    4. (Gelöst) Javascript Adapter starten plötzlich nicht mehr
    • crepp1967
      crepp1967 last edited by crepp1967
      Seit heute startet meine beiden Javascript Adapter nicht mehr.
      Ich hatte gestern ein Update des socet.io u. des Web Adapters gemacht.
      Neustart habe ich gemacht und auch ein iob fix.
      Keine Besserung.
      Hier die Fehlermeldungen:
      host.iob-test1-proxmox
      2023-09-02 11:46:36.090	error	instance system.adapter.javascript.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2023-09-02 11:46:36.090	error	Caught by controller[0]: Node.js v18.17.1
      2023-09-02 11:46:36.090	error	Caught by controller[0]: }
      2023-09-02 11:46:36.090	error	Caught by controller[0]: requestPath: 'sshpk'
      2023-09-02 11:46:36.090	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk/package.json',
      2023-09-02 11:46:36.090	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      2023-09-02 11:46:36.090	error	Caught by controller[0]: {
      2023-09-02 11:46:36.090	error	Caught by controller[0]: at node:internal/main/run_main_module:23:47
      2023-09-02 11:46:36.089	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
      2023-09-02 11:46:36.089	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:960:12)
      2023-09-02 11:46:36.089	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
      2023-09-02 11:46:36.089	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
      2023-09-02 11:46:36.089	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
      2023-09-02 11:46:36.089	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:45:23)
      2023-09-02 11:46:36.089	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
      2023-09-02 11:46:36.089	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
      2023-09-02 11:46:36.089	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/lib/request.js:5:18)
      2023-09-02 11:46:36.088	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
      2023-09-02 11:46:36.088	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/index.js:143:19)
      2023-09-02 11:46:36.088	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
      2023-09-02 11:46:36.088	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
      2023-09-02 11:46:36.088	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:960:12)
      2023-09-02 11:46:36.088	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
      2023-09-02 11:46:36.088	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
      2023-09-02 11:46:36.088	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:11:21)
      2023-09-02 11:46:36.088	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature/lib/index.js:3:14)
      2023-09-02 11:46:36.088	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature/lib/parser.js:5:13)
      2023-09-02 11:46:36.087	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
      2023-09-02 11:46:36.087	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
      2023-09-02 11:46:36.087	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
      2023-09-02 11:46:36.087	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature/lib/utils.js:4:13)
      2023-09-02 11:46:36.087	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
      2023-09-02 11:46:36.087	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
      2023-09-02 11:46:36.087	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:922:27)
      2023-09-02 11:46:36.087	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1063:27)
      2023-09-02 11:46:36.087	error	Caught by controller[0]: at Function.Module._findPath (node:internal/modules/cjs/loader:680:18)
      2023-09-02 11:46:36.087	error	Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:438:19)
      2023-09-02 11:46:36.087	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk/lib/index.js'. Please verify that the package.json has a valid "main" entry
      2023-09-02 11:46:36.087	error	Caught by controller[0]: ^
      2023-09-02 11:46:36.087	error	Caught by controller[0]: throw err;
      2023-09-02 11:46:36.087	error	Caught by controller[0]: node:internal/modules/cjs/loader:446
      2023-09-02 11:46:36.046	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2023-09-02 11:46:36.046	error	Caught by controller[0]: Node.js v18.17.1
      2023-09-02 11:46:36.046	error	Caught by controller[0]: }
      2023-09-02 11:46:36.045	error	Caught by controller[0]: requestPath: 'sshpk'
      2023-09-02 11:46:36.045	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk/package.json',
      2023-09-02 11:46:36.045	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      2023-09-02 11:46:36.045	error	Caught by controller[0]: {
      2023-09-02 11:46:36.033	error	Caught by controller[0]: at node:internal/main/run_main_module:23:47
      2023-09-02 11:46:36.033	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
      2023-09-02 11:46:36.033	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:960:12)
      2023-09-02 11:46:36.033	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
      2023-09-02 11:46:36.033	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
      2023-09-02 11:46:36.033	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
      2023-09-02 11:46:36.033	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:45:23)
      2023-09-02 11:46:36.033	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
      2023-09-02 11:46:36.033	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
      2023-09-02 11:46:36.033	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/lib/request.js:5:18)
      2023-09-02 11:46:36.032	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
