    4. ZigBee nach Update auf js-controller 5.x tot (gelöst)
      reutli last edited by reutli
      nach dem Update auf den js-controller 5.x hängt der ZigBee Adapter.
      zigbee.0
      	2023-09-20 17:43:38.480	info	Installed Version: iobroker.zigbee@1.8.23
      zigbee.0
      	2023-09-20 17:43:38.464	error	Error herdsman start
      zigbee.0
      	2023-09-20 17:43:38.462	error	Failed to start Zigbee
      zigbee.0
      	2023-09-20 17:43:38.460	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_74290f152e86ec11b5c6641719c2d21c-if00-port0'"
      zigbee.0
      	2023-09-20 17:43:38.441	debug	Starting zigbee-herdsman...
      zigbee.0
      	2023-09-20 17:43:38.424	info	Starting Zigbee npm ...
      zigbee.0
      	2023-09-20 17:43:38.421	info	Try to reconnect. 1 attempts left
      zigbee.0
      	2023-09-20 17:43:28.420	info	Installed Version: iobroker.zigbee@1.8.23
      zigbee.0
      	2023-09-20 17:43:28.417	error	Error herdsman start
      zigbee.0
      	2023-09-20 17:43:28.416	error	Failed to start Zigbee
      zigbee.0
      	2023-09-20 17:43:28.415	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_74290f152e86ec11b5c6641719c2d21c-if00-port0'"
      zigbee.0
      	2023-09-20 17:43:28.087	debug	Starting zigbee-herdsman...
      zigbee.0
      	2023-09-20 17:43:28.054	debug	Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2023_09_20-17_43_27.tar.gz success
      zigbee.0
      	2023-09-20 17:43:28.016	info	Starting Zigbee npm ...
      zigbee.0
      	2023-09-20 17:43:28.014	info	delete old Backup files. keep only last 10
      zigbee.0
      	2023-09-20 17:43:27.940	debug	Using zigbee-herdsman with settings: {"network":{"panID":2698,"extendedPanID":[140,253,145,109,51,197,149,147],"channelList":[20],"networkKey":[1,3,5,171,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_74290f152e86ec11b5c6641719c2d21c-if00-port0","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}}
      zigbee.0
      	2023-09-20 17:43:27.896	info	starting. Version 1.8.23 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.17.1, js-controller: 5.0.12
      zigbee.0
      	2023-09-20 17:43:25.883	debug	Plugin sentry Initialize Plugin (enabled=true)
      das kennen wir doch irgendwo her?
      Skript v.2023-06-20
      *** BASE SYSTEM ***
         Static hostname: macmini-iobroker
               Icon name: computer-desktop
                 Chassis: desktop
              Machine ID: 0a2b668d0cfb46f0bb08b3f56590d1b0
                 Boot ID: 1d363005dfe14a6f9c331e07a5c39658
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 5.10.0-25-amd64
            Architecture: x86-64
      model name	: Intel(R) Core(TM) i5-2415M CPU @ 2.30GHz
      Docker          : false
      Virtualization  : none
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       17:47:09 up  2:40,  1 user,  load average: 0.75, 0.92, 0.99
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Wed 2023-09-20 17:47:09 CEST
                 Universal time: Wed 2023-09-20 15:47:09 UTC
                       RTC time: Wed 2023-09-20 15:47:09
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      admin
      /home/admin
      admin adm sudo iobroker
      *** X-Server-Setup ***
      X-Server: 	false
      Desktop:
      Terminal: 	tty
      Boot Target: 	graphical.target
      *** MEMORY ***
      Mem:             15G        3.3G        7.3G        0.0K        5.3G         12G
      Swap:            16G          0B         16G
      Total:           32G        3.3G         23G
              15909 M total memory
               3310 M used memory
                536 M active memory
               7634 M inactive memory
               7252 M free memory
                239 M buffer memory
               5106 M swap cache
              16294 M total swap
                  0 M used swap
              16294 M free swap
      *** FILESYSTEM ***
      udev           devtmpfs  7.8G     0  7.8G   0% /dev
      tmpfs          tmpfs     1.6G  896K  1.6G   1% /run
      /dev/sda2      ext4      442G   17G  403G   4% /
      tmpfs          tmpfs     7.8G     0  7.8G   0% /dev/shm
      /dev/sda1      vfat      511M  5.8M  506M   2% /boot/efi
      tmpfs          tmpfs     1.6G  4.0K  1.6G   1% /run/user/1002
      [Wed Sep 20 15:06:32 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
      [Wed Sep 20 15:06:33 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
      Show mounted filesystems (real ones only):
      TARGET      SOURCE    FSTYPE OPTIONS
      /           /dev/sda2 ext4   rw,noatime
      `-/boot/efi /dev/sda1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
      /var:
      5.3G	/var/
      4.3G	/var/log
      4.0G	/var/log/journal/0a2b668d0cfb46f0bb08b3f56590d1b0
      838M	/var/lib
      Archived and active journals take up 3.9G in the file system.
