    4. (erledigt) Zigbee Adapter startet nicht
      hm_krause last edited by hm_krause
      Ich will auf einem Raspi 2 (als Slave) nur den Zigbee Adapter laufen lassen. Leider startet dieser nicht.
      pi@raspberrypi2:~ $ ls -l /dev/serial/by-id
      total 0
      lrwxrwxrwx 1 root root 13 Oct 12 17:17 usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2433967-if00 -> ../../ttyACM0
      Einstellung:
      Log:
      host.raspberrypi2
      	2023-10-12 18:06:52.252	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      zigbee.0
      	2023-10-12 18:06:51.176	error	Cannot read properties of undefined (reading 'getDevice')
      zigbee.0
      	2023-10-12 18:06:51.173	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
      zigbee.0
      	2023-10-12 18:06:51.171	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
      zigbee.0
      	2023-10-12 18:06:51.168	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      zigbee.0
      	2023-10-12 18:06:51.157	error	Cannot read properties of undefined (reading 'getDevice')
      zigbee.0
      	2023-10-12 18:06:51.153	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
      zigbee.0
      	2023-10-12 18:06:51.137	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
      zigbee.0
      	2023-10-12 18:06:51.130	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      host.raspberrypi2
      	2023-10-12 18:06:33.582	info	instance system.adapter.zigbee.0 started with pid 811
      host.raspberrypi2
      	2023-10-12 18:06:02.935	info	Restart adapter system.adapter.zigbee.0 because enabled
      host.raspberrypi2
      	2023-10-12 18:06:02.932	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      zigbee.0
      	2023-10-12 18:06:01.934	error	Cannot read properties of undefined (reading 'getDevice')
      zigbee.0
      	2023-10-12 18:06:01.932	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
      zigbee.0
      	2023-10-12 18:06:01.928	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
      zigbee.0
      	2023-10-12 18:06:01.925	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      zigbee.0
      	2023-10-12 18:06:01.913	error	Cannot read properties of undefined (reading 'getDevice')
      zigbee.0
      	2023-10-12 18:06:01.908	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
      zigbee.0
      	2023-10-12 18:06:01.889	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
      zigbee.0
      	2023-10-12 18:06:01.879	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      Was ist hier falsch, welche Infos werden noch benötigt?
      Thomas Braun ? 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @hm_krause last edited by
        @hm_krause sagte in Zigbee Adapter startet nicht:
        Zeig uns mal einen kompletten Start des Adapters. Bevorzugt via
        iob logs --watch | uniq
          hm_krause @Thomas Braun last edited by
          2023-10-12 19:04:11.759  - info: host.raspberrypi2 "system.adapter.zigbee.0" enabled
          2023-10-12 19:04:12.349  - info: host.raspberrypi2 instance system.adapter.zigbee.0 started with pid 968
          2023-10-12 19:04:29.686  - error: zigbee.0 (968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2023-10-12 19:04:29.693  - error: zigbee.0 (968) unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
          2023-10-12 19:04:29.710  - error: zigbee.0 (968) TypeError: Cannot read properties of undefined (reading 'getDevice')
          2023-10-12 19:04:29.714  - error: zigbee.0 (968) Cannot read properties of undefined (reading 'getDevice')
          2023-10-12 19:04:33.394  - error: host.raspberrypi2 instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          2023-10-12 19:04:33.397  - info: host.raspberrypi2 Restart adapter system.adapter.zigbee.0 because enabled
          ^C
          ...hoffe das reicht.🙄
            @hm_krause
            Ein richtiger Start schaut so aus:
            2023-10-12 19:22:32.152  - info: zigbee.0 (68120) Got terminate signal TERMINATE_YOURSELF
            2023-10-12 19:22:32.154  - info: zigbee.0 (68120) cleaned everything up...
            2023-10-12 19:22:32.157  - info: zigbee.0 (68120) Zigbee: disabling joining new devices.
