    4. Installation
    5. Script Depreciation Warning bei Neuinstallation
    • FredF
      FredF Most Active Forum Testing last edited by
      Bin gerade dabei auf einem Odroid XU4 unter Ubuntu 22.04.03 LTS ioBroker zu installieren.
      Nach absetzen des Befehls
       curl -sLf https://iobroker.net/install.sh | bash -
      kommt
                                 SCRIPT DEPRECATION WARNING
        This script, located at https://deb.nodesource.com/setup_X, used to
        install Node.js is deprecated now and will eventually be made inactive.
        Please visit the NodeSource distributions Github and follow the
        instructions to migrate your repo.
        https://github.com/nodesource/distributions
        The NodeSource Node.js Linux distributions GitHub repository contains
        information about which versions of Node.js and which Linux distributions
        are supported and how to install it.
      TO AVOID THIS WAIT MIGRATE THE SCRIPT
      Continuing in 60 seconds (press Ctrl-C to abort) ...
      Wartet man das ab läuft die Installation allerdings einwandfrei durch
        Thomas Braun Most Active @FredF last edited by Thomas Braun
        @fredf
        Si, si...
        https://github.com/ioBroker/ioBroker/issues/462
        https://github.com/ioBroker/ioBroker/pull/464
        winnyschuster created this issue in ioBroker/ioBroker
        closed Nodejs has changed its repository ==> adapt installer script #462
        Grothesk242 created this issue in ioBroker/ioBroker
        closed Update installer_library.sh due to nodesource repo changes #464
          @fredf
          Im nodejs-HowTo aus meiner Signatur sind die Änderungen auch schon drin.
          Stell das am besten auf das aktuelle Repository um, über das alte werden wohl ab sofort keine Updates mehr kommen.
          81.0k