      /opt/iobroker/backups:
      29M	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      4.0G	/opt/iobroker/iobroker-data/
      3.4G	/opt/iobroker/iobroker-data/history
      396M	/opt/iobroker/iobroker-data/files
      137M	/opt/iobroker/iobroker-data/backup-objects
      72M	/opt/iobroker/iobroker-data/files/telegram.admin
      35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      34M	/opt/iobroker/iobroker-data/objects.jsonl.sic
      21M	/opt/iobroker/iobroker-data/objects.jsonl
      21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
      19M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v18.17.1
      /usr/bin/node 		v18.17.1
      /usr/bin/npm 		9.6.7
      /usr/bin/npx 		9.6.7
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
              100 /var/lib/dpkg/status
           16.20.2-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
           12.22.12~dfsg-1~deb11u4 500
              500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://deb.debian.org/debian bullseye/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      No configuration change needed.
      Multihost discovery server: disabled
      Discovery authentication:   enabled
      Persistent activation:      disabled
      Objects:                    jsonl on 0.0.0.0
      States:                     jsonl on 0.0.0.0
      Core adapters versions
      admin: 		6.10.1
      javascript: 	7.1.4
      Adapters from github: 	3
      Adapter State
      + system.adapter.admin.0                  : admin                 : macmini-iobroker                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.admin.1                  : admin                 : macmini-iobroker                         -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : macmini-iobroker                         -  enabled
        system.adapter.alias-manager.0          : alias-manager         : macmini-iobroker                         -  enabled
      + system.adapter.backitup.0               : backitup              : macmini-iobroker                         -  enabled
        system.adapter.backitup.2               : backitup              : iobroker2                                - disabled
        system.adapter.backitup.3               : backitup              : iobroker                                 - disabled
        system.adapter.bydbatt.0                : bydbatt               : macmini-iobroker                         - disabled
      + system.adapter.cloud.0                  : cloud                 : macmini-iobroker                         -  enabled
      + system.adapter.device-watcher.0         : device-watcher        : macmini-iobroker                         -  enabled
        system.adapter.devices.0                : devices               : macmini-iobroker                         -  enabled
      + system.adapter.discovery.0              : discovery             : macmini-iobroker                         -  enabled
      + system.adapter.ds18b20.1                : ds18b20               : iobroker                                 -  enabled
      + system.adapter.email.0                  : email                 : macmini-iobroker                         -  enabled
      + system.adapter.email.1                  : email                 : iobroker                                 -  enabled
        system.adapter.feiertage.0              : feiertage             : macmini-iobroker                         -  enabled
        system.adapter.flot.0                   : flot                  : macmini-iobroker                         -  enabled
      + system.adapter.followthesun.0           : followthesun          : macmini-iobroker                         -  enabled
      + system.adapter.fronius.0                : fronius               : macmini-iobroker                         -  enabled
      + system.adapter.history.0                : history               : macmini-iobroker                         -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : macmini-iobroker                         -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : macmini-iobroker                         -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : macmini-iobroker                         -  enabled, port: 0
      + system.adapter.hm-rpc.2                 : hm-rpc                : macmini-iobroker                         -  enabled, port: 0
      + system.adapter.husqvarna-automower.0    : husqvarna-automower   : macmini-iobroker                         -  enabled
        system.adapter.ical.0                   : ical                  : macmini-iobroker                         -  enabled
      + system.adapter.influxdb.0               : influxdb              : macmini-iobroker                         -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : macmini-iobroker                         -  enabled
      + system.adapter.iot.0                    : iot                   : macmini-iobroker                         -  enabled
      + system.adapter.jarvis.0                 : jarvis                : macmini-iobroker                         -  enabled
      + system.adapter.javascript.0             : javascript            : macmini-iobroker                         -  enabled
