    4. Auch Probleme nach Node 16.20 Update
      Trashman1981 last edited by
      Re: Mein erster Adapter: Für EZcontrol XS1
      Hallo mcm57,
      ich habe auch nach dem Node Update auf 16 (verbunden mit einer kompletten Neuinstallation meines Iobrokers auf Raspi) das folgende Problem.
      Der Adapter startet, lädt kurz die 12 Aktoren und stoppt dann wieder. Hier das log:
      host.raspberrypi
      2023-09-27 11:14:00.840 info Do not restart adapter system.adapter.xs1.0 because desired by instance
      host.raspberrypi
      2023-09-27 11:14:00.839 info instance system.adapter.xs1.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
      xs1.0
      2023-09-27 11:14:00.276 info Terminated (ADAPTER_REQUESTED_TERMINATION): xs1 Initialization Error:TypeError: Cannot read properties of undefined (reading '_subscribeForeignStates') at subscribeStates (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:7433:21) at /opt/iobroker/node_modules/iobroker.xs1/myAdapter.js:709:111 at new Promise (<anonymous>) at /opt/iobroker/node_modules/iobroker.xs1/myAdapter.js:709:20 at /opt/iobroker/node_modules/iobroker.xs1/myAdapter.js:267:81
      xs1.0
      2023-09-27 11:13:59.633 info Finished state creation. Added totally 0 actuators or sensors
      xs1.0
      2023-09-27 11:13:59.633 info Update Error: Error: getaddrinfo ENOTFOUND 192.168.188.50,242at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:109:26) {errno: -3008,code: 'ENOTFOUND',syscall: 'getaddrinfo',hostname: '192.168.188.50,242'}
      xs1.0
      2023-09-27 11:13:59.631 warn Error message from XS1:Error: getaddrinfo ENOTFOUND 192.168.188.50,242at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:109:26) {errno: -3008,code: 'ENOTFOUND',syscall: 'getaddrinfo',hostname: '192.168.188.50,242'}
      xs1.0
      2023-09-27 11:13:59.422 warn Error message from XS1:Error: getaddrinfo ENOTFOUND 192.168.188.50,242at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:109:26) {errno: -3008,code: 'ENOTFOUND',syscall: 'getaddrinfo',hostname: '192.168.188.50,242'}
      xs1.0
      2023-09-27 11:13:59.376 warn Adapter will exit in latest 1 sec with code xs1 Initialization Error:TypeError: Cannot read properties of undefined (reading '_subscribeForeignStates') at subscribeStates (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:7433:21) at /opt/iobroker/node_modules/iobroker.xs1/myAdapter.js:709:111 at new Promise (<anonymous>) at /opt/iobroker/node_modules/iobroker.xs1/myAdapter.js:709:20 at /opt/iobroker/node_modules/iobroker.xs1/myAdapter.js:267:81!
      xs1.0
      2023-09-27 11:13:59.374 info CopyList = {}
      xs1.0
      2023-09-27 11:13:59.372 info config XS1 Addresse: http://192.168.188.50,242:80
      xs1.0
      2023-09-27 11:13:59.370 info xs1 starting main...
      xs1.0
      2023-09-27 11:13:59.368 info Adapter disconnected and stopped with dostop(xs1 Initialization Error:TypeError: Cannot read properties of undefined (reading '_subscribeForeignStates') at subscribeStates (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:7433:21) at /opt/iobroker/node_modules/iobroker.xs1/myAdapter.js:709:111 at new Promise (<anonymous>) at /opt/iobroker/node_modules/iobroker.xs1/myAdapter.js:709:20 at /opt/iobroker/node_modules/iobroker.xs1/myAdapter.js:267:81) and callback(false)
      xs1.0
      2023-09-27 11:13:59.367 error xs1 Initialization Error:TypeError: Cannot read properties of undefined (reading '_subscribeForeignStates') at subscribeStates (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:7433:21) at /opt/iobroker/node_modules/iobroker.xs1/myAdapter.js:709:111 at new Promise (<anonymous>) at /opt/iobroker/node_modules/iobroker.xs1/myAdapter.js:709:20 at /opt/iobroker/node_modules/iobroker.xs1/myAdapter.js:267:81
      Hat mit Node 12 noch alles funktioniert.
      adapter: XS1@1.1.0
      js-controller: 16.20.2
      NPM: 8.19.14
      Kannst Du mir hier weiterhelfen?
