    4. ESPHome json per mqtt senden
      Jacke last edited by
      Hallo zusammen ich versuche von meinem Growatt modstick auf dem ESPHome läuft werte direkt an mein VenusOS zu senden.
      so sieht meine config aus ```
      substitutions:
      devicename: "esphome-growatt-01"
      upper_devicename: "ESPHome Growatt 01"
      esphome:
      platform: ESP8266
      board: esp07s
      Enable logging
      logger:
      baud_rate: 0
      Enable Home Assistant API
      #api:
      password: "01234"
      mqtt:
      broker: 192.168.1.12
      port: 1884
      username: Nils
      password: !secret mqtt_password
      ota:
      password: "01234"
      wifi:
      ssid: !secret wifi_ssid
      password: !secret wifi_password
      Enable fallback hotspot (captive portal) in case wifi connection fails
      ap:
      ssid: "GGrowatt"
      password: "oLjULFvNXq1l"
      Enable Web server
      web_server:
      port: 80
      captive_portal:
      #time:
      - platform: homeassistant
      output:
      Blue Led
      - id: light_bl
        platform: gpio
        pin: 16
      Green Led
      - id: light_gr
        platform: gpio
        pin: 0
      Red Led
      - id: light_rd
        platform: gpio
        pin: 2
      uart:
      tx_pin: 1
      rx_pin: 3
      baud_rate: 115200
      modbus:
      uart_id: mod_bus
      modbus_controller:
      - id: growatt
      the Modbus device addr
        address: 0x1
        modbus_id: modbus1
        update_interval: 10s
        setup_priority: -10
      sensor:
      - platform: modbus_controller
      address: 5
      register_type: "read"
      unit_of_measurement: W
      device_class: power
      icon: mdi:flash
      value_type: U_DWORD
      accuracy_decimals: 1
      filters:
      - multiply: 0.1
        name: "${devicename} DcVoltage"
        address: 3
        unit_of_measurement: V
        device_class: voltage
        icon: mdi:flash
        value_type: U_WORD
        filters:
        - multiply: 0.1
        name: "${devicename} DcInputCurrent"
        address: 4
        unit_of_measurement: A
        device_class: current
        icon: mdi:flash
        value_type: U_WORD
        filters:
        - multiply: 0.1
        name: "${devicename} AcFrequency"
        address: 37
        unit_of_measurement: Hz
        icon: mdi:flash
        value_type: U_WORD
        filters:
        - multiply: 0.01
        name: "${devicename} AcVoltage"
        address: 38
        icon: mdi:flash
        value_type: U_WORD
        filters:
        - multiply: 0.1
        name: "${devicename} AcOutputCurrent"
        address: 39
        icon: mdi:flash
        value_type: U_WORD
        filters:
        - multiply: 0.1
        address: 40
        device_class: power
        icon: mdi:flash
        value_type: U_DWORD
        filters:
        - multiply: 0.1
        on_value:
          then:
          - mqtt.publish_json:
              topic: "Growatt/mic2000/meters"
              payload: |
                  "pv": {
                    "power": id(pv_power).state,
                    "voltage": id(pv_voltage).state,
                    "current": id(pv_current).state,
                    "energy_forward": id(pv_energy_forward).state,
                    "L1": {
        name: "${devicename} EnergyToday"
        address: 53
        unit_of_measurement: kWh
        device_class: energy
        icon: mdi:flash
        value_type: U_DWORD
        filters:
        - multiply: 0.1
        name: "${devicename} EnergyTotal"
        address: 55
        state_class: total_increasing
        icon: mdi:flash
        value_type: U_DWORD
        accuracy_decimals: 2
        filters:
        - multiply: 0.1
        name: "${devicename} Temperature"
        address: 93
        unit_of_measurement: C
        device_class: temperature
        icon: mdi:thermometer
        value_type: U_WORD
        filters:
        - multiply: 0.1
      - platform: mqtt_subscribe
        topic: the/topic
        on_value:
          then:
            - lambda: |-
                esphome::modbus_controller::ModbusController *controller = id(growatt);
                uint16_t reg = 3; // Register: Max output active power (in %)
                float value = id(mqtttest).state;
                uint16_t register_value = static_cast<uint16_t>(value);
                modbus_controller::ModbusCommandItem setOutputPower_command = modbus_controller::ModbusCommandItem::create_write_single_command(controller, reg, register_value);
                controller->queue_command(setOutputPower_command);
      #- platform: mqtt_subscribe
      #  name: "mqtttest"
      #  id: mqtttest
      #  topic: the/topic
      #  on_value:
      #    lambda: |-
      #      id(poweroutput).state;
      #neu test power factor 02/2023
      number:
      name: "${devicename} Max Output Active Power"
      address: 3
      value_type: U_WORD
      min_value: 0
      max_value: 100
      entity_category: config
      step: 1
      ich habe folgenden abschnitt hinzugefügt
      on_value:
      then:
      payload: |
      "pv": {
      "L1": {
      Vorweg vorher lief es über Node Red ohne Probleme
      Die payload soll folgendermaßen aussehen
      msg.payload = {
      "pv": {
      "power": msg.payload["P"],
      "voltage": msg.payload["V"],
      "current": msg.payload["I"],
      "energy_forward": msg.payload["W"],
      "L1": {
      return msg;
      Evtl hat jemand einen tip
      • mickym
        Warum machst Du es dann nicht weiter über NodeRed?
