    4. Homekit-controller lässt sich nicht installieren
      SirDrinsAlot last edited by
      Moin
      Hatte versucht den iobroker von raspberry auf einen Intel zu migrieren, aber egal ob unter windows oder linux, kann weder Homekit-controller noch vis installieren.
      Das bringt er als Fehler:
      code_text
      NPM version: 9.6.7
      Installing iobroker.homekit-controller@0.5.8... (System call)
      npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:66232) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T13_00_49_922Z-debug-0.log
      host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1
      ERROR: Process exited with code 25
      DJMarc75 Thomas Braun 2 Replies Last reply Reply Quote 0
      • DJMarc75
        DJMarc75 @SirDrinsAlot last edited by
        @sirdrinsalot
        https://forum.iobroker.net/topic/57337/fehler-25-217-oder-enotempty-bei-adapter-install-update
          Thomas Braun Most Active @SirDrinsAlot last edited by
          @sirdrinsalot sagte in Homekit-controller lässt sich nicht installieren:
          Was steht da drin?
            Der Error 25 Befehl ändert leider nix und das /home/iobroker/ Verzeichnis ist leer.
              Nein, ist es nicht.
              Dateien und Verzeichnisse, die mit einem Punkt beginnen sind ausgeblendet.
              ls -lAh /home/iobroker
              zeigt auch diese Dateien.
                Stimmt, sry bin eher windows user.
                0 verbose cli /usr/bin/node /usr/bin/npm
                1 info using npm@9.6.7
                2 info using node@v18.17.1
                3 timing npm:load:whichnode Completed in 1ms
                4 timing config:load:defaults Completed in 1ms
                5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 0ms
                6 timing config:load:builtin Completed in 0ms
                7 timing config:load:cli Completed in 2ms
                8 timing config:load:env Completed in 0ms
                9 timing config:load:file:/opt/iobroker/.npmrc Completed in 2ms
                10 timing config:load:project Completed in 2ms
                11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
                12 timing config:load:user Completed in 0ms
                13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
                14 timing config:load:global Completed in 0ms
                15 timing config:load:setEnvs Completed in 1ms
                16 timing config:load Completed in 8ms
                17 timing npm:load:configload Completed in 8ms
                18 timing npm:load:mkdirpcache Completed in 1ms
                19 timing npm:load:mkdirplogs Completed in 0ms
                20 verbose title npm install iobroker.homekit-controller@0.5.8
                21 verbose argv "install" "--save-exact" "--loglevel" "error" "iobroker.homekit-controller@0.5.8"
                22 timing npm:load:setTitle Completed in 1ms
                23 timing config:load:flatten Completed in 2ms
                24 timing npm:load:display Completed in 3ms
                25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2023-09-15T13_34_54_805Z-
                26 verbose logfile /home/iobroker/.npm/_logs/2023-09-15T13_34_54_805Z-debug-0.log
                27 timing npm:load:logFile Completed in 7ms
                28 timing npm:load:timers Completed in 0ms
                29 timing npm:load:configScope Completed in 0ms
                30 timing npm:load Completed in 21ms
                31 timing arborist:ctor Completed in 0ms
                32 silly logfile start cleaning logs, removing 2 files
                33 silly logfile done cleaning log files
                34 timing idealTree:init Completed in 1269ms
                35 timing idealTree:userRequests Completed in 2ms
                36 silly idealTree buildDeps
                37 silly fetch manifest iobroker.homekit-controller@0.5.8
                38 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
                39 http fetch GET 200 https://registry.npmjs.org/iobroker.homekit-controller 1537ms (cache revalidated)
                40 silly placeDep ROOT iobroker.homekit-controller@0.5.8 OK for: iobroker.inst@3.0.0 want: 0.5.8
                41 silly fetch manifest @iobroker/adapter-core@^2.6.7
                42 silly fetch manifest debug@^4.3.4
                43 silly fetch manifest hap-controller@^0.9.3
                44 silly fetch manifest @esm2cjs/p-queue@^7.3.0
                45 http fetch GET 200 https://registry.npmjs.org/debug 101ms (cache revalidated)
                46 http fetch GET 200 https://registry.npmjs.org/@iobroker%2fadapter-core 596ms (cache revalidated)
                47 http fetch GET 200 https://registry.npmjs.org/@esm2cjs%2fp-queue 1428ms (cache revalidated)
                48 http fetch GET 200 https://registry.npmjs.org/hap-controller 1609ms (cache revalidated)
                49 timing idealTree:#root Completed in 3167ms
                50 silly placeDep ROOT @esm2cjs/p-queue@7.3.0 OK for: iobroker.homekit-controller@0.5.8 want: ^7.3.0
                51 silly fetch manifest @esm2cjs/p-timeout@^5.0.2
                52 silly fetch manifest eventemitter3@^4.0.7
                53 silly placeDep node_modules/iobroker.homekit-controller @iobroker/adapter-core@2.6.8 OK for: iobroker.homekit-controller@0.5.8 want: ^2.6.7
                54 silly placeDep node_modules/iobroker.homekit-controller debug@4.3.4 OK for: iobroker.homekit-controller@0.5.8 want: ^4.3.4
                55 silly fetch manifest ms@2.1.2
                56 silly placeDep ROOT hap-controller@0.9.3 OK for: iobroker.homekit-controller@0.5.8 want: ^0.9.3
                57 silly fetch manifest @abandonware/noble@1.9.2-20
                58 silly fetch manifest dnssd@^0.4.1
                59 silly fetch manifest fast-srp-hap@^2.0.4
                60 silly fetch manifest http-parser-js@^0.5.8
                61 silly fetch manifest libsodium-wrappers@^0.7.11
                62 silly fetch manifest node-hkdf-sync@^1.0.0
                63 http fetch GET 200 https://registry.npmjs.org/http-parser-js 90ms (cache revalidated)
                64 http fetch GET 200 https://registry.npmjs.org/eventemitter3 407ms (cache revalidated)
                65 http fetch GET 200 https://registry.npmjs.org/ms 606ms (cache revalidated)
                66 http fetch GET 200 https://registry.npmjs.org/@abandonware%2fnoble 603ms (cache revalidated)
                67 http fetch GET 200 https://registry.npmjs.org/libsodium-wrappers 778ms (cache revalidated)
                68 http fetch GET 200 https://registry.npmjs.org/node-hkdf-sync 1094ms (cache revalidated)
                69 http fetch GET 200 https://registry.npmjs.org/fast-srp-hap 1214ms (cache revalidated)
                70 http fetch GET 200 https://registry.npmjs.org/@esm2cjs%2fp-timeout 1532ms (cache revalidated)
                71 http fetch GET 200 https://registry.npmjs.org/dnssd 1934ms (cache revalidated)
                72 timing idealTree:node_modules/iobroker.homekit-controller Completed in 1950ms
                73 silly placeDep ROOT @esm2cjs/p-timeout@5.1.0 OK for: @esm2cjs/p-queue@7.3.0 want: ^5.0.2