      MfG
      • crunchip
        @trashman1981 sagte in Auch Probleme nach Node 16.20 Update:
        bevor ich den ganzen Text lese, eine Neuinstallation bringt von vornherein v18 automatisch mit, daher die Frage, wie dann v16 aufs System kommt
          Thomas Braun Most Active @Trashman1981 last edited by
          @trashman1981
          Erstmal prüfen ob/wie nodejs senkrecht installiert wurde.
          Kannst du auch mit dem Skript aus meiner Signatur machen.
          Oder
          iob diag
          anschauen.
            Habe auf 18.18 gewechselt. Gleicher Fehler
              Homoran Global Moderator Administrators @Trashman1981 last edited by
              wo ist die Ausgabe von iob diag vorher?
              und die Ausgabe von iob diag danach?
                Habe erst auf 18.18 gewechselt und dann iob laufen lassen.
                Bei iob (nutze ich zum ersten Mal) kam aber viel Text aber nichts, was irgendwie falsch aussah. Worauf müssten ich achten?
                crunchip Ro75 2 Replies Last reply Reply Quote 0
                • crunchip
                  crunchip Forum Testing Most Active @Trashman1981 last edited by
                  du erst mal gar nicht, einfach zeigen
                  frage mich allerdings noch immer
                  • Ro75
                    Ro75 @Trashman1981 last edited by
                    @trashman1981 deswegen hier posten, damit Hilfe auch kommen kann.
                      Copy text starting here:
                                           v.2023-06-20
                         Static hostname: raspberrypi
                               Icon name: computer
                              Machine ID: e92f2d8df54949499e286d108a5309ad
                                 Boot ID: 87a8e81479b04ddea680ea3b3bf7d275
                        Operating System: Debian GNU/Linux 11 (bullseye)
                                  Kernel: Linux 6.1.21-v8+
                            Architecture: arm64
                      Userland:               arm64
                      User-ID:                1000
                      X-Server:               false
                      Pending OS-Updates:     0
                      Pending iob updates:    0
                      Nodejs-Installation:    /usr/bin/nodejs         v18.18.0
                                              /usr/bin/node           v18.18.0
                                              /usr/bin/npm            9.8.1
                                              /usr/bin/npx            9.8.1
                      Recommended versions are nodejs 18.x.y and npm 9.x.y
                      MEMORY:
                      Mem:            3.8G        457M        2.7G        1.0M        654M        3.3G
                      Swap:            99M          0B         99M
                      Total:          3.9G        457M        2.8G
                      Active iob-Instances:   6
                      Active repo(s): stable
                      ioBroker Core:          js-controller           5.0.12
                                              admin                   6.10.1
                      Objects type: jsonl
                      States  type: jsonl
                      Objects:                3135
                      States:                 2777
                      Size of iob-Database:
                      10M     /opt/iobroker/iobroker-data/objects.jsonl
                      5.9M    /opt/iobroker/iobroker-data/states.jsonl
                        @trashman1981
                        Das sieht so auf den ersten Blick gut aus.
                          Ist halt komisch, das XS1 startet, die Aktoren lädt und nach ca 1sec (wie im log angekündigt) einfach stoppt
                          • mcm1957
                            mcm1957 @Trashman1981 last edited by
                            @trashman1981
                            XS1 ist ein sehr alter adapter. Er düfte prinzipiell Probleme haben:
                            https://github.com/iobroker-community-adapters/ioBroker.xs1/issues/1
                            Falls das Problem in ca 1 Woche noch von niemand nagegangen wurde, bitt emich nochmals explizit pingen. ICh schau dann mal kurz ob ich was machen kann.
                              Danke, @mcm57 .
                              Ich über mich mal in Geduld und Demut und hoffe, dass sich jemand diesem Problem annehmen wird...
                              Gruss
                              650