      2023-09-02 11:46:36.032	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:960:12)
      2023-09-02 11:46:36.032	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
      2023-09-02 11:46:36.032	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
      2023-09-02 11:46:36.032	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
      2023-09-02 11:46:36.032	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/index.js:143:19)
      2023-09-02 11:46:36.032	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
      2023-09-02 11:46:36.032	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:11:21)
      2023-09-02 11:46:36.031	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
      2023-09-02 11:46:36.031	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
      2023-09-02 11:46:36.031	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
      2023-09-02 11:46:36.031	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature/lib/index.js:3:14)
      2023-09-02 11:46:36.031	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
      2023-09-02 11:46:36.031	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
      2023-09-02 11:46:36.031	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:960:12)
      2023-09-02 11:46:36.031	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature/lib/parser.js:5:13)
      2023-09-02 11:46:36.031	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature/lib/utils.js:4:13)
      2023-09-02 11:46:36.030	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
      2023-09-02 11:46:36.030	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
      2023-09-02 11:46:36.030	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:922:27)
      2023-09-02 11:46:36.030	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1063:27)
      2023-09-02 11:46:36.030	error	Caught by controller[0]: at Function.Module._findPath (node:internal/modules/cjs/loader:680:18)
      2023-09-02 11:46:36.030	error	Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:438:19)
      2023-09-02 11:46:36.030	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk/lib/index.js'. Please verify that the package.json has a valid "main" entry
      2023-09-02 11:46:36.030	error	Caught by controller[0]: ^
      2023-09-02 11:46:36.030	error	Caught by controller[0]: throw err;
      2023-09-02 11:46:36.030	error	Caught by controller[0]: node:internal/modules/cjs/loader:446
      Weiss jemand Rat?
      Verzweifelte Grüße
      Torsten
      • Glasfaser
        Glasfaser @crepp1967 last edited by
        @crepp1967 sagte in Javascript Adapter starten plötzlich nicht mehr:
        Zeige erstmal was du hast ,
        dann kann ich dir auch helfen , weil was bringt dir schon die Lösung wenn der Rest nicht stimmt :
        bitte die Full-Ausgabe von
        iob diag
        crepp1967 1 Reply Last reply Reply Quote 0
        • crepp1967
          crepp1967 @Glasfaser last edited by Homoran
          @glasfaser
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Architecture    : x86_64
          Docker          : false
          Virtualization  : kvm
          Distributor ID: Debian
          Description:    Debian GNU/Linux 11 (bullseye)
          Release:        11
          Codename:       bullseye
          PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
          NAME="Debian GNU/Linux"
          VERSION_ID="11"
          VERSION="11 (bullseye)"
          VERSION_CODENAME=bullseye
          ID=debian
          HOME_URL="https://www.debian.org/"
          SUPPORT_URL="https://www.debian.org/support"
          BUG_REPORT_URL="https://bugs.debian.org/"
          Systemuptime and Load:
           12:13:57 up 25 min,  2 users,  load average: 0.23, 0.29, 0.50
          CPU threads: 8
          *** Time and Time Zones ***
                         Local time: Sat 2023-09-02 12:13:57 CEST
                     Universal time: Sat 2023-09-02 10:13:57 UTC
                           RTC time: Sat 2023-09-02 10:13:58
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi cdrom floppy audio dip video plugdev netdev bluetooth scanner iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:             11G        3.3G        7.1G         10M        1.3G        8.1G
          Swap:           974M          0B        974M
          Total:           12G        3.3G        8.0G
                  11679 M total memory
                   3298 M used memory
                    471 M active memory
                   3804 M inactive memory
                   7059 M free memory
                    115 M buffer memory
                   1207 M swap cache
                    974 M total swap
                      0 M used swap
                    974 M free swap
          *** FILESYSTEM ***
          udev           devtmpfs  5.7G     0  5.7G   0% /dev
          tmpfs          tmpfs     1.2G  1.2M  1.2G   1% /run
          /dev/sda1      ext4       31G   18G  9.9G  65% /
          tmpfs          tmpfs     5.8G     0  5.8G   0% /dev/shm
          tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
          tmpfs          tmpfs     1.2G  116K  1.2G   1% /run/user/1000
          [Sat Sep  2 11:48:41 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
          [Sat Sep  2 11:48:42 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
          Show mounted filesystems (real ones only):
          TARGET SOURCE    FSTYPE OPTIONS
          /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
          /var:
          3.2G    /var/
          1.6G    /var/log
          1.4G    /var/log/journal/33dc4f3a0bb843a19efcff7c642a250d
          1.4G    /var/cache
          Archived and active journals take up 72.0M in the file system.