      + system.adapter.linkeddevices.0          : linkeddevices         : macmini-iobroker                         -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : macmini-iobroker                         -  enabled, port: 1887, bind: 0.0.0.0
      + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.nut.0                    : nut                   : macmini-iobroker                         -  enabled
      + system.adapter.panasonic-viera.0        : panasonic-viera       : macmini-iobroker                         -  enabled
      + system.adapter.pushover.0               : pushover              : macmini-iobroker                         -  enabled
      + system.adapter.scenes.0                 : scenes                : macmini-iobroker                         -  enabled
        system.adapter.schoolfree.0             : schoolfree            : macmini-iobroker                         -  enabled
      + system.adapter.shelly.0                 : shelly                : macmini-iobroker                         -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shelly.1                 : shelly                : macmini-iobroker                         -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.signal-cmb.0             : signal-cmb            : macmini-iobroker                         -  enabled
      + system.adapter.simple-api.0             : simple-api            : macmini-iobroker                         -  enabled, port: 8087, bind: 192.168.200.5, run as: admin
      + system.adapter.smartgarden.0            : smartgarden           : macmini-iobroker                         -  enabled
      + system.adapter.sonoff.0                 : sonoff                : macmini-iobroker                         -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.telegram.0               : telegram              : macmini-iobroker                         -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.terminal.0               : terminal              : macmini-iobroker                         -  enabled, port: 8090, bind: 0.0.0.0, run as: admin
      + system.adapter.text2command.0           : text2command          : macmini-iobroker                         -  enabled
      + system.adapter.tr-064.0                 : tr-064                : macmini-iobroker                         -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : macmini-iobroker                         -  enabled
      + system.adapter.tuya.0                   : tuya                  : macmini-iobroker                         -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : macmini-iobroker                         -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : macmini-iobroker                         -  enabled
        system.adapter.vis.0                    : vis                   : macmini-iobroker                         -  enabled
      + system.adapter.web.0                    : web                   : macmini-iobroker                         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.yahka.0                  : yahka                 : macmini-iobroker                         -  enabled
      + system.adapter.zigbee.0                 : zigbee                : iobroker2                                -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_74290f152e86ec11b5c6641719c2d21c-if00-port0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.10.1   , installed 6.10.1
      Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
      Adapter    "alias-manager": 1.2.4    , installed 1.2.4
      Adapter    "backitup"     : 2.6.23   , installed 2.6.23
      Adapter    "bydbatt"      : 1.0.8    , installed 1.0.8
      Adapter    "device-watcher": 2.9.3   , installed 2.9.3
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Adapter    "email"        : 1.2.0    , installed 1.2.0
      Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
      Adapter    "followthesun" : 0.4.2    , installed 0.4.2
      Adapter    "fronius"      : 1.1.3    , installed 1.1.3
      Adapter    "history"      : 2.2.6    , installed 2.2.6
      Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "info"         : 1.9.26   , installed 1.9.26
      Adapter    "iot"          : 1.14.5   , installed 1.14.5
      Adapter    "jarvis"       : 3.1.2    , installed 3.1.9-beta.2
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.12   , installed 5.0.12
      Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
      Adapter    "pushover"     : 3.0.3    , installed 3.0.3
      Adapter    "scenes"       : 2.3.9    , installed 2.3.3  [Updatable]
      Adapter    "schoolfree"   : 1.1.1    , installed 1.1.1
      Adapter    "shelly"       : 6.4.1    , installed 6.4.1
      Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
      Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
      Adapter    "socketio"     : 6.5.5    , installed 6.5.5
      Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
      Adapter    "telegram"     : 1.16.0   , installed 1.16.0
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "text2command" : 3.0.2    , installed 3.0.2
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "tuya"         : 3.14.2   , installed 3.14.2
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "web"          : 6.1.2    , installed 6.1.2
      Adapter    "ws"           : 2.5.5    , installed 2.5.5
