    4. Installation unter Debian 10 bricht ab
      Drillo123 last edited by
      Ich versuche auf DEBIAN 10 (unter Proxmox) iobrocker zu installieren. Leider bricht es immer ab:
      root@ioBroker:~# curl -sLf https://iobroker.net/install.sh | bash -
      library: loaded
      Library version=2022-12-09
          Welcome to the ioBroker installer!
          Installer version: 2023-09-13
          Installing prerequisites (1/4)
      Hit:1 https://deb.nodesource.com/node_18.x bullseye InRelease
      Hit:2 http://ftp.debian.org/debian bullseye InRelease
      Hit:3 http://security.debian.org bullseye-security InRelease
      Hit:4 http://ftp.debian.org/debian bullseye-updates InRelease
      Reading package lists... Done
      Installed gcc-c++
          Creating ioBroker user and directory (2/4)
      Created /etc/sudoers.d/iobroker
      Directory /opt/iobroker created
          Installing ioBroker (3/4)
      npm ERR! code ENOTEMPTY
      npm ERR! syscall rename
      npm ERR! path /opt/iobroker/node_modules/crc-32
      npm ERR! dest /opt/iobroker/node_modules/.crc-32-aq21qRu1
      npm ERR! errno -39
      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/crc-32' -> '/opt/iobroker/node_modules/.crc-32-aq21qRu1'
      npm ERR! A complete log of this run can be found in: /root/.npm/_logs/2023-10-09T18_55_16_337Z-debug-0.log
          Finalizing installation (4/4)
      Enabling autostart...
      Autostart enabled!
          ioBroker was installed successfully
          Open http://192.168.24.209:8081 in a browser and start configuring!
      You need to re-login before doing anything else on the console!
      root@ioBroker:~#
      Hier der LOG als Auszug:
      997 silly reify ]
      998 silly reify mark retired [
      998 silly reify   '/opt/iobroker/node_modules/@iobroker/db-states-jsonl/node_modules/universalify'
      998 silly reify ]
      999 silly reify mark retired [
      999 silly reify   '/opt/iobroker/node_modules/@iobroker/db-states-jsonl/node_modules/@iobroker/db-base'
      999 silly reify ]
      1000 silly reify mark retired [
      1000 silly reify   '/opt/iobroker/node_modules/@iobroker/db-states-redis/node_modules/cluster-key-slot'
      1000 silly reify ]
      1001 silly reify mark retired [
      1001 silly reify   '/opt/iobroker/node_modules/@iobroker/db-states-redis/node_modules/debug'
      1001 silly reify ]
      1002 silly reify mark retired [
      1002 silly reify   '/opt/iobroker/node_modules/@iobroker/db-states-redis/node_modules/ioredis'
      1002 silly reify ]
      1003 silly reify mark retired [
      1003 silly reify   '/opt/iobroker/node_modules/@iobroker/db-states-redis/node_modules/ms'
      1003 silly reify ]
      1004 silly reify mark retired [
      1004 silly reify   '/opt/iobroker/node_modules/@iobroker/db-states-redis/node_modules/redis-commands'
      1004 silly reify ]
      1005 silly reify mark retired [
      1005 silly reify   '/opt/iobroker/node_modules/@iobroker/db-states-redis/node_modules/redis-errors'
      1005 silly reify ]
      1006 silly reify mark retired [
      1006 silly reify   '/opt/iobroker/node_modules/@iobroker/db-states-redis/node_modules/respjs'
      1006 silly reify ]
      1007 silly reify mark retired [
      1007 silly reify   '/opt/iobroker/node_modules/@iobroker/db-states-redis/node_modules/@iobroker/db-base'
      1007 silly reify ]
      1008 silly reify mark retired [
      1008 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-cli/node_modules/fsevents'
      1008 silly reify ]
      1009 silly reify mark retired [
      1009 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-cli/node_modules/debug'
      1009 silly reify ]
      1010 silly reify mark retired [
      1010 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-cli/node_modules/mime-db'
      1010 silly reify ]
      1011 silly reify mark retired [
      1011 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-cli/node_modules/mime-types'
      1011 silly reify ]
      1012 silly reify mark retired [
      1012 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-cli/node_modules/ms'
      1012 silly reify ]
      1013 silly reify mark retired [
      1013 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-common-db/node_modules/inherits'
      1013 silly reify ]
      1014 silly reify mark retired [
      1014 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-common-db/node_modules/is-stream'
      1014 silly reify ]
      1015 silly reify mark retired [
      1015 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/follow-redirects'
      1015 silly reify ]
      1016 silly reify mark retired [
      1016 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/graceful-fs'
      1016 silly reify ]
      1017 silly reify mark retired [
      1017 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/inherits'
      1017 silly reify ]
      1018 silly reify mark retired [
      1018 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/is-stream'
      1018 silly reify ]
      1019 silly reify mark retired [
      1019 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/jsonfile'
      1019 silly reify ]
      1020 silly reify mark retired [
      1020 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/universalify'
      1020 silly reify ]
      1021 silly reify mark retired [
      1021 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/which',
      1021 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/.bin/node-which'
      1021 silly reify ]
      1022 silly reify mark retired [
      1022 silly reify   '/opt/iobroker/node_modules/@iobroker/plugin-sentry/node_modules/localforage'
      1022 silly reify ]
      1023 silly reify mark retired [
      1023 silly reify   '/opt/iobroker/node_modules/@iobroker/plugin-sentry/node_modules/cookie'
      1023 silly reify ]
      1024 silly reify mark retired [
      1024 silly reify   '/opt/iobroker/node_modules/@iobroker/plugin-sentry/node_modules/debug'
      1024 silly reify ]
      1025 silly reify mark retired [
      1025 silly reify   '/opt/iobroker/node_modules/@iobroker/plugin-sentry/node_modules/lie'
      1025 silly reify ]
      1026 silly reify mark retired [
      1026 silly reify   '/opt/iobroker/node_modules/@iobroker/plugin-sentry/node_modules/ms'
      1026 silly reify ]
      1027 silly reify mark retired [
      1027 silly reify   '/opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/@iobroker/types'