                74 silly placeDep node_modules/@esm2cjs/p-queue eventemitter3@4.0.7 OK for: @esm2cjs/p-queue@7.3.0 want: ^4.0.7
                75 timing idealTree:node_modules/@esm2cjs/p-queue Completed in 9ms
                76 timing idealTree:node_modules/@esm2cjs/p-timeout Completed in 0ms
                77 silly placeDep node_modules/hap-controller @abandonware/noble@1.9.2-20 OK for: hap-controller@0.9.3 want: 1.9.2-20
                78 silly fetch manifest node-addon-api@^4.3.0
                79 silly placeDep node_modules/hap-controller debug@4.3.4 OK for: hap-controller@0.9.3 want: ^4.3.4
                80 silly placeDep ROOT dnssd@0.4.1 OK for: hap-controller@0.9.3 want: ^0.4.1
                81 silly placeDep ROOT fast-srp-hap@2.0.4 OK for: hap-controller@0.9.3 want: ^2.0.4
                82 silly placeDep ROOT http-parser-js@0.5.8 OK for: hap-controller@0.9.3 want: ^0.5.8
                83 silly placeDep ROOT libsodium-wrappers@0.7.13 OK for: hap-controller@0.9.3 want: ^0.7.11
                84 silly fetch manifest libsodium@^0.7.13
                85 silly placeDep ROOT node-hkdf-sync@1.0.0 OK for: hap-controller@0.9.3 want: ^1.0.0
                86 silly fetch manifest vows@0.5.13
                87 http fetch GET 200 https://registry.npmjs.org/node-addon-api 88ms (cache revalidated)
                88 http fetch GET 200 https://registry.npmjs.org/libsodium 398ms (cache revalidated)
                89 http fetch GET 200 https://registry.npmjs.org/vows 1387ms (cache revalidated)
                90 timing idealTree:node_modules/hap-controller Completed in 1405ms
                91 timing idealTree:node_modules/dnssd Completed in 0ms
                92 timing idealTree:node_modules/fast-srp-hap Completed in 0ms
                93 timing idealTree:node_modules/http-parser-js Completed in 0ms
                94 silly placeDep ROOT libsodium@0.7.13 OK for: libsodium-wrappers@0.7.13 want: ^0.7.13
                95 timing idealTree:node_modules/libsodium-wrappers Completed in 4ms
                96 timing idealTree:node_modules/libsodium Completed in 0ms
                97 silly placeDep ROOT vows@0.5.13 OK for: node-hkdf-sync@1.0.0 want: 0.5.13
                98 timing idealTree:node_modules/node-hkdf-sync Completed in 4ms
                99 timing idealTree:node_modules/vows Completed in 0ms
                100 timing idealTree:node_modules/@esm2cjs/p-queue/node_modules/eventemitter3 Completed in 0ms
                101 silly placeDep node_modules/hap-controller node-addon-api@4.3.0 OK for: @abandonware/noble@1.9.2-20 want: ^4.3.0
                102 timing idealTree:node_modules/hap-controller/node_modules/@abandonware/noble Completed in 3ms
                103 silly placeDep node_modules/hap-controller ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
                104 timing idealTree:node_modules/hap-controller/node_modules/debug Completed in 1ms
                105 timing idealTree:node_modules/hap-controller/node_modules/ms Completed in 0ms
                106 timing idealTree:node_modules/hap-controller/node_modules/node-addon-api Completed in 0ms
                107 timing idealTree:node_modules/iobroker.homekit-controller/node_modules/@iobroker/adapter-core Completed in 0ms
                108 silly placeDep node_modules/iobroker.homekit-controller ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
                109 timing idealTree:node_modules/iobroker.homekit-controller/node_modules/debug Completed in 1ms
                110 timing idealTree:node_modules/iobroker.homekit-controller/node_modules/ms Completed in 0ms
                111 timing idealTree:buildDeps Completed in 6549ms
                112 timing idealTree:fixDepFlags Completed in 13ms
                113 timing idealTree Completed in 7847ms
                114 timing reify:loadTrees Completed in 7848ms
                115 timing reify:diffTrees Completed in 40ms
                116 silly reify moves {}
                117 timing reify:retireShallow Completed in 0ms
                118 timing reify:createSparse Completed in 2ms
                119 timing reify:loadBundles Completed in 0ms
                120 verbose reify failed optional dependency /opt/iobroker/node_modules/osx-temperature-sensor
                121 silly reify mark deleted [ '/opt/iobroker/node_modules/osx-temperature-sensor' ]
                122 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents
                123 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]
                124 timing reifyNode:node_modules/osx-temperature-sensor Completed in 9ms
                125 timing reifyNode:node_modules/fsevents Completed in 10ms
                126 timing reifyNode:node_modules/mdns/node_modules/bindings Completed in 168ms
                127 timing reifyNode:node_modules/authenticate-pam Completed in 168ms
                128 timing reifyNode:node_modules/hap-controller/node_modules/ms Completed in 170ms
                129 timing reifyNode:node_modules/iobroker.homekit-controller/node_modules/ms Completed in 170ms
                130 timing reifyNode:node_modules/node-gyp/node_modules/strip-ansi Completed in 170ms
                131 timing reifyNode:node_modules/node-gyp/node_modules/string-width Completed in 170ms
                132 timing reifyNode:node_modules/node-gyp/node_modules/is-fullwidth-code-point Completed in 171ms
                133 timing reifyNode:node_modules/node-gyp/node_modules/brace-expansion Completed in 171ms
                134 timing reifyNode:node_modules/node-gyp/node_modules/ansi-regex Completed in 171ms
                135 timing reifyNode:node_modules/node-gyp/node_modules/aproba Completed in 171ms
                136 timing reifyNode:node_modules/@abandonware/noble/node_modules/ms Completed in 171ms
                137 timing reifyNode:node_modules/http-parser-js Completed in 173ms
                138 timing reifyNode:node_modules/node-gyp/node_modules/string_decoder Completed in 177ms
                139 timing reifyNode:node_modules/node-gyp/node_modules/npmlog Completed in 177ms
                140 timing reifyNode:node_modules/node-gyp/node_modules/minimatch Completed in 178ms
                141 timing reifyNode:node_modules/hap-controller/node_modules/debug Completed in 181ms
                142 timing reifyNode:node_modules/iobroker.homekit-controller/node_modules/debug Completed in 180ms
                143 timing reifyNode:node_modules/@abandonware/noble/node_modules/debug Completed in 180ms
                144 timing reifyNode:node_modules/node-hkdf-sync Completed in 182ms
                145 timing reifyNode:node_modules/usocket Completed in 182ms
                146 timing reifyNode:node_modules/node-gyp/node_modules/are-we-there-yet Completed in 183ms
                147 timing reifyNode:node_modules/node-gyp/node_modules/glob Completed in 184ms
                148 timing reifyNode:node_modules/libsodium-wrappers Completed in 186ms
                149 timing reifyNode:node_modules/@esm2cjs/p-queue/node_modules/eventemitter3 Completed in 188ms
                150 timing reifyNode:node_modules/@esm2cjs/p-timeout Completed in 188ms
