    4. update auf node.js 18.XX
    • Kusselin
      Kusselin last edited by Kusselin
      Hallo Zusammen, wollte von 16.xx auf 18.xx wieder updaten....leider klappt das nicht....
      gebe an der Kommandoline das hier ein wie immer nur auf 18.x geändert
      curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash -
      dann warte ich 60 sek.
      dann das:
      TO AVOID THIS WAIT MIGRATE THE SCRIPT
      Continuing in 60 seconds (press Ctrl-C to abort) ...
      ## Installing the NodeSource Node.js 18.x repo...
      ## Populating apt-get cache...
      + apt-get update
      OK:1 https://dl.yarnpkg.com/debian stable InRelease
      OK:2 https://deb.nodesource.com/node_18.x bionic InRelease
      OK:3 http://archive.ubuntu.com/ubuntu bionic InRelease
      OK:4 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
      OK:5 http://archive.ubuntu.com/ubuntu bionic-security InRelease
      ## Confirming "bionic" is supported...
      + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_18.x/dists/bionic/Release'
      ## Adding the NodeSource signing key to your keyring...
      + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
      ## Creating apt sources list file for the NodeSource Node.js 18.x repo...
      + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x bionic main' > /etc/apt/sources.list.d/nodesource.list
      + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x bionic main' >> /etc/apt/sources.list.d/nodesource.list
      ## Running `apt-get update` for you...
      + apt-get update
      OK:1 https://deb.nodesource.com/node_18.x bionic InRelease
      OK:2 https://dl.yarnpkg.com/debian stable InRelease
      ## Run `sudo apt-get install -y nodejs` to install Node.js 18.x and npm
      ## You may also need development tools to build native addons:
           sudo apt-get install gcc g++ make
      ## To install the Yarn package manager, run:
           curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
           echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
           sudo apt-get update && sudo apt-get install yarn
      dann sudo apt install -y nodejs eingegeben.... dann das hier:
      Abhängigkeitsbaum wird aufgebaut.
      Statusinformationen werden eingelesen.... Fertig
      Einige Pakete konnten nicht installiert werden. Das kann bedeuten, dass
      Sie eine unmögliche Situation angefordert haben oder, wenn Sie die
      Unstable-Distribution verwenden, dass einige erforderliche Pakete noch
      nicht erstellt wurden oder Incoming noch nicht verlassen haben.
      Die folgenden Informationen helfen Ihnen vielleicht, die Situation zu lösen:
      Die folgenden Pakete haben unerfüllte Abhängigkeiten:
       nodejs : Hängt ab von: libc6 (>= 2.28) aber 2.27-3ubuntu1.6 soll installiert werden
      E: Probleme können nicht korrigiert werden, Sie haben zurückgehaltene defekte Pakete.
      Könnt Ihr mir bitte mitteilen was ich hier noch installieren muss und in welcher Reihenfolge.
      Vielen herzlichen Dank.
      Thomas Braun W 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Kusselin last edited by Thomas Braun
        @kusselin
        Schau in meine Signatur, da gibt's ein Skript dafür.
        Und dein 5 Jahre altes Ubuntu ist tot. Da wird kein aktuelles nodejs drauf laufen. Aktualisieren.
        Kusselin 1 Reply Last reply Reply Quote 0
        • Kusselin
          Kusselin @Thomas Braun last edited by
          @thomas-braun o.k. danke Dir für die Info...das ist der fixer O.K.
          Nächste Frage wäre wie ich das bestehende Linux system auf ein aktuelles Update...da ich kein LinuxUser bin sag ichs ehrlich weiss ich es nicht..
          gibt es da ein HowtoDo?
          Danek und Gruss
            @kusselin sagte in update auf node.js 18.XX:
            Für Ubuntu gibt es ein hauseigenes Updateskript, wenn ich mich Recht entsinne. Musste Mal nach suchen.