          Jacke @mickym last edited by
          @mickym Node red läuft auf einem zusätzlichen gerät. warum die Daten per Mqtt an den IoBroker senden dort in Node red dann wieder per Mqtt an das VenusOS senden.
          Ich habe nur leider wenig ahnung von ESPHome und yaml. Es ist merh ein Trial & Error.
          • mickym
            mickym Most Active @Jacke last edited by
            @jacke Du sendest nicht. Das VenusOS ist ein mqtt-Broker und kann beliebig viele mqtt-Clients bedienen. Du kannst Dir ja dann NodeRed auf dem zusätzlichen Gerät sparen, wenn Du NodeRed als Logikmaschine im iobroker verwendest.
              Jacke @mickym last edited by Jacke
              @mickym ich schicke es ja nicht am das Venus sondern am einem zusätzlichen Treiber auf dem VenusOS dieser subscribed ein topic von einem Broker uns sendet die Daten an das dbus system.
              Ich bin noch ziemlich unerfahren in node red aber ist der Venus Treiber dann nicht Client?
              Mir fällt gerade auf das ich im esp Home den iobroker als Broker angebe also benötige ich ihn doch noch. Besser wäre ohne.
              Ich habe den esp Code hinbekommen das richtige Stichwort was mir geholfen hat war adruino json library.
              So sieht der richtige code aus
                    on_value:
                      then:
                            payload: |-
                                root["pv"]["power"] = id(pv_power).state;
                                root["pv"]["voltage"] = id(pv_voltage).state;
                                root["pv"]["current"] = id(pv_current).state;
                                root["pv"]["energy_forward"] = id(pv_energy_forward).state;
                                root["pv"]["L1"]["power"] = id(pv_power).state;
                                root["pv"]["L1"]["voltage"] = id(pv_voltage).state;
                                root["pv"]["L1"]["current"] = id(pv_current).state;
                                root["pv"]["L1"]["energy_forward"] = id(pv_energy_forward).state;
              • mickym
                @jacke Für das ESP Home brauchst Du einen mqtt-Broker. Ich hätte Dir aber eher einen externen Broker, wie mosquitto empfohlen. Aber kannst Du immer noch machen,
                  @mickym ich hätte es halt gerne komplett ohne zusätzliche Hardware. Also nur den Growatt stick mit ESHome und das Vensu OS ich weiß nicht ob ich den MQTT vom VenusOS benutzen kann?
                  Aber das gehört bestimmt ins Victron forum?
                  • mickym
                    @jacke Ja ich kann Dir da nicht helfen. Aber ich glaube auch nicht dass Du das VenusOS als normalen Mqtt-Broker nutzen kannst.
                      succo_J @Jacke last edited by
                      @jacke
                      Ich vermute mal, du willst die Daten im Victron-System abbilden.
                      Dann müssen die noch auch dem Venus-OS von MQTT auf dbus umgeschrieben werden.
                      Hier habe ich zB. etwas dazu gefunden: https://github.com/Louisvdw/dbus-serialbattery/discussions/258#discussioncomment-5482398
                      Ansonsten, ja - auf dem Venus-OS läuft ein vollständiger MQTT-Broker. Noch ist es mosquitto, bald soll es FlashMQ werden.
