    4. Oilfox adapter aktualisiert nicht mehr *HILFE*
      driftkingisback last edited by driftkingisback
      Hallo, was mache ich falsch das dieser Adapter nicht mehr aktausliert.
      Diese Meldung bekomme ich:
      host.buanet-iobroker1
      2023-10-06 10:40:04.045	warn	instance system.adapter.oilfox.0 already running with pid 8264
      2023-10-06 10:30:04.056	warn	instance system.adapter.oilfox.0 already running with pid 8264
      2023-10-06 10:20:04.045	warn	instance system.adapter.oilfox.0 already running with pid 8264
      2023-10-06 10:10:04.041	warn	instance system.adapter.oilfox.0 already running with pid 8264
      2023-10-06 10:00:04.062	warn	instance system.adapter.oilfox.0 already running with pid 8264
      2023-10-06 09:50:04.041	warn	instance system.adapter.oilfox.0 already running with pid 8264
      2023-10-06 09:40:04.043	warn	instance system.adapter.oilfox.0 already running with pid 8264
      2023-10-06 09:30:04.064	warn	instance system.adapter.oilfox.0 already running with pid 8264
      2023-10-06 09:20:04.041	warn	instance system.adapter.oilfox.0 already running with pid 8264
      2023-10-06 09:10:04.042	warn	instance system.adapter.oilfox.0 already running with pid 8264
      2023-10-06 09:00:04.059	warn	instance system.adapter.oilfox.0 already running with pid 8264
      2023-10-06 08:50:04.041	warn	instance system.adapter.oilfox.0 already running with pid 8264
      2023-10-06 08:40:04.044	warn	instance system.adapter.oilfox.0 already running with pid 8264
      2023-10-06 08:30:04.056	warn	instance system.adapter.oilfox.0 already running with pid 8264
      Das ist mein Stand:
      Plattform: docker
      Betriebssystem: linux
      Architektur: x64
      CPUs: 4
      Geschwindigkeit: 2001 MHz
      Modell: Intel(R) Celeron(R) J4125 CPU @ 2.00GHz
      RAM: 3.6 GB
      System-Betriebszeit: 178 T. 20:56:26
      Node.js: v18.16.1
      time: 1696579879997
      timeOffset: -120
      Adapter-Anzahl: 504
      NPM: 9.5.1
      Datenträgergröße: 7149.5 GB
      Freier Festplattenspeicher: 5366.7 GB
      Betriebszeit: 86 T. 10:37:06
      Aktive Instanzen: 13
      Pfad: /opt/iobroker/
        Thomas Braun Most Active @driftkingisback last edited by
        @driftkingisback
        Starte den Docker mal durch.
          driftkingisback @Thomas Braun last edited by
          @thomas-braun hab ich gemacht als neustart, keine abhilfe...woran kann es noch liegen? Gibt es welche die das gleiche Problem haben?
            @driftkingisback
            iob diag
            in der Langfassung sagt?
              @thomas-braun was genau meinst du?
                @driftkingisback
                Du möchstest bitte
                iob diag
                in dein bevorzugtes Terminal hacken und die dann ausgespuckte Langfassung der Diagnose hier bekannt machen.
                • mcm1957
                  mcm1957 @Thomas Braun last edited by
                  Dies ist ein Problem des Adapters:
                  https://github.com/iobroker-community-adapters/ioBroker.oilfox/issues/122
                  Ich hab zwar schon eine Vermutung wie das passiert ('Exception während der http Kommunication die nicht richtig abgefangen wird') weiß aber leider noch nicht wann ich dazu komme eine Testversion zu machen.
                  Bis dahin bleibt nix anderes übrig, als den hängenden Prozess abzuschießen. @thomas-braun kann sicher sagen wie das am sichersten im ioBroker Umfeld geht.
                  DANKE und SORRY
                  P.S: Oilfox ist nicht von mir und ich habe auch kein passended Gerät / keine Testmöglichkeit. SOllte es daher Freiwillige geben, die den Adapter warten können vermittle ich gerne.
                  lxffm created this issue in iobroker-community-adapters/ioBroker.oilfox
                  closed Process occasionally stuck - still occuring #122
                    Thomas Braun Most Active @mcm1957 last edited by Thomas Braun
                    @mcm57 @driftkingisback
                    sudo -u iobroker kill `pgrep oilfox`
                      @thomas-braun also kann ich garnichts machen , dachte der fehler liegt bei mir
                      • mcm1957
                        mcm1957 @driftkingisback last edited by
                        @driftkingisback
                        Kannst bei dir nicht wirklcihw as tun. Außer du hast eine besonders instabile Internetanbindung die das Problem ev. verschärft.
                        Bitte schau aber einmal in dein Log ob da irgendeine (Fehler-)Meldung vom oilfox VOR den already running drinnen steht und gib hier oder noch besser im Issue ein Feedback dazu.
                        Friedhofsblond 1 Reply Last reply Reply Quote 0
                        • Friedhofsblond
                          Friedhofsblond @mcm1957 last edited by
                          @mcm57
                          Moin,
                          ich habe auch irgendein Problem mit dem Oilfox.
