    4. Javascript/Yahka Fehler beim installieren
    • N
      noxx last edited by Jey Cee
      moin
      musste javascript deinstallieren, lief nicht mehr richtig.
      nun kann ich es nicht wieder neu installieren, bekomme
      einen Fehler
      Über GUI:
      $ ./iobroker add yahka
      npm install iobroker.yahka --production --prefix "/opt/iobroker" (System call)
      In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
       #include <dns_sd.h>
      compilation terminated.
      make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
      gyp
      ERR!
       build error
      gyp
       ERR!
       stack Error: `make` failed with exit code: 2gyp
       ERR! stack
           at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)gyp
       ERR!
       stack     at emitTwo (events.js:87:13)
      gyp ERR! stack     at ChildProcess.emit (events.js:172:7)
      gyp
      ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:211:12)gyp ERR! System Linux 4.9.35-v7+
      gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs/node_modules/mdns
      gyp ERR! node -v v4.6.2gyp ERR! node-gyp -v
       v3.4.0gyp ERR! not ok
      npm
       ERR! Linux 4.9.35-v7+
      npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.yahka" "--production" "--prefix" "/opt/iobroker"
      npm ERR! node v4.6.2npm ERR! npm  v2.15.11
      npm ERR! code ELIFECYCLE
       npm ERR! mdns@2.3.3 install: `node-gyp rebuild`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR!
       Failed at the mdns@2.3.3 install script 'node-gyp rebuild'.npm ERR! This is most likely a problem with the mdns package,
      npm ERR! not with npm itself.
      npm ERR! Tell the author that this fails on your system:
      npm ERR!     node-gyp rebuild
      npm ERR! You can get information on how to open an issue for this project with:
      npm ERR!     npm bugs mdnsnpm ERR! Or if that isn't available, you can get their info via:
      npm ERR!
      npm ERR!
      npm owner ls mdnsnpm ERR! There is likely additional logging output above.
      npm ERR! Please include the following file with any support request:npm ERR!
           /npm-debug.log
      host.raspberrypi install adapter yahka
       #include <dns_sd.h>
      gyp
      ERR! build error
      gyp
       ERR!
       stack
      ERR! stack
      gyp
       ERR! stack     at emitTwo (events.js:87:13)gyp ERR! stack     at ChildProcess.emit (events.js:172:7)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:211:12)
      gyp ERR! System Linux 4.9.35-v7+gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! node-gyp -v v3.4.0
      gyp ERR!
       not ok
      npm
      npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.yahka" "--production" "--prefix" "/opt/iobroker"npm ERR!
      npm
       ERR! mdns@2.3.3 install: `node-gyp rebuild`npm ERR! Exit status 1
      npm
       ERR! npm ERR! Failed at the mdns@2.3.3 install script 'node-gyp rebuild'.
      npm ERR!     node-gyp rebuildnpm ERR! You can get information on how to open an issue for this project with:
      npm
      ERR! Or if that isn't available, you can get their info via:npm ERR!
      npm ERR!     npm owner ls mdns
           /npm-debug.log
       #include <dns_sd.h>
      gyp
      ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
      gyp ERR! stack     at emitTwo (events.js:87:13)gyp
       ERR! stack     at ChildProcess.emit (events.js:172:7)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:211:12)
      gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs/node_modules/mdns
      gyp
      ERR!
      node -v v4.6.2gyp ERR! node-gyp -v v3.4.0
      gyp ERR! not ok
      npm
      npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.yahka" "--production" "--prefix" "/opt/iobroker"npm ERR! node v4.6.2
      npm ERR! npm ERR! Failed at the mdns@2.3.3 install script 'node-gyp rebuild'.
      npm ERR!
