    4. History Adapter steht auf rot
      Linedancer last edited by
      Hallo Gemeinde,
      seit 3 Tagen steht mein History Adapter auf rot.
      hier meine Konfig:
      Host 1.0.3
      Admin 1.7.6
      History 1.6.2
      Flot 1.6.1
      Wenn ich den History Adapter neu laden steht er einige Minuten auf grün, um dann wieder rot zu werden.
      im Log finde ich folgendes dazu:
      ! host.HTPC 2017-07-12 10:14:37.172 error instance system.adapter.history.0 terminated with code 6 (uncaught exception)
      ! history.0 2017-07-12 10:14:34.625 error at Decoder.add (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\node_modules\socket.io-parser\index.js:246:12)
      ! history.0 2017-07-12 10:14:34.625 error at Decoder.Emitter.emit (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\node_modules\socket.io-parser\node_modules\component-emitter\index.js:134:20)
      ! history.0 2017-07-12 10:14:34.625 error at Decoder. (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\node_modules\component-bind\index.js:21:15)
      ! history.0 2017-07-12 10:14:34.625 error at Manager.ondecoded (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\manager.js:332:8)
      ! history.0 2017-07-12 10:14:34.625 error at Manager.Emitter.emit (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\node_modules\component-emitter\index.js:133:20)
      ! history.0 2017-07-12 10:14:34.625 error at Manager. (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\node_modules\component-bind\index.js:21:15)
      ! history.0 2017-07-12 10:14:34.625 error at Socket.onpacket (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\socket.js:228:12)
      ! history.0 2017-07-12 10:14:34.625 error at Socket.onevent (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\socket.js:270:10)
      ! history.0 2017-07-12 10:14:34.625 error at Socket.Emitter.emit (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\node_modules\component-emitter\index.js:133:20)
      ! history.0 2017-07-12 10:14:34.625 error at Socket. (C:\iobroker\node_modules\iobroker.js-controller\lib\states\statesInMemClient.js:47:80)
      ! history.0 2017-07-12 10:14:34.625 error RangeError: Maximum call stack size exceeded
      ! history.0 2017-07-12 10:14:34.594 error uncaught exception: Maximum call stack size exceeded
      Natürlich macht mir flot jetzt keine Diagramme mehr in vis.
      Seit das Problem auftritt, hab ich keine neuen Werte zum Loggen hinzugefügt, habe allerdings heute einige rausgeworfen.
      Auffällig ist, das das gesamte iobroker system gefühlt etwas langsamer ist. Der Aufbau der vis views dauert eine sekunde länger als normal, Schaltbefehle kommen 2-3 Sekunden später an…
      Ein Neustart des iobroker Rechners (Windows 7) ändert daran nix
      Was kann ich da tun?
      • apollon77
        apollon77 last edited by
        Interessant …
        Sarte den Adapter bitte mal unter "Debug" Level.
        (Instanzen -> Expertenmodus" dann dort hinter dem Adapter "debug" wählen.
        Was gibt er dann so aus?
          Hallo und danke für die schnelle Reaktion.
