    4. Roborock - Adapter stürzt ständig ab
    • Michael Sauer
      Michael Sauer last edited by Michael Sauer
      habe das Problem das ich den Adapter bisher nicht richtig nutzen kann.
      Mein Saugroboter ist ein S8+. Verbindung wird aufgebaut jedoch stürzt der Adapter im Minuten Takt ab.
      Habe den Adapter auf Debug gestellt:
      roborock.0
      2023-09-28 20:32:33.060	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
      roborock.0
      2023-09-28 20:32:33.043	error	adapter disabled
      roborock.0
      2023-09-28 20:32:33.023	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      roborock.0
      2023-09-28 20:31:50.150	warn	setInterval called, but adapter is shutting down
      roborock.0
      2023-09-28 20:31:44.518	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      roborock.0
      2023-09-28 20:31:44.515	info	terminating
      roborock.0
      2023-09-28 20:31:44.502	error	Cannot read properties of undefined (reading 'captureException')
      roborock.0
      2023-09-28 20:31:44.502	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
      roborock.0
      2023-09-28 20:31:44.500	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
      roborock.0
      2023-09-28 20:31:44.499	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      roborock.0
      2023-09-28 20:31:32.436	info	MQTT initialized
      roborock.0
      2023-09-28 20:31:27.501	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v16.20.2, js-controller: 4.0.24
      roborock.0
      2023-09-28 20:31:26.946	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      roborock.0
      2023-09-28 20:30:35.148	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      roborock.0
      2023-09-28 20:30:35.143	info	terminating
      roborock.0
      2023-09-28 20:30:35.127	error	Cannot read properties of undefined (reading 'captureException')
      roborock.0
      2023-09-28 20:30:35.126	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
      roborock.0
      2023-09-28 20:30:35.124	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
      roborock.0
      2023-09-28 20:30:35.122	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      roborock.0
      2023-09-28 20:30:08.135	info	MQTT initialized
      roborock.0
      2023-09-28 20:30:04.677	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v16.20.2, js-controller: 4.0.24
      roborock.0
      2023-09-28 20:30:04.393	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      roborock.0
      2023-09-28 20:01:20.818	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      roborock.0
      2023-09-28 20:01:20.815	info	terminating
      roborock.0
      2023-09-28 20:01:20.806	error	Cannot read properties of undefined (reading 'captureException')
      roborock.0
      2023-09-28 20:01:20.806	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
      roborock.0
      2023-09-28 20:01:20.805	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
      roborock.0
      2023-09-28 20:01:20.804	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      roborock.0
      2023-09-28 20:01:06.531	info	MQTT initialized
      roborock.0
      2023-09-28 20:01:05.376	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v16.20.2, js-controller: 4.0.24
      roborock.0
      2023-09-28 20:01:05.189	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      roborock.0
      2023-09-28 20:00:24.153	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      roborock.0
      2023-09-28 20:00:24.150	info	terminating
      roborock.0
      2023-09-28 20:00:24.120	error	Cannot read properties of undefined (reading 'captureException')
      roborock.0
      2023-09-28 20:00:24.119	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
      roborock.0
      2023-09-28 20:00:24.118	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
      roborock.0
      2023-09-28 20:00:24.116	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      roborock.0
      2023-09-28 20:00:08.550	info	MQTT initialized
      roborock.0
      2023-09-28 20:00:03.663	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v16.20.2, js-controller: 4.0.24
      roborock.0
      2023-09-28 20:00:03.375	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      roborock.0
      2023-09-28 19:59:19.285	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      roborock.0
      2023-09-28 19:59:19.282	info	terminating
      roborock.0
      2023-09-28 19:59:19.274	error	Cannot read properties of undefined (reading 'captureException')
      roborock.0
      2023-09-28 19:59:19.273	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
      roborock.0
      2023-09-28 19:59:19.272	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
      roborock.0
      2023-09-28 19:59:19.271	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      roborock.0
      2023-09-28 19:59:07.700	info	MQTT initialized
      roborock.0
      2023-09-28 19:59:05.970	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v16.20.2, js-controller: 4.0.24
      roborock.0
      2023-09-28 19:59:05.760	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      roborock.0
      2023-09-28 19:58:55.753	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      roborock.0
      2023-09-28 19:58:55.751	info	terminating
      roborock.0
      2023-09-28 19:58:55.746	info	Got terminate signal TERMINATE_YOURSELF
      Jemand eine Idee?
      Thomas Braun Glasfaser copystring 3 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Michael Sauer last edited by
        @michael-sauer sagte in Adapter stürzt ständig ab:
        Jemand eine Idee?
        System auf Stand halten. nodejs@18 und js-controller@5 z. B.
        Michael Sauer 1 Reply Last reply Reply Quote 0
        • Michael Sauer
          Michael Sauer @Thomas Braun last edited by
          @thomas-braun Ist ein Argument. Danke
          • Glasfaser
            Glasfaser last edited by
            Version 0.4.4
            Die Version ist BETA , läuft es auch nicht mit dem Stable !?
            Keine Verbindung !?