                151 timing reifyNode:node_modules/napi-thread-safe-callback Completed in 188ms
                152 timing reifyNode:node_modules/net-ping Completed in 195ms
                153 timing reifyNode:node_modules/buildcheck Completed in 195ms
                154 timing reifyNode:node_modules/raw-socket Completed in 201ms
                155 timing reifyNode:node_modules/node-gyp/node_modules/gauge Completed in 201ms
                156 timing reifyNode:node_modules/fast-srp-hap Completed in 203ms
                157 timing reifyNode:node_modules/iobroker.homekit-controller/node_modules/@iobroker/adapter-core Completed in 207ms
                158 timing reifyNode:node_modules/node-gyp/node_modules/readable-stream Completed in 211ms
                159 timing reifyNode:node_modules/libsodium Completed in 212ms
                160 timing reifyNode:node_modules/@esm2cjs/p-queue Completed in 214ms
                161 timing reifyNode:node_modules/hap-controller/node_modules/node-addon-api Completed in 222ms
                162 timing reifyNode:node_modules/@abandonware/noble/node_modules/node-addon-api Completed in 221ms
                163 timing reifyNode:node_modules/vows Completed in 231ms
                164 timing reifyNode:node_modules/raw-socket/node_modules/nan Completed in 248ms
                165 timing reifyNode:node_modules/mdns Completed in 253ms
                166 timing reifyNode:node_modules/hap-controller Completed in 282ms
                167 timing reifyNode:node_modules/cpu-features Completed in 300ms
                168 timing reifyNode:node_modules/dnssd Completed in 302ms
                169 timing reifyNode:node_modules/hap-controller/node_modules/@abandonware/noble Completed in 302ms
                170 timing reifyNode:node_modules/@abandonware/noble Completed in 300ms
                171 timing reifyNode:node_modules/node-gyp Completed in 307ms
                172 timing reifyNode:node_modules/iobroker.homekit-controller Completed in 329ms
                173 timing reify:unpack Completed in 331ms
                174 timing reify:unretire Completed in 0ms
                175 timing build:queue Completed in 3ms
                176 timing build:link:node_modules/dnssd Completed in 1ms
                177 timing build:link:node_modules/node-gyp Completed in 0ms
                178 timing build:link:node_modules/vows Completed in 0ms
                179 timing build:link Completed in 1ms
                180 info run @abandonware/noble@1.9.2-19 install node_modules/@abandonware/noble node-gyp-build
                181 info run authenticate-pam@1.0.5 install node_modules/authenticate-pam node-gyp rebuild
                182 info run cpu-features@0.0.9 install node_modules/cpu-features node buildcheck.js > buildcheck.gypi && node-gyp rebuild
                183 info run mdns@2.7.2 install node_modules/mdns node-gyp rebuild
                184 info run mdns@2.7.2 install { code: 1, signal: null }
                185 verbose reify failed optional dependency /opt/iobroker/node_modules/mdns
                186 silly reify mark deleted [ '/opt/iobroker/node_modules/mdns' ]
                187 verbose reify failed optional dependency /opt/iobroker/node_modules/mdns/node_modules/bindings
                188 silly reify mark deleted [ '/opt/iobroker/node_modules/mdns/node_modules/bindings' ]
                189 timing build:run:install:node_modules/mdns Completed in 551ms
                190 info run raw-socket@1.7.0 install node_modules/raw-socket node-gyp rebuild
                191 info run authenticate-pam@1.0.5 install { code: 1, signal: null }
                192 verbose reify failed optional dependency /opt/iobroker/node_modules/authenticate-pam
                193 silly reify mark deleted [ '/opt/iobroker/node_modules/authenticate-pam' ]
                194 timing build:run:install:node_modules/authenticate-pam Completed in 590ms
                195 info run usocket@0.3.0 install node_modules/usocket node-gyp rebuild
                196 info run cpu-features@0.0.9 install { code: 1, signal: null }
                197 verbose reify failed optional dependency /opt/iobroker/node_modules/cpu-features
                198 silly reify mark deleted [ '/opt/iobroker/node_modules/cpu-features' ]
                199 verbose reify failed optional dependency /opt/iobroker/node_modules/buildcheck
                200 silly reify mark deleted [ '/opt/iobroker/node_modules/buildcheck' ]
                201 timing build:run:install:node_modules/cpu-features Completed in 648ms
                202 info run @abandonware/noble@1.9.2-20 install node_modules/hap-controller/node_modules/@abandonware/noble node-gyp-build
                203 info run @abandonware/noble@1.9.2-19 install { code: 1, signal: null }
                204 verbose reify failed optional dependency /opt/iobroker/node_modules/@abandonware/noble
                205 silly reify mark deleted [ '/opt/iobroker/node_modules/@abandonware/noble' ]
                206 verbose reify failed optional dependency /opt/iobroker/node_modules/@abandonware/noble/node_modules/debug
                207 silly reify mark deleted [ '/opt/iobroker/node_modules/@abandonware/noble/node_modules/debug' ]
                208 verbose reify failed optional dependency /opt/iobroker/node_modules/@abandonware/noble/node_modules/node-addon-api
                209 silly reify mark deleted [
                209 silly reify   '/opt/iobroker/node_modules/@abandonware/noble/node_modules/node-addon-api'
                209 silly reify ]
                210 verbose reify failed optional dependency /opt/iobroker/node_modules/@abandonware/noble/node_modules/ms
                211 silly reify mark deleted [ '/opt/iobroker/node_modules/@abandonware/noble/node_modules/ms' ]
                212 timing build:run:install:node_modules/@abandonware/noble Completed in 685ms
                213 info run raw-socket@1.7.0 install { code: 1, signal: null }
                214 verbose reify failed optional dependency /opt/iobroker/node_modules/raw-socket
                215 silly reify mark deleted [ '/opt/iobroker/node_modules/raw-socket' ]
                216 verbose reify failed optional dependency /opt/iobroker/node_modules/net-ping
                217 silly reify mark deleted [ '/opt/iobroker/node_modules/net-ping' ]
                218 verbose reify failed optional dependency /opt/iobroker/node_modules/raw-socket/node_modules/nan
                219 silly reify mark deleted [ '/opt/iobroker/node_modules/raw-socket/node_modules/nan' ]
                220 timing build:run:install:node_modules/raw-socket Completed in 433ms
                221 info run usocket@0.3.0 install { code: 1, signal: null }
                222 verbose reify failed optional dependency /opt/iobroker/node_modules/usocket
                223 silly reify mark deleted [ '/opt/iobroker/node_modules/usocket' ]
                224 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp
                225 silly reify mark deleted [
                225 silly reify   '/opt/iobroker/node_modules/node-gyp',