      1027 silly reify ]
      1028 silly reify mark retired [
      1028 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/follow-redirects'
      1028 silly reify ]
      1029 silly reify mark retired [
      1029 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/graceful-fs'
      1029 silly reify ]
      1030 silly reify mark retired [
      1030 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/is-stream'
      1030 silly reify ]
      1031 silly reify mark retired [
      1031 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/jsonfile'
      1031 silly reify ]
      1032 silly reify mark retired [
      1032 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/universalify'
      1032 silly reify ]
      1033 silly reify mark retired [
      1033 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/which',
      1033 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/.bin/node-which'
      1033 silly reify ]
      1034 silly reify mark retired [
      1034 silly reify   '/opt/iobroker/node_modules/sshpk',
      1034 silly reify   '/opt/iobroker/node_modules/.bin/sshpk-conv',
      1034 silly reify   '/opt/iobroker/node_modules/.bin/sshpk-sign',
      1034 silly reify   '/opt/iobroker/node_modules/.bin/sshpk-verify'
      1034 silly reify ]
      1035 silly reify moves {
      1035 silly reify   '/opt/iobroker/node_modules/color-string': '/opt/iobroker/node_modules/.color-string-TIiP9v7Y',
      1035 silly reify   '/opt/iobroker/node_modules/ecdsa-sig-formatter': '/opt/iobroker/node_modules/.ecdsa-sig-formatter-Q9OtX6RW',
      1035 silly reify   '/opt/iobroker/node_modules/get-stream': '/opt/iobroker/node_modules/.get-stream-huR1ASVM',
      1035 silly reify   '/opt/iobroker/node_modules/iobroker.admin': '/opt/iobroker/node_modules/.iobroker.admin-TtUA2igk',
      1035 silly reify   '/opt/iobroker/node_modules/jsbn': '/opt/iobroker/node_modules/.jsbn-mwX02yM6',
      1035 silly reify   '/opt/iobroker/node_modules/luxon': '/opt/iobroker/node_modules/.luxon-LJKUBvGN',
      1035 silly reify   '/opt/iobroker/node_modules/nan': '/opt/iobroker/node_modules/.nan-VJWFtQnQ',
      1035 silly reify   '/opt/iobroker/node_modules/normalize-path': '/opt/iobroker/node_modules/.normalize-path-OU9YSYPX',
      1035 silly reify   '/opt/iobroker/node_modules/once': '/opt/iobroker/node_modules/.once-2jbVM5Dp',
      1035 silly reify   '/opt/iobroker/node_modules/readable-stream': '/opt/iobroker/node_modules/.readable-stream-z2JbSRcZ',
      1035 silly reify   '/opt/iobroker/node_modules/redis-errors': '/opt/iobroker/node_modules/.redis-errors-bKsJha3t',
      1035 silly reify   '/opt/iobroker/node_modules/safe-buffer': '/opt/iobroker/node_modules/.safe-buffer-2t2nP1wL',
      1035 silly reify   '/opt/iobroker/node_modules/safer-buffer': '/opt/iobroker/node_modules/.safer-buffer-F3JrHNU9',
      1035 silly reify   '/opt/iobroker/node_modules/triple-beam': '/opt/iobroker/node_modules/.triple-beam-GgMpEggS',
      1035 silly reify   '/opt/iobroker/node_modules/ansi-styles/node_modules/color-convert': '/opt/iobroker/node_modules/ansi-styles/node_modules/.color-convert-xVzBOLEB',
      1035 silly reify   '/opt/iobroker/node_modules/archiver/node_modules/fs.realpath': '/opt/iobroker/node_modules/archiver/node_modules/.fs.realpath-GUStRGYH',
      1035 silly reify   '/opt/iobroker/node_modules/archiver/node_modules/glob': '/opt/iobroker/node_modules/archiver/node_modules/.glob-fkx3jYOc',
      1035 silly reify   '/opt/iobroker/node_modules/archiver/node_modules/graceful-fs': '/opt/iobroker/node_modules/archiver/node_modules/.graceful-fs-h3E0mphy',
      1035 silly reify   '/opt/iobroker/node_modules/archiver/node_modules/inflight': '/opt/iobroker/node_modules/archiver/node_modules/.inflight-i79hk84T',
      1035 silly reify   '/opt/iobroker/node_modules/archiver/node_modules/inherits': '/opt/iobroker/node_modules/archiver/node_modules/.inherits-Kw0P8c1j',
      1035 silly reify   '/opt/iobroker/node_modules/archiver/node_modules/isarray': '/opt/iobroker/node_modules/archiver/node_modules/.isarray-oR53wNZL',
      1035 silly reify   '/opt/iobroker/node_modules/archiver/node_modules/lazystream': '/opt/iobroker/node_modules/archiver/node_modules/.lazystream-AoNkD97h',
      1035 silly reify   '/opt/iobroker/node_modules/archiver/node_modules/lodash': '/opt/iobroker/node_modules/archiver/node_modules/.lodash-N1ZwAkLR',
      1035 silly reify   '/opt/iobroker/node_modules/archiver/node_modules/minimatch': '/opt/iobroker/node_modules/archiver/node_modules/.minimatch-EmRbwJkT',
      1035 silly reify   '/opt/iobroker/node_modules/archiver/node_modules/normalize-path': '/opt/iobroker/node_modules/archiver/node_modules/.normalize-path-ruBkIRi8',
      1035 silly reify   '/opt/iobroker/node_modules/archiver/node_modules/once': '/opt/iobroker/node_modules/archiver/node_modules/.once-weKIHqNg',
      1035 silly reify   '/opt/iobroker/node_modules/archiver/node_modules/safe-buffer': '/opt/iobroker/node_modules/archiver/node_modules/.safe-buffer-E788vCy3',
      1035 silly reify   '/opt/iobroker/node_modules/archiver/node_modules/string_decoder': '/opt/iobroker/node_modules/archiver/node_modules/.string_decoder-kFuyj5sB',
      1035 silly reify   '/opt/iobroker/node_modules/archiver/node_modules/wrappy': '/opt/iobroker/node_modules/archiver/node_modules/.wrappy-nDpotDcC',
      1035 silly reify   '/opt/iobroker/node_modules/axios/node_modules/asynckit': '/opt/iobroker/node_modules/axios/node_modules/.asynckit-Yj8S3qe9',
      1035 silly reify   '/opt/iobroker/node_modules/axios/node_modules/combined-stream': '/opt/iobroker/node_modules/axios/node_modules/.combined-stream-y2U4cgto',
      1035 silly reify   '/opt/iobroker/node_modules/axios/node_modules/delayed-stream': '/opt/iobroker/node_modules/axios/node_modules/.delayed-stream-fDRNKvjd',
      1035 silly reify   '/opt/iobroker/node_modules/axios/node_modules/mime-db': '/opt/iobroker/node_modules/axios/node_modules/.mime-db-uHTxPiqf',
      1035 silly reify   '/opt/iobroker/node_modules/axios/node_modules/mime-types': '/opt/iobroker/node_modules/axios/node_modules/.mime-types-WWvYtWxH',
      1035 silly reify   '/opt/iobroker/node_modules/b4a': '/opt/iobroker/node_modules/.b4a-ZneFXh0o',
      1035 silly reify   '/opt/iobroker/node_modules/balanced-match': '/opt/iobroker/node_modules/.balanced-match-I9YlRhpD',