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Objects and States
      Objects: 	15908
      States: 	13343
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 https://apt.grafana.com stable InRelease
      Get:5 https://deb.nodesource.com/node_16.x bullseye InRelease [4586 B]
      Hit:6 https://repos.influxdata.com/debian stable InRelease
      Get:7 https://deb.nodesource.com/node_18.x bullseye InRelease [4586 B]
      Hit:8 https://repos.influxdata.com/debian bullseye InRelease
      Fetched 9172 B in 1s (12.2 kB/s)
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 192.168.200.5:2001      0.0.0.0:*               LISTEN      1001       380966     246385/io.hm-rpc.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17832      784/sshd: /usr/sbin
      tcp        0      0 192.168.200.5:8087      0.0.0.0:*               LISTEN      1001       384165     247726/io.simple-ap
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      998        14305      757/influxd
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          16796      1031/exim4
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       378423     246462/io.shelly.1
      tcp        0      0 192.168.200.5:2010      0.0.0.0:*               LISTEN      1001       379179     246400/io.hm-rpc.1
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       378477     246480/io.sonoff.0
      tcp        0      0 192.168.200.5:8701      0.0.0.0:*               LISTEN      1001       380120     246415/io.hm-rpc.2
      tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       379240     246430/io.mqtt.0
      tcp        0      0 0.0.0.0:37055           0.0.0.0:*               LISTEN      109        21939      1584/rpc.statd
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       377992     246190/iobroker.js-
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       377985     246190/iobroker.js-
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          9533       1/init
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       380862     247166/io.jarvis.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       378033     246208/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       382857     248487/io.web.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      998        16814      757/influxd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          17843      784/sshd: /usr/sbin
      tcp6       0      0 :::3000                 :::*                    LISTEN      111        16868      1058/grafana
      tcp6       0      0 :::8089                 :::*                    LISTEN      1001       375743     246235/io.admin.1
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          16797      1031/exim4
      tcp6       0      0 :::8090                 :::*                    LISTEN      1001       384318     247988/io.terminal.
      tcp6       0      0 :::44575                :::*                    LISTEN      1001       384508     248537/io.yahka.0
      tcp6       0      0 :::48737                :::*                    LISTEN      109        21945      1584/rpc.statd
      tcp6       0      0 :::111                  :::*                    LISTEN      0          9537       1/init
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17658      580/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          9534       1/init
      udp        0      0 127.0.0.1:912           0.0.0.0:*                           0          23064      1584/rpc.statd
      udp        0      0 0.0.0.0:53977           0.0.0.0:*                           109        21936      1584/rpc.statd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       384509     248537/io.yahka.0
      udp        0      0 192.168.200.5:5353      0.0.0.0:*                           1001       381164     246491/io.tr-064.0
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       378393     246447/io.shelly.0
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       380300     246521/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       380301     246521/io.tuya.0
      udp6       0      0 :::111                  :::*                                0          9540       1/init
      udp6       0      0 :::54630                :::*                                109        21942      1584/rpc.statd
      2023-09-20 17:30:09.448  - info: host.macmini-iobroker instance system.adapter.trashschedule.0 started with pid 248765
      2023-09-20 17:30:11.601  - info: trashschedule.0 (248765) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v18.17.1, js-controller: 5.0.12
      2023-09-20 17:30:11.744  - info: trashschedule.0 (248765) [ical] configurured ical preview is 30 days - increase this value to find more events in the future
      2023-09-20 17:30:13.372  - info: host.macmini-iobroker instance system.adapter.device-watcher.0 started with pid 248802
      2023-09-20 17:30:15.078  - info: device-watcher.0 (248802) starting. Version 2.9.3 in /opt/iobroker/node_modules/iobroker.device-watcher, node: v18.17.1, js-controller: 5.0.12
      2023-09-20 17:30:15.097  - info: device-watcher.0 (248802) Number of selected adapters: 9. Loading data from: Fritzdect, HmiP, Hmrpc, MqttClientZigbee2Mqtt, Shelly, Smartgarden, Sonoff, Zigbee, Zigbee2MQTT ...
