    4. Performance Probleme durch Shelly Adapter?
      Schtallone last edited by
      seit einigen Tagen bemerke ich Performance-Probeme im ioBroker. Oft können z.b. die Instancen nicht angeigt werden. Ich habe den Shelly Adapter in Verdacht, da dieser häufig folgende Fehlermeldung ausgibt:
      2023-09-16 10:08:19.966  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b8d61a8b94fc"
      2023-09-16 10:08:19.967  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-5443b23fd3dc"
      2023-09-16 10:08:19.968  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-5443b23d6114"
      2023-09-16 10:08:19.968  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus1-441793a820f4"
      2023-09-16 10:08:20.526  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-a8032ab96370"
      2023-09-16 10:08:21.305  - info: shelly.0 (31449) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-5443b23d6114 / shellyplus2pm#5443b23d6114#1) (false)
      2023-09-16 10:08:21.309  - info: shelly.0 (31449) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-5443b23e5f74 / shellyplus2pm#5443b23e5f74#1) (false)
      2023-09-16 10:08:21.790  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-4022d8da969c"
      2023-09-16 10:08:21.794  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b8d61a8abb7c"
      2023-09-16 10:08:21.795  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-a8032ab96980"
      2023-09-16 10:08:21.795  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-485519a2a5d4"
      2023-09-16 10:08:21.935  - info: shelly.0 (31449) [MQTT] Device with client id "shellyplus2pm-4022d8dbe474" connected!
      2023-09-16 10:08:22.320  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b8d61a876248"
      2023-09-16 10:08:24.058  - info: shelly.0 (31449) [MQTT] Device with client id "shellyplus1pm-a8032ab96980" connected!
      2023-09-16 10:08:24.359  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-7c87ce65d794"
      2023-09-16 10:08:24.359  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-7c87ce65d970"
      2023-09-16 10:08:24.360  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-a8032ab94e10"
      2023-09-16 10:08:24.360  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b8d61a8bf730"
      2023-09-16 10:08:24.360  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-5443b23e5f74"
      2023-09-16 10:08:24.360  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-3c610579bd34"
      2023-09-16 10:08:24.361  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-a8032ab94e10"
      2023-09-16 10:08:24.361  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-441793acae2c"
      2023-09-16 10:08:24.361  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-a8032ab96370"
      2023-09-16 10:08:24.479  - info: shelly.0 (31449) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-b8d61a863524 / shellyplus2pm#b8d61a863524#1) (false)
      2023-09-16 10:08:24.525  - info: shelly.0 (31449) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-b8d61a8abb7c / shellyplus2pm#b8d61a8abb7c#1) (false)
      2023-09-16 10:08:24.606  - info: shelly.0 (31449) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-b8d61a8b94fc / shellyplus2pm#b8d61a8b94fc#1) (false
      Hat jemand eine Idee oder ähnliche Probleme?
      Was benötigt Ihr noch von mir als Infos?
      Vielen Dank und Gruß
      Homoran Glasfaser 3 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @Schtallone last edited by Homoran
        @schtallone
        ist deine andere Baustelle komplett erledigt?
        https://forum.iobroker.net/post/1044181
        selbst wenn, dann nicht bereits
        @schtallone sagte in Performance Probleme durch Shelly Adapter?:
        seit einigen Tagen
        und weder das englische Forum noch die Kategorie Bug (von iobroker) ist passend
          Schtallone @Homoran last edited by
          ja, ich habe wieder Zugriff. ICh denke aber das dieses Performance Problem mit dazu gehört. Ich habe aber dafür dann einen eigenen Thread aufgemacht, leider ja in falschem Bereich....
            Kannst Du das in das richtige Forum schieben? Sorry und Danke
              @schtallone erledigt!
                ich auch!
                also entweder doch nicht komplett gelöst, oder auch die Shellys kommen nicht rein
                  @homoran Aber die Daten kommen ja an, also schein zzugriff auf die Shellys zu funktionieren. Zumindest teilweise.
                  Ist vielleicht das Intervall mit 15s Abfragezzeit (Default-Wert) zu viel des Guten?
                    @homoran said in Performance Probleme durch Shelly Adapter?:
                    ich auch!
                    Gbit es eine Art Performance Monitor, welcher mir zeigen könnte, welche Recourcen der iobroker bei welchem Adapter verwendet? Der belegte RAM por Adapter sagt doch nicht so viel aus, oder?
