    4. inMem-objekt on Port Fehler
      toki1973 last edited by
      Was ist denn da passiert?
      iob fix hat nichts geholfen. Die Proxmox VM läuft.
      Was kann man tun?
        Thomas Braun Most Active @toki1973 last edited by
        @toki1973 sagte in inMem-objekt on Port Fehler:
        Gute Frage...
        WAS ist denn wo genau 'passiert'?
          toki1973 @Thomas Braun last edited by
          @thomas-braun Eigentlich nicht verändert
          /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
                  throw e;
          Error: Connection is closed.
              at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
              at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
              at Object.onceWrapper (node:events:628:26)
              at Socket.emit (node:events:513:28)
              at TCP.<anonymous> (node:net:322:12)
          Emitted 'error' event on ScanStream instance at:
              at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
              at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
              at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
              at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
          Node.js v18.16.1
            Wann kommt denn diese Meldung?
            Hau mal
            iob diag
            durch, vielleicht kann man da mehr sehen...
              @thomas-braun Bei der Diag wurden keine Fehler angezeigt. Hier die summary
                                   v.2023-06-20
                 Static hostname: iobrokerNUC1
                       Icon name: computer-vm
                         Chassis: vm
                      Machine ID: 145d9bb4c8454499a6d5214583f44589
                         Boot ID: 0aafc08dc8ad4c258e44490b5d74197c
                  Virtualization: kvm
                Operating System: Debian GNU/Linux 10 (buster)
                          Kernel: Linux 4.19.0-24-amd64
                    Architecture: x86-64
              Installation:           kvm
              Userland:               amd64
              User-ID:                0
              X-Server:               false
              Pending OS-Updates:     38
              Pending iob updates:    6
              Nodejs-Installation:    /usr/bin/nodejs         v18.16.1
                                      /usr/bin/node           v18.16.1
                                      /usr/bin/npm            9.5.1
                                      /usr/bin/npx            9.5.1
              Recommended versions are nodejs 18.x.y and npm 9.x.y
              MEMORY:
              Mem:           5.8G        3.6G        1.1G         32M        1.1G        1.9G
              Swap:          974M         55M        919M
              Total:         6.8G        3.7G        2.0G
              Active iob-Instances:   37
              Active repo(s): stable
              ioBroker Core:          js-controller           4.0.24
                                      admin                   6.6.0
              Objects type: jsonl
              States  type: jsonl
              + system.adapter.admin.0                  : admin                 : iobrokerNUC1                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                system.adapter.web-speedy.0             : web-speedy            : iobrokerNUC1                             - disabled
              + system.adapter.web.0                    : web                   : iobrokerNUC1                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              Objects:                114665
              States:                 88682
              Size of iob-Database:
              69M     /opt/iobroker/iobroker-data/objects.jsonl
              19M     /opt/iobroker/iobroker-data/objects.json.migrated
              19M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
              28M     /opt/iobroker/iobroker-data/states.jsonl
              4.7M    /opt/iobroker/iobroker-data/states.json.migrated
              4.7M    /opt/iobroker/iobroker-data/states.json.broken
              4.7M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                Thomas Braun Most Active @toki1973 last edited by Thomas Braun
                @toki1973
                Die alte Leier mal wieder....
                Buster ist zu alt und du hampelst als root herum.
                Beides abstellen. Sofort
                  Ja ich habe bereits eine neue VM erzeugt - bin aber noch nicht umgezogen...
                  Aber trotzdem sollte doch etwas zu retten sein?
                  Thomas Braun Meister Mopper 2 Replies Last reply Reply Quote 0
                    Ja, vielleicht. Aber nicht von mir...
                    • Meister Mopper
                      Meister Mopper @toki1973 last edited by
                      Ich würde ein
                      • konsistentes Backup von backitup vorhalten,
                      • eine neue vm aufsetzen,
                      • einen user mit sudo-Rechten einrichten,
                      • nur mit diesem user arbeiten,
                      • ioBroker mit dem Einzeiler installieren,
                      • den Adapter backitup installieren,
                      • das Backup einlesen (dabei sehr viel Geduld haben und in einer separaten bash das Geschehen beobachten,
                      • hoffen, dass hinterher alles wieder funktioniert.
                        toki1973 @Meister Mopper last edited by
                        Und kann so etwas passieren?
                        War nicht auf dem System unterwegs.
                        Hatte schnell vor dem Urlaub einen neu VM vorbereitet wollte aber noch nicht umziehen- ist ehr so ein schlecht Wetter Projekt bei mir 😉
                        inmem
                        189