                225 silly reify   '/opt/iobroker/node_modules/.bin/node-gyp'
                225 silly reify ]
                226 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/glob
                227 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/glob' ]
                228 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/npmlog
                229 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/npmlog' ]
                230 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/minimatch
                231 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/minimatch' ]
                232 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/are-we-there-yet
                233 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/are-we-there-yet' ]
                234 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/gauge
                235 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/gauge' ]
                236 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/brace-expansion
                237 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/brace-expansion' ]
                238 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/readable-stream
                239 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/readable-stream' ]
                240 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/aproba
                241 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/aproba' ]
                242 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/string-width
                243 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/string-width' ]
                244 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/strip-ansi
                245 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/strip-ansi' ]
                246 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/string_decoder
                247 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/string_decoder' ]
                248 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/is-fullwidth-code-point
                249 silly reify mark deleted [
                249 silly reify   '/opt/iobroker/node_modules/node-gyp/node_modules/is-fullwidth-code-point'
                249 silly reify ]
                250 verbose reify failed optional dependency /opt/iobroker/node_modules/node-gyp/node_modules/ansi-regex
                251 silly reify mark deleted [ '/opt/iobroker/node_modules/node-gyp/node_modules/ansi-regex' ]
                252 timing build:run:install:node_modules/usocket Completed in 435ms
                253 info run @abandonware/noble@1.9.2-20 install { code: 1, signal: null }
                254 timing reify:rollback:createSparse Completed in 51ms
                255 timing reify:rollback:retireShallow Completed in 0ms
                256 timing command:install Completed in 9458ms
                257 verbose stack Error: command failed
                257 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:53:27)
                257 verbose stack     at ChildProcess.emit (node:events:514:28)
                257 verbose stack     at maybeClose (node:internal/child_process:1091:16)
                257 verbose stack     at ChildProcess._handle.onexit (node:internal/child_process:302:5)
                258 verbose pkgid @abandonware/noble@1.9.2-20
                259 verbose cwd /opt/iobroker
                260 verbose Linux 6.1.0-12-amd64
                261 verbose node v18.17.1
                262 verbose npm  v9.6.7
                263 error code 1
                264 error path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noble
                265 error command failed
                266 error command sh -c node-gyp-build
                267 error (node:73159) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
                267 error (Use `node --trace-deprecation ...` to show where the warning was created)
                267 error Traceback (most recent call last):
                267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>
                267 error     sys.exit(gyp.script_main())
                267 error              ^^^^^^^^^^^^^^^^^
                267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_main
                267 error     return main(sys.argv[1:])
                267 error            ^^^^^^^^^^^^^^^^^^
                267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in main
                267 error     return gyp_main(args)
                267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_main
                267 error     [generator, flat_list, targets, data] = Load(
                267 error                                             ^^^^^
                267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Load
                267 error     result = gyp.input.Load(
                267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Load
                267 error     LoadTargetBuildFile(
                267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFile
                267 error     build_file_data = LoadOneBuildFile(
                267 error   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFile
                267 error     build_file_contents = open(build_file_path, "rU").read()
                267 error                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^
                267 error ValueError: invalid mode: 'rU' while trying to load binding.gyp
                267 error gyp ERR! configure error
                267 error gyp ERR! stack Error: `gyp` failed with exit code: 1
                267 error gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)
                267 error gyp ERR! stack     at ChildProcess.emit (node:events:514:28)
                267 error gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)
                267 error gyp ERR! System Linux 6.1.0-12-amd64
                267 error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                267 error gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noble
                267 error gyp ERR! node -v v18.17.1
                267 error gyp ERR! node-gyp -v v7.1.2
                267 error gyp ERR! not ok
                268 verbose exit 1
                269 timing npm Completed in 9617ms
                270 verbose unfinished npm timer reify 1694784894962
                271 verbose unfinished npm timer reify:build 1694784903192
                272 verbose unfinished npm timer build 1694784903193
                273 verbose unfinished npm timer build:deps 1694784903193
                274 verbose unfinished npm timer build:run:install 1694784903197
                275 verbose unfinished npm timer build:run:install:node_modules/hap-controller/node_modules/@abandonware/noble 1694784903869
                276 verbose code 1
                277 error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T13_34_54_805Z-debug-0.log
                  @abandonware/noble
                  Da kann @abandonware/noble nicht gebaut werden.
                  build-environment am Start?