          /opt/iobroker/backups:
          2.2G    /opt/iobroker/backups/
          1.5M    /opt/iobroker/backups/js
          788K    /opt/iobroker/backups/js/Produktiv
          616K    /opt/iobroker/backups/js/TEST
          288K    /opt/iobroker/backups/js/Produktiv/JS
          /opt/iobroker/iobroker-data:
          980M    /opt/iobroker/iobroker-data/
          505M    /opt/iobroker/iobroker-data/files
          246M    /opt/iobroker/iobroker-data/backup-objects
          78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
          72M     /opt/iobroker/iobroker-data/files/telegram.admin
          39M     /opt/iobroker/iobroker-data/objects.jsonl
          31M     /opt/iobroker/iobroker-data/states.jsonl
          21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js.map
          19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
          18M     /opt/iobroker/iobroker-data/objects.json.migrated
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.17.1
          /usr/bin/node           v18.17.1
          /usr/bin/npm            9.6.7
          /usr/bin/npx            9.6.7
          nodejs:
            Installed: 18.17.1-deb-1nodesource1
            Candidate: 18.17.1-deb-1nodesource1
            Version table:
           *** 18.17.1-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                  100 /var/lib/dpkg/status
               12.22.12~dfsg-1~deb11u4 500
                  500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
               12.22.12~dfsg-1~deb11u3 500
                  500 http://deb.debian.org/debian bullseye/main amd64 Packages
          No problems detected
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          MULTIHOSTSERVICE/enabled: false
          Core adapters versions
          js-controller:  4.0.24
          admin:          6.8.0
          javascript:     7.0.3
          Adapters from github:   4
          Adapter State
          + system.adapter.admin.0                  : admin                 : iob-test1-proxmox                        -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : iob-test1-proxmox                        -  enabled
          + system.adapter.awtrix-light.0           : awtrix-light          : iob-test1-proxmox                        -  enabled
          + system.adapter.backitup.0               : backitup              : iob-test1-proxmox                        -  enabled
          + system.adapter.bring.0                  : bring                 : iob-test1-proxmox                        -  enabled
            system.adapter.broadlink2.0             : broadlink2            : iob-test1-proxmox                        - disabled
            system.adapter.daswetter.0              : daswetter             : iob-test1-proxmox                        -  enabled
            system.adapter.discovery.0              : discovery             : iob-test1-proxmox                        - disabled
            system.adapter.ds18b20.0                : ds18b20               : iob-test1-proxmox                        - disabled
            system.adapter.dwd.0                    : dwd                   : iob-test1-proxmox                        -  enabled
            system.adapter.email.0                  : email                 : iob-test1-proxmox                        - disabled
            system.adapter.feiertage.0              : feiertage             : iob-test1-proxmox                        - disabled
            system.adapter.flot.0                   : flot                  : iob-test1-proxmox                        - disabled
          + system.adapter.fritzbox.0               : fritzbox              : iob-test1-proxmox                        -  enabled
            system.adapter.fully-tablet-control.0   : fully-tablet-control  : iob-test1-proxmox                        - disabled
            system.adapter.history.0                : history               : iob-test1-proxmox                        - disabled
          + system.adapter.hm-rega.0                : hm-rega               : iob-test1-proxmox                        -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : iob-test1-proxmox                        -  enabled, port: 0
          + system.adapter.hm-rpc.1                 : hm-rpc                : iob-test1-proxmox                        -  enabled, port: 0
          + system.adapter.hue-extended.0           : hue-extended          : iob-test1-proxmox                        -  enabled
          + system.adapter.hue.0                    : hue                   : iob-test1-proxmox                        -  enabled, port: 80
            system.adapter.ical.0                   : ical                  : iob-test1-proxmox                        -  enabled
            system.adapter.ical.1                   : ical                  : iob-test1-proxmox                        -  enabled
            system.adapter.ical.2                   : ical                  : iob-test1-proxmox                        -  enabled
            system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iob-test1-proxmox                        - disabled