          hier also der Inhalt vom Log nach dem Start im Debug Mode:
          ! history.0 2017-07-12 12:15:47.890 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854547437, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:15:47.874 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854547437, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:15:47.874 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854547437, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:15:47.859 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854547437, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:15:47.437 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854547422, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:15:46.062 info enabled logging of javascript.0.Alarmanlage.Bewegung_GartenCam
          ! history.0 2017-07-12 12:15:46.062 info enabled logging of javascript.0.Alarmanlage.Bewegung_HaustuerCam
          ! history.0 2017-07-12 12:15:46.062 info enabled logging of hm-rega.0.65422
          ! history.0 2017-07-12 12:15:46.062 info enabled logging of hm-rega.0.43683
          ! history.0 2017-07-12 12:15:46.062 info enabled logging of hm-rega.0.25167
          ! history.0 2017-07-12 12:15:46.062 info enabled logging of hm-rega.0.3381
          ! history.0 2017-07-12 12:15:46.062 info enabled logging of hm-rega.0.3380
          ! history.0 2017-07-12 12:15:46.046 info enabled logging of hm-rega.0.3254
          ! history.0 2017-07-12 12:15:46.046 info enabled logging of hm-rega.0.3253
          ! history.0 2017-07-12 12:15:46.046 info enabled logging of hm-rega.0.2830
          ! history.0 2017-07-12 12:15:46.046 info enabled logging of hm-rega.0.1993
          ! history.0 2017-07-12 12:15:46.046 info enabled logging of hm-rega.0.1992
          ! history.0 2017-07-12 12:15:46.046 info enabled logging of hm-rega.0.1386
          ! history.0 2017-07-12 12:15:46.046 info enabled logging of hm-rpc.1.CUX9000002.1.TEMPERATURE
          ! history.0 2017-07-12 12:15:46.046 info enabled logging of hm-rpc.1.CUX9000001.1.TEMPERATURE
          ! history.0 2017-07-12 12:15:45.999 info enabled logging of hm-rpc.0.KEQzzzzzzz.1.STATE
          ! history.0 2017-07-12 12:15:45.999 info enabled logging of javascript.0.Wetter.Counter_Sonnenschein
          ! history.0 2017-07-12 12:15:45.999 info enabled logging of javascript.0.Wetter.Tageshöchsttemperatur
          ! history.0 2017-07-12 12:15:45.999 info enabled logging of javascript.0.Wetter.Regenmenge
          ! history.0 2017-07-12 12:15:45.999 info enabled logging of javascript.0.Wetter.Luftdruck
          ! history.0 2017-07-12 12:15:45.999 info enabled logging of weatherunderground.1.forecast_day.0d.minhumidity
          ! history.0 2017-07-12 12:15:45.999 info enabled logging of weatherunderground.1.forecast_day.0d.maxhumidity
          ! history.0 2017-07-12 12:15:45.999 info enabled logging of weatherunderground.1.forecast_day.0d.qpf.allday
          ! history.0 2017-07-12 12:15:45.999 info enabled logging of javascript.0.Android_Tablets.OG_Flur.Akkustand
          ! history.0 2017-07-12 12:15:45.999 info enabled logging of javascript.0.Strom.Pool.Min_Max_Delta
          ! history.0 2017-07-12 12:15:45.984 info enabled logging of javascript.0.Strom.Pool.Tagesminimum
          ! history.0 2017-07-12 12:15:45.984 info enabled logging of javascript.0.Strom.Pool.Tagesmaximum
          ! history.0 2017-07-12 12:15:45.984 info enabled logging of radar.0.yyy_Handy.here
          ! history.0 2017-07-12 12:15:45.984 info enabled logging of radar.0.xxx_Handy.here
          ! history.0 2017-07-12 12:15:45.984 info enabled logging of javascript.0.Strom.Pool.Laufzeit_Filter_tagesmax
          ! history.0 2017-07-12 12:15:45.984 info enabled logging of javascript.0.Strom.Pool.Laufzeit_Heizung_tagesmax
          ! history.0 2017-07-12 12:15:45.984 info enabled logging of javascript.0.Alarmanlage.Alarmanzahl_GartenCam
          ! history.0 2017-07-12 12:15:45.984 info enabled logging of javascript.0.Alarmanlage.Alarmanzahl_HaustuerCam
          ! history.0 2017-07-12 12:15:45.984 info enabled logging of tr-064.0.devices.L-925-GB.active
          ! history.0 2017-07-12 12:15:45.984 info enabled logging of tr-064.0.devices.xxx-Lumia.active
          ! history.0 2017-07-12 12:15:45.984 info enabled logging of javascript.0.Alarmanlage.Alarm_HaustuerCam
          ! history.0 2017-07-12 12:15:45.984 info enabled logging of javascript.0.Alarmanlage.Alarm_GartenCam
          ! history.0 2017-07-12 12:15:45.984 info enabled logging of javascript.0.Wetter.Aussentemperatur
          ! history.0 2017-07-12 12:15:45.984 info enabled logging of javascript.0.Wetter.Grass Temperatur
          ! history.0 2017-07-12 12:15:45.968 info enabled logging of javascript.0.Wetter.Windspeed
          ! history.0 2017-07-12 12:15:45.968 info enabled logging of radar.0.Tablet_OG_Flur.here
          ! history.0 2017-07-12 12:15:45.968 info enabled logging of javascript.0.Wetter.Regenwahrscheinlichkeit
          ! history.0 2017-07-12 12:15:45.968 info enabled logging of javascript.0.Wetter.rel_Humidity
          ! history.0 2017-07-12 12:15:45.968 info enabled logging of weatherunderground.1.current.precip_today_metric
          ! history.0 2017-07-12 12:15:45.968 info enabled logging of javascript.0.Strom.Heizkoerper-DG-Bad.Verbrauch.Monat
          ! history.0 2017-07-12 12:15:45.968 info enabled logging of javascript.0.Strom.Heizkoerper-DG-Bad.Verbrauch.Tag
          ! history.0 2017-07-12 12:15:45.968 info enabled logging of javascript.0.Strom.Waschmaschine.Kosten.Jahr
          ! history.0 2017-07-12 12:15:45.968 info enabled logging of javascript.0.Strom.Waschmaschine.Kosten.Monat
          ! history.0 2017-07-12 12:15:45.968 info enabled logging of weatherunderground.0.current.precip_today_metric
          ! history.0 2017-07-12 12:15:45.953 info enabled logging of weatherunderground.0.current.wind_gust_kph
          ! history.0 2017-07-12 12:15:45.953 info enabled logging of weatherunderground.0.current.wind_kph
          ! history.0 2017-07-12 12:15:45.953 info enabled logging of weatherunderground.0.current.wind_degrees
          ! history.0 2017-07-12 12:15:45.953 info enabled logging of yr.0.forecast.day0.precipitation_level
          ! history.0 2017-07-12 12:15:45.953 info enabled logging of yr.0.forecast.day0.pressure
          ! history.0 2017-07-12 12:15:45.953 info enabled logging of tankerkoenig.0.stations.0.e5.short