      1035 silly reify   '/opt/iobroker/node_modules/body-parser/node_modules/inherits': '/opt/iobroker/node_modules/body-parser/node_modules/.inherits-CCjpJh0C',
      1035 silly reify   '/opt/iobroker/node_modules/body-parser/node_modules/mime-db': '/opt/iobroker/node_modules/body-parser/node_modules/.mime-db-i1Mlwauy',
      1035 silly reify   '/opt/iobroker/node_modules/body-parser/node_modules/mime-types': '/opt/iobroker/node_modules/body-parser/node_modules/.mime-types-mwJ2poLB',
      1035 silly reify   '/opt/iobroker/node_modules/body-parser/node_modules/ms': '/opt/iobroker/node_modules/body-parser/node_modules/.ms-1F9FHauY',
      1035 silly reify   '/opt/iobroker/node_modules/body-parser/node_modules/safer-buffer': '/opt/iobroker/node_modules/body-parser/node_modules/.safer-buffer-W62t7hBs',
      1035 silly reify   '/opt/iobroker/node_modules/body-parser/node_modules/setprototypeof': '/opt/iobroker/node_modules/body-parser/node_modules/.setprototypeof-64PPVW1o',
      1035 silly reify   '/opt/iobroker/node_modules/body-parser/node_modules/statuses': '/opt/iobroker/node_modules/body-parser/node_modules/.statuses-LT9puWoW',
      1035 silly reify   '/opt/iobroker/node_modules/body-parser/node_modules/toidentifier': '/opt/iobroker/node_modules/body-parser/node_modules/.toidentifier-PPKBxu7a',
      1035 silly reify   '/opt/iobroker/node_modules/brace-expansion': '/opt/iobroker/node_modules/.brace-expansion-A2cUvsBz',
      1035 silly reify   '/opt/iobroker/node_modules/colors': '/opt/iobroker/node_modules/.colors-GR03HjNm',
      1035 silly reify   '/opt/iobroker/node_modules/compress-commons': '/opt/iobroker/node_modules/.compress-commons-NNtCb3yz',
      1035 silly reify   '/opt/iobroker/node_modules/compression/node_modules/mime-db': '/opt/iobroker/node_modules/compression/node_modules/.mime-db-V87tlD8i',
      1035 silly reify   '/opt/iobroker/node_modules/compression/node_modules/mime-types': '/opt/iobroker/node_modules/compression/node_modules/.mime-types-evijQFMa',
      1035 silly reify   '/opt/iobroker/node_modules/compression/node_modules/ms': '/opt/iobroker/node_modules/compression/node_modules/.ms-WdIiuk1Y',
      1035 silly reify   '/opt/iobroker/node_modules/compression/node_modules/negotiator': '/opt/iobroker/node_modules/compression/node_modules/.negotiator-yzdGqYjt',
      1035 silly reify   '/opt/iobroker/node_modules/crc-32': '/opt/iobroker/node_modules/.crc-32-aq21qRu1',
      1035 silly reify   '/opt/iobroker/node_modules/.bin/crc32': '/opt/iobroker/node_modules/.bin/.crc32-mA3oGLf0',
      1035 silly reify   '/opt/iobroker/node_modules/crc32-stream': '/opt/iobroker/node_modules/.crc32-stream-eBgrslHM',
      1035 silly reify   '/opt/iobroker/node_modules/cycle': '/opt/iobroker/node_modules/.cycle-xUsdM6g3',
      1035 silly reify   '/opt/iobroker/node_modules/eckles': '/opt/iobroker/node_modules/.eckles-3COyV8wU',
      1035 silly reify   '/opt/iobroker/node_modules/.bin/eckles': '/opt/iobroker/node_modules/.bin/.eckles-3gqRdiGx',
      1035 silly reify   '/opt/iobroker/node_modules/express/node_modules/body-parser': '/opt/iobroker/node_modules/express/node_modules/.body-parser-M9dldBif',
      1035 silly reify   '/opt/iobroker/node_modules/express/node_modules/bytes': '/opt/iobroker/node_modules/express/node_modules/.bytes-ZtJupt19',
      1035 silly reify   '/opt/iobroker/node_modules/express/node_modules/content-type': '/opt/iobroker/node_modules/express/node_modules/.content-type-exddcArg',
      1035 silly reify   '/opt/iobroker/node_modules/express/node_modules/debug': '/opt/iobroker/node_modules/express/node_modules/.debug-sNzTx7pW',
      1035 silly reify   '/opt/iobroker/node_modules/express/node_modules/depd': '/opt/iobroker/node_modules/express/node_modules/.depd-UkXvMlmq',
      1035 silly reify   '/opt/iobroker/node_modules/express/node_modules/destroy': '/opt/iobroker/node_modules/express/node_modules/.destroy-iVT7fWKd',
      1035 silly reify   '/opt/iobroker/node_modules/express/node_modules/http-errors': '/opt/iobroker/node_modules/express/node_modules/.http-errors-IERX7XqM',
      1035 silly reify   '/opt/iobroker/node_modules/express/node_modules/iconv-lite': '/opt/iobroker/node_modules/express/node_modules/.iconv-lite-VUM01Ruf',
      1035 silly reify   '/opt/iobroker/node_modules/express/node_modules/inherits': '/opt/iobroker/node_modules/express/node_modules/.inherits-DRnu1GOC',
      1035 silly reify   '/opt/iobroker/node_modules/express/node_modules/ipaddr.js': '/opt/iobroker/node_modules/express/node_modules/.ipaddr.js-BdG4GHBI',
      1035 silly reify   '/opt/iobroker/node_modules/express/node_modules/mime': '/opt/iobroker/node_modules/express/node_modules/.mime-vconMtPp',
      1035 silly reify   '/opt/iobroker/node_modules/express/node_modules/mime-db': '/opt/iobroker/node_modules/express/node_modules/.mime-db-nBr6wfS2',
      1035 silly reify   '/opt/iobroker/node_modules/express/node_modules/mime-types': '/opt/iobroker/node_modules/express/node_modules/.mime-types-7wrYuND1',
      1035 silly reify   '/opt/iobroker/node_modules/express/node_modules/ms': '/opt/iobroker/node_modules/express/node_modules/.ms-XUDPqAcF',
      1035 silly reify   '/opt/iobroker/node_modules/express/node_modules/negotiator': '/opt/iobroker/node_modules/express/node_modules/.negotiator-boCWWTYz',
      1035 silly reify   '/opt/iobroker/node_modules/express/node_modules/on-finished': '/opt/iobroker/node_modules/express/node_modules/.on-finished-4O5rQU9S',
      1035 silly reify   '/opt/iobroker/node_modules/express/node_modules/qs': '/opt/iobroker/node_modules/express/node_modules/.qs-ajI3nBpv',
      1035 silly reify   '/opt/iobroker/node_modules/express/node_modules/raw-body': '/opt/iobroker/node_modules/express/node_modules/.raw-body-QMmBWi4M',
      1035 silly reify   '/opt/iobroker/node_modules/express/node_modules/safe-buffer': '/opt/iobroker/node_modules/express/node_modules/.safe-buffer-cGvDEgKz',
      1035 silly reify   '/opt/iobroker/node_modules/express/node_modules/safer-buffer': '/opt/iobroker/node_modules/express/node_modules/.safer-buffer-cXXocaoP',
      1035 silly reify   '/opt/iobroker/node_modules/express/node_modules/send/node_modules/ms': '/opt/iobroker/node_modules/express/node_modules/send/node_modules/.ms-DE6vySZx',
      1035 silly reify   '/opt/iobroker/node_modules/express/node_modules/toidentifier': '/opt/iobroker/node_modules/express/node_modules/.toidentifier-xE38vSuD',