            • Kusselin
              Kusselin @Thomas Braun last edited by Kusselin
              habe das hier gefunden....geht das mit dem /etc/apt/sources.list
              https://www.tuxedocomputers.com/de/Infos/Hilfe-Support/Anleitungen/Ubuntu-Upgrade-von-18-04-auf-20-04.tuxedo
              schau das steht bei mir in der SourceList drin:
              deb http://archive.ubuntu.com/ubuntu bionic main restricted universe multiverse
              deb http://archive.ubuntu.com/ubuntu bionic-updates main restricted universe multiverse
              deb http://archive.ubuntu.com/ubuntu bionic-security main restricted universe multiverse
                @kusselin
                Das wirst du herausfinden müssen.
                • Kusselin
                  @thomas-braun kannst du mir bitte mitteilen was ich da ändern muss..ich gehe davon aus das ich das bionic ändern muss aber in was...?
                  Kannst du mir den Code bitte mitteilen...
                    @kusselin
                    Das steht doch in der Anleitung drin?
                    • Kusselin
                      @thomas-braun o.k. sorry ...habdie source.list ..mit Befehl
                      sudo sed -i 's/bionic/focal/g' /etc/apt/sources.list
                      ändern können dann das ausgeführt:
                      sudo apt update && sudo apt -y dist-upgrade
                      bekomme aber immer noch einen Fehler nachdem ich
                      eingegeben habe..
                      Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                        gyp libc-ares2 libhttp-parser2.7.1 libjs-async libjs-inherits
                        libjs-node-uuid libjs-underscore libssl1.0-dev libuv1-dev node-abbrev
                        node-ansi node-ansi-color-table node-archy node-async node-balanced-match
                        node-block-stream node-brace-expansion node-builtin-modules
                        node-combined-stream node-concat-map node-cookie-jar node-delayed-stream
                        node-forever-agent node-form-data node-fs.realpath node-fstream
                        node-fstream-ignore node-github-url-from-git node-glob node-graceful-fs
                        node-gyp node-hosted-git-info node-inflight node-inherits node-ini
                        node-is-builtin-module node-isexe node-json-stringify-safe node-lockfile
                        node-lru-cache node-mime node-minimatch node-mkdirp node-mute-stream
                        node-node-uuid node-nopt node-normalize-package-data node-npmlog node-once
                        node-osenv node-path-is-absolute node-pseudomap node-qs node-read
                        node-read-package-json node-request node-retry node-rimraf node-semver
                        node-sha node-slide node-spdx-correct node-spdx-expression-parse
                        node-spdx-license-ids node-tar node-tunnel-agent node-underscore
                        node-validate-npm-package-license node-which node-wrappy node-yallist
                        python-chardet python-cliapp python-markdown python-pkg-resources
                        python-pygments python-ttystatus python-yaml
                      Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                      Die folgenden zusätzlichen Pakete werden installiert:
                        gcc-10-base libc-bin libc-dev-bin libc6 libc6-dev libcrypt-dev libcrypt1
                        libgcc-s1 libidn2-0 locales manpages-dev
                      Vorgeschlagene Pakete:
                        glibc-doc
                      Die folgenden NEUEN Pakete werden installiert:
                        gcc-10-base libcrypt-dev libcrypt1 libgcc-s1
                      Die folgenden Pakete werden aktualisiert (Upgrade):
                        libc-bin libc-dev-bin libc6 libc6-dev libidn2-0 locales manpages-dev nodejs
                      8 aktualisiert, 4 neu installiert, 0 zu entfernen und 581 nicht aktualisiert.
                      Es müssen noch 28,7 MB von 41,1 MB an Archiven heruntergeladen werden.
                      Nach dieser Operation werden 64,8 MB Plattenplatz zusätzlich benutzt.
                      Fehl:1 https://deb.nodesource.com/node_18.x bionic/main amd64 nodejs amd64 18.16.0-deb-1nodesource1
                        404  Not Found [IP: 104.22.5.26 443]
                      E: Fehlschlag beim Holen von https://deb.nodesource.com/node_18.x/pool/main/n/nodejs/nodejs_18.16.0-deb-1nodesource1_amd64.deb 404  Not Found [IP: 104.22.5.26 443]
                      E: Einige Archive konnten nicht heruntergeladen werden; vielleicht »apt-get update« ausführen oder mit »--fix-missing« probieren?
