    4. WLED Fehler?
    WLED Fehler?
      TimoWald last edited by
      Hallo, kann mir jemand was zu dieser Meldung sagen?
      Was ist da falsch?
      2023-09-21 00:00:00.165 - warn: wled.0 (6171) State attribute definition missing for : liveseg with value : -1
      2023-09-21 00:00:00.185 - warn: wled.0 (6171) State attribute definition missing for : cpalcount with value : 0
      2023-09-21 00:00:00.189 - warn: wled.0 (6171) State attribute definition missing for : 0 with value : [object Object]
      2023-09-21 00:00:00.320 - warn: wled.0 (6171) State attribute definition missing for : set with value : 0
      2023-09-21 00:00:00.338 - warn: wled.0 (6171) State attribute definition missing for : c1 with value : 128
      2023-09-21 00:00:00.340 - warn: wled.0 (6171) State attribute definition missing for : c2 with value : 128
      2023-09-21 00:00:00.341 - warn: wled.0 (6171) State attribute definition missing for : c3 with value : 16
      2023-09-21 00:00:00.347 - warn: wled.0 (6171) State attribute definition missing for : o1 with value : false
      2023-09-21 00:00:00.348 - warn: wled.0 (6171) State attribute definition missing for : o2 with value : false
      2023-09-21 00:00:00.350 - warn: wled.0 (6171) State attribute definition missing for : o3 with value : false
      2023-09-21 00:00:00.353 - warn: wled.0 (6171) State attribute definition missing for : si with value : 0
      2023-09-21 00:00:00.356 - warn: wled.0 (6171) State attribute definition missing for : m12 with value : 1
      2023-09-21 00:00:00.374 - warn: wled.0 (6171) State attribute definition missing for : set with value : 0
      2023-09-21 00:00:00.398 - warn: wled.0 (6171) State attribute definition missing for : c1 with value : 128
      2023-09-21 00:00:00.400 - warn: wled.0 (6171) State attribute definition missing for : c2 with value : 128
      2023-09-21 00:00:00.401 - warn: wled.0 (6171) State attribute definition missing for : c3 with value : 16
      2023-09-21 00:00:00.408 - warn: wled.0 (6171) State attribute definition missing for : o1 with value : false
      2023-09-21 00:00:00.409 - warn: wled.0 (6171) State attribute definition missing for : o2 with value : false
      2023-09-21 00:00:00.412 - warn: wled.0 (6171) State attribute definition missing for : o3 with value : false
      2023-09-21 00:00:00.413 - warn: wled.0 (6171) State attribute definition missing for : si with value : 0
      2023-09-21 00:00:00.415 - warn: wled.0 (6171) State attribute definition missing for : m12 with value : 0
      2023-09-21 00:00:00.429 - warn: wled.0 (6171) State attribute definition missing for : set with value : 0
      2023-09-21 00:00:00.445 - warn: wled.0 (6171) State attribute definition missing for : c1 with value : 128
      2023-09-21 00:00:00.447 - warn: wled.0 (6171) State attribute definition missing for : c2 with value : 128
      2023-09-21 00:00:00.449 - warn: wled.0 (6171) State attribute definition missing for : c3 with value : 16
      2023-09-21 00:00:00.463 - warn: wled.0 (6171) State attribute definition missing for : o1 with value : false
      2023-09-21 00:00:00.468 - warn: wled.0 (6171) State attribute definition missing for : o2 with value : false
      2023-09-21 00:00:00.471 - warn: wled.0 (6171) State attribute definition missing for : o3 with value : false
      2023-09-21 00:00:00.473 - warn: wled.0 (6171) State attribute definition missing for : si with value : 0
      2023-09-21 00:00:00.476 - warn: wled.0 (6171) State attribute definition missing for : m12 with value : 0
        arteck Developer Most Active @TimoWald last edited by
        @timowald adapter Version ?
          TimoWald @arteck last edited by
          @arteck Die Version ist die v0.6.7
          • crunchip
            crunchip Forum Testing Most Active @TimoWald last edited by
            @timowald es gibt
            v 0.7 seit 02023-07-25