                    Wenn ich wüsste was das wäre... Linux ist nicht mein Gebiet.
                      @sirdrinsalot
                      Lass mal sehen wie du da womit unterwegs bist.
                      iob diag
                      Langfassung.
                        SirDrinsAlot last edited by Homoran
                        Ohje, is ne Menge.
                         *** BASE SYSTEM ***
                         Static hostname: iobrokerNUC
                               Icon name: computer-desktop
                                 Chassis: desktop 🖥️
                              Machine ID: 5d7cb8cbe58a4a17a905354431cfbb8d
                                 Boot ID: 200f822a21c448e884941fd698e54ca1
                                  Kernel: Linux 6.1.0-12-amd64
                            Architecture: x86-64
                         Hardware Vendor: Default string
                          Hardware Model: Default string
                        Firmware Version: 5.27
                        model name      : Intel(R) N95
                        Docker          : false
                        Virtualization  : none
                        Kernel          : x86_64
                        Userland        : amd64
                        Systemuptime and Load:
                         16:48:21 up  3:32,  3 users,  load average: 0.43, 0.35, 0.26
                        CPU threads: 4
                        *** Time and Time Zones ***
                                       Local time: Fri 2023-09-15 16:48:21 CEST
                                   Universal time: Fri 2023-09-15 14:48:21 UTC
                                         RTC time: Fri 2023-09-15 14:48:21
                                      NTP service: active
                                  RTC in local TZ: no
                        *** User and Groups ***
                        root
                        /root
                        root
                        *** X-Server-Setup ***
                        X-Server:       true
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:             16G        5.5G        4.6G        210M        7.0G         11G
                        Swap:           1.0G          0B        1.0G
                        Total:           17G        5.5G        5.6G
                                15767 M total memory
                                 5258 M used memory
                                 1133 M active memory
                                 9391 M inactive memory
                                 4349 M free memory
                                  242 M buffer memory
                                 6451 M swap cache
                                  975 M total swap
                                    0 M used swap
                                  975 M free swap
                        *** FILESYSTEM ***
                        udev           devtmpfs  7.7G     0  7.7G   0% /dev
                        tmpfs          tmpfs     1.6G  1.5M  1.6G   1% /run
                        /dev/sda2      ext4      467G  9.8G  434G   3% /
                        tmpfs          tmpfs     7.7G  792K  7.7G   1% /dev/shm
                        tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
                        /dev/sda1      vfat      511M  5.9M  506M   2% /boot/efi
                        tmpfs          tmpfs     1.6G  3.7M  1.6G   1% /run/user/1000
                        [Fri Sep 15 13:15:34 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                        [Fri Sep 15 13:15:34 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                        Show mounted filesystems (real ones only):
                        TARGET               SOURCE    FSTYPE      OPTIONS
                        /                    /dev/sda2 ext4        rw,relatime,errors=remount-ro
                        |-/run/user/1000/doc portal    fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                        `-/boot/efi          /dev/sda1 vfat        rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
                        /var:
                        503M    /var/
                        231M    /var/cache
                        221M    /var/cache/apt
                        216M    /var/lib
                        145M    /var/cache/apt/archives
                        Archived and active journals take up 32.0M in the file system.
                        /opt/iobroker/backups:
                        71M     /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        784M    /opt/iobroker/iobroker-data/
                        698M    /opt/iobroker/iobroker-data/files
                        119M    /opt/iobroker/iobroker-data/files/vis-2
                        78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                        71M     /opt/iobroker/iobroker-data/files/vis-2/static
                        73M     /opt/iobroker/iobroker-data/objects.jsonl
                        41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
                        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.67295ba8.js.map
                        *** NodeJS-Installation ***
                        /usr/bin/nodejs         v18.17.1
                        /usr/bin/node           v18.17.1
                        /usr/bin/npm            9.6.7
                        /usr/bin/npx            9.6.7
                        nodejs:
                          Installed: 18.17.1-deb-1nodesource1
                          Candidate: 18.17.1-deb-1nodesource1
                          Version table:
                         *** 18.17.1-deb-1nodesource1 500
                                500 https://deb.nodesource.com/node_18.x bookworm/main amd64 Packages
                                100 /var/lib/dpkg/status
                             18.13.0+dfsg1-1 500
                                500 http://deb.debian.org/debian bookworm/main amd64 Packages
                        No problems detected
                        Errors in npm tree: 0
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        No configuration change needed.