           /npm-debug.log
      ERROR: host.raspberrypi Cannot install yahka
      ERROR: process exited with code 13</dns_sd.h></dns_sd.h></dns_sd.h>
      über Konsole:
      pi@raspberrypi:/opt/iobroker $ sudo npm install iobroker.yahka --production     -
      > curve25519-n2@1.1.3 install /opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs/node_modules/curve25519-n2
      > node-gyp rebuild
      gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/4.6.2"
      gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs/node_modules/curve25519-n2/.node-gyp"
      make: Entering directory '/opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs/node_modules/curve25519-n2/build'
        CXX(target) Release/obj.target/curve/node_curve.o
        SOLINK_MODULE(target) Release/obj.target/curve.node
        COPY Release/curve.node
      make: Leaving directory '/opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs/node_modules/curve25519-n2/build'
      > ed25519@0.0.4 install /opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs/node_modules/ed25519
      > node-gyp rebuild
      gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs/node_modules/ed25519/.node-gyp"
      make: Entering directory '/opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs/node_modules/ed25519/build'
        CC(target) Release/obj.target/ed25519/src/ed25519/keypair.o
        CC(target) Release/obj.target/ed25519/src/ed25519/sign.o
        CC(target) Release/obj.target/ed25519/src/ed25519/open.o
        CC(target) Release/obj.target/ed25519/src/ed25519/crypto_verify_32.o
        CC(target) Release/obj.target/ed25519/src/ed25519/ge_double_scalarmult.o
        CC(target) Release/obj.target/ed25519/src/ed25519/ge_frombytes.o
        CC(target) Release/obj.target/ed25519/src/ed25519/ge_scalarmult_base.o
        CC(target) Release/obj.target/ed25519/src/ed25519/ge_precomp_0.o
        CC(target) Release/obj.target/ed25519/src/ed25519/ge_p2_0.o
        CC(target) Release/obj.target/ed25519/src/ed25519/ge_p2_dbl.o
        CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_0.o
        CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_dbl.o
        CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_to_p2.o
        CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_to_cached.o
        CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_tobytes.o
        CC(target) Release/obj.target/ed25519/src/ed25519/ge_madd.o
        CC(target) Release/obj.target/ed25519/src/ed25519/ge_add.o
        CC(target) Release/obj.target/ed25519/src/ed25519/ge_msub.o
        CC(target) Release/obj.target/ed25519/src/ed25519/ge_sub.o
        CC(target) Release/obj.target/ed25519/src/ed25519/ge_p1p1_to_p3.o
        CC(target) Release/obj.target/ed25519/src/ed25519/ge_p1p1_to_p2.o
        CC(target) Release/obj.target/ed25519/src/ed25519/ge_tobytes.o
        CC(target) Release/obj.target/ed25519/src/ed25519/fe_0.o
        CC(target) Release/obj.target/ed25519/src/ed25519/fe_1.o
        CC(target) Release/obj.target/ed25519/src/ed25519/fe_cmov.o
        CC(target) Release/obj.target/ed25519/src/ed25519/fe_copy.o
        CC(target) Release/obj.target/ed25519/src/ed25519/fe_neg.o
        CC(target) Release/obj.target/ed25519/src/ed25519/fe_add.o
        CC(target) Release/obj.target/ed25519/src/ed25519/fe_sub.o
        CC(target) Release/obj.target/ed25519/src/ed25519/fe_mul.o
        CC(target) Release/obj.target/ed25519/src/ed25519/fe_sq.o
        CC(target) Release/obj.target/ed25519/src/ed25519/fe_sq2.o
        CC(target) Release/obj.target/ed25519/src/ed25519/fe_invert.o
        CC(target) Release/obj.target/ed25519/src/ed25519/fe_tobytes.o
        CC(target) Release/obj.target/ed25519/src/ed25519/fe_isnegative.o
        CC(target) Release/obj.target/ed25519/src/ed25519/fe_isnonzero.o
        CC(target) Release/obj.target/ed25519/src/ed25519/fe_frombytes.o
        CC(target) Release/obj.target/ed25519/src/ed25519/fe_pow22523.o
        CC(target) Release/obj.target/ed25519/src/ed25519/sc_reduce.o
        CC(target) Release/obj.target/ed25519/src/ed25519/sc_muladd.o
        CXX(target) Release/obj.target/ed25519/src/ed25519.o
        SOLINK_MODULE(target) Release/obj.target/ed25519.node
        COPY Release/ed25519.node
      make: Leaving directory '/opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs/node_modules/ed25519/build'
      > mdns@2.3.3 install /opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs/node_modules/mdns
      > node-gyp rebuild
      gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs/node_modules/mdns/.node-gyp"
      make: Entering directory '/opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs/node_modules/mdns/build'
        CXX(target) Release/obj.target/dns_sd_bindings/src/dns_sd.o
       #include <dns_sd.h>^
      dns_sd_bindings.target.mk:151: recipe for target 'Release/obj.target/dns_sd_bindings/src/dns_sd.o' failed
      make: Leaving directory '/opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs/node_modules/mdns/build'
      gyp ERR! build error
      gyp ERR! not ok
      npm ERR! Linux 4.9.35-v7+
      npm ERR!
      npm ERR!
      npm ERR!     /opt/iobroker/npm-debug.log
      pi@raspberrypi:/opt/iobroker $</dns_sd.h>
      • apollon77
        apollon77 last edited by
        Du willst aber hier jahka neu installieren und nicht JavaScript?! Schau mal auf die github Seite von yahka und schau das alle Abhängigkeiten (apt-get …) installiert sind. Dann neu versuchen.
        javascript yahka