                        Wildbill @Kusselin last edited by
                        @kusselin Ubuntu macht doch automatisch Upgrades auf die nächste Version mittels
                        sudo do-release-upgrade
                        Gruss, Jürgen
                        • Kusselin
                          Kusselin @Wildbill last edited by
                          @wildbill sorry habe zwar schon eine weile iobroker aber ich bin da trotzdem nicht so im Geschäft wie ihr..bitte habt verständnis......
                            @kusselin
                            Lösch die nodesource.list komplett und leg die nach dem Doppelsprung über Ubuntu 20.04 auf 22.04 dann frisch an. Deine jetzige Version der Datei ist eh noch im alten Format und müsste angepasst werden.
                              @kusselin
                              ändern können
                              Und warum machste es nicht nach der einfachen Anleitung und nimmst den Weg für erfahrene User?
                              • Kusselin
                                @thomas-braun sagte in update auf node.js 18.XX:
                                @kusselin
                                wie mach ich das?
                                • Kusselin
                                  @kusselin
                                  ändern können
                                  ?? sorry verstehe nur bahnhof
                                    @kusselin
                                    sudo rm /etc/apt/sources.list.d/node*
                                    • Kusselin
                                      @kusselin
                                      das steht jetzt aktuell in dieser nodeliste drin
                                      ..und wenn ich die gelöscht habe...was muss ich da dann eintragen...umd das ich dann mit dem Befehlen
                                      die aktuelle Node.js version bekomme?
                                        @kusselin
                                        Aus deiner Anleitung:
                                        Der Ubuntu-Weg
                                        Ubuntu hat seine eigene automatische Art des Upgrades zwischen den Versionen entwickelt. So können Sie alles vorbereiten und dann vom Rechner weggehen. Den Rest erledigt Ubuntu.
                                        Mach das doch danach. Da steht auch drin, das Herumgeschreibe in den .list-Files nur für erfahrenere User empfohlen wird...
                                          @kusselin
                                          Lass die Finger von nodejs, solange da nicht Ubuntu 22.04 LTS drauf ist. Das schnallst du erst danach dann drauf..
                                          Ich würde das sogar temporär komplett rauswerfen.
                                          sudo apt remove nodejs
                                          Das verhindert, dass du dir die dfsg-Versiin von nodejs einhandelst.
                                          • Kusselin
                                            @kusselin
                                            Der Ubuntu-Weg
                                            bin das jetzt durchgegangen..
                                             iobroker stop
                                            root@iobroker-live:~# sudo apt install update-manager-core
                                            update-manager-core ist schon die neueste Version (1:20.04.10.11).
                                              gyp libc-ares2 libcups2 libhttp-parser2.7.1 libjansson4 libjs-async
                                              libjs-inherits libjs-node-uuid libjs-underscore libldb1 libssl1.0-dev
                                              libtdb1 libtevent0 libuv1-dev node-abbrev node-ansi node-ansi-color-table
                                              node-archy node-async node-balanced-match node-block-stream
                                              node-brace-expansion node-builtin-modules node-combined-stream
                                              node-concat-map node-cookie-jar node-delayed-stream node-forever-agent
                                              node-form-data node-fs.realpath node-fstream node-fstream-ignore
                                              node-github-url-from-git node-glob node-graceful-fs node-gyp
                                              python-chardet python-cliapp python-crypto python-ldb python-markdown
                                              python-pkg-resources python-pygments python-samba python-talloc python-tdb
                                              python-ttystatus python-yaml samba-common samba-common-bin samba-libs
                                            0 aktualisiert, 0 neu installiert, 0 zu entfernen und 255 nicht aktualisiert.
                                            root@iobroker-live:~# sudo apt autoremove
                                            Die folgenden Pakete werden ENTFERNT:
                                            0 aktualisiert, 0 neu installiert, 91 zu entfernen und 229 nicht aktualisiert.