          ! history.0 2017-07-12 12:15:45.671 info starting. Version 1.6.2 in C:/iobroker/node_modules/iobroker.history, node: v4.4.7
          ! history.0 2017-07-12 12:15:45.515 debug statesDB connected
          ! history.0 2017-07-12 12:15:44.499 debug objectDB connected
          ! host.HTPC 2017-07-12 12:15:41.797 info instance system.adapter.history.0 started with pid 4472
          ! history.0 2017-07-12 12:15:47.453 debug inMem message * hm-rega.0.25167
          (Klarnamen und SerienNr anonymisiert)
          und hier der Log Inhalt nachdem history wieder rot geworden ist:
          ! history.0 2017-07-12 12:16:39.890 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854548172, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:39.890 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854548156, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:39.890 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854548140, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:39.890 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854548140, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:39.874 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854548140, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:39.874 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854548140, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:39.874 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854548125, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:39.874 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854548125, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:37.140 debug moving 11 entries from hm-rega.0.65422 to file
          ! history.0 2017-07-12 12:16:37.140 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854548125, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:34.499 debug moving 11 entries from hm-rega.0.25167 to file
          ! history.0 2017-07-12 12:16:34.499 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854548125, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:34.499 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854548125, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:34.499 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854548109, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:34.484 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854548109, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:34.484 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854548109, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:34.484 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854548094, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:34.484 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854548094, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:34.468 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854548094, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:34.468 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854548094, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:32.328 debug moving 11 entries from hm-rega.0.65422 to file
          ! history.0 2017-07-12 12:16:32.328 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854548078, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:32.312 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854548078, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:32.312 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854548078, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:29.484 debug moving 11 entries from hm-rega.0.25167 to file
          ! history.0 2017-07-12 12:16:29.484 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854548078, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:29.484 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854548078, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:29.468 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854548062, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:29.468 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854548062, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:29.468 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854548047, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:29.468 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854548047, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:29.453 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854548047, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:29.453 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854548047, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:27.328 debug moving 11 entries from hm-rega.0.65422 to file
          ! history.0 2017-07-12 12:16:27.328 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854548031, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:27.312 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854548031, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:24.984 debug moving 11 entries from hm-rega.0.25167 to file
          ! history.0 2017-07-12 12:16:24.984 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854548031, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:24.984 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854548031, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:24.984 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854548015, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:24.984 debug inMem message * system.adapter.sayit.2.outputCount val=8, ack=true, ts=1499854547937, q=0, from=system.adapter.sayit.2, lc=1498944405437
          ! history.0 2017-07-12 12:16:24.984 debug inMem message * system.adapter.sayit.2.inputCount val=0, ack=true, ts=1499854547922, q=0, from=system.adapter.sayit.2, lc=1499846242219
          ! history.0 2017-07-12 12:16:24.984 debug inMem message * system.adapter.sayit.2.uptime val=10261, ack=true, ts=1499854547922, q=0, from=system.adapter.sayit.2, lc=1499854547922
          ! history.0 2017-07-12 12:16:24.984 debug inMem message * system.adapter.sayit.2.memHeapUsed val=8.15, ack=true, ts=1499854547922, q=0, from=system.adapter.sayit.2, lc=1499854547922
          ! history.0 2017-07-12 12:16:24.984 debug inMem message * system.adapter.sayit.2.memHeapTotal val=12.41, ack=true, ts=1499854547922, q=0, from=system.adapter.sayit.2, lc=1499849337047