            Stelle mal auf DEBUG
            • Glasfaser
              Glasfaser @Michael Sauer last edited by
              @michael-sauer
              kannst du den Thread Titel anpassen auf :
              roborock Adapter stürzt ständig ab
              • Michael Sauer
                Michael Sauer @Glasfaser last edited by
                @glasfaser
                Steht auf Debug. System ist aktualisiert:
                roborock.0
                2023-09-29 08:17:46.345	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
                roborock.0
                2023-09-29 08:17:46.334	error	adapter disabled
                roborock.0
                2023-09-29 08:17:46.317	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                roborock.0
                2023-09-29 08:17:10.665	info	terminating
                roborock.0
                2023-09-29 08:17:10.373	warn	State "roborock.0.Devices.5Eo7zrAcFZhjGJqyG5saSx.cleaningInfo.Records.0.avoid_count" has no existing object, this might lead to an error in future versions
                roborock.0
                2023-09-29 08:17:10.370	warn	setTimeout called, but adapter is shutting down
                roborock.0
                2023-09-29 08:17:10.369	warn	setTimeout called, but adapter is shutting down
                roborock.0
                2023-09-29 08:17:10.271	warn	setTimeout called, but adapter is shutting down
                roborock.0
                roborock.0
                2023-09-29 08:17:10.185	warn	setTimeout called, but adapter is shutting down
                roborock.0
                2023-09-29 08:17:10.181	warn	Failed to create map. retry
                roborock.0
                2023-09-29 08:17:10.161	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                roborock.0
                2023-09-29 08:17:10.160	info	terminating
                roborock.0
                2023-09-29 08:17:10.146	error	Cannot read properties of undefined (reading 'captureException')
                roborock.0
                2023-09-29 08:17:10.146	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
                roborock.0
                2023-09-29 08:17:10.145	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
                roborock.0
                2023-09-29 08:17:10.144	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                roborock.0
                2023-09-29 08:17:07.454	warn	Failed to execute load_multi_map on robot 5Eo7zrAcFZhjGJqyG5saSx Error: There was an error processing the request with id 3224 error: {"code":-10003,"message":"action locked"}
                roborock.0
                2023-09-29 08:16:54.267	info	MQTT initialized
                roborock.0
                2023-09-29 08:16:52.229	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v18.18.0, js-controller: 5.0.12
                roborock.0
                2023-09-29 08:16:52.080	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                S Glasfaser 2 Replies Last reply Reply Quote 0
                  SpacerX @Michael Sauer last edited by SpacerX
                  @michael-sauer Hast du einen Raspi laufen? Wenn ja dort funzt das mit der Map nicht richtig. Deshalb vielleicht die deine Probs. Schau mal in den Beitrag zum Adapter.
                  https://forum.iobroker.net/topic/67186/neuer-adapter-f%C3%BCr-roborock-staubsauger
                  • Glasfaser
                    @michael-sauer sagte in Roborock - Adapter stürzt ständig ab:
                    Steht auf Debug.
                    Nö ist nicht , ist die gleiche Info wie zuvor !
                    Die Adapter Instanz auf DEBUG stellen .
                    Beispiel :
                    Was war hiermit !?
                    @glasfaser sagte in Roborock - Adapter stürzt ständig ab:
                    Und Zeige mal die Full Ausgabe von
                    iob diag
                      ticaki Developer last edited by
                      Kannst du das versenden von anonymisierten Daten mal aktivieren? Sentry
                      • Michael Sauer
                        @glasfaser Hast recht.
                        Hier der vollständige Log:
                        roborock.0
                        2023-09-29 20:44:27.997	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v18.18.0, js-controller: 5.0.12
                        roborock.0
                        2023-09-29 20:44:27.787	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                        roborock.0
                        2023-09-29 20:44:27.769	debug	Plugin sentry Initialize Plugin (enabled=true)
                        roborock.0
                        2023-09-29 20:43:40.797	warn	Failed to execute get_clean_summary on robot 5Eo7zrAcFZhjGJqyG5saSx TypeError: Cannot read properties of undefined (reading 'captureException')
                        roborock.0
                        2023-09-29 20:43:40.797	debug	ERROR Online state for 5Eo7zrAcFZhjGJqyG5saSx: true
                        roborock.0
                        2023-09-29 20:43:40.791	warn	Failed to execute get_clean_record_map on robot 5Eo7zrAcFZhjGJqyG5saSx retry
                        roborock.0
                        2023-09-29 20:43:40.790	debug	ERROR Online state for 5Eo7zrAcFZhjGJqyG5saSx: true
                        roborock.0
                        2023-09-29 20:43:40.775	debug	Length of message queue: 0
                        roborock.0
                        2023-09-29 20:43:40.774	debug	dps debug: {"id":3403,"result":["retry"]}
                        roborock.0
                        2023-09-29 20:43:40.614	warn	State "roborock.0.Devices.5Eo7zrAcFZhjGJqyG5saSx.cleaningInfo.Records.0.avoid_count" has no existing object, this might lead to an error in future versions
                        roborock.0
                        2023-09-29 20:43:40.611	warn	setTimeout called, but adapter is shutting down
                        roborock.0
                        2023-09-29 20:43:40.610	warn	setTimeout called, but adapter is shutting down