                        Multihost discovery server: disabled
                        Discovery authentication:   enabled
                        Persistent activation:      disabled
                        Objects:                    jsonl on 127.0.0.1
                        States:                     jsonl on 127.0.0.1
                        Core adapters versions
                        js-controller:  5.0.12
                        admin:          6.10.1
                        javascript:     7.1.4
                        Adapters from github:   5
                        Adapter State
                        + system.adapter.admin.0                  : admin                 : iobrokerNUC                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                          system.adapter.admin.1                  : admin                 : iobrokerNUC                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                          system.adapter.alexa2.0                 : alexa2                : iobrokerNUC                              - disabled
                        + system.adapter.backitup.0               : backitup              : iobrokerNUC                              -  enabled
                          system.adapter.ble.0                    : ble                   : iobrokerNUC                              - disabled
                          system.adapter.broadlink2.0             : broadlink2            : iobrokerNUC                              - disabled
                          system.adapter.cameras.0                : cameras               : iobrokerNUC                              - disabled, port: 8200, bind: 0.0.0.0
                          system.adapter.chromecast.0             : chromecast            : iobrokerNUC                              - disabled
                          system.adapter.cloud.0                  : cloud                 : iobrokerNUC                              - disabled
                          system.adapter.daswetter.0              : daswetter             : iobrokerNUC                              - disabled
                          system.adapter.devices.0                : devices               : iobrokerNUC                              - disabled
                          system.adapter.discovery.0              : discovery             : iobrokerNUC                              - disabled
                          system.adapter.ecovacs-deebot.2         : ecovacs-deebot        : iobrokerNUC                              - disabled
                          system.adapter.ecovacs-deebot.3         : ecovacs-deebot        : iobrokerNUC                              - disabled
                          system.adapter.ecovacs-deebot.4         : ecovacs-deebot        : iobrokerNUC                              - disabled
                          system.adapter.energiefluss.0           : energiefluss          : iobrokerNUC                              - disabled
                          system.adapter.eusec.0                  : eusec                 : iobrokerNUC                              - disabled
                          system.adapter.feiertage.0              : feiertage             : iobrokerNUC                              - disabled
                          system.adapter.flot.0                   : flot                  : iobrokerNUC                              - disabled
                          system.adapter.fritzbox.0               : fritzbox              : iobrokerNUC                              - disabled
                          system.adapter.fritzdect.0              : fritzdect             : iobrokerNUC                              - disabled
                          system.adapter.fullcalendar.0           : fullcalendar          : iobrokerNUC                              - disabled
                          system.adapter.fullybrowser.0           : fullybrowser          : iobrokerNUC                              - disabled
                          system.adapter.govee-app.0              : govee-app             : iobrokerNUC                              - disabled
                          system.adapter.habpanel.0               : habpanel              : iobrokerNUC                              - disabled
                          system.adapter.history.0                : history               : iobrokerNUC                              - disabled
                          system.adapter.hm-rega.0                : hm-rega               : iobrokerNUC                              - disabled
                          system.adapter.hm-rpc.0                 : hm-rpc                : iobrokerNUC                              - disabled, port: 0
                          system.adapter.hm-rpc.1                 : hm-rpc                : iobrokerNUC                              - disabled, port: 0
                          system.adapter.homeconnect.0            : homeconnect           : iobrokerNUC                              - disabled
                          system.adapter.homekit-controller.0     : homekit-controller    : iobrokerNUC                              - disabled
                          system.adapter.homepilot20.0            : homepilot20           : iobrokerNUC                              - disabled
                          system.adapter.hue-extended.0           : hue-extended          : iobrokerNUC                              - disabled
                          system.adapter.hue.0                    : hue                   : iobrokerNUC                              - disabled, port: 443
                          system.adapter.ical.0                   : ical                  : iobrokerNUC                              - disabled
                          system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobrokerNUC                              - disabled
                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobrokerNUC                              - disabled
                          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobrokerNUC                              - disabled
                          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobrokerNUC                              - disabled
                          system.adapter.influxdb.0               : influxdb              : iobrokerNUC                              - disabled, port: 8090
                          system.adapter.info.0                   : info                  : iobrokerNUC                              - disabled
                          system.adapter.iot.0                    : iot                   : iobrokerNUC                              - disabled
                          system.adapter.javascript.0             : javascript            : iobrokerNUC                              - disabled
                          system.adapter.linux-control.0          : linux-control         : iobrokerNUC                              - disabled
                          system.adapter.material.0               : material              : iobrokerNUC                              - disabled
                          system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobrokerNUC                              - disabled, port: 54321
                          system.adapter.mihome.0                 : mihome                : iobrokerNUC                              - disabled, port: 9898, bind: 0.0.0.0
                          system.adapter.mobile.0                 : mobile                : iobrokerNUC                              - disabled
                          system.adapter.mqtt.0                   : mqtt                  : iobrokerNUC                              - disabled, port: 1888, bind: 0.0.0.0
                          system.adapter.musiccast.0              : musiccast             : iobrokerNUC                              - disabled
                          system.adapter.net-tools.0              : net-tools             : iobrokerNUC                              - disabled
                          system.adapter.netatmo.0                : netatmo               : iobrokerNUC                              - disabled
                          system.adapter.netatmo.1                : netatmo               : iobrokerNUC                              - disabled
                          system.adapter.node-red.0               : node-red              : iobrokerNUC                              - disabled, port: 1880, bind: 192.168.178.143
                          system.adapter.radar2.0                 : radar2                : iobrokerNUC                              - disabled
                          system.adapter.sayit.0                  : sayit                 : iobrokerNUC                              - disabled
                          system.adapter.scenes.0                 : scenes                : iobrokerNUC                              - disabled
                          system.adapter.shelly.0                 : shelly                : iobrokerNUC                              - disabled, port: 1886, bind: 0.0.0.0
                          system.adapter.simple-api.0             : simple-api            : iobrokerNUC                              - disabled, port: 8087, bind: 192.168.178.143, run as: admin
                          system.adapter.slideshow.0              : slideshow             : iobrokerNUC                              - disabled
                          system.adapter.smartthings.0            : smartthings           : iobrokerNUC                              - disabled
                          system.adapter.socketio.0               : socketio              : iobrokerNUC                              - disabled, port: 8085, bind: 0.0.0.0, run as: admin
                          system.adapter.sonoff.0                 : sonoff                : iobrokerNUC                              - disabled, port: 1883, bind: 192.168.178.143
                          system.adapter.sourceanalytix.0         : sourceanalytix        : iobrokerNUC                              - disabled
                          system.adapter.synology.0               : synology              : iobrokerNUC                              - disabled, port: 5000
                          system.adapter.telegram.0               : telegram              : iobrokerNUC                              - disabled, port: 8443, bind: 0.0.0.0
                          system.adapter.terminal.0               : terminal              : iobrokerNUC                              - disabled, port: 8088, bind: 0.0.0.0, run as: admin