      1035 silly reify   '/opt/iobroker/node_modules/express/node_modules/type-is': '/opt/iobroker/node_modules/express/node_modules/.type-is-PstzLSjj',
      1035 silly reify   '/opt/iobroker/node_modules/express/node_modules/unpipe': '/opt/iobroker/node_modules/express/node_modules/.unpipe-sBRyDrsE',
      1035 silly reify   '/opt/iobroker/node_modules/express-fileupload/node_modules/streamsearch': '/opt/iobroker/node_modules/express-fileupload/node_modules/.streamsearch-KLg2mUCe',
      1035 silly reify   '/opt/iobroker/node_modules/express-session/node_modules/ms': '/opt/iobroker/node_modules/express-session/node_modules/.ms-7Okkf0AM',
      1035 silly reify   '/opt/iobroker/node_modules/eyes': '/opt/iobroker/node_modules/.eyes-lUCga7KE',
      1035 silly reify   '/opt/iobroker/node_modules/fast-fifo': '/opt/iobroker/node_modules/.fast-fifo-5g2GsFDw',
      1035 silly reify   '/opt/iobroker/node_modules/fast-xml-parser': '/opt/iobroker/node_modules/.fast-xml-parser-jvT0QQEl',
      1035 silly reify   '/opt/iobroker/node_modules/.bin/fxparser': '/opt/iobroker/node_modules/.bin/.fxparser-BkDZWtmg',
      1035 silly reify   '/opt/iobroker/node_modules/forwarded': '/opt/iobroker/node_modules/.forwarded-VbnEdnMC',
      1035 silly reify   '/opt/iobroker/node_modules/fs-minipass/node_modules/minipass': '/opt/iobroker/node_modules/fs-minipass/node_modules/.minipass-TNOsuAjC',
      1035 silly reify   '/opt/iobroker/node_modules/ftp/node_modules/inherits': '/opt/iobroker/node_modules/ftp/node_modules/.inherits-wX5ULqVN',
      1035 silly reify   '/opt/iobroker/node_modules/ftp/node_modules/readable-stream': '/opt/iobroker/node_modules/ftp/node_modules/.readable-stream-C3fn8Nws',
      1035 silly reify   '/opt/iobroker/node_modules/ftp/node_modules/string_decoder': '/opt/iobroker/node_modules/ftp/node_modules/.string_decoder-9Yz2ilPK',
      1035 silly reify   '/opt/iobroker/node_modules/google-auth-library/node_modules/agent-base': '/opt/iobroker/node_modules/google-auth-library/node_modules/.agent-base-0oLvtzKc',
      1035 silly reify   '/opt/iobroker/node_modules/google-auth-library/node_modules/bignumber.js': '/opt/iobroker/node_modules/google-auth-library/node_modules/.bignumber.js-7onuYVMN',
      1035 silly reify   '/opt/iobroker/node_modules/google-auth-library/node_modules/debug': '/opt/iobroker/node_modules/google-auth-library/node_modules/.debug-MUnayzca',
      1035 silly reify   '/opt/iobroker/node_modules/google-auth-library/node_modules/ecdsa-sig-formatter': '/opt/iobroker/node_modules/google-auth-library/node_modules/.ecdsa-sig-formatter-FKLapVX9',
      1035 silly reify   '/opt/iobroker/node_modules/google-auth-library/node_modules/extend': '/opt/iobroker/node_modules/google-auth-library/node_modules/.extend-gw5TBqc2',
      1035 silly reify   '/opt/iobroker/node_modules/google-auth-library/node_modules/https-proxy-agent': '/opt/iobroker/node_modules/google-auth-library/node_modules/.https-proxy-agent-ekmm3b0q',
      1035 silly reify   '/opt/iobroker/node_modules/google-auth-library/node_modules/is-stream': '/opt/iobroker/node_modules/google-auth-library/node_modules/.is-stream-fLRWXFol',
      1035 silly reify   '/opt/iobroker/node_modules/google-auth-library/node_modules/json-bigint': '/opt/iobroker/node_modules/google-auth-library/node_modules/.json-bigint-ODwCVQDS',
      1035 silly reify   '/opt/iobroker/node_modules/google-auth-library/node_modules/ms': '/opt/iobroker/node_modules/google-auth-library/node_modules/.ms-gHbztUFi',
      1035 silly reify   '/opt/iobroker/node_modules/google-auth-library/node_modules/node-fetch': '/opt/iobroker/node_modules/google-auth-library/node_modules/.node-fetch-kkZ4WRwp',
      1035 silly reify   '/opt/iobroker/node_modules/google-auth-library/node_modules/safe-buffer': '/opt/iobroker/node_modules/google-auth-library/node_modules/.safe-buffer-zYdZpgdc',
      1035 silly reify   '/opt/iobroker/node_modules/google-auth-library/node_modules/whatwg-url': '/opt/iobroker/node_modules/google-auth-library/node_modules/.whatwg-url-gBuDVWEG',
      1035 silly reify   '/opt/iobroker/node_modules/greenlock/node_modules/greenlock-manager-fs': '/opt/iobroker/node_modules/greenlock/node_modules/.greenlock-manager-fs-Z2L9ETGX',
      1035 silly reify   '/opt/iobroker/node_modules/greenlock/node_modules/@root/acme/node_modules/@root/keypairs': '/opt/iobroker/node_modules/greenlock/node_modules/@root/acme/node_modules/@root/.keypairs-WYrECOGj',
      1035 silly reify   '/opt/iobroker/node_modules/greenlock/node_modules/@root/asn1': '/opt/iobroker/node_modules/greenlock/node_modules/@root/.asn1-7AW7g2xY',
      1035 silly reify   '/opt/iobroker/node_modules/greenlock/node_modules/@root/encoding': '/opt/iobroker/node_modules/greenlock/node_modules/@root/.encoding-QkWQfkpB',
      1035 silly reify   '/opt/iobroker/node_modules/greenlock/node_modules/@root/greenlock/node_modules/@root/keypairs': '/opt/iobroker/node_modules/greenlock/node_modules/@root/greenlock/node_modules/@root/.keypairs-b51zu19b',
      1035 silly reify   '/opt/iobroker/node_modules/greenlock/node_modules/@root/pem': '/opt/iobroker/node_modules/greenlock/node_modules/@root/.pem-s4aSrg0h',
      1035 silly reify   '/opt/iobroker/node_modules/greenlock/node_modules/@root/x509': '/opt/iobroker/node_modules/greenlock/node_modules/@root/.x509-1ZgnfQ2C',
      1035 silly reify   '/opt/iobroker/node_modules/greenlock-express/node_modules/acme-http-01-standalone': '/opt/iobroker/node_modules/greenlock-express/node_modules/.acme-http-01-standalone-gNv72Ilb',
      1035 silly reify   '/opt/iobroker/node_modules/greenlock-express/node_modules/cert-info': '/opt/iobroker/node_modules/greenlock-express/node_modules/.cert-info-t9sv7DQk',
      1035 silly reify   '/opt/iobroker/node_modules/greenlock-express/node_modules/escape-html': '/opt/iobroker/node_modules/greenlock-express/node_modules/.escape-html-jNqUIKfd',
      1035 silly reify   '/opt/iobroker/node_modules/greenlock-express/node_modules/greenlock-manager-fs': '/opt/iobroker/node_modules/greenlock-express/node_modules/.greenlock-manager-fs-5T3hUBFF',
      1035 silly reify   '/opt/iobroker/node_modules/greenlock-express/node_modules/greenlock-store-fs': '/opt/iobroker/node_modules/greenlock-express/node_modules/.greenlock-store-fs-YYlX3h06',
      1035 silly reify   '/opt/iobroker/node_modules/greenlock-express/node_modules/safe-replace': '/opt/iobroker/node_modules/greenlock-express/node_modules/.safe-replace-MueiC65i',