                                            Nach dieser Operation werden 59,9 MB Plattenplatz freigegeben.
                                            Möchten Sie fortfahren? [J/n] J
                                            (Lese Datenbank ... 37958 Dateien und Verzeichnisse sind derzeit installiert.)
                                            Entfernen von node-gyp (3.6.2-1ubuntu1) ...
                                            Entfernen von gyp (0.1+20150913git1f374df9-1ubuntu1) ...
                                            Entfernen von libc-ares2:amd64 (1.15.0-1ubuntu0.4) ...
                                            Entfernen von samba-common-bin (2:4.7.6+dfsg~ubuntu-0ubuntu2.29) ...
                                            Entfernen von python-samba (2:4.7.6+dfsg~ubuntu-0ubuntu2.29) ...
                                            Entfernen von samba-libs:amd64 (2:4.7.6+dfsg~ubuntu-0ubuntu2.29) ...
                                            Entfernen von libcups2:amd64 (2.2.7-1ubuntu2.10) ...
                                            Entfernen von libhttp-parser2.7.1:amd64 (2.7.1-2ubuntu0.1) ...
                                            Entfernen von libjansson4:amd64 (2.12-1build1) ...
                                            Entfernen von node-request (2.26.1-1) ...
                                            Entfernen von node-form-data (0.1.0-1) ...
                                            Entfernen von node-async (0.8.0-3) ...
                                            Entfernen von libjs-async (0.8.0-3) ...
                                            Entfernen von node-tar (2.2.1-1) ...
                                            Entfernen von node-read-package-json (1.2.4-1) ...
                                            Entfernen von node-node-uuid (1.4.7-5) ...
                                            Entfernen von libjs-node-uuid (1.4.7-5) ...
                                            Entfernen von node-underscore (1.9.1~dfsg-1ubuntu0.20.04.1) ...
                                            Entfernen von libjs-underscore (1.9.1~dfsg-1ubuntu0.20.04.1) ...
                                            Entfernen von python-ldb:amd64 (2:1.2.3-1ubuntu0.2) ...
                                            Entfernen von libldb1:amd64 (2:1.2.3-1ubuntu0.2) ...
                                            Entfernen von libssl1.0-dev:amd64 (1.0.2n-1ubuntu5.13) ...
                                            Entfernen von python-tdb (1.3.15-2) ...
                                            Entfernen von libtdb1:amd64 (1.3.15-2) ...
                                            Entfernen von libtevent0:amd64 (0.9.34-1) ...
                                            Entfernen von libuv1-dev:amd64 (1.34.2-1ubuntu1.3) ...
                                            Entfernen von node-nopt (3.0.6-4) ...
                                            Entfernen von node-abbrev (1.1.1-2) ...
                                            Entfernen von node-ansi-color-table (1.0.0-1) ...
                                            Entfernen von node-npmlog (0.0.4-1) ...
                                            Entfernen von node-ansi (0.3.1-1) ...
                                            Entfernen von node-archy (1.0.0-3) ...
                                            Entfernen von node-fstream-ignore (0.0.6-2) ...
                                            Entfernen von node-block-stream (0.0.9-1ubuntu1) ...
                                            Entfernen von node-normalize-package-data (2.3.5-2) ...
                                            Entfernen von node-is-builtin-module (2.0.0-1) ...
                                            Entfernen von node-builtin-modules (3.1.0-1) ...
                                            Entfernen von node-combined-stream (1.0.8-1) ...
                                            Entfernen von node-cookie-jar (0.3.1-1) ...
                                            Entfernen von node-delayed-stream (1.0.0-4) ...
                                            Entfernen von node-forever-agent (0.6.1-2) ...
                                            Entfernen von node-fstream (1.0.12-2) ...
                                            Entfernen von node-github-url-from-git (1.5.0-1) ...
                                            Entfernen von node-sha (3.0.0-1) ...
