F;PrN.B6Tn(|)qqo/(};">
                              <field name="TEXT">S</field>
                        <block type="logic_compare" id=";Gh~nN/4r0eMPrp-E2wl">
                            <block type="variables_get" id="B3!+}Nf(!T@J?$WiZW8K">
                            <block type="math_number" id="5R7S_c`NTE0vxo7Nq66V">
                              <field name="NUM">0</field>
                    <block type="control" id="d*bWgR_/ES/hz^s{Y8Wa">
                      <field name="DELAY_MS">1</field>
                        <block type="math_number" id="8d}5.dy(y_0ftay{c[^P">
                          <field name="NUM">1</field>
                        <block type="control" id="(LE-$Me,qfa26rg$|3$A">
                          <field name="OID">homee.0.DimmableExtendedColorLight-20.Color-91</field>
                          <field name="DELAY_MS">2</field>
                            <block type="colour_picker" id="CV/XTdDOh2GiPh1wU6K}">
                              <field name="COLOUR">#ffffff</field>
                            <block type="control" id="1L-d8knA@x;bN89=hmO}">
                              <field name="DELAY_MS">30</field>
                                <block type="math_number" id="H,78vdb6PgfWrHErB2x%">
                    <block type="controls_if" id="0I616g;@sp3x6,ZMN()u">
                        <block type="logic_operation" id="M0/~l(zi,B(Y$w2i(QH9" inline="false">
                            <block type="logic_compare" id=".B~8:qT9*zdnOV_AJxzJ">
                                <block type="field_oid" id="r`B{[EEkvtCDop}vxZEx">
                                <block type="text" id="84uKwjctaiBUF1@[`w~a">
                            <block type="logic_compare" id="uiBO/~Im^!Q3xmOt?.VK">
                                <block type="variables_get" id="Hg[Y{#L+xEG#OmWy=SCE">
                                <block type="math_number" id="#m}F7Jq`YO!8|$G*DOSu">
                        <block type="control" id="3c!hmc};|:nA_~)^H{@l">
                            <block type="math_number" id="YXwt0:F*COf#@Qrelr,%">
      nach Lesen einiger Beiträge zum Shelly Button, will ich meinen hier aus dem homee herauslösen und in Blockly umsetzen.
      og skript hab ich nach bestem Wissen angelegt…. der Counter als Trigger und den aktuellen Status des Streifens , dazu das „S“ als shortbutton…. den ledstreifen les ich noch über den homee adapter aus…
      stand jetzt geht der streifen nicht an.. wo hab ich den Fehler eingebaut?
      • N
        Nordischerjung @docsnyder7 last edited by Nordischerjung
        @docsnyder7 Kannst du den Baustein als Screenshot einfügen
          docsnyder7 @Nordischerjung last edited by
          @nordischerjung
          N DJMarc75 2 Replies Last reply Reply Quote 0
          • N
            @docsnyder7 Kommt der Trigger denn? Bau doch mal Debug Bausteine dort ein, dann siehst du im LOG wo etwas klemmt
            • DJMarc75
              DJMarc75 @docsnyder7 last edited by
              @docsnyder7 Du verwendest falsche Bausteine, nimm diese:
              N D 2 Replies Last reply Reply Quote 1
              • N
                Nordischerjung @DJMarc75 last edited by
                @djmarc75 Stimmt, nicht drauf geachtet
                  docsnyder7 @DJMarc75 last edited by
                  @djmarc75
                  Danke... soooooo einfach 😕
                  darf ich den farbwechsel Blockly ggf hier auch noch überprüfen lassen?
                  • DJMarc75
                    @docsnyder7 sagte in Shelly Button soll LED streifen steuern:
                    klar, aber dazu müsste man den Typ vom Datenpunkt wissen und auch die Objektdaten.
                      @djmarc75
                      Bitteschön
                      D DJMarc75 2 Replies Last reply Reply Quote 0
                        docsnyder7 @docsnyder7 last edited by docsnyder7
                        @docsnyder7
                        hab jetzt am NAchmittag bissel gegoogelt und gelesen und herumexperimentiert...
                        leider noch nicht weit genug , um hier mherauszulsene, was falsch läuft...
                          ticaki Developer last edited by ticaki
                          du hast da die Blockly falsch zusammen gebaut:
                          Object ID muß direkt in Wert von Objekt sein und dieser ganze Block muß dann in dem Vergleichsblockly sein.
                          Du willst gebe mir Wert von Object und Vergleich mit SS ... Du tust Vergleiche Object ID mit SS (false) und geben wir den Wert von Objekt(False) - das gibts nicht, deshalb Fehler.
                          • DJMarc75
                            DJMarc75 @docsnyder7 last edited by DJMarc75
                            @docsnyder7 und schon wieder falsche Blöcke verwendet...
                            Verwende es so bitte:
                            wenn Du mal DIESE Basics drin hast kannst Du auch mit Schleifenfunktionen weiter machen.
                            edit: und alles was Text ist bitte hier in Codetags reinsetzen !
                              @djmarc75
                              ey das gibts doch nicht... warum seh ich sowas nicht 😞
                              Danke für die Hilfe @DJMarc75 @Nordischerjung @ticaki
                                @DJMarc75
                                ich muss das Thema nochmals aufgreifen
                                hab heute den conbee 2 Stick in betrieb genommen und die Zigbee Streifen eingelernt
                                Nun wollte ich das Blockly anpassen... das AN/AUS hab ich hinbekommen... aber keiner der datenpunkte ändert die Farbe
                                • DJMarc75
                                  @docsnyder7 sagte in Shelly Button soll LED streifen steuern (gelöst):
                                  bitte immer alles zeigen
                                    @djmarc75
                                    sorry zu schnell abgeschickt
                                    • DJMarc75
                                      Ja, weil der Block "zufällige Farbe" auch nur HEX ausspuckt und Du keinen Datenpunkt HEX hast.
                                        @djmarc75
                                        das heisst ich sollte den Stripe besser im homee lassen?
                                        • DJMarc75
                                          Kann ich Dir so nicht beantworten, nutze weder Homee noch so einen Stripe.
                                          Vielleicht gibts ja eine Möglichkeit einen HEX-Wert in XY oder HUE umzurechnen.
                                          Da kenn ich mich aber nicht aus.
                                          EDIT: mir fällt grad auf - in welchen Adapter hast Du den Stripe eigentlich jetzt eingebunden ???
                                            @djmarc75
                                            deConz , warum
                                            1426
