    4. Fehler MQTT-Adapter
    Fehler MQTT-Adapter
      AndyUM61 last edited by
      mein MQTT-Adapter startet leider nicht mehr:(!
      Folgender Fehler im LOG:
      mqtt.0	2017-07-16 19:38:00.649	error	at Connection.Duplexify._write (C:\Program Files\ioBroker\node_modules\iobroker.mqtt\node_modules\mqtt-connection\node_modules\duplexify\index.js:201:22)
      mqtt.0	2017-07-16 19:38:00.649	error	at Writable.write (_stream_writable.js:214:11)
      mqtt.0	2017-07-16 19:38:00.649	error	at doWrite (_stream_writable.js:300:12)
      mqtt.0	2017-07-16 19:38:00.649	error	at Writable.write [as _write] (C:\Program Files\ioBroker\node_modules\iobroker.mqtt\node_modules\mqtt-connection\lib\writeToStream.js:10:9)
      mqtt.0	2017-07-16 19:38:00.649	error	at generate (C:\Program Files\ioBroker\node_modules\iobroker.mqtt\node_modules\mqtt-connection\node_modules\mqtt-packet\writeToStream.js:22:14)
      mqtt.0	2017-07-16 19:38:00.649	error	at Function.Buffer.concat (buffer.js:281:24)
      mqtt.0	2017-07-16 19:37:25.988	error	at Connection.Duplexify._write (C:\Program Files\ioBroker\node_modules\iobroker.mqtt\node_modules\mqtt-connection\node_modules\duplexify\index.js:201:22)
      mqtt.0	2017-07-16 19:37:25.988	error	at Writable.write (_stream_writable.js:214:11)
      mqtt.0	2017-07-16 19:37:25.988	error	at doWrite (_stream_writable.js:300:12)
      mqtt.0	2017-07-16 19:37:25.988	error	at Writable.write [as _write] (C:\Program Files\ioBroker\node_modules\iobroker.mqtt\node_modules\mqtt-connection\lib\writeToStream.js:10:9)
      mqtt.0	2017-07-16 19:37:25.988	error	at generate (C:\Program Files\ioBroker\node_modules\iobroker.mqtt\node_modules\mqtt-connection\node_modules\mqtt-packet\writeToStream.js:32:14)
      mqtt.0	2017-07-16 19:37:25.988	error	at Function.Buffer.concat (buffer.js:281:24)
      • apollon77
        apollon77 last edited by
        Hast du irgendwas gemacht? Systemupdates oder so?
          nein, nichts am ioBroker-System.
          Ich habe nur die FritzBox neu gestartet, und dann war das Problem da.
          Ist aber auch schon wieder erledigt.
          Ich habe erst versucht den Adapter noch einmal über zu installieren - erfolglos,
          dann habe ich in den Einstellungen "Benutze Pathch für Chunking:" deaktiviert, und jetzt läuft es wieder Fehlerfrei.
          Tja, was auch immer das war…???
          P.S. Da fällt mir gerade auf, dass da ein Schreibfehler in den Einstellungen ist: "Pat<u>h</u>ch";)
          • apollon77
            @AndyUM61:
            P.S. Da fällt mir gerade auf, dass da ein Schreibfehler in den Einstellungen ist: "Pat<u>h</u>ch";) `
            Fixed auf Github. mache dafür aber keine eigene neue Version 🙂
            • chucky666
              chucky666 last edited by
              Hallo zusammen
              Bei mir stützt der Mqtt ab und zu ab ,
              Leider verbindet er sich nicht selbstständig neu .
              Kann man das irgendwie einbauen ?
              Ich starte die Instanz regelmäßig neu , ich hoffe das gibt keine neuen Probleme
              Gesendet von iPad mit Tapatalk Pro
              81.0k