                        roborock.0
                        2023-09-29 20:43:40.591	debug	Length of message queue: 0
                        roborock.0
                        2023-09-29 20:43:40.591	debug	dps debug: {"id":8382,"result":[{"begin":1695980402,"end":1695981303,"duration":901,"area":11682500,"error":0,"complete":0,"start_type":3,"clean_type":3,"finish_reason":62,"dust_collection_status":1,"avoid_count":2,"map_flag":0}]}
                        roborock.0
                        2023-09-29 20:43:40.379	warn	Failed to create map. retry
                        roborock.0
                        2023-09-29 20:43:40.377	warn	setTimeout called, but adapter is shutting down
                        roborock.0
                        2023-09-29 20:43:40.344	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                        roborock.0
                        2023-09-29 20:43:40.343	debug	Plugin sentry destroyed
                        roborock.0
                        2023-09-29 20:43:40.341	info	terminating
                        roborock.0
                        2023-09-29 20:43:40.321	error	Cannot read properties of undefined (reading 'captureException')
                        roborock.0
                        2023-09-29 20:43:40.320	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
                        roborock.0
                        2023-09-29 20:43:40.319	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
                        roborock.0
                        2023-09-29 20:43:40.319	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        roborock.0
                        2023-09-29 20:43:40.316	debug	Length of message queue: 2
                        roborock.0
                        2023-09-29 20:43:40.316	debug	Not clearing messageQueue. null - 24752
                        roborock.0
                        2023-09-29 20:43:40.315	debug	dps debug: {"id":5996,"result":["retry"]}
                        roborock.0
                        2023-09-29 20:43:40.312	debug	Length of message queue: 2
                        roborock.0
                        2023-09-29 20:43:40.312	debug	dps debug: {"id":1492,"result":{"clean_time":202871,"clean_area":2843662500,"clean_count":144,"dust_collection_count":128,"records":[1695980402,1695978009,1695807600,1695805205,1695718805,1695634800,1695632403,1695546005,1695459607,1695375600,1695373208,1695286806,1695202799,1695200405,1695114008,1695030000,1695027609,1694941211,1694854807,1694770801]}}
                        roborock.0
                        2023-09-29 20:43:39.961	debug	downloadURL: https://github.com/AlexxIT/go2rtc/releases/download/v1.3.0/go2rtc_linux_arm
                        roborock.0
                        2023-09-29 20:43:39.961	debug	System type: go2rtc_linux_arm
                        roborock.0
                        2023-09-29 20:43:39.961	debug	platform: linux
                        roborock.0
                        2023-09-29 20:43:39.960	debug	arch: arm
                        roborock.0
                        2023-09-29 20:43:39.958	debug	Update map
                        roborock.0
                        2023-09-29 20:43:39.955	debug	Length of message queue: 1
                        roborock.0
                        2023-09-29 20:43:39.954	debug	dps debug: {"id":1643,"result":{"water_box_mode":201}}
                        roborock.0
                        2023-09-29 20:43:39.684	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_water_box_custom_mode
                        roborock.0
                        2023-09-29 20:43:39.681	debug	Length of message queue: 1
                        roborock.0
                        2023-09-29 20:43:39.679	debug	dps debug: {"id":3641,"result":[{"carpet_clean_mode":3}]}
                        roborock.0
                        2023-09-29 20:43:39.388	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_carpet_clean_mode
                        roborock.0
                        2023-09-29 20:43:39.386	debug	Length of message queue: 1
                        roborock.0
                        2023-09-29 20:43:39.384	debug	dps debug: {"id":5183,"result":[{"enable":1,"current_integral":1000,"current_high":500,"current_low":1000,"stall_time":10}]}
                        roborock.0
                        2023-09-29 20:43:39.303	debug	get_timer: []
                        roborock.0
                        2023-09-29 20:43:39.302	debug	Length of message queue: 2
                        roborock.0
                        2023-09-29 20:43:39.301	debug	dps debug: {"id":1710,"result":[]}
                        roborock.0
                        2023-09-29 20:43:39.299	debug	get_server_timer: [["1688127243968","on",0],["1688127295244","on",0]]
                        roborock.0
                        2023-09-29 20:43:39.298	debug	Length of message queue: 3
                        roborock.0
                        2023-09-29 20:43:39.297	debug	dps debug: {"id":9140,"result":[["1688127243968","on",0],["1688127295244","on",0]]}
                        roborock.0
                        2023-09-29 20:43:38.906	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_carpet_mode
                        roborock.0
                        2023-09-29 20:43:38.905	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_timer
                        roborock.0
                        2023-09-29 20:43:38.904	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_server_timer
                        roborock.0
                        2023-09-29 20:43:38.903	debug	Length of message queue: 1
                        roborock.0
                        2023-09-29 20:43:38.902	debug	dps debug: {"id":1525,"result":{"ssid":"S-Home","ip":"192.168.78.122","mac":"b0:4a:39:6b:e2:59","bssid":"b0:f2:08:d9:88:ed","rssi":-68}}
                        roborock.0
                        2023-09-29 20:43:38.555	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_network_info
                        roborock.0