                                            Entfernen von node-graceful-fs (4.2.3-2) ...
                                            Entfernen von node-hosted-git-info (2.8.5-1) ...
                                            Entfernen von node-ini (1.3.5-1) ...
                                            Entfernen von node-which (2.0.2-1) ...
                                            Entfernen von node-isexe (2.0.0-4) ...
                                            Entfernen von node-json-stringify-safe (5.0.1+repack-2) ...
                                            Entfernen von node-lockfile (0.4.1-1) ...
                                            Entfernen von node-lru-cache (5.1.1-5) ...
                                            Entfernen von node-mime (2.4.4+dfsg-1) ...
                                            Entfernen von node-mkdirp (0.5.1-2) ...
                                            Entfernen von node-read (1.0.7-2) ...
                                            Entfernen von node-mute-stream (0.0.8-2) ...
                                            Entfernen von node-osenv (0.1.5-1) ...
                                            Entfernen von node-pseudomap (1.0.2-1) ...
                                            Entfernen von node-qs (6.9.1+ds-1) ...
                                            Entfernen von node-retry (0.12.0-1) ...
                                            Entfernen von node-rimraf (2.6.3-1) ...
                                            Entfernen von node-semver (5.4.1-1) ...
                                            Entfernen von node-slide (1.1.6-2) ...
                                            Entfernen von node-validate-npm-package-license (3.0.4-1) ...
                                            Entfernen von node-spdx-correct (1.0.2-1) ...
                                            Entfernen von node-spdx-expression-parse (1.0.4-1) ...
                                            Entfernen von node-spdx-license-ids (3.0.5-1) ...
                                            Entfernen von node-tunnel-agent (0.3.1-1) ...
                                            Entfernen von node-yallist (4.0.0-1) ...
                                            Entfernen von python-chardet (3.0.4-1) ...
                                            Entfernen von python-cliapp (1.20170827-1) ...
                                            Entfernen von python-crypto (2.6.1-8ubuntu2) ...
                                            Entfernen von python-markdown (2.6.9-1) ...
                                            Entfernen von python-pkg-resources (39.0.1-2ubuntu0.1) ...
                                            Entfernen von python-pygments (2.2.0+dfsg-1ubuntu0.2) ...
                                            Entfernen von python-talloc (2.1.10-2ubuntu1) ...
                                            Entfernen von python-ttystatus (0.38-1) ...
                                            Entfernen von python-yaml (3.12-1build2) ...
                                            Entfernen von samba-common (2:4.7.6+dfsg~ubuntu-0ubuntu2.29) ...
                                            Entfernen von node-glob (7.1.6-1) ...
                                            Entfernen von node-inherits (2.0.4-1) ...
                                            Entfernen von libjs-inherits (2.0.4-1) ...
                                            Entfernen von node-minimatch (3.0.4-4ubuntu0.1) ...
                                            Entfernen von node-brace-expansion (1.1.11-1) ...
                                            Entfernen von node-balanced-match (1.0.0-1) ...
                                            Entfernen von node-concat-map (0.0.1-2) ...
                                            Entfernen von node-fs.realpath (1.0.0-1) ...
                                            Entfernen von node-inflight (1.0.6-1) ...
                                            Entfernen von node-once (1.4.0-3) ...
                                            Entfernen von node-path-is-absolute (2.0.0-1) ...
                                            Entfernen von node-wrappy (1.0.2-1) ...
                                            Trigger für man-db (2.8.3-2ubuntu0.1) werden verarbeitet ...
                                            Trigger für libc-bin (2.27-3ubuntu1.6) werden verarbeitet ...
                                            root@iobroker-live:~# sudo do-release-upgrade
                                            Checking for a new Ubuntu release
                                            Please install all available updates for your release before upgrading.
                                            root@iobroker-live:~# sudo do-release-upgrade -d
                                            There is no development version of an LTS available.
                                            To upgrade to the latest non-LTS development release
                                            set Prompt=normal in /etc/update-manager/release-upgrades.
                                            und jetzt....?
                                            7498