      2023-09-20 17:30:15.098  - info: device-watcher.0 (248802) Found instances items on blacklist for notifications:
      2023-09-20 17:30:17.326  - info: host.macmini-iobroker instance system.adapter.husqvarna-automower.0 started with pid 249030
      2023-09-20 17:30:19.567  - info: husqvarna-automower.0 (249030) starting. Version 0.4.0 (non-npm: ice987987/ioBroker.husqvarna-automower) in /opt/iobroker/node_modules/iobroker.husqvarna-automower, node: v18.17.1, js-controller: 5.0.12
      2023-09-20 17:30:19.587  - info: husqvarna-automower.0 (249030) starting adapter "husqvarna-automower"...
      2023-09-20 17:30:19.940  - info: husqvarna-automower.0 (249030) "Husqvarna Authentication API Access token" received.
      2023-09-20 17:30:20.563  - info: husqvarna-automower.0 (249030) Mowerdata initially saved.
      2023-09-20 17:30:20.880  - info: husqvarna-automower.0 (249030) Connection to "Husqvarna WebSocket" established. Ready to get data...
      2023-09-20 17:32:01.056  - info: javascript.0 (246295) script.js.PV_Überwachung.Fronius: Solarweb Token erstellt
      2023-09-20 17:33:00.003  - info: javascript.0 (246295) script.js.Sonnenschutz_Beschattung_Jalousien.Sonnenschutz_Süd: Anwesenheit Annette: true
      2023-09-20 17:35:02.335  - info: javascript.0 (246295) script.js.PV_Überwachung.Fronius: Solarweb Forecast Forecast Today konnte nicht abgefragt werden - Kein Premiumaccount
      2023-09-20 17:35:06.242  - info: javascript.0 (246295) script.js.PV_Überwachung.Fronius: Solarweb Forecast Forecast Tomorrow konnte nicht abgefragt werden - Kein Premiumaccount
      2023-09-20 17:38:00.003  - info: javascript.0 (246295) script.js.Sonnenschutz_Beschattung_Jalousien.Sonnenschutz_Süd: Anwesenheit Annette: true
      2023-09-20 17:42:44.160  - info: admin.0 (246208) ==> Connected system.user.admin from ::ffff:192.168.200.167
      2023-09-20 17:43:00.003  - info: javascript.0 (246295) script.js.Sonnenschutz_Beschattung_Jalousien.Sonnenschutz_Süd: Anwesenheit Annette: true
      2023-09-20 17:43:13.078  - info: admin.0 (246208) <== Disconnect system.user.admin from ::ffff:192.168.200.167
      2023-09-20 17:44:10.727  - info: smartgarden.0 (247949) 1/ setServiceStates: relationship searching
      2023-09-20 17:44:10.741  - info: smartgarden.0 (247949) 1/ setServiceStates: relationship searching
      2023-09-20 17:44:10.879  - info: smartgarden.0 (247949) 1/ setServiceStates: relationship searching
      2023-09-20 17:44:10.886  - info: smartgarden.0 (247949) 1/ setServiceStates: relationship searching
      		     v.2023-06-20
                 Chassis: desktop
      Installation: 		native
      Kernel: 		x86_64
      Userland: 		amd64
      Timezone: 		Europe/Berlin (CEST, +0200)
      User-ID: 		1002
      X-Server: 		false
      Pending OS-Updates: 	0
      Pending iob updates: 	1
      Nodejs-Installation: 	/usr/bin/nodejs 	v18.17.1
      			/usr/bin/npm 		9.6.7
      			/usr/bin/npx 		9.6.7
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:             15G        3.3G        7.3G        0.0K        5.4G         12G
      Swap:            16G          0B         16G
      Total:           32G        3.3G         23G
      Active iob-Instances: 	46
      ioBroker Core: 		js-controller 		5.0.12
      			admin 			6.10.1
      ioBroker Status: 	iobroker is running on this host.
      Objects type: jsonl
      States  type: jsonl
      Objects: 		15908
      States: 		13343
      Size of iob-Database:
      9.7M	/opt/iobroker/iobroker-data/objects.json.migrated
      9.7M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
      20M	/opt/iobroker/iobroker-data/states.jsonl
      2.0M	/opt/iobroker/iobroker-data/states.json.migrated
      2.0M	/opt/iobroker/iobroker-data/states.json.bak.migrated
      0	/opt/iobroker/iobroker-data/states.json.broken
      Mist...