            system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iob-test1-proxmox                        - disabled
            system.adapter.icons-icons8.0           : icons-icons8          : iob-test1-proxmox                        - disabled
            system.adapter.icons-material-png.0     : icons-material-png    : iob-test1-proxmox                        - disabled
            system.adapter.icons-material-svg.0     : icons-material-svg    : iob-test1-proxmox                        - disabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : iob-test1-proxmox                        - disabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iob-test1-proxmox                        - disabled
            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iob-test1-proxmox                        - disabled
          + system.adapter.influxdb.0               : influxdb              : iob-test1-proxmox                        -  enabled, port: 8086
          + system.adapter.info.0                   : info                  : iob-test1-proxmox                        -  enabled
          + system.adapter.iot.0                    : iot                   : iob-test1-proxmox                        -  enabled
            system.adapter.javascript.0             : javascript            : iob-test1-proxmox                        -  enabled
            system.adapter.javascript.1             : javascript            : iob-test1-proxmox                        -  enabled
          + system.adapter.kodi.0                   : kodi                  : iob-test1-proxmox                        -  enabled, port: 9090
          + system.adapter.kodi.1                   : kodi                  : iob-test1-proxmox                        -  enabled, port: 9090
          + system.adapter.lgtv.0                   : lgtv                  : iob-test1-proxmox                        -  enabled
            system.adapter.luftdaten.0              : luftdaten             : iob-test1-proxmox                        -  enabled
            system.adapter.mobile.0                 : mobile                : iob-test1-proxmox                        - disabled
          + system.adapter.moma.0                   : moma                  : iob-test1-proxmox                        -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : iob-test1-proxmox                        -  enabled, port: 1886, bind: 192.168.1.203
            system.adapter.mqtt.1                   : mqtt                  : iob-test1-proxmox                        - disabled, port: 1884, bind: 192.168.1.203
          + system.adapter.nina.0                   : nina                  : iob-test1-proxmox                        -  enabled
            system.adapter.node-red.0               : node-red              : iob-test1-proxmox                        - disabled, port: 1880, bind: 192.168.1.203
            system.adapter.openweathermap.0         : openweathermap        : iob-test1-proxmox                        -  enabled
            system.adapter.owfs.0                   : owfs                  : iob-test1-proxmox                        - disabled, port: 4304
            system.adapter.parser.0                 : parser                : iob-test1-proxmox                        - disabled
          + system.adapter.pi-hole.0                : pi-hole               : iob-test1-proxmox                        -  enabled
          + system.adapter.proxmox.0                : proxmox               : iob-test1-proxmox                        -  enabled, port: 8006
          + system.adapter.pushover.0               : pushover              : iob-test1-proxmox                        -  enabled
          + system.adapter.radar2.0                 : radar2                : iob-test1-proxmox                        -  enabled
            system.adapter.rpi2.0                   : rpi2                  : iob-test1-proxmox                        - disabled
          + system.adapter.sayit.0                  : sayit                 : iob-test1-proxmox                        -  enabled
            system.adapter.scenes.0                 : scenes                : iob-test1-proxmox                        - disabled
          + system.adapter.senec.0                  : senec                 : iob-test1-proxmox                        -  enabled
          + system.adapter.shelly.0                 : shelly                : iob-test1-proxmox                        -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.shelly.1                 : shelly                : iob-test1-proxmox                        -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.socketio.0               : socketio              : iob-test1-proxmox                        -  enabled, port: 8084, bind: 192.168.1.203, run as: admin
            system.adapter.solarwetter.0            : solarwetter           : iob-test1-proxmox                        - disabled
          + system.adapter.sonoff.0                 : sonoff                : iob-test1-proxmox                        -  enabled, port: 1883, bind: 192.168.1.203