                        2023-09-29 20:43:38.554	debug	Consumables of robot: [{"main_brush_work_time":203079,"side_brush_work_time":203079,"filter_work_time":203079,"filter_element_work_time":0,"sensor_dirty_time":90815,"dust_collection_work_times":128}]
                        roborock.0
                        2023-09-29 20:43:38.551	debug	Length of message queue: 1
                        roborock.0
                        2023-09-29 20:43:38.550	debug	dps debug: {"id":1936,"result":[{"main_brush_work_time":203079,"side_brush_work_time":203079,"filter_work_time":203079,"filter_element_work_time":0,"sensor_dirty_time":90815,"dust_collection_work_times":128}]}
                        roborock.0
                        2023-09-29 20:43:38.287	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_consumable
                        roborock.0
                        2023-09-29 20:43:38.286	debug	Mapped room matched: 11316198 with name: Küche
                        roborock.0
                        2023-09-29 20:43:38.285	debug	Mapped room matched: 11316194 with name: Flur
                        roborock.0
                        2023-09-29 20:43:38.284	debug	Mapped room matched: 12646380 with name: Esszimmer
                        roborock.0
                        2023-09-29 20:43:38.283	debug	Mapped room matched: 11309675 with name: Wohnzimmer
                        roborock.0
                        2023-09-29 20:43:38.282	debug	All mapped rooms: [[16,"11309675",6],[17,"12646380",13],[18,"11316194",8],[19,"11316198",14]]
                        roborock.0
                        2023-09-29 20:43:38.281	debug	Length of message queue: 1
                        roborock.0
                        2023-09-29 20:43:38.281	debug	dps debug: {"id":8606,"result":[[16,"11309675",6],[17,"12646380",13],[18,"11316194",8],[19,"11316198",14]]}
                        roborock.0
                        2023-09-29 20:43:38.238	debug	foreign.message attribute: 128 with value: 4
                        roborock.0
                        2023-09-29 20:43:38.237	debug	dps debug: {"128":4}
                        roborock.0
                        2023-09-29 20:43:38.143	debug	Length of message queue: 1
                        roborock.0
                        2023-09-29 20:43:38.142	debug	dps debug: {"id":8398,"result":[{"msg_ver":2,"msg_seq":126,"state":8,"battery":100,"clean_time":901,"clean_area":11682500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":103,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":201,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":385,"is_exploring":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":5,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":2,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":0,"unsave_map_reason":4,"unsave_map_flag":0,"clean_percent":0,"rss":2,"dss":128}]}
                        roborock.0
                        2023-09-29 20:43:37.907	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_room_mapping
                        roborock.0
                        2023-09-29 20:43:37.891	debug	get_status: {"msg_ver":2,"msg_seq":125,"state":8,"battery":100,"clean_time":901,"clean_area":11682500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":103,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":201,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":385,"is_exploring":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":5,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":2,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":0,"unsave_map_reason":4,"unsave_map_flag":0,"clean_percent":0,"rss":2,"dss":128}
                        roborock.0
                        2023-09-29 20:43:37.889	debug	Length of message queue: 0
                        roborock.0
                        2023-09-29 20:43:37.888	debug	dps debug: {"id":5982,"result":[{"msg_ver":2,"msg_seq":125,"state":8,"battery":100,"clean_time":901,"clean_area":11682500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":103,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":201,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":385,"is_exploring":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":5,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":2,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":0,"unsave_map_reason":4,"unsave_map_flag":0,"clean_percent":0,"rss":2,"dss":128}]}
                        roborock.0
                        2023-09-29 20:43:37.645	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_status
                        roborock.0
                        2023-09-29 20:43:37.644	debug	Latest data requested
                        roborock.0
                        2023-09-29 20:43:37.642	debug	Length of message queue: 0
                        roborock.0
                        2023-09-29 20:43:37.640	debug	dps debug: {"id":1305,"result":[{"max_multi_map":4,"max_bak_map":1,"multi_map_count":2,"map_info":[{"mapFlag":0,"add_time":1695979052,"length":12,"name":"Erdgeschoss ","bak_maps":[{"mapFlag":4,"add_time":1695806345}]},{"mapFlag":1,"add_time":1692254347,"length":12,"name":"Obergeschoss","bak_maps":[{"mapFlag":5,"add_time":1688451884}]}]}]}
                        roborock.0
                        2023-09-29 20:43:37.486	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_multi_maps_list
                        roborock.0
                        2023-09-29 20:43:37.382	debug	Length of message queue: 0
                        roborock.0
                        2023-09-29 20:43:37.379	debug	dps debug: {"id":3178,"result":[111,112,113,114,115,116,117,118,119,120,121,122,123,124,125]}
                        roborock.0
                        2023-09-29 20:43:37.164	debug	Firmware features request
                        roborock.0
                        2023-09-29 20:43:37.164	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_fw_features
                        roborock.0
                        2023-09-29 20:43:37.160	debug	5Eo7zrAcFZhjGJqyG5saSx online. Starting mainUpdateInterval.