          ! history.0 2017-07-12 12:16:24.968 debug inMem message * system.adapter.sayit.2.memRss val=24.8, ack=true, ts=1499854547922, q=0, from=system.adapter.sayit.2, lc=1499853346031
          ! history.0 2017-07-12 12:16:24.968 debug inMem message * system.adapter.sayit.2.connected val=true, ack=true, ts=1499854547922, q=0, from=system.adapter.sayit.2, lc=1499844368875
          ! history.0 2017-07-12 12:16:24.968 debug inMem message * system.adapter.sayit.2.alive val=true, ack=true, ts=1499854547906, q=0, from=system.adapter.sayit.2, lc=1499844368875
          ! history.0 2017-07-12 12:16:24.968 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854547640, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:24.968 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854547640, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:24.968 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854547625, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:24.968 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854547625, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:24.953 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854547625, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:24.953 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854547625, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:22.499 debug moving 11 entries from hm-rega.0.65422 to file
          ! history.0 2017-07-12 12:16:22.499 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854547625, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:22.499 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854547625, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:19.765 debug moving 11 entries from hm-rega.0.25167 to file
          ! history.0 2017-07-12 12:16:19.765 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854547625, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:19.718 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854547625, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:19.718 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854547609, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:19.718 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854547609, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:19.703 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854547609, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:19.703 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854547609, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:19.703 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854547594, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:17.687 debug moving 11 entries from hm-rega.0.65422 to file
          ! history.0 2017-07-12 12:16:17.687 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854547594, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:17.687 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854547594, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:17.671 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854547594, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:17.656 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854547594, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:17.624 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854547594, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:14.921 debug moving 11 entries from hm-rega.0.25167 to file
          ! history.0 2017-07-12 12:16:14.921 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854547594, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:14.921 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854547594, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:14.906 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854547594, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:14.874 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854547594, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:14.859 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854547578, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:14.859 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854547578, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:14.843 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854547578, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:14.843 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854547578, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:12.093 debug moving 11 entries from hm-rega.0.65422 to file
          ! history.0 2017-07-12 12:16:12.093 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854547578, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:12.093 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854547578, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:12.078 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854547562, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:12.078 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854547562, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:09.515 debug moving 11 entries from hm-rega.0.25167 to file
          ! history.0 2017-07-12 12:16:09.515 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854547562, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:09.515 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854547562, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:09.499 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854547562, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:09.499 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854547547, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:09.499 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854547547, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:09.484 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854547547, q=0, from=system.adapter.javascript.0, lc=1499453851687
          ! history.0 2017-07-12 12:16:09.484 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854547547, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:06.921 debug moving 11 entries from hm-rega.0.65422 to file
          ! history.0 2017-07-12 12:16:06.921 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499854547547, q=0, from=system.adapter.javascript.0, lc=1499814503922
          ! history.0 2017-07-12 12:16:06.921 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499854547547, q=0, from=system.adapter.javascript.0, lc=1499453851687
          Hilft das zur Fehlereingrenzung?
