    4. iobroker zeschossen
    iobroker zeschossen
    • Krisiun
      Krisiun last edited by
      Hallo allerseits, ich habe gestern versucht Nodje auf die neueste Version zu aktualisieren und hab bestimmt was falsch gemacht. Jetzt startet iob überhaupt nicht mehr.
      Bei " iobroker start" über Konsole kommt:
      root@Marek2:~# iobroker start
      /usr/bin/node: 1: cannot create : Permission denied
      /usr/bin/node: 2: : not found
      /usr/bin/node: 4: Syntax error: Unterminated quoted string
      Wenn ich " iob diag " mache kommt das:
      Skript v.2023-06-20
      *** BASE SYSTEM ***
      Failed to connect to bus: Host is down
      model name      : Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz
      Docker          : false
      Virtualization  : wsl
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       18:46:07 up 27 min,  0 users,  load average: 0.52, 0.58, 0.59
      CPU threads: 8
      *** Time and Time Zones ***
      System has not been booted with systemd as init system (PID 1). Can't operate.
      *** User and Groups ***
      root
      /root
      root
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:             16G        5.9G         10G         17M        223M         10G
      Swap:            30G          0B         30G
      Total:           46G        5.9G         40G
      Error: /proc must be mounted
        To mount /proc at boot you need an /etc/fstab line like:
            proc   /proc   proc    defaults
        In the meantime, run "mount proc /proc -t proc"
      *** FILESYSTEM ***
      Filesystem     Type   Size  Used Avail Use% Mounted on
      rootfs         lxfs   238G  195G   43G  83% /
      none           tmpfs  238G  195G   43G  83% /dev
      none           tmpfs  238G  195G   43G  83% /run
      none           tmpfs  238G  195G   43G  83% /run/lock
      none           tmpfs  238G  195G   43G  83% /run/shm
      none           tmpfs  238G  195G   43G  83% /run/user
      tmpfs          tmpfs  238G  195G   43G  83% /sys/fs/cgroup
      C:\            drvfs  238G  195G   43G  83% /mnt/c
      D:\            drvfs  932G  541G  391G  59% /mnt/d
      Show mounted filesystems (real ones only):
      TARGET   SOURCE FSTYPE OPTIONS
      /        rootfs lxfs   rw,noatime
      |-/mnt/c C:\    drvfs  rw,noatime,uid=0,gid=0,case=off
      `-/mnt/d D:\    drvfs  rw,noatime,uid=0,gid=0,case=off
      /var:
      428M    /var/
      330M    /var/lib
      157M    /var/lib/snapd/seed/snaps
      157M    /var/lib/snapd
      No journal files were found.
      Archived and active journals take up 0B in the file system.
      /opt/iobroker/backups:
      103M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      431M    /opt/iobroker/iobroker-data/
      285M    /opt/iobroker/iobroker-data/files
      107M    /opt/iobroker/iobroker-data/backup-objects
      72M     /opt/iobroker/iobroker-data/files/telegram.admin
      52M     /opt/iobroker/iobroker-data/files/javascript.admin
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
      19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
      15M     /opt/iobroker/iobroker-data/objects.jsonl
      15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
      8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
      *** NodeJS-Installation ***
      /home/iobroker/.diag.sh: line 177: /usr/bin/nodejs: cannot execute binary file: Exec format error
      /usr/bin/nodejs
      /home/iobroker/.diag.sh: line 178: /usr/bin/node: cannot execute binary file: Exec format error
      /usr/bin/node
      /mnt/c/Windows/system32/npm
      : not foundram Files/nodejs/npx: 2:
      : not foundram Files/nodejs/npx: 5:
      : not foundram Files/nodejs/npx: 7:
      : not foundram Files/nodejs/npx: 9:
      /mnt/c/Program Files/nodejs/npx: 10: Syntax error: word unexpected (expecting "in")
      /home/iobroker/.diag.sh: line 186: /usr/bin/nodejs: cannot execute binary file: Exec format error
      /home/iobroker/.diag.sh: line 187: /usr/bin/node: cannot execute binary file: Exec format error
      *** nodejs is NOT correctly installed ***
      nodejs:
        Installed: 12.22.9~dfsg-1ubuntu3
        Candidate: 12.22.9~dfsg-1ubuntu3
        Version table:
       *** 12.22.9~dfsg-1ubuntu3 500