      1035 silly reify   '/opt/iobroker/node_modules/greenlock-express/node_modules/@greenlock/manager': '/opt/iobroker/node_modules/greenlock-express/node_modules/@greenlock/.manager-HSPfQrLP',
      1035 silly reify   '/opt/iobroker/node_modules/greenlock-express/node_modules/@root/acme': '/opt/iobroker/node_modules/greenlock-express/node_modules/@root/.acme-Dw3dDPnF',
      1035 silly reify   '/opt/iobroker/node_modules/greenlock-express/node_modules/@root/asn1': '/opt/iobroker/node_modules/greenlock-express/node_modules/@root/.asn1-lhZ4NBQ6',
      1035 silly reify   '/opt/iobroker/node_modules/greenlock-express/node_modules/@root/csr': '/opt/iobroker/node_modules/greenlock-express/node_modules/@root/.csr-5zs8VD1g',
      1035 silly reify   '/opt/iobroker/node_modules/greenlock-express/node_modules/@root/encoding': '/opt/iobroker/node_modules/greenlock-express/node_modules/@root/.encoding-sJUhJFU1',
      1035 silly reify   '/opt/iobroker/node_modules/greenlock-express/node_modules/@root/keypairs': '/opt/iobroker/node_modules/greenlock-express/node_modules/@root/.keypairs-GkP1JREQ',
      1035 silly reify   '/opt/iobroker/node_modules/greenlock-express/node_modules/@root/mkdirp': '/opt/iobroker/node_modules/greenlock-express/node_modules/@root/.mkdirp-ICZKfSuH',
      1035 silly reify   '/opt/iobroker/node_modules/greenlock-express/node_modules/@root/pem': '/opt/iobroker/node_modules/greenlock-express/node_modules/@root/.pem-LvPL8goQ',
      1035 silly reify   '/opt/iobroker/node_modules/greenlock-express/node_modules/@root/request': '/opt/iobroker/node_modules/greenlock-express/node_modules/@root/.request-pOnoSYXQ',
      1035 silly reify   '/opt/iobroker/node_modules/greenlock-express/node_modules/@root/x509': '/opt/iobroker/node_modules/greenlock-express/node_modules/@root/.x509-hxfSw7QU',
      1035 silly reify   '/opt/iobroker/node_modules/he': '/opt/iobroker/node_modules/.he-XR9Ud2EZ',
      1035 silly reify   '/opt/iobroker/node_modules/.bin/he': '/opt/iobroker/node_modules/.bin/.he-EABCofKe',
      1035 silly reify   '/opt/iobroker/node_modules/iobroker.backitup': '/opt/iobroker/node_modules/.iobroker.backitup-ZZHwpo6A',
      1035 silly reify   '/opt/iobroker/node_modules/iobroker.discovery': '/opt/iobroker/node_modules/.iobroker.discovery-Domn1CAP',
      1035 silly reify   '/opt/iobroker/node_modules/iobroker.js-controller': '/opt/iobroker/node_modules/.iobroker.js-controller-7Q8bmsba',
      1035 silly reify   '/opt/iobroker/node_modules/.bin/iobroker': '/opt/iobroker/node_modules/.bin/.iobroker-dBRdrK4k',
      1035 silly reify   '/opt/iobroker/node_modules/jsonwebtoken/node_modules/ecdsa-sig-formatter': '/opt/iobroker/node_modules/jsonwebtoken/node_modules/.ecdsa-sig-formatter-CQW5PwMP',
      1035 silly reify   '/opt/iobroker/node_modules/jsonwebtoken/node_modules/jwa': '/opt/iobroker/node_modules/jsonwebtoken/node_modules/.jwa-2afDFyYb',
      1035 silly reify   '/opt/iobroker/node_modules/jsonwebtoken/node_modules/jws': '/opt/iobroker/node_modules/jsonwebtoken/node_modules/.jws-WhF8BUKA',
      1035 silly reify   '/opt/iobroker/node_modules/jsonwebtoken/node_modules/safe-buffer': '/opt/iobroker/node_modules/jsonwebtoken/node_modules/.safe-buffer-n6UjWnRU',
      1035 silly reify   '/opt/iobroker/node_modules/jszip/node_modules/inherits': '/opt/iobroker/node_modules/jszip/node_modules/.inherits-4EeYSr8E',
      1035 silly reify   '/opt/iobroker/node_modules/jszip/node_modules/isarray': '/opt/iobroker/node_modules/jszip/node_modules/.isarray-A5HZHWL5',
      1035 silly reify   '/opt/iobroker/node_modules/jszip/node_modules/readable-stream': '/opt/iobroker/node_modules/jszip/node_modules/.readable-stream-kFmg80xA',
      1035 silly reify   '/opt/iobroker/node_modules/jszip/node_modules/safe-buffer': '/opt/iobroker/node_modules/jszip/node_modules/.safe-buffer-npRim5nC',
      1035 silly reify   '/opt/iobroker/node_modules/jszip/node_modules/string_decoder': '/opt/iobroker/node_modules/jszip/node_modules/.string_decoder-XspNRRho',
      1035 silly reify   '/opt/iobroker/node_modules/jwa': '/opt/iobroker/node_modules/.jwa-zW4mnLWg',
      1035 silly reify   '/opt/iobroker/node_modules/keypairs': '/opt/iobroker/node_modules/.keypairs-c0i5Aol5',
      1035 silly reify   '/opt/iobroker/node_modules/.bin/keypairs-install': '/opt/iobroker/node_modules/.bin/.keypairs-install-3hIB6zK7',
      1035 silly reify   '/opt/iobroker/node_modules/mdns-discovery/node_modules/debug': '/opt/iobroker/node_modules/mdns-discovery/node_modules/.debug-fMMtfei4',
      1035 silly reify   '/opt/iobroker/node_modules/mdns-discovery/node_modules/ms': '/opt/iobroker/node_modules/mdns-discovery/node_modules/.ms-w5eX5K0D',
      1035 silly reify   '/opt/iobroker/node_modules/mime': '/opt/iobroker/node_modules/.mime-vbK0FsWq',
      1035 silly reify   '/opt/iobroker/node_modules/.bin/mime': '/opt/iobroker/node_modules/.bin/.mime-q2ubmcdC',
      1035 silly reify   '/opt/iobroker/node_modules/minizlib/node_modules/minipass': '/opt/iobroker/node_modules/minizlib/node_modules/.minipass-dukILAFV',
      1035 silly reify   '/opt/iobroker/node_modules/mkdirp': '/opt/iobroker/node_modules/.mkdirp-yMXn50Ac',
      1035 silly reify   '/opt/iobroker/node_modules/.bin/mkdirp': '/opt/iobroker/node_modules/.bin/.mkdirp-oNMS2XKb',
      1035 silly reify   '/opt/iobroker/node_modules/node-gyp-build': '/opt/iobroker/node_modules/.node-gyp-build-r457ov9R',
      1035 silly reify   '/opt/iobroker/node_modules/.bin/node-gyp-build': '/opt/iobroker/node_modules/.bin/.node-gyp-build-pMZd29Kq',
      1035 silly reify   '/opt/iobroker/node_modules/.bin/node-gyp-build-optional': '/opt/iobroker/node_modules/.bin/.node-gyp-build-optional-AIu7zDCI',
      1035 silly reify   '/opt/iobroker/node_modules/.bin/node-gyp-build-test': '/opt/iobroker/node_modules/.bin/.node-gyp-build-test-G3obRHBE',
      1035 silly reify   '/opt/iobroker/node_modules/node-ssdp/node_modules/debug': '/opt/iobroker/node_modules/node-ssdp/node_modules/.debug-YE0eLLPj',
      1035 silly reify   '/opt/iobroker/node_modules/node-ssdp/node_modules/lodash': '/opt/iobroker/node_modules/node-ssdp/node_modules/.lodash-5VDhHwIR',
      1035 silly reify   '/opt/iobroker/node_modules/node-ssdp/node_modules/ms': '/opt/iobroker/node_modules/node-ssdp/node_modules/.ms-uNSxoZZL',