          + system.adapter.spotify-premium.0        : spotify-premium       : iob-test1-proxmox                        -  enabled
          + system.adapter.squeezeboxrpc.0          : squeezeboxrpc         : iob-test1-proxmox                        -  enabled, port: 9000
          + system.adapter.statistics.0             : statistics            : iob-test1-proxmox                        -  enabled
            system.adapter.telegram.0               : telegram              : iob-test1-proxmox                        - disabled, port: 8443
          + system.adapter.tr-064.0                 : tr-064                : iob-test1-proxmox                        -  enabled
            system.adapter.traccar.0                : traccar               : iob-test1-proxmox                        - disabled
          + system.adapter.trashschedule.0          : trashschedule         : iob-test1-proxmox                        -  enabled
            system.adapter.vis-bars.0               : vis-bars              : iob-test1-proxmox                        - disabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iob-test1-proxmox                        - disabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : iob-test1-proxmox                        - disabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iob-test1-proxmox                        - disabled
            system.adapter.vis-google-fonts.0       : vis-google-fonts      : iob-test1-proxmox                        -  enabled
            system.adapter.vis-history.0            : vis-history           : iob-test1-proxmox                        - disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iob-test1-proxmox                        - disabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : iob-test1-proxmox                        - disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : iob-test1-proxmox                        -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iob-test1-proxmox                        - disabled
            system.adapter.vis-justgage.0           : vis-justgage          : iob-test1-proxmox                        - disabled
            system.adapter.vis-keyboard.0           : vis-keyboard          : iob-test1-proxmox                        - disabled
            system.adapter.vis-map.0                : vis-map               : iob-test1-proxmox                        - disabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : iob-test1-proxmox                        - disabled
            system.adapter.vis-metro.0              : vis-metro             : iob-test1-proxmox                        - disabled
            system.adapter.vis-players.0            : vis-players           : iob-test1-proxmox                        - disabled
            system.adapter.vis-rgraph.0             : vis-rgraph            : iob-test1-proxmox                        - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iob-test1-proxmox                        - disabled
            system.adapter.vis-weather.0            : vis-weather           : iob-test1-proxmox                        - disabled
            system.adapter.vis.0                    : vis                   : iob-test1-proxmox                        -  enabled
            system.adapter.weatherunderground.0     : weatherunderground    : iob-test1-proxmox                        -  enabled
          + system.adapter.web.0                    : web                   : iob-test1-proxmox                        -  enabled, port: 8082, bind: 192.168.1.203, run as: admin
            system.adapter.windows-control.0        : windows-control       : iob-test1-proxmox                        - disabled
          + system.adapter.wled.0                   : wled                  : iob-test1-proxmox                        -  enabled
          + system.adapter.worx.0                   : worx                  : iob-test1-proxmox                        -  enabled
          + system.adapter.zigbee.0                 : zigbee                : iob-test1-proxmox                        -  enabled, port: /dev/ttyACM0
          + instance is alive
          ioBroker-Repositories
          Stable (default): http://download.iobroker.net/sources-dist.json
          Installed ioBroker-Instances
          Adapter    "admin"        : 6.8.0    , installed 6.8.0
          Adapter    "alexa2"       : 3.24.1   , installed 3.24.1
          Adapter    "backitup"     : 2.6.23   , installed 2.6.23
          Adapter    "bring"        : 1.8.1    , installed 1.8.1
          Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
          Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
          Adapter    "discovery"    : 3.1.0    , installed 3.1.0
          Adapter    "ds18b20"      : 1.6.1    , installed 1.6.1
          Adapter    "email"        : 1.2.0    , installed 1.2.0
          Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
          Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
          Adapter    "history"      : 2.2.6    , installed 2.2.6
          Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
          Adapter    "hue"          : 3.9.5    , installed 3.9.5
          Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
          Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
          Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
          Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
          Adapter    "info"         : 1.9.26   , installed 1.9.26
          Adapter    "iot"          : 1.14.5   , installed 1.14.5
          Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
          Adapter    "javascript"   : 7.0.3    , installed 7.0.3
          Controller "js-controller": 4.0.24   , installed 4.0.24
          Adapter    "kodi"         : 2.0.9    , installed 2.0.9
          Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
          Adapter    "luftdaten"    : 3.0.0    , installed 3.0.0
          Adapter    "mobile"       : 1.0.1    , installed 1.0.1
          Adapter    "moma"         : 1.2.9    , installed 1.2.9
          Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
          Adapter    "nina"         : 0.0.25   , installed 0.0.25
          Adapter    "node-red"     : 4.0.3    , installed 4.0.3
          Adapter    "openweathermap": 0.3.9   , installed 0.3.9
          Adapter    "operating-hours": 1.0.4  , installed 1.0.4
          Adapter    "owfs"         : 0.7.0    , installed 0.7.0
          Adapter    "parser"       : 1.3.2    , installed 1.3.2
          Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
          Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
          Adapter    "pushover"     : 3.0.3    , installed 3.0.3
          Adapter    "radar2"       : 2.0.7    , installed 2.0.7
          Adapter    "rest-api"     : 1.1.0    , installed 1.1.0
          Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
          Adapter    "samsung"      : 0.5.11   , installed 0.5.11
          Adapter    "sayit"        : 3.0.5    , installed 3.0.5
          Adapter    "shelly"       : 6.4.1    , installed 6.4.1
          Adapter    "socketio"     : 6.5.2    , installed 6.5.2
          Adapter    "solarwetter"  : 1.0.0    , installed 1.0.0
          Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
          Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
          Adapter    "squeezeboxrpc": 1.3.9    , installed 1.3.9
          Adapter    "statistics"   : 2.3.0    , installed 2.3.0
          Adapter    "swiss-weather-api": 1.0.5, installed 1.0.5
          Adapter    "telegram"     : 1.16.0   , installed 1.16.0
          Adapter    "traccar"      : 0.0.12   , installed 0.0.12
          Adapter    "trashschedule": 2.2.0    , installed 2.2.0
          Adapter    "vis"          : 1.4.16   , installed 1.4.16
          Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
          Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
          Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
          Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
          Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
          Adapter    "weatherunderground": 3.4.2, installed 3.4.2
          Adapter    "web"          : 6.1.0    , installed 6.1.0
          Adapter    "windows-control": 0.1.5  , installed 0.1.5
          Adapter    "wled"         : 0.6.7    , installed 0.6.7
          Adapter    "worx"         : 2.3.2    , installed 2.3.2
          Adapter    "ws"           : 2.5.3    , installed 2.5.3
          Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
          Objects and States
          Objects:        27197
          States:         25018
          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:2 http://deb.debian.org/debian bullseye InRelease
          Hit:3 http://ftp.debian.org/debian bullseye-backports InRelease
          Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:5 https://repos.influxdata.com/debian stable InRelease
          Hit:6 https://repos.influxdata.com/debian bullseye InRelease
          Get:7 https://deb.nodesource.com/node_18.x bullseye InRelease [4586 B]
          Fetched 4586 B in 1s (4901 B/s)
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 192.168.1.203:1883      0.0.0.0:*               LISTEN      1001       30565      3592/io.sonoff.0
          tcp        0      0 192.168.1.203:8701      0.0.0.0:*               LISTEN      1001       19309      2672/io.hm-rpc.1
          tcp        0      0 192.168.1.203:1886      0.0.0.0:*               LISTEN      1001       25737      3366/io.mqtt.0
          tcp        0      0 192.168.1.203:1887      0.0.0.0:*               LISTEN      1001       25738      3366/io.mqtt.0
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       3000       505/iobroker.js-con
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       525        505/iobroker.js-con
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          16551      1/init
          tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      998        18195      1911/monitorix-http
          tcp        0      0 192.168.1.203:2001      0.0.0.0:*               LISTEN      1001       24691      2506/io.hm-rpc.0