            2023-10-12 19:22:32.655  - info: zigbee.0 (68120) terminating
            2023-10-12 19:22:32.664  - info: zigbee.0 (68120) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2023-10-12 19:23:07.364  - info: zigbee.0 (68952) starting. Version 1.8.24 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.8.0, js-controller: 5.0.13
            2023-10-12 19:23:07.532  - info: zigbee.0 (68952) delete old Backup files. keep only last 10
            2023-10-12 19:23:07.535  - info: zigbee.0 (68952) Starting Zigbee  npm ...
            2023-10-12 19:23:07.969  - info: zigbee.0 (68952) Installed Version: iobroker.zigbee@1.8.24
            2023-10-12 19:23:19.816  - info: zigbee.0 (68952) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}}
            2023-10-12 19:23:19.828  - info: zigbee.0 (68952) Unable to disable LED, unsupported function.
            2023-10-12 19:23:19.847  - info: zigbee.0 (68952)   --> transmitPower : normal
            Die Instanz ausschalten und nach einiger Zeit frisch starten.
              @thomas-braun sagte in Zigbee Adapter startet nicht:
              Das hilft aber nicht...
              host.raspberrypi2
              	2023-10-12 19:32:24.742	info	"system.adapter.zigbee.0" disabled
              host.raspberrypi2
              	2023-10-12 19:32:03.015	info	Restart adapter system.adapter.zigbee.0 because enabled
              host.raspberrypi2
              	2023-10-12 19:32:03.012	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
              zigbee.0
              	2023-10-12 19:32:01.525	error	Cannot read properties of undefined (reading 'getDevice')
              zigbee.0
              	2023-10-12 19:32:01.523	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
              zigbee.0
              	2023-10-12 19:32:01.520	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
              zigbee.0
              	2023-10-12 19:32:01.518	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              zigbee.0
              	2023-10-12 19:32:00.965	error	Cannot read properties of undefined (reading 'getDevice')
              zigbee.0
              	2023-10-12 19:32:00.960	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
              zigbee.0
              	2023-10-12 19:32:00.943	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
              zigbee.0
              	2023-10-12 19:32:00.936	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              host.raspberrypi2
              	2023-10-12 19:31:43.336	info	instance system.adapter.zigbee.0 started with pid 1109
              host.raspberrypi2
              	2023-10-12 19:31:42.910	info	"system.adapter.zigbee.0" enabled
                arteck Developer Most Active @hm_krause last edited by
                @hm_krause installier mal von GIT
                https://github.com/ioBroker/ioBroker.zigbee
                der sollte jetzt an der stelle ne Fehlermeldung liefern
                  hm_krause @arteck last edited by
                  @arteck
                  Bringt folgendes:
                  zigbee.0
                  	2023-10-13 13:27:58.858	error	adapter disabled
                  host.raspberrypi2
                  	2023-10-13 13:27:20.259	info	"system.adapter.zigbee.0" disabled
                  host.raspberrypi2
                  	2023-10-13 13:27:14.281	info	Restart adapter system.adapter.zigbee.0 because enabled
                  host.raspberrypi2
                  	2023-10-13 13:27:14.278	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                  zigbee.0
                  	2023-10-13 13:27:12.854	error	Cannot read properties of undefined (reading 'getDevice')
                  zigbee.0
                  	2023-10-13 13:27:12.851	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
                  zigbee.0
                  	2023-10-13 13:27:12.849	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
                  zigbee.0
                  	2023-10-13 13:27:12.846	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  zigbee.0
                  	2023-10-13 13:27:12.836	error	Cannot read properties of undefined (reading 'getDevice')
                  zigbee.0
                  	2023-10-13 13:27:12.833	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
                  zigbee.0
                  	2023-10-13 13:27:12.816	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
                  zigbee.0
                  	2023-10-13 13:27:12.809	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  host.raspberrypi2
                  	2023-10-13 13:26:54.200	info	instance system.adapter.zigbee.0 started with pid 3125
                  host.raspberrypi2
                  	2023-10-13 13:26:23.752	info	Restart adapter system.adapter.zigbee.0 because enabled
                  host.raspberrypi2
                  	2023-10-13 13:26:23.749	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                  zigbee.0
                  	2023-10-13 13:26:22.299	error	this.zbController.getGroup is not a function
                  zigbee.0
                  	2023-10-13 13:26:22.297	error	TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
                  zigbee.0
                  	2023-10-13 13:26:22.279	error	unhandled promise rejection: this.zbController.getGroup is not a function
                  zigbee.0
                  	2023-10-13 13:26:22.273	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  host.raspberrypi2
                  	2023-10-13 13:26:02.219	info	instance system.adapter.zigbee.0 started with pid 3106
                  host.raspberrypi2
                  	2023-10-13 13:26:01.709	info	"system.adapter.zigbee.0" enabled
                    A Former User @hm_krause last edited by
                    Moin,
                    zeig doch mal den langen Output von
                    # iob diag
                    Vielleicht ist ja was an der Grundinstallation krum!
