    4. Warema WMS Adapter funktioniert nicht mehr
    • N
      neo8006 last edited by
      vielleicht kann mir hier jemand weiter helfen, seit heute ohne mein zutun stellte der Adpater den Betrieb ein uns lässt sich auch nicht mehr in gang bringen.
      hier das Protokoll dazu
      host.DESKTOP-TUF9MM7
      2023-10-07 13:44:55.622 info Restart adapter system.adapter.wmswebcontrol.0 because enabled
      2023-10-07 13:44:55.622 error instance system.adapter.wmswebcontrol.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2023-10-07 13:44:55.622 error Caught by controller[0]: Node.js v20.7.0
      2023-10-07 13:44:55.622 error Caught by controller[0]: }
      2023-10-07 13:44:55.622 error Caught by controller[0]: code: 'ERR_PACKAGE_PATH_NOT_EXPORTED'
      2023-10-07 13:44:55.622 error Caught by controller[0]: at Object.<anonymous> (C:\ioBroker\node_modules\axios-cookiejar-support\lib\index.js:8:40) {
      2023-10-07 13:44:55.622 error Caught by controller[0]: at require (node:internal/modules/helpers:130:18)
      2023-10-07 13:44:55.622 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1115:19)
      2023-10-07 13:44:55.622 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:901:27)
      2023-10-07 13:44:55.622 error Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1034:27)
      2023-10-07 13:44:55.622 error Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:621:31)
      2023-10-07 13:44:55.622 error Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:547:36)
      2023-10-07 13:44:55.622 error Caught by controller[0]: at packageExportsResolve (node:internal/modules/esm/resolve:589:9)
      2023-10-07 13:44:55.622 error Caught by controller[0]: at exportsNotFound (node:internal/modules/esm/resolve:259:10)
      2023-10-07 13:44:55.622 error Caught by controller[0]: at new NodeError (node:internal/errors:405:5)
      2023-10-07 13:44:55.622 error Caught by controller[0]: Error [ERR_PACKAGE_PATH_NOT_EXPORTED]: Package subpath './lib/defaults' is not defined by "exports" in C:\ioBroker\node_modules\axios\package.json
      2023-10-07 13:44:55.621 error Caught by controller[0]: ^
      2023-10-07 13:44:55.621 error Caught by controller[0]: throw e;
      2023-10-07 13:44:55.621 error Caught by controller[0]: node:internal/modules/cjs/loader:553
      Danke im Voraus
        Thomas Braun Most Active @neo8006 last edited by
        @neo8006 sagte in Warema WMS Adapter funktioniert nicht mehr:
        Node.js v20.7.0
        Zu neu, installier die vorgesehene nodejs@18-Version.
        • N
          neo8006 @Thomas Braun last edited by
          Hallo Thomas, danke für die Antwort, hatte ich schon versucht, leider aber das selbe Fehlerbild
          2023-10-07 14:36:33.867 info Restart adapter system.adapter.wmswebcontrol.0 because enabled
          2023-10-07 14:36:33.867 error instance system.adapter.wmswebcontrol.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2023-10-07 14:36:33.867 error Caught by controller[0]: Node.js v18.18.0
          2023-10-07 14:36:33.867 error Caught by controller[0]: }
          2023-10-07 14:36:33.866 error Caught by controller[0]: code: 'ERR_PACKAGE_PATH_NOT_EXPORTED'
          2023-10-07 14:36:33.866 error Caught by controller[0]: at Object.<anonymous> (C:\ioBroker\node_modules\axios-cookiejar-support\lib\index.js:8:40) {
          2023-10-07 14:36:33.866 error Caught by controller[0]: at require (node:internal/modules/cjs/helpers:119:18)
          2023-10-07 14:36:33.866 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
          2023-10-07 14:36:33.866 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
          2023-10-07 14:36:33.866 error Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1063:27)
          2023-10-07 14:36:33.866 error Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:636:31)
          2023-10-07 14:36:33.866 error Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:567:36)
          2023-10-07 14:36:33.866 error Caught by controller[0]: at packageExportsResolve (node:internal/modules/esm/resolve:698:9)
          2023-10-07 14:36:33.866 error Caught by controller[0]: at exportsNotFound (node:internal/modules/esm/resolve:362:10)
          2023-10-07 14:36:33.866 error Caught by controller[0]: at new NodeError (node:internal/errors:405:5)
          2023-10-07 14:36:33.866 error Caught by controller[0]: Error [ERR_PACKAGE_PATH_NOT_EXPORTED]: Package subpath './lib/defaults' is not defined by "exports" in C:\ioBroker\node_modules\axios\package.json
          2023-10-07 14:36:33.866 error Caught by controller[0]: ^
          2023-10-07 14:36:33.866 error Caught by controller[0]: throw e;
          2023-10-07 14:36:33.865 error Caught by controller[0]: node:internal/modules/cjs/loader:573
          2023-10-07 14:36:33.249 info instance system.adapter.wmswebcontrol.0 started with pid 568
            Thomas Braun Most Active last edited by Thomas Braun
            wmswebcontrol
            Dann mach ein Issue auf.
            Oder versuch dein Glück mit der github-Version, da scheint jüngst was passiert zu sein.
            Und setze Texte aus der Konsole in CodeTags. Kann man besser lesen.
            • N
              @thomas-braun vielen Danke für den Tipp, über die NPM Version 0.0.6 läufts ohne Probleme!