                          system.adapter.text2command.0           : text2command          : iobrokerNUC                              - disabled
                          system.adapter.tileboard.0              : tileboard             : iobrokerNUC                              - disabled
                          system.adapter.tr-064.0                 : tr-064                : iobrokerNUC                              - disabled
                          system.adapter.tuya.0                   : tuya                  : iobrokerNUC                              - disabled
                          system.adapter.vis-2.0                  : vis-2                 : iobrokerNUC                              - disabled
                          system.adapter.vis-bars.0               : vis-bars              : iobrokerNUC                              - disabled
                          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobrokerNUC                              - disabled
                          system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobrokerNUC                              - disabled
                          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobrokerNUC                              - disabled
                          system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobrokerNUC                              - disabled
                          system.adapter.vis-history.0            : vis-history           : iobrokerNUC                              - disabled
                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobrokerNUC                              - disabled
                          system.adapter.vis-icontwo.0            : vis-icontwo           : iobrokerNUC                              - disabled
                          system.adapter.vis-inventwo.0           : vis-inventwo          : iobrokerNUC                              - disabled
                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobrokerNUC                              - disabled
                          system.adapter.vis-justgage.0           : vis-justgage          : iobrokerNUC                              - disabled
                          system.adapter.vis-keyboard.0           : vis-keyboard          : iobrokerNUC                              - disabled
                          system.adapter.vis-lcars.0              : vis-lcars             : iobrokerNUC                              - disabled
                          system.adapter.vis-map.0                : vis-map               : iobrokerNUC                              - disabled
                          system.adapter.vis-material-advanced.0  : vis-material-advanced : iobrokerNUC                              - disabled
                          system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobrokerNUC                              - disabled
                          system.adapter.vis-metro.0              : vis-metro             : iobrokerNUC                              - disabled
                          system.adapter.vis-players.0            : vis-players           : iobrokerNUC                              - disabled
                          system.adapter.vis-plumb.0              : vis-plumb             : iobrokerNUC                              - disabled
                          system.adapter.vis-rgraph.0             : vis-rgraph            : iobrokerNUC                              - disabled
                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobrokerNUC                              - disabled
                          system.adapter.vis-weather.0            : vis-weather           : iobrokerNUC                              - disabled
                          system.adapter.vis.0                    : vis                   : iobrokerNUC                              - disabled
                          system.adapter.web.0                    : web                   : iobrokerNUC                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                          system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobrokerNUC                              - disabled
                          system.adapter.wifilight.0              : wifilight             : iobrokerNUC                              - disabled
                          system.adapter.yeelight-2.0             : yeelight-2            : iobrokerNUC                              - disabled
                          system.adapter.yr.0                     : yr                    : iobrokerNUC                              - disabled
                          system.adapter.zigbee.0                 : zigbee                : iobrokerNUC                              - disabled, port: /dev/ttyUSB0
                          system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobrokerNUC                              - disabled
                        + instance is alive
                        ioBroker-Repositories
                        Active repo(s): stable
                        Installed ioBroker-Instances
                        Used repository: stable
                        Adapter    "admin"        : 6.8.0    , installed 6.10.1
                        Adapter    "alexa2"       : 3.24.1   , installed 3.25.2
                        Adapter    "backitup"     : 2.6.23   , installed 2.8.1
                        Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
                        Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
                        Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                        Adapter    "discovery"    : 3.1.0    , installed 4.0.0
                        Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
                        Adapter    "eusec"        : 1.1.2    , installed 1.1.2
                        Adapter    "feiertage"    : 1.1.0    , installed 1.1.4
                        Adapter    "fritzbox"     : 0.2.1    , installed 0.5.0
                        Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
                        Adapter    "fullcalendar" : 1.2.0    , installed 2.2.6
                        Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                        Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                        Adapter    "history"      : 2.2.6    , installed 2.2.6
                        Adapter    "hm-rega"      : 3.0.47   , installed 4.0.0
                        Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
                        Adapter    "hue"          : 3.9.5    , installed 3.10.0
                        Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
                        Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
                        Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                        Adapter    "info"         : 1.9.26   , installed 2.0.0
                        Adapter    "iot"          : 1.14.5   , installed 2.0.11
                        Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                        Controller "js-controller": 5.0.12   , installed 5.0.12
                        Adapter    "linux-control": 1.1.5    , installed 1.1.5
                        Adapter    "material"     : 1.3.1    , installed 1.3.1
                        Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                        Adapter    "mihome-vacuum": 3.11.0   , installed 4.0.0
                        Adapter    "mobile"       : 1.0.1    , installed 1.0.1
                        Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                        Adapter    "musiccast"    : 1.1.0    , installed 1.1.0
                        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                        Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                        Adapter    "radar2"       : 2.0.7    , installed 2.0.7
                        Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                        Adapter    "shelly"       : 6.4.1    , installed 6.4.1
                        Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
                        Adapter    "socketio"     : 6.5.5    , installed 6.5.3  [Updatable]
                        Adapter    "sonoff"       : 2.5.3    , installed 2.5.7
                        Adapter    "synology"     : 2.1.13   , installed 3.0.0
                        Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                        Adapter    "text2command" : 3.0.2    , installed 3.0.2
                        Adapter    "tuya"         : 3.14.2   , installed 3.14.2
                        Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
                        Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                        Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                        Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                        Adapter    "vis-material-advanced": 1.7.2, installed 1.7.4
                        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                        Adapter    "web"          : 6.1.2    , installed 6.1.1  [Updatable]
                        Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                        Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
                        Adapter    "ws"           : 2.5.5    , installed 2.5.3  [Updatable]
                        Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
                        Adapter    "yr"           : 5.3.0    , installed 5.3.0
                        Adapter    "zigbee"       : 1.8.23   , installed 1.8.24
                        Adapter    "zigbee2mqtt"  : 2.13.1   , installed 2.13.1
                        Objects and States
                        Objects:        37997
                        States:         31034
                        W: http://deb.anydesk.com/dists/all/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                        Hit:1 https://deb.nodesource.com/node_18.x bookworm InRelease
                        Hit:2 http://deb.debian.org/debian bookworm InRelease
                        Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
                        Hit:4 http://deb.anydesk.com all InRelease
                        Reading package lists...
