    4. Fehler im web.0
    Fehler im web.0
      Mic905 last edited by Mic905
      ich habe gestern mein System auf aktuellen Stand gebracht und seit dem bekomme ich ständig folgende Fehlermeldungen:
      web.0
      289725	2023-09-16 07:00:38.030	error	Invalid pattern on subscribe: The pattern "Last Check <p>16.09.2023 - 07:00:37" is not a valid ID pattern
      web.0
      289725	2023-09-16 06:59:45.723	error	Invalid pattern on subscribe: The pattern "Last Check <p>16.09.2023 - 06:59:45" is not a valid ID pattern
      web.0
      289725	2023-09-16 06:59:14.717	error	Cannot subscribe "Last Check <p>16.09.2023 - 06:59:14": Error The pattern "Last Check <p>16.09.2023 - 06:59:14" is not a valid ID pattern
      host.iobroker-ubuntu-Server States 127.0.0.1:40668 Error from InMemDB: Error: The pattern "Last Check <p>16.09.2023 - 07:14:56" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StatesInMemoryServer.handleSubscribe (/opt/iobroker/node_modules/@iobroker/db-base/src/lib/inMemFileDB.ts:324:59) at StatesInMemoryServer._subscribeForClient (/opt/iobroker/node_modules/@iobroker/db-states-file/src/lib/states/statesInMemFileDB.js:258:14) at RedisHandler.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-jsonl/src/lib/states/statesInMemServerRedis.js:395:26) at RedisHandler.emit (node:events:514:28) at RedisHandler.emit (node:domain:489:12) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/db-base/src/lib/redisHandler.ts:209:37) at processImmediate (node:internal/timers:476:21)
      Kann mir hier jemand weiterhelfen? Der Neustart des Systems war ohne Erfolg.
      Schonmal vielen Dank
      Systemdata
      Hardwaresystem: Fujitsu Q520
      Arbeitsspeicher: 4GB
      Festplattenart: SSD
      Betriebssystem: Ubuntu
      Node-Version: 18.17.1
      Nodejs-Version: 18.17.1
      NPM-Version: 9.6.7
      Installationsart: Manuell
      Image genutzt: Nein
      sigi234 Scrounger 2 Replies Last reply Reply Quote 0
      • sigi234
        sigi234 Forum Testing Most Active @Mic905 last edited by
        @mic905 sagte in Fehler im web.0:
        valid ID pattern
        Fehler bekannt, suche mal nach: valid ID pattern
        • Scrounger
          Scrounger Developer @Mic905 last edited by
          @mic905
          https://github.com/ioBroker/ioBroker.js-controller/issues/2431
          Scrounger created this issue in ioBroker/ioBroker.js-controller
          closed Error: Invalid pattern on subscribe #2431
          • mcm1957
            mcm1957 last edited by
            @mic905
            js-controller 5 meldet nunmehr ungültige Bindings. Es sollte allerdings mit den aktuellen Versionen von web/ws/sockeitio im stable kein Absturz mehr auftreten.
            In den meisten Fällen ist ein ungültiges Binding in deiner vis die Ursache und muss dort behoben werden. Es dürfte aber auch spezielle Fälle geben wo ein fehler in VIS die Ursache sein könnte.
            Details siehe https://github.com/ioBroker/ioBroker.js-controller/issues/2431 und auch https://forum.iobroker.net/topic/68290/js-controller-5-0-x-jetzt-für-alle-user-im-stable/100