              500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
              100 /var/lib/dpkg/status
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Core adapters versions
      js-controller:
      admin:
      javascript:
      Adapters from github:   0
      Adapter State
      ioBroker-Repositories
      Installed ioBroker-Instances
      Objects and States
      Objects:        0
      States:         0
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://dl.yarnpkg.com/debian stable InRelease: The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx>
      W: Failed to fetch https://dl.yarnpkg.com/debian/dists/stable/InRelease  The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging <yarn@dan.cx>
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      Get:1 https://dl.yarnpkg.com/debian stable InRelease [17.1 kB]
      Hit:2 http://security.ubuntu.com/ubuntu jammy-security InRelease
      Hit:3 http://archive.ubuntu.com/ubuntu jammy InRelease
      Hit:4 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
      Hit:5 http://archive.ubuntu.com/ubuntu jammy-backports InRelease
      Err:1 https://dl.yarnpkg.com/debian stable InRelease
      Fetched 17.1 kB in 3s (5230 B/s)
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      2023-10-07 21:49:27.501  - info: host.Marek2 instance system.adapter.kodi.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-10-07 21:49:27.502  - info: host.Marek2 instance system.adapter.tr-064.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-10-07 21:49:27.502  - info: host.Marek2 instance system.adapter.shelly.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-10-07 21:49:27.502  - info: host.Marek2 stopInstance system.adapter.pushover.0 killing pid 9396
      2023-10-07 21:49:27.537  - info: host.Marek2 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-10-07 21:49:27.538  - info: host.Marek2 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-10-07 21:49:27.539  - info: host.Marek2 instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-10-07 21:49:27.634  - info: host.Marek2 stopInstance system.adapter.web.0 killing pid 10344
      2023-10-07 21:49:27.635  - info: host.Marek2 stopInstance system.adapter.philips-tv.0 killing pid 10481
      2023-10-07 21:49:27.647  - info: host.Marek2 instance system.adapter.sonoff.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-10-07 21:49:27.668  - info: host.Marek2 instance system.adapter.iot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-10-07 21:49:27.668  - info: host.Marek2 instance system.adapter.broadlink2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-10-07 21:49:27.730  - info: host.Marek2 instance system.adapter.info.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-10-07 21:49:27.730  - info: host.Marek2 instance system.adapter.yahka.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-10-07 21:49:27.730  - info: host.Marek2 instance system.adapter.tankerkoenig.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-10-07 21:49:27.765  - info: host.Marek2 instance system.adapter.firetv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-10-07 21:49:27.765  - info: host.Marek2 instance system.adapter.parcel.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-10-07 21:49:27.839  - info: host.Marek2 instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-10-07 21:49:27.840  - info: host.Marek2 instance system.adapter.philips-tv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-10-07 21:49:27.901  - info: host.Marek2 instance system.adapter.pushover.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-10-07 21:49:29.473  - info: tuya.0 (9456) terminating
      2023-10-07 21:49:29.475  - info: tuya.0 (9456) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-10-07 21:49:30.080  - info: host.Marek2 instance system.adapter.tuya.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-10-07 21:49:30.081  - info: host.Marek2 All instances are stopped.
      2023-10-07 21:49:30.150  - info: host.Marek2 terminated
      Kann mir da jemand helfen oder ist das schon ein hofnungsose Fahl?
      Thomas Braun Glasfaser 3 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Krisiun last edited by
        @krisiun sagte in iobroker zeschossen:
        Was hast du denn genau gemacht?