                          Der Fox scannt jeden Tag um 11:55 den Tankstand und läd den in die Cloud hoch.
                          Ab 12:00 stehen dann die Werte aktuell in der App zur Ansicht.
                          Habe also die Abfrage auf täglich 12:00 gestellt - was auch getan wird.
                          Aber die Abfrage wird dann trotzdem jede Minute neu gemacht. Das wird wohl in der "Fox-Cloud" als Angriff gewertet und man wird temporär gesperrt.
                          Ich bin letztens schon rausgeflogen und mußte mein Passwort neu setzen und ein paar Stunden warten.
                          So denke ich jedenfalls.
                          Der Abfrageprozess wird nicht gestoppt.
                          Was kann man tun?
                          • mcm1957
                            mcm1957 @Friedhofsblond last edited by
                            @friedhofsblond
                            Bitte zeig mal, welche Config du eingestellt hast (auf Uhr in den Instanzen stellen):
                            Bzw die Zeitplungsansicht:
                            -> Bleistift
                            Beispiel ist von anderem Adapter - aber bei Oilfox sollte es prinzipiell genauso aussehen,
                            • Friedhofsblond
                              Friedhofsblond @mcm1957 last edited by Friedhofsblond
                              @mcm57
                              so habe ich es:
                              Abfrage ist 12:00 gestartet und hab ich nach 5min manuell gestoppt.
                              2023-10-08 12:00:00.086 - info: host.ioserver instance system.adapter.oilfox.0 started with pid 1735
                              2023-10-08 12:00:01.272 - info: oilfox.0 (1735) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.oilfox, node: v18.17.1, js-controller: 5.0.12
                              2023-10-08 12:00:26.977 - info: oilfox.0 (1735) Terminated (NO_ERROR): Without reason
                              2023-10-08 12:00:27.594 - info: host.ioserver instance system.adapter.oilfox.0 terminated with code 0 (NO_ERROR)
                              2023-10-08 12:01:00.054 - info: host.ioserver instance system.adapter.oilfox.0 started with pid 1750
                              2023-10-08 12:01:01.154 - info: oilfox.0 (1750) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.oilfox, node: v18.17.1, js-controller: 5.0.12
                              2023-10-08 12:01:10.868 - info: oilfox.0 (1750) Terminated (NO_ERROR): Without reason
                              2023-10-08 12:01:11.413 - info: host.ioserver instance system.adapter.oilfox.0 terminated with code 0 (NO_ERROR)
                              2023-10-08 12:02:00.052 - info: host.ioserver instance system.adapter.oilfox.0 started with pid 1766
                              2023-10-08 12:02:01.309 - info: oilfox.0 (1766) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.oilfox, node: v18.17.1, js-controller: 5.0.12
                              2023-10-08 12:02:03.933 - info: oilfox.0 (1766) Terminated (NO_ERROR): Without reason
                              2023-10-08 12:02:04.476 - info: host.ioserver instance system.adapter.oilfox.0 terminated with code 0 (NO_ERROR)
                              2023-10-08 12:03:00.061 - info: host.ioserver instance system.adapter.oilfox.0 started with pid 1784
                              2023-10-08 12:03:01.269 - info: oilfox.0 (1784) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.oilfox, node: v18.17.1, js-controller: 5.0.12
                              2023-10-08 12:03:08.493 - info: oilfox.0 (1784) Terminated (NO_ERROR): Without reason
                              2023-10-08 12:03:09.034 - info: host.ioserver instance system.adapter.oilfox.0 terminated with code 0 (NO_ERROR)
                              2023-10-08 12:04:00.056 - info: host.ioserver instance system.adapter.oilfox.0 started with pid 1799
                              2023-10-08 12:04:01.307 - info: oilfox.0 (1799) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.oilfox, node: v18.17.1, js-controller: 5.0.12
                              2023-10-08 12:04:04.091 - info: oilfox.0 (1799) Terminated (NO_ERROR): Without reason
                              2023-10-08 12:04:04.628 - info: host.ioserver instance system.adapter.oilfox.0 terminated with code 0 (NO_ERROR)
                              2023-10-08 12:05:00.057 - info: host.ioserver instance system.adapter.oilfox.0 started with pid 1814
                              2023-10-08 12:05:01.239 - info: oilfox.0 (1814) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.oilfox, node: v18.17.1, js-controller: 5.0.12
                              2023-10-08 12:05:10.269 - info: oilfox.0 (1814) Terminated (NO_ERROR): Without reason
                              2023-10-08 12:05:10.810 - info: host.ioserver instance system.adapter.oilfox.0 terminated with code 0 (NO_ERROR)
                              2023-10-08 12:06:00.053 - info: host.ioserver instance system.adapter.oilfox.0 started with pid 1829
                              2023-10-08 12:06:01.315 - info: oilfox.0 (1829) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.oilfox, node: v18.17.1, js-controller: 5.0.12
                              2023-10-08 12:06:04.837 - info: oilfox.0 (1829) Terminated (NO_ERROR): Without reason
                              2023-10-08 12:06:05.376 - info: host.ioserver instance system.adapter.oilfox.0 terminated with code 0 (NO_ERROR)
                              2023-10-08 12:06:05.407 - info: host.ioserver "system.adapter.oilfox.0" disabled
                              2023-10-08 12:06:05.408 - info: host.ioserver stopInstance system.adapter.oilfox.0 (force=false, process=false)
                              2023-10-08 12:06:05.408 - info: host.ioserver stopInstance canceled schedule system.adapter.oilfox.0
                              2023-10-08 12:18:55.593 - info: admin.0 (1000) <== Disconnect system.user.admin from ::ffff:192.168.115.175 admin
                              2023-10-08 12:18:55.928 - info: opendtu.0 (1111) Connect to OpenDTU over websocket connection.