                        Pending Updates: 0
                        *** Listening Ports ***
                        tcp        0      0 0.0.0.0:37838           0.0.0.0:*               LISTEN      0          188418     28229/anydesk
                        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          21612      662/cupsd
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       212660     43636/iobroker.js-c
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       211792     43636/iobroker.js-c
                        tcp        0      0 0.0.0.0:7070            0.0.0.0:*               LISTEN      0          145110     28229/anydesk
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          166031     33594/sshd: /usr/sb
                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          135901     1/init
                        tcp        0      0 127.0.0.1:4101          0.0.0.0:*               LISTEN      0          21672      544/brltty
                        tcp6       0      0 ::1:4101                :::*                    LISTEN      0          17962      544/brltty
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       211857     43667/io.admin.0
                        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          21611      662/cupsd
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          166033     33594/sshd: /usr/sb
                        tcp6       0      0 :::111                  :::*                    LISTEN      0          136579     1/init
                        udp        0      0 0.0.0.0:56190           0.0.0.0:*                           103        17893      594/avahi-daemon: r
                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          137387     1/init
                        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          23634      907/cups-browsed
                        udp        0      0 0.0.0.0:50001           0.0.0.0:*                           0          146842     28229/anydesk
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           103        17891      594/avahi-daemon: r
                        udp6       0      0 :::111                  :::*                                0          136581     1/init
                        udp6       0      0 :::52127                :::*                                103        17894      594/avahi-daemon: r
                        udp6       0      0 :::5353                 :::*                                103        17892      594/avahi-daemon: r
                        2023-09-15 15:18:57.566  - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call)
                        2023-09-15 15:19:42.074  - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:69843) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T13_18_57_748Z-debug-0.log
                        2023-09-15 15:19:42.074  - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1
                        2023-09-15 15:19:43.092  - info: host.iobrokerNUC iobroker exit 25
                        2023-09-15 15:23:58.531  - info: host.iobrokerNUC iobroker add homekit-controller --host iobrokerNUC
                        2023-09-15 15:23:59.537  - info: host.iobrokerNUC iobroker NPM version: 9.6.7
                        2023-09-15 15:23:59.537  - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call)
                        2023-09-15 15:24:04.010  - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:70887) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T13_23_59_740Z-debug-0.log
                        2023-09-15 15:24:04.011  - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1
                        2023-09-15 15:24:05.036  - info: host.iobrokerNUC iobroker exit 25
                        2023-09-15 15:34:53.572  - info: host.iobrokerNUC iobroker add homekit-controller --host iobrokerNUC
                        2023-09-15 15:34:54.600  - info: host.iobrokerNUC iobroker NPM version: 9.6.7
                        2023-09-15 15:34:54.601  - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call)
                        2023-09-15 15:35:04.442  - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:73159) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T13_34_54_805Z-debug-0.log
                        2023-09-15 15:35:04.443  - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1
                        2023-09-15 15:35:05.468  - info: host.iobrokerNUC iobroker exit 25
                        2023-09-15 16:34:59.946  - info: admin.0 (43667) ==> Connected system.user.admin from ::ffff:192.168.178.105
                        2023-09-15 16:35:01.497  - info: host.iobrokerNUC Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                        2023-09-15 16:39:44.533  - info: admin.0 (43667) <== Disconnect system.user.admin from ::ffff:192.168.178.105
                        2023-09-15 16:39:53.534  - info: host.iobrokerNUC iobroker add homekit-controller --host iobrokerNUC
                        2023-09-15 16:39:54.568  - info: host.iobrokerNUC iobroker NPM version: 9.6.7
                        2023-09-15 16:39:54.569  - info: host.iobrokerNUC iobroker Installing iobroker.homekit-controller@0.5.8... (System call)
                        2023-09-15 16:40:03.838  - error: host.iobrokerNUC iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! (node:85655) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! Traceback (most recent call last):npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR!     sys.exit(gyp.script_main())npm ERR!              ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR!     return main(sys.argv[1:])npm ERR!            ^^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR!     return gyp_main(args)npm ERR!            ^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR!     [generator, flat_list, targets, data] = Load(npm ERR!                                             ^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR!     result = gyp.input.Load(npm ERR!              ^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR!     LoadTargetBuildFile(npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR!     build_file_data = LoadOneBuildFile(npm ERR!                       ^^^^^^^^^^^^^^^^^npm ERR!   File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR!     build_file_contents = open(build_file_path, "rU").read()npm ERR!                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:514:28)npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:291:12)npm ERR! gyp ERR! System Linux 6.1.0-12-amd64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/hap-controller/node_modules/@abandonware/noblenpm ERR! gyp ERR! node -v v18.17.1npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-09-15T14_39_54_749Z-debug-0.log
                        2023-09-15 16:40:03.838  - error: host.iobrokerNUC iobroker host.iobrokerNUC Cannot install iobroker.homekit-controller@0.5.8: 1
                        2023-09-15 16:40:04.857  - info: host.iobrokerNUC iobroker exit 25
                                             v.2023-06-20
                                 Chassis: desktop 🖥️
                        Userland:               amd64
                        User-ID:                0
                        X-Server:               true
                        Pending OS-Updates:     0
                          @sirdrinsalot
                          Statt spoiler die codetags verwenden.
                            HAt nicht funktioniert, kam Forbidden, sry.
                              User-ID: 0
                              X-Server: true
                              Root und Desktop...
                              'nuff seen.
                              Schalt den Krampf aus und agier da als Standard-User.
                                @thomas-braun sagte in Homekit-controller lässt sich nicht installieren:
                                @sirdrinsalot
                                habs gefixt
                                  Thomas Braun Most Active @Homoran last edited by Thomas Braun
                                  @homoran sagte in Homekit-controller lässt sich nicht installieren:
                                  habs gefixt
                                  Den Desktop und den root? Respekt!
                                    habs gefixt
                                    Natürlich!
                                    ist jetzt forbidden!
                                    Thomas Braun 1 Reply Last reply Reply Quote 1
                                      Mein Standarduser hat keine Rootrechte, hat mich nur im Nachhinein als root angemeldet für Reparaturversuche.
                                      Ohne root hats eben auch nicht funktioniert.
                                        Ja, das ohnehin. AnyDesk ist auch verboten.
                                          Homoran Global Moderator Administrators @SirDrinsAlot last edited by Homoran
                                          @sirdrinsalot und root verbiegt noch die letzten Rechte vom user iobroker
                                          dann nimm jetzt den root und gib deinem user roottechte.
                                          melde dich dann als user an und mach
                                          iob stop
                                          iob fix
                                          iob start
                                            Richtig, der sollte aber per sudo in die root-Rolle wechseln können. Man meldet sich niemals als root an. Schon gar nicht auf einem Desktop.
                                            2106
