    4. ioBroker restore problem
      root_ last edited by root_
      Ich versuche ein backup auf einer vorhandenen iobroker Installation wiederherzustellen.
      Habs über das webif und in der Konsole probiert.
      Bekomme auch nach "iobroker Restore meinfile.tar.gz" ein "System successfully restored!"
      Wenn ich jetzt aber "iobroker host this" starte, bekomme ich immer:
      test@raspberry:~$ iobroker host this
      node:internal/modules/cjs/loader:1024
        throw err;
      Error: Cannot find module 'tar'
      Require stack:
      - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js
      - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js
      - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1021:15)
          at Function.Module._load (node:internal/modules/cjs/loader:866:27)
          at Module.require (node:internal/modules/cjs/loader:1093:19)
          at require (node:internal/modules/cjs/helpers:108:18)
          at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js:12:31)
          at Module._compile (node:internal/modules/cjs/loader:1191:14)
          at Object.Module._extensions..js (node:internal/modules/cjs/loader:1245:10)
          at Module.load (node:internal/modules/cjs/loader:1069:32)
          at Function.Module._load (node:internal/modules/cjs/loader:904:12)
          at Module.require (node:internal/modules/cjs/loader:1093:19) {
        code: 'MODULE_NOT_FOUND',
        requireStack: [
          '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js',
          '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js',
          '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
      iobroker lässt sich auch nicht starten.
      Alle Adapter und Host sind auf aktuellem beta release.
      Glasfaser 2 Replies Last reply Reply Quote 0
      • Glasfaser
        Glasfaser @root_ last edited by
        @root_ sagte in ioBroker restore problem:
        Das gleiche Aktuell hier :
        https://forum.iobroker.net/topic/68636/gestern-update-alles-gut-nach-restart-nicht-erreichbar
        Nur zur Info , deine Vorgaben zum System von dir sind recht dünn !
          root_ @Glasfaser last edited by root_
          @glasfaser stimmt. sorry.
          Wo bekomm ich denn die Tabelle zum ausfüllen her?
          • Glasfaser
            Glasfaser @root_ last edited by Glasfaser
            würde dann mal in meine Glaskugel schauen , hast du dann auch die zuvor neu installierte installation von ioBroker auch danach den JS-Controller auf die Version 5 geupdaten und dann erst dein Backup eingespielt !?
            Als Beta Tester sollte man das schon wissen !
            R Glasfaser 2 Replies Last reply Reply Quote 1
              @glasfaser ich habe auf einer laufenden Version mit js5 das backup vom Vortag wieder herstellen wollen. Ist keine neu Installation.
              • Glasfaser
                Also auf ein laufendes ioBroker von dir und dann eine Backup eingespielt !?
                So funktioniert das nicht .
                Neues Image mit ioBroker , dann das Backup einspielen ( Restore )
                  @glasfaser dann ist mir die Funktion von backitup nicht klar. Wozu ein backup wenn ich es dann nicht in der laufenden Konfiguration wiederherstellen kann. Das ging bis jetzt immer.
                  • Glasfaser
                    ist im Prinzip z.b der Konsolen Befehl
                    iobroker backup
                    halt nur verfeinert in einer Weboberfläche .
                    Eine Restore nur auf einem frischen ioBroker , dann über den Backitup !
                    • Glasfaser
                      Kurz und knapp der Müll ... Fehler usw, bleibt vorhanden !
                        @glasfaser alles klar. War mir nicht bewusst. Dann mach Ichs mal mit einer neuen Installation. Werde berichten. Danke dir.
                        • Glasfaser
                          Glasfaser @Glasfaser last edited by
                          @root_
                          und dann auch daran denken :
                          @glasfaser sagte in ioBroker restore problem:
                            @glasfaser said in ioBroker restore problem:
                            @root_
                            Danke dir noch mal.
                            Hat super funktioniert. Wieder was gelernt.
                            Glasfaser 1 Reply Last reply Reply Quote 1
                            • Glasfaser
                              Dann setze den Thread auf [gelöst]
                              1010