      1035 silly reify   '/opt/iobroker/node_modules/prompt/node_modules/lodash': '/opt/iobroker/node_modules/prompt/node_modules/.lodash-RIZfMD0V',
      1035 silly reify   '/opt/iobroker/node_modules/prompt/node_modules/winston/node_modules/async': '/opt/iobroker/node_modules/prompt/node_modules/winston/node_modules/.async-rsrVC8Bc',
      1035 silly reify   '/opt/iobroker/node_modules/queue-tick': '/opt/iobroker/node_modules/.queue-tick-2LeQtUWJ',
      1035 silly reify   '/opt/iobroker/node_modules/random-bytes': '/opt/iobroker/node_modules/.random-bytes-75onKzPj',
      1035 silly reify   '/opt/iobroker/node_modules/rasha': '/opt/iobroker/node_modules/.rasha-R1kuiCfI',
      1035 silly reify   '/opt/iobroker/node_modules/.bin/rasha': '/opt/iobroker/node_modules/.bin/.rasha-nDII0s2I',
      1035 silly reify   '/opt/iobroker/node_modules/request/node_modules/asynckit': '/opt/iobroker/node_modules/request/node_modules/.asynckit-den44mpn',
      1035 silly reify   '/opt/iobroker/node_modules/request/node_modules/combined-stream': '/opt/iobroker/node_modules/request/node_modules/.combined-stream-ReeUam7h',
      1035 silly reify   '/opt/iobroker/node_modules/request/node_modules/delayed-stream': '/opt/iobroker/node_modules/request/node_modules/.delayed-stream-t2S4U7oX',
      1035 silly reify   '/opt/iobroker/node_modules/request/node_modules/form-data': '/opt/iobroker/node_modules/request/node_modules/.form-data-f3gZCQps',
      1035 silly reify   '/opt/iobroker/node_modules/request/node_modules/mime-db': '/opt/iobroker/node_modules/request/node_modules/.mime-db-4Xm616Mo',
      1035 silly reify   '/opt/iobroker/node_modules/request/node_modules/mime-types': '/opt/iobroker/node_modules/request/node_modules/.mime-types-AeQyADCM',
      1035 silly reify   '/opt/iobroker/node_modules/request/node_modules/qs': '/opt/iobroker/node_modules/request/node_modules/.qs-dcdEU87b',
      1035 silly reify   '/opt/iobroker/node_modules/request/node_modules/uuid': '/opt/iobroker/node_modules/request/node_modules/.uuid-jkLo7REU',
      1035 silly reify   '/opt/iobroker/node_modules/rsa-compat': '/opt/iobroker/node_modules/.rsa-compat-Y41rnGV4',
      1035 silly reify   '/opt/iobroker/node_modules/.bin/rsa-keygen-js': '/opt/iobroker/node_modules/.bin/.rsa-keygen-js-0hwD4ZwC',
      1035 silly reify   '/opt/iobroker/node_modules/semver': '/opt/iobroker/node_modules/.semver-n8m5lQuN',
      1035 silly reify   '/opt/iobroker/node_modules/.bin/semver': '/opt/iobroker/node_modules/.bin/.semver-LPDaIsIH',
      1035 silly reify   '/opt/iobroker/node_modules/serialport/node_modules/ms': '/opt/iobroker/node_modules/serialport/node_modules/.ms-KxSQYshc',
      1035 silly reify   '/opt/iobroker/node_modules/streamx': '/opt/iobroker/node_modules/.streamx-D5pjfJfJ',
      1035 silly reify   '/opt/iobroker/node_modules/tr46': '/opt/iobroker/node_modules/.tr46-YjyqY81U',
      1035 silly reify   '/opt/iobroker/node_modules/webidl-conversions': '/opt/iobroker/node_modules/.webidl-conversions-dJIVq13g',
      1035 silly reify   '/opt/iobroker/node_modules/decompress-response/node_modules/mimic-response': '/opt/iobroker/node_modules/decompress-response/node_modules/.mimic-response-dSRxVlZr',
      1035 silly reify   '/opt/iobroker/node_modules/@googleapis/drive/node_modules/agent-base': '/opt/iobroker/node_modules/@googleapis/drive/node_modules/.agent-base-ww7ISf3a',
      1035 silly reify   '/opt/iobroker/node_modules/@googleapis/drive/node_modules/debug': '/opt/iobroker/node_modules/@googleapis/drive/node_modules/.debug-8FttNnY8',
      1035 silly reify   '/opt/iobroker/node_modules/@googleapis/drive/node_modules/extend': '/opt/iobroker/node_modules/@googleapis/drive/node_modules/.extend-pHCXN2hV',
      1035 silly reify   '/opt/iobroker/node_modules/@googleapis/drive/node_modules/gaxios': '/opt/iobroker/node_modules/@googleapis/drive/node_modules/.gaxios-ntzysOUB',
      1035 silly reify   '/opt/iobroker/node_modules/@googleapis/drive/node_modules/https-proxy-agent': '/opt/iobroker/node_modules/@googleapis/drive/node_modules/.https-proxy-agent-9v9w60j3',
      1035 silly reify   '/opt/iobroker/node_modules/@googleapis/drive/node_modules/is-stream': '/opt/iobroker/node_modules/@googleapis/drive/node_modules/.is-stream-ufTZ37if',
      1035 silly reify   '/opt/iobroker/node_modules/@googleapis/drive/node_modules/node-fetch': '/opt/iobroker/node_modules/@googleapis/drive/node_modules/.node-fetch-Z5Pms4Cf',
      1035 silly reify   '/opt/iobroker/node_modules/@googleapis/drive/node_modules/qs': '/opt/iobroker/node_modules/@googleapis/drive/node_modules/.qs-VcwhwUhj',
      1035 silly reify   '/opt/iobroker/node_modules/@googleapis/drive/node_modules/url-template': '/opt/iobroker/node_modules/@googleapis/drive/node_modules/.url-template-X3XcX8po',
      1035 silly reify   '/opt/iobroker/node_modules/@googleapis/drive/node_modules/uuid': '/opt/iobroker/node_modules/@googleapis/drive/node_modules/.uuid-YjMWpt3h',
      1035 silly reify   '/opt/iobroker/node_modules/@googleapis/drive/node_modules/whatwg-url': '/opt/iobroker/node_modules/@googleapis/drive/node_modules/.whatwg-url-ocZOyB0D',
      1035 silly reify   '/opt/iobroker/node_modules/@googleapis/drive/node_modules/ms': '/opt/iobroker/node_modules/@googleapis/drive/node_modules/.ms-36uPP8sv',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-objects-file/node_modules/respjs': '/opt/iobroker/node_modules/@iobroker/db-objects-file/node_modules/.respjs-voA09GuD',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-objects-jsonl/node_modules/debug': '/opt/iobroker/node_modules/@iobroker/db-objects-jsonl/node_modules/.debug-U3fQ9zGT',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-objects-jsonl/node_modules/graceful-fs': '/opt/iobroker/node_modules/@iobroker/db-objects-jsonl/node_modules/.graceful-fs-7qoqAiII',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-objects-jsonl/node_modules/jsonfile': '/opt/iobroker/node_modules/@iobroker/db-objects-jsonl/node_modules/.jsonfile-I9AV9cGI',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-objects-jsonl/node_modules/ms': '/opt/iobroker/node_modules/@iobroker/db-objects-jsonl/node_modules/.ms-Y9xqPwFo',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-objects-jsonl/node_modules/respjs': '/opt/iobroker/node_modules/@iobroker/db-objects-jsonl/node_modules/.respjs-HuEKe8zJ',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-objects-jsonl/node_modules/universalify': '/opt/iobroker/node_modules/@iobroker/db-