      Den udev habe ich eigentlich auf "on hold"
        Thomas Braun Most Active @reutli last edited by
        @reutli
        Und in welcher Version 'on hold'?
        apt policy udev
        find /dev/serial/by-id -mindepth=1 -maxdepth=1
        sagt?
        R 2 Replies Last reply Reply Quote 0
          reutli @Thomas Braun last edited by reutli
          @thomas-braun sagte in ZigBee nach Update auf js-controller 5.x tot:
          pi@iobroker2:~ $ apt policy udev
          > udev:
          >   Installed: 247.3-7+rpi1+deb11u2
          >   Candidate: 247.3-7+rpi1+deb11u2
          >   Version table:
          >  *** 247.3-7+rpi1+deb11u2 500
          >         500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
          >      247.3-7+deb11u4 500
          >         500 http://deb.debian.org/debian bullseye-proposed-updates/main armhf Packages
          pi@iobroker2:~ $ find /dev/serial/by-id -mindepth=1 -maxdepth=1
          find: unknown predicate `-mindepth=1'
          hat der mir den hold rausgenommen ??? Hab apt update && upgrade gemacht.. vor update
            habe nur noch:
            pi@iobroker2:/dev/serial/by-path $ ls
            platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3:1.0-port0
              Thomas Braun Most Active @reutli last edited by Thomas Braun
              @reutli sagte in ZigBee nach Update auf js-controller 5.x tot:
              Du hast die defekte Version am Start.
              247.3-7+deb11u4
              funktioniert.
                247.3-7+deb11u4
                Hast Du mir einen Tipp?
                Die Version die ich bisher hatte:
                sudo apt install udev=247.3-7+deb11u4 libudev1=247.3-7+deb11u4
                tut nicht:
                pi@iobroker2:/dev $ sudo apt install udev=247.3-7+deb11u4 libudev1=247.3-7+deb11u4
                Reading package lists... Done
                Building dependency tree... Done
                The following packages were automatically installed and are no longer required:
                  libfuse2 raspinfo
                Use 'sudo apt autoremove' to remove them.
                The following packages will be REMOVED:
                  libudev-dev
                The following packages will be DOWNGRADED:
                  libudev1 udev
                0 upgraded, 0 newly installed, 2 downgraded, 1 to remove and 0 not upgraded.
                Need to get 1,602 kB of archives.
                After this operation, 573 kB disk space will be freed.
                Do you want to continue? [Y/n] Y
                Get:1 http://deb.debian.org/debian bullseye-proposed-updates/main armhf udev armhf 247.3-7+deb11u4 [1,440 kB]
                Get:2 http://deb.debian.org/debian bullseye-proposed-updates/main armhf libudev1 armhf 247.3-7+deb11u4 [162 kB]
                Fetched 1,602 kB in 1s (3,173 kB/s)
                (Reading database ... 113609 files and directories currently installed.)
                Removing libudev-dev:armhf (247.3-7+rpi1+deb11u2) ...
                dpkg: warning: downgrading udev from 247.3-7+rpi1+deb11u2 to 247.3-7+deb11u4
                (Reading database ... 113534 files and directories currently installed.)
                Preparing to unpack .../udev_247.3-7+deb11u4_armhf.deb ...
                Unpacking udev (247.3-7+deb11u4) over (247.3-7+rpi1+deb11u2) ...
                dpkg: warning: downgrading libudev1:armhf from 247.3-7+rpi1+deb11u2 to 247.3-7+deb11u4
                Preparing to unpack .../libudev1_247.3-7+deb11u4_armhf.deb ...
                Unpacking libudev1:armhf (247.3-7+deb11u4) over (247.3-7+rpi1+deb11u2) ...
                Setting up libudev1:armhf (247.3-7+deb11u4) ...
                Setting up udev (247.3-7+deb11u4) ...
                Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u5) ...
                Processing triggers for man-db (2.9.4-2) ...