                        roborock.0
                        2023-09-29 20:43:23.804	debug	Robot key: roborock.vacuum.a51
                        roborock.0
                        2023-09-29 20:43:23.803	debug	RoomIDs debug: {"11309675":"Wohnzimmer","11314643":"Wohnzimmer1","11316194":"Flur","11316198":"Küche","11316201":"Küche1","11319794":"Badezimmer","11319802":"Spielzimmer","11319804":"Kinderzimmer","11319806":"Schlafzimmer","12646380":"Esszimmer","13421850":"Standard","13421863":"Phillip Schlafzimmer","13421865":"Badezimmer1"}
                        roborock.0
                        2023-09-29 20:43:23.801	info	MQTT initialized
                        roborock.0
                        2023-09-29 20:43:20.623	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v18.18.0, js-controller: 5.0.12
                        roborock.0
                        2023-09-29 20:43:20.491	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                        roborock.0
                        2023-09-29 20:43:20.474	debug	Plugin sentry Initialize Plugin (enabled=true)
                        roborock.0
                        2023-09-29 20:43:20.348	debug	States connected to redis: 127.0.0.1:6379
                        roborock.0
                        2023-09-29 20:43:20.336	debug	States create User PubSub Client
                        roborock.0
                        2023-09-29 20:43:20.335	debug	States create System PubSub Client
                        roborock.0
                        2023-09-29 20:43:20.327	debug	Redis States: Use Redis connection: 127.0.0.1:6379
                        roborock.0
                        2023-09-29 20:43:20.307	debug	Objects connected to redis: 127.0.0.1:6379
                        roborock.0
                        2023-09-29 20:43:20.300	debug	Objects client initialize lua scripts
                        roborock.0
                        2023-09-29 20:43:19.846	debug	Objects create User PubSub Client
                        roborock.0
                        2023-09-29 20:43:19.844	debug	Objects create System PubSub Client
                        roborock.0
                        2023-09-29 20:43:19.842	debug	Objects client ready ... initialize now
                        roborock.0
                        2023-09-29 20:43:19.803	debug	Redis Objects: Use Redis connection: 127.0.0.1:6379
                        Skript v.2023-06-20
                        *** BASE SYSTEM ***
                           Static hostname: iobroker
                                 Icon name: computer
                                Machine ID: 5f09e0dc24364fc8951dcf01ea03774d
                                   Boot ID: 687f969e56cf41c2bcbbdd9cffef19bb
                          Operating System: Raspbian GNU/Linux 10 (buster)
                                    Kernel: Linux 5.10.103-v7l+
                              Architecture: arm
                        Model           : Raspberry Pi 4 Model B Rev 1.2
                        Docker          : false
                        Virtualization  : none
                        Kernel          : armv7l
                        Userland        : armhf
                        Systemuptime and Load:
                         20:55:52 up 23:02,  1 user,  load average: 4.01, 3.35, 2.81
                        CPU threads: 4
                        Raspberry only:
                        throttled=0x0
                        Other values than 0x0 hint to temperature/voltage problems
                        temp=57.4'C
                        volt=0.8500V
                        *** Time and Time Zones ***
                                       Local time: Fri 2023-09-29 20:55:53 CEST
                                   Universal time: Fri 2023-09-29 18:55:53 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        *** User and Groups ***
                        pi
                        /home/pi
                        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                        *** X-Server-Setup ***
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:           3.8G        2.7G        111M         13M        1.0G        971M
                        Swap:           99M         99M        0.0K
                        Total:         3.9G        2.8G        111M
                                 3838 M total memory
                                 2706 M used memory
                                  670 M active memory
                                 2888 M inactive memory
                                  111 M free memory
                                  167 M buffer memory
                                  853 M swap cache
                                   99 M total swap
                                   99 M used swap
                                    0 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /dev/root      ext4       59G   19G   38G  34% /
                        devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
                        tmpfs          tmpfs     1.9G  2.2M  1.9G   1% /dev/shm
                        tmpfs          tmpfs     1.9G   18M  1.9G   1% /run
                        tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
                        /dev/loop1     squashfs   41M   41M     0 100% /snap/certbot/3025
                        /dev/loop0     squashfs   54M   54M     0 100% /snap/core20/2018
                        /dev/loop2     squashfs   91M   91M     0 100% /snap/core/15929
                        /dev/loop3     squashfs   91M   91M     0 100% /snap/core/16098
                        /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
                        tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
                        Show mounted filesystems (real ones only):
                        TARGET               SOURCE         FSTYPE   OPTIONS
                        /                    /dev/mmcblk0p2 ext4     rw,noatime
                        |-/sys/fs/bpf        none           bpf      rw,nosuid,nodev,noexec,relatime,mode=700
                        |-/snap/certbot/3025 /dev/loop1     squashfs ro,nodev,relatime
                        |-/snap/core20/2018  /dev/loop0     squashfs ro,nodev,relatime
                        |-/snap/core/15929   /dev/loop2     squashfs ro,nodev,relatime
                        |-/snap/core/16098   /dev/loop3     squashfs ro,nodev,relatime
                        `-/boot              /dev/mmcblk0p1 vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                        /var:
                        3.6G    /var/
                        3.1G    /var/lib
                        1.9G    /var/lib/mysql
                        1.7G    /var/lib/mysql/iobroker
                        525M    /var/lib/piVCCU3
                        Archived and active journals take up 16.0M in the file system.