objects-jsonl/node_modules/.universalify-WyLg4ZAk',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-objects-jsonl/node_modules/@alcalzone/jsonl-db/node_modules/fs-extra': '/opt/iobroker/node_modules/@iobroker/db-objects-jsonl/node_modules/@alcalzone/jsonl-db/node_modules/.fs-extra-hoCGk0Y6',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-objects-redis/node_modules/cluster-key-slot': '/opt/iobroker/node_modules/@iobroker/db-objects-redis/node_modules/.cluster-key-slot-RpsjwIys',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-objects-redis/node_modules/debug': '/opt/iobroker/node_modules/@iobroker/db-objects-redis/node_modules/.debug-vck1otRu',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-objects-redis/node_modules/mime-db': '/opt/iobroker/node_modules/@iobroker/db-objects-redis/node_modules/.mime-db-RXnRzT6m',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-objects-redis/node_modules/ms': '/opt/iobroker/node_modules/@iobroker/db-objects-redis/node_modules/.ms-xQUFixY5',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-objects-redis/node_modules/redis-commands': '/opt/iobroker/node_modules/@iobroker/db-objects-redis/node_modules/.redis-commands-2ipHMTd9',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-objects-redis/node_modules/redis-errors': '/opt/iobroker/node_modules/@iobroker/db-objects-redis/node_modules/.redis-errors-sRhVjOzV',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-objects-redis/node_modules/respjs': '/opt/iobroker/node_modules/@iobroker/db-objects-redis/node_modules/.respjs-4WiJNzFF',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-objects-redis/node_modules/@iobroker/db-base': '/opt/iobroker/node_modules/@iobroker/db-objects-redis/node_modules/@iobroker/.db-base-jFr6SRfA',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-states-file/node_modules/respjs': '/opt/iobroker/node_modules/@iobroker/db-states-file/node_modules/.respjs-W4wJyj08',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-states-file/node_modules/@iobroker/db-base': '/opt/iobroker/node_modules/@iobroker/db-states-file/node_modules/@iobroker/.db-base-akrW0tLn',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-states-jsonl/node_modules/debug': '/opt/iobroker/node_modules/@iobroker/db-states-jsonl/node_modules/.debug-af1kn7cb',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-states-jsonl/node_modules/graceful-fs': '/opt/iobroker/node_modules/@iobroker/db-states-jsonl/node_modules/.graceful-fs-9LmKGw8Y',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-states-jsonl/node_modules/jsonfile': '/opt/iobroker/node_modules/@iobroker/db-states-jsonl/node_modules/.jsonfile-fnpfpkLi',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-states-jsonl/node_modules/ms': '/opt/iobroker/node_modules/@iobroker/db-states-jsonl/node_modules/.ms-5PZZnVzx',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-states-jsonl/node_modules/respjs': '/opt/iobroker/node_modules/@iobroker/db-states-jsonl/node_modules/.respjs-IxZow2XY',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-states-jsonl/node_modules/universalify': '/opt/iobroker/node_modules/@iobroker/db-states-jsonl/node_modules/.universalify-c4Kb6dgR',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-states-jsonl/node_modules/@iobroker/db-base': '/opt/iobroker/node_modules/@iobroker/db-states-jsonl/node_modules/@iobroker/.db-base-P9UnILAJ',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-states-redis/node_modules/cluster-key-slot': '/opt/iobroker/node_modules/@iobroker/db-states-redis/node_modules/.cluster-key-slot-RUYLP1oe',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-states-redis/node_modules/debug': '/opt/iobroker/node_modules/@iobroker/db-states-redis/node_modules/.debug-2AL7TxhI',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-states-redis/node_modules/ioredis': '/opt/iobroker/node_modules/@iobroker/db-states-redis/node_modules/.ioredis-bauDiWPJ',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-states-redis/node_modules/ms': '/opt/iobroker/node_modules/@iobroker/db-states-redis/node_modules/.ms-dchBoQ1r',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-states-redis/node_modules/redis-commands': '/opt/iobroker/node_modules/@iobroker/db-states-redis/node_modules/.redis-commands-139B2pdl',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-states-redis/node_modules/redis-errors': '/opt/iobroker/node_modules/@iobroker/db-states-redis/node_modules/.redis-errors-CxHYgb1I',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-states-redis/node_modules/respjs': '/opt/iobroker/node_modules/@iobroker/db-states-redis/node_modules/.respjs-lzeSv4E5',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/db-states-redis/node_modules/@iobroker/db-base': '/opt/iobroker/node_modules/@iobroker/db-states-redis/node_modules/@iobroker/.db-base-ZYXhiDBx',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-cli/node_modules/fsevents': '/opt/iobroker/node_modules/@iobroker/js-controller-cli/node_modules/.fsevents-bNc8HnGE',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-cli/node_modules/debug': '/opt/iobroker/node_modules/@iobroker/js-controller-cli/node_modules/.debug-PujdK3GO',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-cli/node_modules/mime-db': '/opt/iobroker/node_modules/@iobroker/js-controller-cli/node_modules/.mime-db-qZ71uT0G',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-cli/node_modules/mime-types': '/opt/iobroker/node_modules/@iobroker/js-controller-cli/node_modules/.mime-types-jXYYnQsa',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-cli/node_modules/ms': '/opt/iobroker/node_modules/@iobroker/js-controller-cli/node_modules/.ms-RZpfocaN',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-common-db/node_modules/inherits': '/opt/iobroker/node_modules/@iobroker/js-controller-common-db/node_modules/.inherits-duHeIwUH',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-common-db/node_modules/is-stream': '/opt/iobroker/node_modules/@iobroker/js-controller-common-db/node_modules/.is-stream-gQI98qof',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/follow-redirects': '/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/.follow-redirects-4rbjR1Ae',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/graceful-fs': '/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/.graceful-fs-bgYLG1We',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/inherits': '/