          tcp        0      0 192.168.1.203:8082      0.0.0.0:*               LISTEN      1001       33466      5230/io.web.0
          tcp        0      0 192.168.1.203:8084      0.0.0.0:*               LISTEN      1001       37427      6517/io.socketio.0
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14001      543/sshd: /usr/sbin
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          2477       504/cupsd
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       22188      3805/io.shelly.1
          tcp6       0      0 :::111                  :::*                    LISTEN      0          116        1/init
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       20697      1123/io.admin.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          14003      543/sshd: /usr/sbin
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          2476       504/cupsd
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       30488      3515/io.shelly.0
          udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       22446      4423/io.radar2.0
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12729      1/init
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          2836       524/cups-browsed
          udp        0      0 0.0.0.0:59462           0.0.0.0:*                           112        13921      464/avahi-daemon: r
          udp        0      0 0.0.0.0:3483            0.0.0.0:*                           1001       35642      6544/io.squeezeboxr
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       37622      6615/io.wled.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        13919      464/avahi-daemon: r
          udp6       0      0 :::111                  :::*                                0          2352       1/init
          udp6       0      0 fe80::1e95:cc09:f9a:546 :::*                                0          13133      467/NetworkManager
          udp6       0      0 :::54050                :::*                                112        13922      464/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                112        13920      464/avahi-daemon: r
          2023-09-02 12:00:27.705  - info: host.iob-test1-proxmox instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-09-02 12:00:28.118  - info: host.iob-test1-proxmox instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
          2023-09-02 12:00:31.870  - info: awtrix-light.0 (6905) error ECONNABORTED from /api/custom?name=pvakt: timeout of 3000ms exceeded
          2023-09-02 12:00:31.871  - warn: awtrix-light.0 (6905) (custom?name=pvakt) Unable to update custom app "pvakt": AxiosError: timeout of 3000ms exceeded
          2023-09-02 12:00:41.886  - warn: awtrix-light.0 (6905) (custom?name=pvakt) Unable to update custom app "pvakt": AxiosError: timeout of 3000ms exceeded
          2023-09-02 12:03:34.236  - info: hm-rpc.1 (2672) xmlrpc -> listDevices 0
          2023-09-02 12:03:34.278  - info: hm-rpc.1 (2672) new CUxD devices/channels after filter: 0
          2023-09-02 12:05:00.086  - info: host.iob-test1-proxmox instance system.adapter.luftdaten.0 started with pid 14652
          2023-09-02 12:05:04.112  - info: host.iob-test1-proxmox instance system.adapter.dwd.0 started with pid 14696
          2023-09-02 12:05:06.024  - info: dwd.0 (14696) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 4.0.24
          2023-09-02 12:05:07.733  - info: dwd.0 (14696) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2023-09-02 12:05:08.251  - info: host.iob-test1-proxmox instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-09-02 12:05:12.934  - info: host.iob-test1-proxmox instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
          2023-09-02 12:07:04.291  - info: hm-rpc.1 (2672) xmlrpc -> listDevices 0
          2023-09-02 12:07:04.327  - info: hm-rpc.1 (2672) new CUxD devices/channels after filter: 0
          2023-09-02 12:10:00.038  - info: host.iob-test1-proxmox instance system.adapter.dwd.0 started with pid 17562
          2023-09-02 12:10:02.028  - info: dwd.0 (17562) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 4.0.24
          2023-09-02 12:10:02.981  - info: dwd.0 (17562) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2023-09-02 12:10:03.512  - info: host.iob-test1-proxmox instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-09-02 12:10:04.062  - info: host.iob-test1-proxmox instance system.adapter.luftdaten.0 started with pid 17624
          2023-09-02 12:10:11.494  - info: host.iob-test1-proxmox instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
          2023-09-02 12:10:34.342  - info: hm-rpc.1 (2672) xmlrpc -> listDevices 0
          2023-09-02 12:10:34.377  - info: hm-rpc.1 (2672) new CUxD devices/channels after filter: 0
          2023-09-02 12:14:04.395  - info: hm-rpc.1 (2672) xmlrpc -> listDevices 0
          2023-09-02 12:14:04.453  - info: hm-rpc.1 (2672) new CUxD devices/channels after filter: 0
          Glasfaser Thomas Braun crunchip 3 Replies Last reply Reply Quote 0
          • Glasfaser
            @crepp1967
            setzte es bitte in Code-Tags ... kann man schlecht lesen !