                        /opt/iobroker/backups:
                        197M    /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        695M    /opt/iobroker/iobroker-data/
                        466M    /opt/iobroker/iobroker-data/files
                        136M    /opt/iobroker/iobroker-data/backup-objects
                        87M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js
                        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                        28M     /opt/iobroker/iobroker-data/objects.jsonl
                        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c4efe404.js.map
                        20M     /opt/iobroker/iobroker-data/objects.json.migrated
                        20M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                        *** NodeJS-Installation ***
                        /usr/bin/nodejs         v18.18.0
                        /usr/bin/node           v18.18.0
                        /usr/bin/npm            9.8.1
                        /usr/bin/npx            9.8.1
                        nodejs:
                          Installed: 18.18.0-1nodesource1
                          Candidate: 18.18.0-1nodesource1
                          Version table:
                         *** 18.18.0-1nodesource1 500
                                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                100 /var/lib/dpkg/status
                             18.17.1-1nodesource1 500
                             18.17.0-1nodesource1 500
                             18.16.1-1nodesource1 500
                             18.16.0-1nodesource1 500
                             18.15.0-1nodesource1 500
                             18.14.2-1nodesource1 500
                             18.14.1-1nodesource1 500
                             18.14.0-1nodesource1 500
                             18.13.0-1nodesource1 500
                             18.12.0-1nodesource1 500
                             18.11.0-1nodesource1 500
                             18.10.0-1nodesource1 500
                             18.9.1-1nodesource1 500
                             18.9.0-1nodesource1 500
                             18.8.0-1nodesource1 500
                             18.7.0-1nodesource1 500
                             18.6.0-1nodesource1 500
                             18.5.0-1nodesource1 500
                             18.4.0-1nodesource1 500
                             18.3.0-1nodesource1 500
                             18.2.0-1nodesource1 500
                             18.1.0-1nodesource1 500
                             18.0.0-1nodesource1 500
                             10.24.0~dfsg-1~deb10u3 500
                        No problems detected
                        Errors in npm tree: 0
                        *** ioBroker-Installation ***
                        ioBroker Status
                        At least one iobroker host is running.
                        Objects type: redis
                        States  type: redis
                        No configuration change needed.
                        Multihost discovery server: disabled
                        Discovery authentication:   enabled
                        Persistent activation:      disabled
                        Objects:                    redis on 127.0.0.1
                        States:                     redis on 127.0.0.1
                        Core adapters versions
                        admin:          6.10.2
                        javascript:     7.1.4
                        Adapters from github:   2
                        Adapter State
                        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          system.adapter.alarm.0                  : alarm                 : iobroker                                 - disabled
                        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                        + system.adapter.bring.0                  : bring                 : iobroker                                 -  enabled
                        + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                          system.adapter.coronavirus-statistics.0 : coronavirus-statistics: iobroker                                 - disabled
                          system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                        + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                        + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
                          system.adapter.eusec.0                  : eusec                 : iobroker                                 - disabled
                          system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                          system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                        + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 -  enabled
                        + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 42001
                        + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
                          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                          system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
                          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
                        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                        + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                        + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
                        + system.adapter.linkeddevices.0          : linkeddevices         : iobroker                                 -  enabled
                        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                        + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
                        + system.adapter.pi-hole.0                : pi-hole               : iobroker                                 -  enabled
                        + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
                        + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                        + system.adapter.radar2.0                 : radar2                : iobroker                                 -  enabled
                        + system.adapter.radar2.1                 : radar2                : iobroker                                 -  enabled
                          system.adapter.ring.0                   : ring                  : iobroker                                 - disabled
                          system.adapter.roadtraffic.0            : roadtraffic           : iobroker                                 - disabled
                          system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled
                        + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
                          system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled
                        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                        + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
                        + system.adapter.smartcontrol.0           : smartcontrol          : iobroker                                 -  enabled
                          system.adapter.socketio.0               : socketio              : iobroker                                 - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                        + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
                        + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                        + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
                        + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                          system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
                          system.adapter.tr-064.1                 : tr-064                : iobroker                                 - disabled
                        + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                          system.adapter.upnp.0                   : upnp                  : iobroker                                 - disabled
                          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