                Processing triggers for initramfs-tools (0.140) ...
                pi@iobroker2:/dev $ sudo apt-mark hold udev
                udev set on hold.
                zigbee.0
                	2023-09-20 18:47:20.364	info	Installed Version: iobroker.zigbee@1.8.23
                zigbee.0
                	2023-09-20 18:47:20.328	error	Error herdsman start
                zigbee.0
                	2023-09-20 18:47:20.326	error	Failed to start Zigbee
                zigbee.0
                	2023-09-20 18:47:20.325	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_74290f152e86ec11b5c6641719c2d21c-if00-port0'"
                zigbee.0
                	2023-09-20 18:47:20.304	debug	Starting zigbee-herdsman...
                zigbee.0
                	2023-09-20 18:47:20.291	info	Starting Zigbee npm ...
                zigbee.0
                	2023-09-20 18:47:20.289	info	Try to reconnect. 1 attempts left
                zigbee.0
                	2023-09-20 18:47:10.288	info	Installed Version: iobroker.zigbee@1.8.23
                zigbee.0
                	2023-09-20 18:47:10.284	error	Error herdsman start
                zigbee.0
                	2023-09-20 18:47:10.283	error	Failed to start Zigbee
                zigbee.0
                	2023-09-20 18:47:10.282	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_74290f152e86ec11b5c6641719c2d21c-if00-port0'"
                zigbee.0
                	2023-09-20 18:47:09.964	debug	Starting zigbee-herdsman...
                zigbee.0
                	2023-09-20 18:47:09.956	debug	Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2023_09_20-18_47_07.tar.gz success
                zigbee.0
                	2023-09-20 18:47:09.881	info	Starting Zigbee npm ...
                zigbee.0
                	2023-09-20 18:47:07.989	info	delete old Backup files. keep only last 10
                zigbee.0
                	2023-09-20 18:47:07.917	debug	Using zigbee-herdsman with settings: {"network":{"panID":2698,"extendedPanID":[140,253,145,109,51,197,149,147],"channelList":[20],"networkKey":[1,3,5,171,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_74290f152e86ec11b5c6641719c2d21c-if00-port0","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}}
                zigbee.0
                	2023-09-20 18:47:07.873	info	starting. Version 1.8.23 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.17.1, js-controller: 5.0.12
                zigbee.0
                	2023-09-20 18:47:06.531	debug	Plugin sentry Initialize Plugin (enabled=true)
                host.iobroker2
                	2023-09-20 18:47:02.197	info	instance system.adapter.zigbee.0 started with pid 1240
                host.iobroker2
                	2023-09-20 18:47:02.182	info	Do not restart adapter system.adapter.zigbee.0 because desired by instance
                host.iobroker2
                	2023-09-20 18:47:02.181	info	instance system.adapter.zigbee.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                zigbee.0
                	2023-09-20 18:47:01.320	info	debug devices set to []
                zigbee.0
                	2023-09-20 18:47:01.311	debug	UpdateState: Device is deactivated f0d1b800001d5c46 {"type":"device","common":{"name":"Wiga Bulb 1","type":"AC33906","icon":"img/AC33906.png","color":null,"statusStates":{"onlineId":"zigbee.0.f0d1b800001d5c46.available"},"deactivated":true},"native":{"id":"f0d1b800001d5c46"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1694902559413,"_id":"zigbee.0.f0d1b800001d5c46","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                zigbee.0
                	2023-09-20 18:47:01.310	debug	UpdateState: Device is deactivated f0d1b800001d5c46 {"type":"device","common":{"name":"Wiga Bulb 1","type":"AC33906","icon":"img/AC33906.png","color":null,"statusStates":{"onlineId":"zigbee.0.f0d1b800001d5c46.available"},"deactivated":true},"native":{"id":"f0d1b800001d5c46"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1694902559413,"_id":"zigbee.0.f0d1b800001d5c46","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                zigbee.0
                	2023-09-20 18:47:01.244	info	terminating
                zigbee.0
                	2023-09-20 18:47:01.243	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                zigbee.0
                	2023-09-20 18:47:01.243	debug	Plugin sentry destroyed
                zigbee.0
                	2023-09-20 18:47:01.242	info	terminating
                zigbee.0
                	2023-09-20 18:47:01.241	warn	Failed to stop zigbee during
                  @reutli
                  Udev bzw das gesamte System neu gestartet?