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/.inherits-uwoJB4nI',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/is-stream': '/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/.is-stream-KrVINJgo',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/jsonfile': '/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/.jsonfile-NdF2kHj3',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/universalify': '/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/.universalify-KPWE5L8g',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/which': '/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/.which-5FtWIHNL',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/.bin/node-which': '/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/.bin/.node-which-ukJT5zci',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/plugin-sentry/node_modules/localforage': '/opt/iobroker/node_modules/@iobroker/plugin-sentry/node_modules/.localforage-CjETxd2L',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/plugin-sentry/node_modules/cookie': '/opt/iobroker/node_modules/@iobroker/plugin-sentry/node_modules/.cookie-XMG2B8UV',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/plugin-sentry/node_modules/debug': '/opt/iobroker/node_modules/@iobroker/plugin-sentry/node_modules/.debug-nNYbzpX7',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/plugin-sentry/node_modules/lie': '/opt/iobroker/node_modules/@iobroker/plugin-sentry/node_modules/.lie-5MQAd981',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/plugin-sentry/node_modules/ms': '/opt/iobroker/node_modules/@iobroker/plugin-sentry/node_modules/.ms-2PClC4TJ',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/@iobroker/types': '/opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/@iobroker/.types-vY08Xq5c',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/follow-redirects': '/opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/.follow-redirects-nprH6U6s',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/graceful-fs': '/opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/.graceful-fs-E88jRv8n',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/is-stream': '/opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/.is-stream-29FJB45k',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/jsonfile': '/opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/.jsonfile-ElBOt5x2',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/universalify': '/opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/.universalify-6YeCArh8',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/which': '/opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/.which-l8AiQbqc',
      1035 silly reify   '/opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/.bin/node-which': '/opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/.bin/.node-which-Sa9Yxm3p',
      1035 silly reify   '/opt/iobroker/node_modules/sshpk': '/opt/iobroker/node_modules/.sshpk-cCL4zyMp',
      1035 silly reify   '/opt/iobroker/node_modules/.bin/sshpk-conv': '/opt/iobroker/node_modules/.bin/.sshpk-conv-10TbNdNs',
      1035 silly reify   '/opt/iobroker/node_modules/.bin/sshpk-sign': '/opt/iobroker/node_modules/.bin/.sshpk-sign-iDI0Q2jB',
      1035 silly reify   '/opt/iobroker/node_modules/.bin/sshpk-verify': '/opt/iobroker/node_modules/.bin/.sshpk-verify-Vb7nRdrF'
      1035 silly reify }
      1036 timing reify:rollback:retireShallow Completed in 84ms
      1037 timing command:i Completed in 67149ms
      1038 verbose stack Error: ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.discovery' -> '/opt/iobroker/node_modules/.iobroker.discovery-Domn1CAP'
      1039 verbose cwd /opt/iobroker
      1040 verbose Linux 5.4.189-2-pve
      1041 verbose node v18.17.1
      1042 verbose npm  v9.6.7
      1043 error code ENOTEMPTY
      1044 error syscall rename
      1045 error path /opt/iobroker/node_modules/iobroker.discovery
      1046 error dest /opt/iobroker/node_modules/.iobroker.discovery-Domn1CAP
      1047 error errno -39
      1048 error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.discovery' -> '/opt/iobroker/node_modules/.iobroker.discovery-Domn1CAP'
      1049 verbose exit -39
      1050 timing npm Completed in 67506ms
      1051 verbose unfinished npm timer reify 1696877847040
      1052 verbose unfinished npm timer reify:retireShallow 1696877913958
      1053 verbose code -39
      Kann jemand helfen?
      Thomas Braun Glasfaser amg_666 5 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Drillo123 last edited by Thomas Braun
        @drillo123 sagte in Installation unter Debian 10 bricht ab:
        DEBIAN 10
        Ist tot, nimm ein Debian 12 'Bookworm'.
        Und auch in Debian 10 springt man nicht als root umher.
        Edit: Wobe du da Debian 11 'Bullseye' am Wickel hast...
        • Glasfaser
          Glasfaser @Drillo123 last edited by Glasfaser
          (unter Proxmox)
          root@
          Kann jemand helfen?
          USER anmelden !! nicht als ROOT
          • amg_666
            amg_666 @Drillo123 last edited by
            Das ist jetzt keine Antwort auf deine Frage, aber WARUM Debian10? Geh auf 12 (Bookworm), die 10er läuft aus (nächstes Jahr eol)
              Kann jemand helfen?
              Versuchst du eine bereits bestehende Installation nochmal drüber zu installieren?
                Thomas Braun Most Active @amg_666 last edited by
                @amg_666 sagte in Installation unter Debian 10 bricht ab:
                Debian 10 ist schon tot, aber 11 läuft nächstes Jahr auch aus.
                amg_666 1 Reply Last reply Reply Quote 0
                • Glasfaser
                  Glasfaser @Thomas Braun last edited by Glasfaser
                  Bestimmt wegen dieses ... habe ich auch gerade gesehn
                  rename ... usw.
                  • amg_666
                    amg_666 @Thomas Braun last edited by
                    @thomas-braun ich meinte den long-term support, dann ist es endgültig tot
                      @drillo123
                      Noch da?
                      User angelegt?
                      Siehe:
                      https://www.iobroker.net/#de/documentation/install/proxmox.md
                        Drillo123 @Thomas Braun last edited by
                        @thomas-braun Schau ich mir gleich mal an. Ich sage erstmal schon vielen Dank für euer Feedback!
                        184