          • apollon77
            Beim zweiten Log fehlt der Teil mit dem "crash" (also wenn wie vorher dann die "exception" und ein paar zeilen davor. Kannst Du bitte nochmal schauen ?!
              Die Exeption tritt leider nicht mehr auf, trotzdem wechselt der Adapter alle paar Minuten von grün nach rot und zurück.
              Hier noch einige Infos aus dem Log
              ! history.0 2017-07-12 12:46:06.265 info enabled logging of tankerkoenig.0.stations.0.e5.short
              ! history.0 2017-07-12 12:46:05.936 info starting. Version 1.6.2 in C:/iobroker/node_modules/iobroker.history, node: v4.4.7
              ! history.0 2017-07-12 12:45:22.593 debug statesDB connected
              ! history.0 2017-07-12 12:45:22.453 warn Reconnection to DB.
              ! history.0 2017-07-12 12:45:22.453 debug statesDB connected
              ! history.0 2017-07-12 12:45:21.093 debug transport close
              ! history.0 2017-07-12 12:45:21.093 debug inMem message * hm-rega.0.65422
              ! history.0 2017-07-12 12:45:21.093 debug inMem message * hm-rega.0.25167
              ! history.0 2017-07-12 12:45:21.078 debug inMem message * hm-rega.0.25167
              ! history.0 2017-07-12 12:45:21.078 debug inMem message * hm-rega.0.65422
              ! history.0 2017-07-12 12:40:41.155 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499855972015, q=0, from=system.adapter.javascript.0, lc=1499453851687
              ! history.0 2017-07-12 12:40:41.155 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499855972015, q=0, from=system.adapter.javascript.0, lc=1499814503922
              ! history.0 2017-07-12 12:40:41.139 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499855972015, q=0, from=system.adapter.javascript.0, lc=1499814503922
              ! history.0 2017-07-12 12:40:41.139 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499855972000, q=0, from=system.adapter.javascript.0, lc=1499814503922
              ! history.0 2017-07-12 12:40:38.499 debug moving 11 entries from hm-rega.0.25167 to file
              ! history.0 2017-07-12 12:40:38.499 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499855972000, q=0, from=system.adapter.javascript.0, lc=1499453851687
              ! history.0 2017-07-12 12:40:38.499 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499855972000, q=0, from=system.adapter.javascript.0, lc=1499814503922
              ! history.0 2017-07-12 12:40:38.483 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499855972000, q=0, from=system.adapter.javascript.0, lc=1499814503922
              ! history.0 2017-07-12 12:40:38.483 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499855972000, q=0, from=system.adapter.javascript.0, lc=1499453851687
              ! history.0 2017-07-12 12:40:38.483 debug inMem message * hm-rega.0.25167 val=true, ack=true, ts=1499855971984, q=0, from=system.adapter.javascript.0, lc=1499453851687
              ! history.0 2017-07-12 12:40:38.483 debug inMem message * hm-rega.0.65422 val=true, ack=true, ts=1499855971984, q=0, from=system.adapter.javascript.0, lc=1499814503922
              Adapter neu installieren?
              neue Instanz vom History installieren?