                    VG
                    Bernd
                      hm_krause @Guest last edited by
                      @dp20eic
                      Bitte schön
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                         Static hostname: raspberrypi2
                               Icon name: computer
                                  Kernel: Linux 6.1.21-v7+
                            Architecture: arm
                      Model           : Raspberry Pi 2 Model B Rev 1.1
                      Docker          : false
                      Virtualization  : none
                      Kernel          : armv7l
                      Userland        : armhf
                      Systemuptime and Load:
                       17:45:09 up 23:50,  1 user,  load average: 0.23, 0.07, 0.02
                      CPU threads: 4
                      *** RASPBERRY THROTTLING ***
                      Current issues:
                      Previously detected issues:
                      *** Time and Time Zones ***
                                     Local time: Fri 2023-10-13 17:45:09 CEST
                                 Universal time: Fri 2023-10-13 15:45:09 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      *** User and Groups ***
                      pi
                      /home/pi
                      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                      *** X-Server-Setup ***
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            921M        236M        409M        0.0K        276M        628M
                      Swap:            99M          0B         99M
                      Total:          1.0G        236M        509M
                                921 M total memory
                                236 M used memory
                                174 M active memory
                                276 M inactive memory
                                409 M free memory
                                 54 M buffer memory
                                221 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FAILED SERVICES ***
                      0 loaded units listed.
                      *** FILESYSTEM ***
                      /dev/root      ext4       15G  3.4G   11G  25% /
                      devtmpfs       devtmpfs  333M     0  333M   0% /dev
                      tmpfs          tmpfs     461M     0  461M   0% /dev/shm
                      tmpfs          tmpfs     185M  948K  184M   1% /run
                      /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
                      tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
                      [Thu Oct 12 17:54:32 2023] Kernel command line: coherent_pool=1M snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=984cb146-02 rootfstype=ext4 fsck.repair=yes rootwait
                      [Thu Oct 12 17:54:36 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                      [Thu Oct 12 17:54:36 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                      [Thu Oct 12 17:54:37 2023] EXT4-fs (mmcblk0p2): recovery complete
                      [Thu Oct 12 17:54:37 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                      [Thu Oct 12 17:54:37 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                      [Thu Oct 12 17:54:41 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                      TARGET  SOURCE         FSTYPE OPTIONS
                      /       /dev/mmcblk0p2 ext4   rw,noatime
                      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                      /var:
                      894M    /var/
                      574M    /var/log
                      417M    /var/log/journal/d396ac506ad544c8953772923028cd1b
                      120M    /var/cache
                      Archived and active journals take up 416.0M in the file system.