                    jetzt ja (schäm) 😢
                    zigbee.0
                    	2023-09-20 18:58:36.854	info	debug devices set to []
                    zigbee.0
                    	2023-09-20 18:58:36.848	info	deregister device Ping for deactivated device "0xf0d1b800001d5c46"
                    zigbee.0
                    	2023-09-20 18:58:36.594	info	Zigbee started
                    zigbee.0
                    	2023-09-20 18:58:36.593	info	0x84fd27fffec235d4 (addr 41502): TS0044 - TuYa Wireless switch with 4 buttons (EndDevice)
                    zigbee.0
                    	2023-09-20 18:58:36.591	info	0xf0d1b800001d5c46 (addr 57366): AC33906 - LEDVANCE SMART+ spot GU10 multicolor RGBW (Router)
                    zigbee.0
                    	2023-09-20 18:58:36.587	info	0x00124b00251302ed (addr 1205): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
                    zigbee.0
                    	2023-09-20 18:58:36.561	info	Currently 3 devices are joined:
                    zigbee.0
                    	2023-09-20 18:58:36.549	info	--> transmitPower : normal
                    zigbee.0
                    	2023-09-20 18:58:36.529	info	Unable to disable LED, unsupported function.
                    zigbee.0
                    	2023-09-20 18:58:36.520	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20221226}}
                    zigbee.0
                    	2023-09-20 18:58:35.787	info	Installed Version: iobroker.zigbee@1.8.23
                    zigbee.0
                    	2023-09-20 18:58:35.424	info	Starting Zigbee npm ...
                    zigbee.0
                    	2023-09-20 18:58:35.422	info	delete old Backup files. keep only last 10
                    zigbee.0
                    	2023-09-20 18:58:35.303	info	starting. Version 1.8.23 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.17.1, js-controller: 5.0.12
                    host.iobroker2
                    	2023-09-20 18:58:29.612	info	instance system.adapter.zigbee.0 started with pid 1076
                    host.iobroker2
                    	2023-09-20 18:58:27.505	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    zigbee.0
                    	2023-09-20 18:58:26.593	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    zigbee.0
                    	2023-09-20 18:58:26.592	debug	Plugin sentry destroyed
                    zigbee.0
                    	2023-09-20 18:58:26.590	info	terminating
                    zigbee.0
                    	2023-09-20 18:58:26.269	debug	UpdateState: Device is deactivated f0d1b800001d5c46 {"type":"device","common":{"name":"Wiga Bulb 1","type":"AC33906","icon":"img/AC33906.png","color":null,"statusStates":{"onlineId":"zigbee.0.f0d1b800001d5c46.available"},"deactivated":true},"native":{"id":"f0d1b800001d5c46"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1695229090512,"_id":"zigbee.0.f0d1b800001d5c46","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                    zigbee.0
                    	2023-09-20 18:58:26.267	debug	UpdateState: Device is deactivated f0d1b800001d5c46 {"type":"device","common":{"name":"Wiga Bulb 1","type":"AC33906","icon":"img/AC33906.png","color":null,"statusStates":{"onlineId":"zigbee.0.f0d1b800001d5c46.available"},"deactivated":true},"native":{"id":"f0d1b800001d5c46"},"from":"system.adapter.zigbee.0","user":"system.user.admin","ts":1695229090512,"_id":"zigbee.0.f0d1b800001d5c46","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                    Aber wie der "hold" rausfliegt ist mir immer noch ein Rätsel!
                      Kann nur jemand mit root-Rechten getan haben...
                        root Rechte habe ich ja immer (temporär), wenn ich 'sudo' mache, aber doch nicht bei
                        sudo apt update
                        sudo apt upgrade
                        oder?
                        Ich verbriefe mich dafür, dass ich sonst auf PI'chen (nach den Erfahrungen) nicht gemacht habe.
                        Lasse mich aber gerne überführen! Will schließlich wissen, woran es lag.
                        Was ich gemacht habe:
                        • Update master und zwei slaves (siehe oben sudo apt update && sudo apt upgrade)
                        • master mit js-controller 5.x versorgt
                        • slaves mit js-controller 5.x versorgt
                          aber doch nicht bei
                          sudo führt immer (wenn nicht mittels Optionen anders verwendet) zum root:
                          echad@chet:~ $ sudo whoami
                          root
                          echad@chet:~ $
                            da sind wir uns unstrittig einig!
                            Dennoch habe ich keinen unhold o.ä. ausgeführt.
                            522