                    Dann könnte man ja den/die Übeltäter ggf. indetifizieren.
                      nennt sich top
                        top
                        top - 11:24:42 up 20:49,  0 users,  load average: 11,64, 10,50, 9,33
                        Tasks:  35 total,   2 running,  33 sleeping,   0 stopped,   0 zombie
                        %Cpu(s): 60,3 us, 35,6 sy,  0,0 ni,  0,0 id,  3,1 wa,  0,0 hi,  1,0 si,  0,0 st
                        MiB Mem :   7792,2 total,    382,3 free,   5621,0 used,   1789,0 buff/cache
                        MiB Swap:  23447,2 total,  21723,8 free,   1723,4 used.   1402,6 avail Mem
                          PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
                          453 iobroker  20   0   11,2g 346132  13608 R  42,8   4,3 382:34.44 iobroker.js-con
                         1071 iobroker  20   0 1107856 496636  11188 S  12,7   6,2 265:04.48 io.device-watch
                        32461 iobroker  20   0 1037420 173836  29084 S   9,8   2,2   4:49.51 io.shelly.0
                        31327 iobroker  20   0   21,0g 178732  29500 S   2,3   2,2   2:23.76 node-red
                         1082 iobroker  20   0  961136  48932  11872 S   0,7   0,6   1:01.23 io.cloud.0
                         1167 iobroker  20   0  847028 123344  10764 S   0,7   1,5  17:41.63 io.javascript.0
                         1854 iobroker  20   0  700064  75264  10420 S   0,7   0,9  10:41.33 io.jarvis.0
                          486 iobroker  20   0 1062628 154228  14452 S   0,3   1,9   3:14.73 io.admin.0
                         1119 iobroker  20   0  683472  66092  28988 S   0,3   0,8   0:04.52 io.pvforecast.0
                         1174 iobroker  20   0  697508  43884  10460 S   0,3   0,5   0:43.09 io.modbus.0
                         1189 iobroker  20   0  781124  60116   9308 S   0,3   0,8   5:03.98 io.mqtt.0
                         1644 iobroker  20   0  691912  40832  10604 S   0,3   0,5   0:49.32 io.snmp.0
                         1861 iobroker  20   0  705392  50536  10576 S   0,3   0,6   1:37.57 io.influxdb.0
                        31312 iobroker  20   0  685056  70144  28884 S   0,3   0,9   0:05.37 io.node-red.0
                            1 root      20   0    7372    204    204 S   0,0   0,0   0:00.07 bash
                          499 iobroker  20   0  866600  78152   9984 S   0,0   1,0   1:41.61 io.admin.1
                          516 iobroker  20   0   10,9g  36644  11560 S   0,0   0,5   0:24.09 io.backitup.0
                         1056 iobroker  20   0  687888  35920   9224 S   0,0   0,5   0:46.48 io.energiefluss
                         1196 iobroker  20   0  699244  29936   9480 S   0,0   0,4   0:24.00 io.mqtt.1
                         1390 iobroker  20   0  959208  47588  11420 S   0,0   0,6   0:35.27 io.netatmo.0
                         1423 iobroker  20   0  693820  42312  11180 S   0,0   0,5   0:25.44 io.shuttercontr
                         1655 iobroker  20   0  705512  61428  11776 S   0,0   0,8   1:12.40 io.sourceanalyt
                         1666 iobroker  20   0  757796  23380   9028 S   0,0   0,3   0:21.21 io.termin
                        sieht nicht auffällig aus bzgl. Shelly`
                          naja, aber...
                          dein gesamtes System klemmt gewaltig.
                            ja das merke ich auch irgendwie. Nur finde ich (aufgrund "keine Ahnung") nicht das Problem...
                              ticaki Developer @Schtallone last edited by ticaki
                              @schtallone
                              Sortiere die Ausgabe mal nach CPU Zeit.
                              Was steht beim device watcher bei Ereignissen? Ist das wo auf meinem Bild 1868 / 1879 steht.
                                Schtallone @ticaki last edited by
                                @ticaki
                                Ich habe vor 20 min mal den device watcher ausgeschaltet.