                          system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 - disabled
                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                          system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                          system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                          system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
                          system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
                        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
                        + instance is alive
                        ioBroker-Repositories
                        Active repo(s): beta
                        Installed ioBroker-Instances
                        Used repository: beta
                        Adapter    "admin"        : 6.10.4   , installed 6.10.2 [Updatable]
                        Adapter    "alarm"        : 3.3.13   , installed 3.3.13
                        Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
                        Adapter    "backitup"     : 2.8.2    , installed 2.8.1  [Updatable]
                        Adapter    "bring"        : 1.8.4    , installed 1.8.1  [Updatable]
                        Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                        Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                        Adapter    "email"        : 1.2.0    , installed 1.2.0
                        Adapter    "eusec"        : 1.1.2    , installed 1.1.0  [Updatable]
                        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                        Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
                        Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
                        Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
                        Adapter    "iot"          : 2.0.11   , installed 2.0.11
                        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                        Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                        Controller "js-controller": 5.0.12   , installed 5.0.12
                        Adapter    "lgtv"         : 1.1.12   , installed 1.1.12
                        Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
                        Adapter    "mqtt"         : 5.0.0    , installed 5.0.0
                        Adapter    "node-red"     : 4.0.3    , installed 4.0.3
                        Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
                        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                        Adapter    "pvforecast"   : 2.8.1    , installed 2.8.1
                        Adapter    "radar2"       : 2.0.7    , installed 2.0.7
                        Adapter    "ring"         : 5.0.0-alpha.0, installed 3.4.0 [Updatable]
                        Adapter    "roadtraffic"  : 0.2.0    , installed 0.2.0
                        Adapter    "roborock"     : 0.4.4    , installed 0.4.4
                        Adapter    "samsung"      : 0.5.11   , installed 0.5.11
                        Adapter    "schoolfree"   : 1.1.2    , installed 1.1.2
                        Adapter    "shelly"       : 6.4.5    , installed 6.4.1  [Updatable]
                        Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
                        Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
                        Adapter    "socketio"     : 6.5.6    , installed 6.5.5  [Updatable]
                        Adapter    "sonos"        : 2.3.3    , installed 2.3.1  [Updatable]
                        Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                        Adapter    "sql"          : 2.2.0    , installed 2.2.0
                        Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                        Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                        Adapter    "vis"          : 1.4.16   , installed 1.4.16
                        Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                        Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                        Adapter    "web"          : 6.1.3    , installed 6.1.2  [Updatable]
                        Adapter    "ws"           : 2.5.6    , installed 2.5.5  [Updatable]
                        Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
                        Objects and States
                        Objects:        32411
                        States:         52049
                        Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                        Hit:2 http://phoscon.de/apt/deconz buster InRelease
                        Ign:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                        Hit:4 http://archive.raspberrypi.org/debian buster InRelease
                        Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
                        Err:6 https://deb.nodesource.com/node_18.x nodistro Release
                          Could not handshake: Error in the pull function. [IP: 2606:4700:10::6816:41a 443]
                        Get:7 https://apt.grafana.com stable InRelease [5984 B]
                        Reading package lists...
                        E: The repository 'https://deb.nodesource.com/node_18.x nodistro Release' no longer has a Release file.
                        Pending Updates: 0
                        *** Listening Ports ***
                        tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       1318755    12061/io.jarvis.0
                        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          22913      809/lighttpd
                        tcp        0      0 192.168.78.83:42001     0.0.0.0:*               LISTEN      1001       87501      6525/io.hm-rpc.0
                        tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        21806      724/pihole-FTL
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18356      738/sshd
                        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          332335     14432/cupsd
                        tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       88205      6262/node-red
                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       86309      6281/io.shelly.0
                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       87235      6402/io.mqtt.0
                        tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          22964      818/smbd
                        tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        21812      724/pihole-FTL
                        tcp        0      0 0.0.0.0:3306            0.0.0.0:*               LISTEN      110        16875      808/mysqld
                        tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          22965      818/smbd
                        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        16819      772/redis-server 12
                        tcp6       0      0 :::80                   :::*                    LISTEN      0          22914      809/lighttpd
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       3021956    27005/io.admin.0
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       2963823    25413/io.web.0
                        tcp6       0      0 :::53                   :::*                    LISTEN      999        21808      724/pihole-FTL
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          18358      738/sshd
                        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          332334     14432/cupsd
                        tcp6       0      0 :::3000                 :::*                    LISTEN      113        136316     8949/grafana
                        tcp6       0      0 :::445                  :::*                    LISTEN      0          22962      818/smbd
                        tcp6       0      0 ::1:4711                :::*                    LISTEN      999        21813      724/pihole-FTL
                        tcp6       0      0 ::1:6379                :::*                    LISTEN      109        16820      772/redis-server 12
                        tcp6       0      0 :::139                  :::*                    LISTEN      0          22963      818/smbd