              • apollon77
                Wie geht es denn dem System an sich? Du hast geschrieben das es langsamer ist?
                Mal iobroker komplett stoppen, schauen das auch wirklich alls "io*" Prozesse weg sind und nicht irgendwas hängengeblieben ist und neu starten.
                neue Instanz oder so macht keinen Unterschied
                  so, hab dann auf dem Host unter iobroker/log doch noch einen EIntrag gefunden der evtl. weiterhilft:
                  ! 2017-07-11 20:50:30.281 - [32minfo[39m: host.HTPC instance system.adapter.tvspielfilm.0 terminated with code 0 (OK)
                  ! 2017-07-11 20:50:42.281 - [32minfo[39m: hm-rega.0 pollingTrigger
                  ! 2017-07-11 20:51:24.014 - [32minfo[39m: admin.0 Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
                  ! 2017-07-11 20:52:24.422 - [32minfo[39m: admin.0 Subscribe on all states again
                  ! 2017-07-11 20:52:40.031 - [32minfo[39m: hm-rega.0 pollingTrigger
                  ! 2017-07-11 20:52:57.484 - [32minfo[39m: admin.0 Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
                  ! 2017-07-11 20:53:57.719 - [32minfo[39m: admin.0 Subscribe on all states again
                  ! 2017-07-11 20:54:39.687 - [32minfo[39m: hm-rega.0 pollingTrigger
                  ! 2017-07-11 20:54:50.375 - [32minfo[39m: admin.0 Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
                  ! 2017-07-11 20:54:57.937 - [31merror[39m: history.0 uncaught exception: Maximum call stack size exceeded
                  ! 2017-07-11 20:55:00.639 - [32minfo[39m: host.HTPC instance system.adapter.tvspielfilm.0 started with pid 2796
                  ! 2017-07-11 20:54:57.969 - [31merror[39m: history.0 RangeError: Maximum call stack size exceeded
                  ! at Socket. <anonymous>(C:\iobroker\node_modules\iobroker.js-controller\lib\states\statesInMemClient.js:47:80)
                  ! at Socket.Emitter.emit (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\node_modules\component-emitter\index.js:133:20)
                  ! at Socket.onevent (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\socket.js:270:10)
                  ! at Socket.onpacket (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\socket.js:228:12)
                  ! at Manager. <anonymous>(C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\node_modules\component-bind\index.js:21:15)
                  ! at Manager.Emitter.emit (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\node_modules\component-emitter\index.js:133:20)
                  ! at Manager.ondecoded (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\manager.js:332:8)
                  ! at Decoder. <anonymous>(C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\node_modules\component-bind\index.js:21:15)
                  ! at Decoder.Emitter.emit (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\node_modules\socket.io-parser\node_modules\component-emitter\index.js:134:20)
                  ! at Decoder.add (C:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\node_modules\socket.io-parser\index.js:246:12)
                  ! 2017-07-11 20:55:03.625 - [33mwarn[39m: history.0 Reconnection to DB.