                                top - 12:22:05 up 21:46,  0 users,  load average: 7,08, 7,24, 7,59
                                Tasks:  37 total,   2 running,  35 sleeping,   0 stopped,   0 zombie
                                %Cpu(s): 36,9 us, 21,1 sy,  0,0 ni, 12,1 id, 29,2 wa,  0,0 hi,  0,7 si,  0,0 st
                                MiB Mem :   7792,2 total,   1012,2 free,   5113,5 used,   1666,5 buff/cache
                                MiB Swap:  23447,2 total,  21722,4 free,   1724,8 used.   1911,4 avail Mem
                                  453 iobroker  20   0   11,2g 298988  10992 S   5,3   3,7 396:15.25 iobroker.js-con
                                32461 iobroker  20   0 1062764 204584  11836 S   2,0   2,6   8:16.99 io.shelly.0
                                31327 iobroker  20   0   21,0g 167288  12832 S   1,7   2,1   3:54.99 node-red
                                 1167 iobroker  20   0  851380 126644   9148 S   0,7   1,6  18:48.56 io.javascript.0
                                 1390 iobroker  20   0  960232  46568  10124 R   0,7   0,6   0:37.93 io.netatmo.0
                                 1854 iobroker  20   0  694088  67636   9896 S   0,7   0,8  11:39.10 io.jarvis.0
                                  486 iobroker  20   0 1063652 151672   9988 S   0,3   1,9   3:27.47 io.admin.0
                                 1423 iobroker  20   0  694844  42024   9476 S   0,3   0,5   0:27.42 io.shuttercontr
                                 1655 iobroker  20   0  705512  61012   9400 S   0,3   0,8   1:29.35 io.sourceanalyt
                                 1831 iobroker  20   0  952040  32844  10696 S   0,3   0,4   0:23.47 io.pushover.0
                                 3859 root      20   0   10308   2204   1724 S   0,3   0,0   0:03.83 top
                                 3878 root      20   0   10308   2144   1676 R   0,3   0,0   0:03.79 top
                                  499 iobroker  20   0  866856  76112   8560 S   0,0   1,0   1:46.15 io.admin.1
                                  516 iobroker  20   0   10,9g  48316   9540 S   0,0   0,6   0:25.88 io.backitup.0
                                 1056 iobroker  20   0  689424  40376   8428 S   0,0   0,5   0:51.22 io.energiefluss
                                 1082 iobroker  20   0  961136  47388   9816 S   0,0   0,6   1:04.70 io.cloud.0
                                 1119 iobroker  20   0  950440  51728  12392 S   0,0   0,6   0:08.78 io.pvforecast.0
                                 1174 iobroker  20   0  697508  42024   8908 S   0,0   0,5   0:46.79 io.modbus.0
                                 1189 iobroker  20   0  779844  60304   8884 S   0,0   0,8   5:30.04 io.mqtt.0
                                 1196 iobroker  20   0  700524  29568   8512 S   0,0   0,4   0:25.82 io.mqtt.1
                                 1644 iobroker  20   0  691912  39412   8984 S   0,0   0,5   0:53.31 io.snmp.0
                                 1666 iobroker  20   0  758052  22932   8364 S   0,0   0,3   0:22.84 io.terminal.0
                                ist seit dem auch im Log ruhiger
                                Ich mache den device watcher nochmals an und teile die ergebnisse
                                Homoran Glasfaser 2 Replies Last reply Reply Quote 0
                                  auch im Log ruhiger
                                  aber hier ist immer noch viel zu viel
                                    was wäre denn ein sinnvoller Wert? Ist das average % CPU?
                                      nein, das ist die Load average der letzten, letzten 5 und letzren 10 Minuten.
                                      Das beinhaltet einige Parameter
                                      dieser Wert s8llte die Anzahl Kerne nicht überschreiten, liegt bei vernünftiger Installation meist unter 1.
                                        Schtallone @Homoran last edited by Schtallone
                                        oh! Hmm. Aufgrund von "keine Ahnung" kann es sein, dass ich hier eine miese Installation habe.
                                        Jetzt ist guter Rat teuer.... Wie kann ich dem denn vernünftig Herr werden? Bzgl. gibt es kardinalfehler, die dieses VErhalten erzeugen/begünstigen?
                                        Und dann kann nicht an der Performance meines NAS liegen?
                                          das hab ich ja bereits im anderen Thread befürchtet.
                                          Habe aber auch dort keinerlei Informationen zu deinem System gefunden, ausser x86_amd64.
                                          was ist das denn für ein NAS?
                                          was sagt denn iob diag
                                          S Homoran 2 Replies Last reply Reply Quote 0
                                            @Homoran
                                            Copy text starting here:
        v.2023-06-20
                                            model name      : Intel(R) Celeron(R) J4005 CPU @ 2.00GHz
                                            Kernel          : x86_64
                                            Userland        : amd64
                                            Docker          : v8.1.0
                                            Installation:           Docker
                                            Userland:               amd64
                                            Timezone:               Etc/UTC
                                            User-ID:                0
                                            X-Server:               false
                                            Pending OS-Updates:     0
                                            Pending iob updates:    0
                                            Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
        /usr/bin/node           v18.17.1
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
                                            Recommended versions are nodejs 18.x.y and npm 9.x.y
                                            MEMORY:
                                            Mem:            7.8G        5.3G        854M        238M        1.6G        1.6G
                                            Swap:            23G        1.7G         21G
                                            Total:           31G        7.0G         22G
                                            Active iob-Instances:   23
                                            Active repo(s): beta
                                            ioBroker Core:          js-controller           5.0.12
        admin                   6.10.1
                                            Objects type: jsonl
                                            States  type: jsonl
                                            + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                            + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                            Objects:                10441
                                            States:                 8960
                                            Size of iob-Database:
                                            32M     /opt/iobroker/iobroker-data/objects.jsonl
                                            16M     /opt/iobroker/iobroker-data/states.jsonl
                                            === Mark text until here for copying ===
                                            256
                                            40929
