    4. SolarLog Adapt keine Funktion seit js-controller 5.0.x
      Karacho last edited by
      Hallo Gemeinde,
      seit dem Update auf JS-Controller 5.x funktioniert der Solarlog Adapter nicht mehr.
      Gruss
      Karacho
      host.raspberrypi4-iob
      2023-09-19 10:52:59.754	error	instance system.adapter.solarlog.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      solarlog.0
      2023-09-19 10:52:59.031	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      solarlog.0
      2023-09-19 10:52:59.015	error	undefined is not a valid state value
      solarlog.0
      2023-09-19 10:52:59.014	error	Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at AdapterClass._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5439:49) at AdapterClass.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5400:21) at /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2037:16 at new Promise (<anonymous>) at AdapterClass.setStateAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2036:16) at setDeviceInfo (/opt/iobroker/node_modules/iobroker.solarlog/main.js:2155:19) at test (/opt/iobroker/node_modules/iobroker.solarlog/main.js:291:13) at async Timeout.<anonymous> (/opt/iobroker/node_modules/iobroker.solarlog/main.js:231:39)
      solarlog.0
      2023-09-19 10:52:59.004	error	unhandled promise rejection: undefined is not a valid state value
      solarlog.0
      2023-09-19 10:52:59.003	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      solarlog.0
      2023-09-19 10:52:56.999	warn	Nicht alle WR/Zaehler gefunden