                  ! 2017-07-11 20:55:03.921 - [31merror[39m: host.HTPC instance system.adapter.history.0 terminated with code 6 (uncaught exception)
                  ! 2017-07-11 20:55:03.921 - [32minfo[39m: host.HTPC Restart adapter system.adapter.history.0 because enabled
                  ! 2017-07-11 20:55:05.765 - [32minfo[39m: tvspielfilm.0 starting. Version 0.2.2 in C:/iobroker/node_modules/iobroker.tvspielfilm, node: v4.4.7
                  ! 2017-07-11 20:55:05.844 - [32minfo[39m: tvspielfilm.0 objects written
                  ! 2017-07-11 20:55:07.905 - [32minfo[39m: host.HTPC instance system.adapter.tvspielfilm.0 terminated with code 0 (OK)
                  ! 2017-07-11 20:55:34.389 - [32minfo[39m: host.HTPC instance system.adapter.history.0 started with pid 5104
                  ! 2017-07-11 20:55:37.984 - [32minfo[39m: history.0 starting. Version 1.6.2 in C:/iobroker/node_modules/iobroker.history, node: v4.4.7
                  ! 2017-07-11 20:55:38.234 - [32minfo[39m: history.0 enabled logging of tankerkoenig.0.stations.0.e5.short
                  ! 2017-07-11 20:55:38.234 - [32mgeht die LAst auf 1% runter.info[39m: history.0 enabled logging of yr.0.forecast.day0.pressure
                  ! 2017-07-11 20:55:38.234 - [32minfo[39m: history.0 enabled logging of yr.0.forecast.day0.precipitation_level[/spoiler]</anonymous></anonymous></anonymous>
                  Das iobroker so langsam ist liegt wohl daran, das er auf dem Host die CPU Last durch die Decke treibt. Alle vier Kerne mit 100% am Anschlag.
                  Schalte ich den iobroker Dienst ab, geht die Last auf 1% runter.
                  • apollon77
                    Dann finde mal raus woran die Last liegt.
                    AM besten mal alle Adapter ausser Admin ausschalten und dann iobroker auch. Dann ioBroker starten und schrittweise die Adapter wieder aktivieren. Dann solltest Du den finden der es auslöst.
                    Wieviele Datenpunkte hast Du im History, sah nach nicht sooo vielen aus.
                      Es sieht so aus, das der Javascript Adapter die CPU Last treibt.
                      So, ich denke ich hab das Problem gefunden. War selbstgemacht :evil:
                      Ich habe eine CCU Sysvar mit dem History Adapter geloggt.
                      Diese Sysvar habe ich per Javascript mit einem "tr-064.0.devices.xxx.active" Datenpunkt aktualisiert. D.h. alle 10 Sekunden musste History was wegschreiben.
                      Nachdem dieses Script deaktiviert ist läuft alles wieder. VIS zeigt auch wieder Diagramme an.
                      Zu deiner letzten Frage, ich hab ca. 100 Datenpunkte in History geloggt. Gibt's da eine Grenze?
                      Und ja, Danke für deine Hilfe.
                      • apollon77
                        @Linedancer:
                        Zu deiner letzten Frage, ich hab ca. 100 Datenpunkte in History geloggt. Gibt's da eine Grenze? `
                        Die Grenze ist "I/O" - wie Du ja selbst gemerkt hast 🙂
                        Und i/o ist dann egal ob es durch wenige Datenpunkte mit vielen Aktualisierungen oder viele Datenpunkte verursacht wird.
                        Hoffe Du hast keine SD-Karte drunter … 🙂 Würde ich mittelfristig drüber nachdenken
                        Ingo F
                          @Linedancer:
                          Nicht dass ich wüsste:
                          History und SQL
                          auf den anderen Installationen um die 230.
                            @apollon77:
                            Hoffe Du hast keine SD-Karte drunter … 🙂 Würde ich mittelfristig drüber nachdenken `
                            Ne Ne, kein SD Karte
                            Meine iobroker Kiste ist ein Intel Atom mit 4GB Ram und einer 320GB Harddisc unter Windows 7 - 64Bit.
                            Vielleicht etwas oversized aber war halt "übrig".
                            • apollon77
                              Ich hab 3 Nucs 🙂 2x ioBroker mit 4GB RAM und 1x Influxdb und Tools mit 8 GB RAM 🙂
                              81.0k
                              1404