                        tcp6       0      0 :::3500                 :::*                    LISTEN      1001       90354      6593/io.sonos.0
                        udp        0      0 0.0.0.0:41879           0.0.0.0:*                           1001       601710     9411/io.backitup.0
                        udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        21805      724/pihole-FTL
                        udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       89218      6437/io.radar2.0
                        udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       88118      6318/io.radar2.1
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16209      471/dhclient
                        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          332343     14433/cups-browsed
                        udp        0      0 192.168.78.255:137      0.0.0.0:*                           0          21669      701/nmbd
                        udp        0      0 192.168.78.83:137       0.0.0.0:*                           0          21668      701/nmbd
                        udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          21656      701/nmbd
                        udp        0      0 192.168.78.255:138      0.0.0.0:*                           0          21671      701/nmbd
                        udp        0      0 192.168.78.83:138       0.0.0.0:*                           0          21670      701/nmbd
                        udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          21657      701/nmbd
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17448      402/avahi-daemon: r
                        udp        0      0 0.0.0.0:44942           0.0.0.0:*                           108        17450      402/avahi-daemon: r
                        udp6       0      0 :::53                   :::*                                999        21807      724/pihole-FTL
                        udp6       0      0 :::5353                 :::*                                108        17449      402/avahi-daemon: r
                        udp6       0      0 :::52557                :::*                                108        17451      402/avahi-daemon: r
                        2023-09-29 20:45:44.387  - warn: host.iobroker Do not restart adapter system.adapter.roborock.0 because restart loop detected
                        2023-09-29 20:46:00.229  - error: node-red.0 (6192) 29 Sep 20:46:00 - [error] [modbus-getter:n37000-37123] Error: Modbus exception 6: Slave device busy (retry request again later)
                            at /opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-modbus/modbus/maps/core/core/modbus-client-core.js:79:156
                            at processTicksAndRejections (node:internal/process/task_queues:95:5)
                        2023-09-29 20:46:00.249  - error: node-red.0 (6192) 29 Sep 20:46:00 - [error] [modbus-getter:n37000-37123] Error: Modbus exception 6: Slave device busy (retry request again later)
                        2023-09-29 20:48:08.985  - error: node-red.0 (6192) 29 Sep 20:48:08 - [error] [modbus-getter:n37000-37123] Error: Timed out
                        2023-09-29 20:48:09.020  - error: node-red.0 (6192) 29 Sep 20:48:09 - [error] [modbus-getter:n37000-37123] Error: Modbus exception 6: Slave device busy (retry request again later)
                        2023-09-29 20:50:45.740  - info: javascript.0 (6113) script.js.common.Weather: Material Design Widgets: Wetter Skript triggered by 'linkeddevices.0.Sensor.Wetter.temperature'
                        2023-09-29 20:55:00.944  - info: sql.0 (6216) Do not store value "NULL" for hm-rpc.0.LTK0086602.4.VALVE_STATE because no number
                        2023-09-29 20:56:42.693  - error: node-red.0 (6192) 29 Sep 20:56:42 - [error] [modbus-getter:n37000-37123] Error: Timed out
                        2023-09-29 20:56:42.720  - error: node-red.0 (6192) 29 Sep 20:56:42 - [error] [modbus-getter:n37000-37123] Error: Modbus exception 6: Slave device busy (retry request again later)
                        Danke fürs ansehen.
                        • Michael Sauer
                          Michael Sauer @ticaki last edited by
                          @ticaki Ist jetzt aktiviert.
                          • Glasfaser
                            Bullseye ist aktuell
                            free 111M
                            Dein Speicher geht aus ...
                            Redis OK , dann läuft aber
                            redis-server 12
                            Beta Tester ... OK ... aber nicht Aktuell ... up to Date!!!
                            Dann
                            • Michael Sauer
                              @glasfaser Was möchtest du mir damit sagen?
                              Glasfaser S 2 Replies Last reply Reply Quote 0
                              • Glasfaser
                                @michael-sauer
                                Ziemlich ausgelastet dein Raspberry und auch nicht ioBroker als "Beta Tester" gepflegt !
                                Ich würde auf jeden Fall mal PiHole prüfen , denn ich habe oben geschrieben :
                                Keine Verbindung !?
                                  @michael-sauer ich bleibe dabei. Stelle die Maperstellung ab, dann sollte er laufen.
                                    ticaki Developer last edited by ticaki
                                    Der hängt in der Fehlerbehandlung(Map) beim Aufruf von Sentry. Das abschalten der Maperzeugung, so das diese Fehlerbehandlung nicht mehr aufgerufen wird, ist sicher ein Weg. @copystring
                                    Hab nur den Sauger aber nicht den Adapter im Einsatz, sollte wohl ein github issue aufgemacht werden.
                                    https://github.com/copystring/ioBroker.roborock
                                    Michael Sauer A 2 Replies Last reply Reply Quote 0
                                    • copystring
                                      copystring @Michael Sauer last edited by
                                      @michael-sauer Die Kartenerstellung kann auf einem RPi nicht funktionieren. Da gibt es ein Problem mit der Canvas-Bibliothek.
                                      https://github.com/copystring/ioBroker.roborock#map-creation-does-not-work-on-raspberry-pi
                                      • Michael Sauer
                                        @ticaki sagte in Roborock - Adapter stürzt ständig ab:
                                        Das war die Lösung. Danke.
                                          Almeda @ticaki last edited by
                                          @ticaki said in Roborock - Adapter stürzt ständig ab:
                                          ich möchte mich an dieses Thema kurz mit anhängen. Nutze den Roborock Adapter seit ca. 4 Wochen und habe seit Anbeginn, trotz ausgeschalteter Map Erstellung, das Problem, dass der Adapter laut dem Host ständig abstürzt und er ihn daher regelhaft nach 1-2 Tagen aus dem Rennen nimmt und den Neustart verhindert.
                                          Tatsächlich hat die Einrichtung nach der Installation problemlos geklappt und auch die Anbindung an Node-Red zum Ausspielen der Stati über Telegramm hat sofort funktioniert.
                                          Eine De- und Neuinstallation des Apdaters hat nichts gebracht. Ich habe dann auf das aktuelle Update gewartet, weil ich es für ein vllt. bekanntes Problem hielt. Das Update von vor einigen Tagen hat jedoch keine Besserung gebracht.
                                          IoB läuft auf einem Synology 918+ mit ausreichend RAM. Kein anderer Adapter macht Probleme.
                                          Kann einer weiterhelfen?
                                          Vielen Dank
                                          Almeda
                                          Thomas Braun haselchen 2 Replies Last reply Reply Quote 0
                                            Thomas Braun Most Active @Almeda last edited by
                                            @almeda sagte in Roborock - Adapter stürzt ständig ab:
                                            Ohne Log? Schwierig.
                                            30
                                            1588