                              2023-10-08 12:19:20.605 - info: opendtu.0 (1111) Connect to OpenDTU over websocket connection.
                              2023-10-08 12:19:32.395 - info: opendtu.0 (1111) Connect to OpenDTU over websocket connection.
                              2023-10-08 13:18:07.739 - info: admin.0 (1000) ==> Connected system.user.admin from ::ffff:192.168.115.175
                              2023-10-08 13:18:07.798 - info: admin.0 (1000) <== Disconnect system.user.admin from ::ffff:192.168.115.175 admin
                              2023-10-08 13:36:04.183 - info: opendtu.0 (1111) Connect to OpenDTU over websocket connection.
                              2023-10-08 13:36:18.301 - info: opendtu.0 (1111) Connect to OpenDTU over websocket connection.
                              2023-10-08 14:13:31.248 - info: admin.0 (1000) ==> Connected system.user.admin from ::ffff:192.168.115.175
                              2023-10-08 14:14:54.176 - info: admin.0 (1000) <== Disconnect system.user.admin from ::ffff:192.168.115.175 admin
                              2023-10-08 14:58:54.606 - info: admin.0 (1000) ==> Connected system.user.admin from ::ffff:192.168.115.175
                              2023-10-08 14:59:57.295 - info: host.ioserver "system.adapter.oilfox.0" enabled
                              2023-10-08 14:59:57.297 - info: host.ioserver stopInstance system.adapter.oilfox.0 (force=false, process=false)
                              2023-10-08 15:00:00.399 - info: host.ioserver instance scheduled system.adapter.oilfox.0 * 12 * * *
                              • Friedhofsblond
                                Friedhofsblond @Friedhofsblond last edited by
                                @friedhofsblond
                                Ah, hab schon gesehen:
                                ... aber wie stelle ich 12:00 Uhr ein?
                                Da ich den IOBroker 1x in der nacht reboote würde ja auch nicht alle 24H passen ??
                                • mcm1957
                                  @friedhofsblond
                                  0 12 * * * *
                                  Das da könnte dir helfen
                                  https://crontab.guru/
                                  Übrigengds - stell besser '3 12 * * *' (12:03 oder irgendwas zwischen 12:00 und 12:15 ein wenn du damit leben kannst. Wenn zig ioBroker installationen alle pünktlich um 12:00 (wqeil das halt so eine schöne Zahl ist 🙂 die Webseite aufrufen, ist Oilfox ev. "genervt" sprich überlastet.
                                  Das gilt übrigends für ALLE scheduled Adapter mit Cloud Zugriff !
                                  • Friedhofsblond
                                    @mcm57
                                    Ah super, vielen Dank - ja immer dieses Crontabzeugs ..... 😄 👌
                                    So passt es:
                                    Sorry, da ist ein Stern zu Viel - ist doch kein Cognac 🙄 (Klugscheissermodus OFF)
                                    • mcm1957
                                      @friedhofsblond
                                      Sorry - sternchenzählen ist nicht meine Stärke 🙂
                                      Hauptsache der Adapter läuft jetzt wieder.
                                      Das weiter oben gemeldeten Problem des Hängenbleibens ist in Evidenz wobei ich nach wie vor um die Info von Betroffenen bitte ob es VOR dem Hängenbelleiben irgendeien Fehlermeldung / Warning des Oilfuches im Log gegeben hat.
                                        driftkingisback @mcm1957 last edited by
                                        @mcm57 ich habe jetzt ein Update des Oilfox adapter gemacht und die gleiche Uhrzeit wie bei dir eingestellt...läuft der Adapter bei dir jetzt?
                                        Ich muss jetzt erstmal bis morgen um 12.05 warten 🙂
                                        • mcm1957
                                          @driftkingisback
                                          Nehme an die Frage geht an @Friedhofsblond
                                          Ich (mcm1957) habe keine Oilfox Installation. Ich versuche nur den Adapter soweit das ohne HW geht zu fixen bzw. zu releasen 🙂
                                            @mcm57 said in Oilfox adapter aktualisiert nicht mehr *HILFE*:
                                            @driftkingisback
                                            @Friedhofsblond geht bei dir der Adapter?
                                            Friedhofsblond 2 Replies Last reply Reply Quote 0
                                            1678