        • Krisiun
          Das weiß ich jetzt nicht so genau aber ich denke ich habe falsche angaben gemacht
          Krisiun Thomas Braun 2 Replies Last reply Reply Quote 0
          • Krisiun
            Krisiun @Krisiun last edited by
            Das habe ich eingegeben
            iobroker stop
            curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash -
            sudo apt install -y nodejs
            Krisiun 1 Reply Last reply Reply Quote 0
            • Krisiun
              iobroker stop
              Aber es hat nicht geklappt dann habe ich weiter probiert und wahrscheinlich das war mein Fehler
                Thomas Braun Most Active @Krisiun last edited by Thomas Braun
                Das ist in Kombination mit einer root-shell eine denkbar ungünstige Situation...
                Da sollte man schon genau wissen, was man wie und warum macht.
                Leg dir einen user an, gibt dem sudo-Rechte und dann installierst du das nodesource-Repo danach:
                https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                • Glasfaser
                  Glasfaser @Krisiun last edited by
                  root@Marek2:
                  Das Thema dazu hatte wir schonmal und auch dich mehrmals dazu gewarnt !!
                  https://forum.iobroker.net/post/897161
                  • Krisiun
                    OK Sorry das kommt davon wenn man nicht auf Euch hört
                    Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
                    • Glasfaser
                      Glasfaser @Krisiun last edited by Glasfaser
                      @krisiun
                      Auch hier ... ein Kommentar dazu ... zu WSL
                      https://forum.iobroker.net/post/897255
                        Wird ja nicht ohne Grund immer wieder darauf hingewiesen.
                        Wer nicht hören will, muss ein Backup haben.
                        Oder seinen Umgang mit dem System ändern.
                        • Krisiun
                          Ich habe schon verstanden. Macht mich nicht noch mehr fertig als ich schon bin.
                          Die istallation auf Windows rechner war für mich für Testzwecke. Ich wollte nicht riskieren aufm rassby zu experimentieren.
                          Eins möchte ich von Euch wissen? Kann man die installation noch retten oder nicht?
                          Thomas Braun bahnuhr 2 Replies Last reply Reply Quote 0
                          • Glasfaser
                            eine Normal Abfrage funktioniert ja noch nicht mal.
                            Ich denke mal da ist Linux zerschossen
                              Keine Ahnung. Du kannst ja nicht sagen, was du da wo mit root-Rechten herumgefummelt hast.
                              Ich würde zuerstmal ordentliche user anlegen, den root dann in Ruh' lassen und ordentlich das nodesource-Repo anlegen.
                              • bahnuhr
                                bahnuhr Forum Testing Most Active @Krisiun last edited by
                                Hab ich alles hinter mir.
                                Kauf dir ein ordentliches System (z.B. nuc) und mach proxmox drauf. Dann kannst du ganz schnell ein backup machen; und dies evtl. wieder zurück spielen.
                                Fazit:
                                nuc kaufen
                                proxmox drauf
                                backup von deinem backitup einspielen.
                                Fertig.
                                P.S.
                                was ist ein rassby ?
                                Glasfaser 1 Reply Last reply Reply Quote 1
                                  Thomas Braun Most Active @Glasfaser last edited by Thomas Braun
                                  @glasfaser sagte in iobroker zeschossen:
                                  Ich vermute, das wsl bootet nicht per systemd.
                                  Edit:
                                  Näheres hier
                                  https://devblogs.microsoft.com/commandline/systemd-support-is-now-available-in-wsl/
                                  • Krisiun
                                    Krisiun @Thomas Braun last edited by
                                    @thomas-braun sagte in iobroker zeschossen:
                                    Nein leider nicht
                                    • Glasfaser
                                      Glasfaser @bahnuhr last edited by
                                      @bahnuhr sagte in iobroker zeschossen:
                                      Krisiun bahnuhr 2 Replies Last reply Reply Quote 1
                                      • Krisiun
                                        Krisiun @Glasfaser last edited by
                                        Raspberry Pi
                                        • bahnuhr
                                          bahnuhr Forum Testing Most Active @Glasfaser last edited by
                                          @glasfaser
                                          Das ist cool.
                                          Bild bitte per Link 😉
                                          • Krisiun
                                            Danke Euch trotzdem. Dann muss ich wohl wieder von vorne anfangen 😧
                                            Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
                                            23922