            so dann
            cd /opt/iobroker
            sudo -H -u iobroker npm install iobroker.js-controller
            iobroker restart
              Homoran Global Moderator Administrators @Glasfaser last edited by
              @glasfaser sagte in Javascript Adapter starten plötzlich nicht mehr:
              das war ja das Problem 😂 zusätzliche Code-tags
              crepp1967 1 Reply Last reply Reply Quote 1
                Thomas Braun Most Active @crepp1967 last edited by Thomas Braun
                @crepp1967
                Schmeiß die bullseye-backports raus und stell das nodesoure-Repo auf die aktuelle Struktur um.
                crepp1967 2 Replies Last reply Reply Quote 0
                • crepp1967
                  crepp1967 @Homoran last edited by
                  ich war mir sicher CodeTags verwendet zu haben
                  • crunchip
                    crunchip Forum Testing Most Active @crepp1967 last edited by
                    'adm', 'systemd-journal'
                    dein user ist nicht in der Gruppe
                    gibt es einen Grund warum sämtliches vis "zubehör" deaktiviert ist?
                    cupsd
                    läuft da noch Desktop/Drucker zeugs?
                    • crepp1967
                      crepp1967 @Thomas Braun last edited by
                      Wie mache ich das?
                      Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
                        Wie mache ich das?
                        Backports musst du mal selber freigeschaltet haben. Einfach wieder rückgängig machen, was damals getan wurde. Hat vermutlich mit udev zu tun gehabt.
                        Zu nodesource:
                        Schau in meine Signatur.
                        • Glasfaser
                          Wie mache ich das?
                          ist der Fehler bei dir mit
                          schon behoben !?
                          Thomas Braun crepp1967 2 Replies Last reply Reply Quote 0
                            Thomas Braun Most Active @Glasfaser last edited by
                            schon behoben !?
                            Hatte ich nie.
                            • Glasfaser
                              Glasfaser @Thomas Braun last edited by Glasfaser
                              ich habe dich doch nicht angeschrieben !!!!?
                              das war für @crepp1967
                              Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                                @glasfaser
                                Axo...
                                Ja, eins mach dem anderen machen.
                                • crunchip
                                  crunchip Forum Testing Most Active @Glasfaser last edited by
                                  aber markiert/benachrichtigt wurde er durch
                                  • crepp1967
                                    crepp1967 @crunchip last edited by
                                    @crunchip
                                    Hab das System unter Proxmox (Ubuntu) aufgesetzt (mit dem iobroker script)
                                    Hab dann nichts mehr angepasst (betriebssystemseitig)
                                    cupsd kann wohl deaktivieren, da hängt kein Drucker dran.
                                    in der shell mit purge oder wie werde ich das los?
                                    • crepp1967
                                      @glasfaser
                                      Also mein Grundproblem (nicht startende Javascript Adapter) ist nun zum Glück behoben, vielen Dank für die schnelle Hilfe und die Tips zum fixen.
                                      Die hier im Thread noch so erwähnten Probleme werde ich im Anschluss beheben.
                                      Damit kann ich den Thread auf "Gelöst" setzen.
                                      Torsten
                                        Homoran Global Moderator Administrators @crepp1967 last edited by
                                        @crepp1967 sagte in (Gelöst) Javascript Adapter starten plötzlich nicht mehr:
                                        ja, eben!
                                        Code-tags sind in der Ausgabe bereits drin, an den richtigen Stellen.
                                        Du hast zusätzliche verwendet
                                        • crepp1967
                                          @thomas-braun Wie kann ich das anstellen?
                                            @crepp1967
                                            Was genau meinst du?
                                            698