                      /opt/iobroker/backups:
                      2.4M    /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      103M    /opt/iobroker/iobroker-data/
                      74M     /opt/iobroker/iobroker-data/files
                      52M     /opt/iobroker/iobroker-data/files/javascript.admin
                      34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                      33M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                      7.8M    /opt/iobroker/iobroker-data/objects.jsonl
                      7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
                      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                      5.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/550.cfbef968.chunk.js.map
                      4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
                      USB-Devices by-id:
                      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2433967-if00
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v18.18.1
                      /usr/bin/node           v18.18.1
                      /usr/bin/npm            9.8.1
                      /usr/bin/npx            9.8.1
                      /usr/bin/corepack       0.19.0
                      nodejs:
                        Installed: 18.18.1-1nodesource1
                        Candidate: 18.18.1-1nodesource1
                        Version table:
                       *** 18.18.1-1nodesource1 1001
                              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                              100 /var/lib/dpkg/status
                           18.18.0-1nodesource1 1001
                           18.17.1-1nodesource1 1001
                           18.17.0-1nodesource1 1001
                           18.16.1-1nodesource1 1001
                           18.16.0-1nodesource1 1001
                           18.15.0-1nodesource1 1001
                           18.14.2-1nodesource1 1001
                           18.14.1-1nodesource1 1001
                           18.14.0-1nodesource1 1001
                           18.13.0-1nodesource1 1001
                           18.12.0-1nodesource1 1001
                           18.11.0-1nodesource1 1001
                           18.10.0-1nodesource1 1001
                           18.9.1-1nodesource1 1001
                           18.9.0-1nodesource1 1001
                           18.8.0-1nodesource1 1001
                           18.7.0-1nodesource1 1001
                           18.6.0-1nodesource1 1001
                           18.5.0-1nodesource1 1001
                           18.4.0-1nodesource1 1001
                           18.3.0-1nodesource1 1001
                           18.2.0-1nodesource1 1001
                           18.1.0-1nodesource1 1001
                           18.0.0-1nodesource1 1001
                           12.22.12~dfsg-1~deb11u4 500
                      No problems detected
                      Errors in npm tree:
                      *** ioBroker-Installation ***
                      ioBroker Status
                      At least one iobroker host is running.
                      Objects type: file
                      States  type: file
                      Core adapters versions
                      js-controller:  5.0.12
                      admin:          6.10.1
                      javascript:     7.1.4
                      Adapters from github:   0
                      Adapter State
                      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.4, run as: admin
                        system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled
                        system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
                      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                      + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
                      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                      + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
                      + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
                      + system.adapter.energiefluss.1           : energiefluss          : iobroker                                 -  enabled
                      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                        system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
                      + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
                      + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 -  enabled
                      + system.adapter.heizoel.0                : heizoel               : iobroker                                 -  enabled
                      + system.adapter.history.0                : history               : iobroker                                 -  enabled
                      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 8701
                        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                        system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
                        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
                        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
                      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                      + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
                      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                      + system.adapter.javascript.1             : javascript            : raspberrypi2                             -  enabled
                      + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
                      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.4
                      + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                      + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                      + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
                      + system.adapter.openligadb.0             : openligadb            : iobroker                                 -  enabled
                        system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                      + system.adapter.operating-hours.0        : operating-hours       : iobroker                                 -  enabled
                      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                      + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                      + system.adapter.resol.0                  : resol                 : iobroker                                 -  enabled
                      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.4
                      + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
                      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
                      + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                        system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
                      + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                      + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                      + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
                        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
                        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
                        system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
                      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
                        system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                        system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
                        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        system.adapter.zigbee.0                 : zigbee                : raspberrypi2                             - disabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2433967-if00
                      + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 -  enabled
                      + instance is alive
                      ioBroker-Repositories
                      Active repo(s): stable
                      Installed ioBroker-Instances
                      Used repository: stable
                      Adapter    "admin"        : 6.10.1   , installed 6.10.1
                      Adapter    "backitup"     : 2.8.1    , installed 2.6.23 [Updatable]
                      Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                      Controller "js-controller": 5.0.12   , installed 5.0.12
                      Adapter    "tuya"         : 3.14.2   , installed 3.14.2
                      Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
                      Objects and States
                      Objects:        22288
                      States:         19027
                      Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
                      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                      Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                      Reading package lists...
                      Pending Updates: 5
                      *** Listening Ports ***
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13985      437/sshd: /usr/sbin
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          13987      437/sshd: /usr/sbin
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1712       536/dhcpcd
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13885      328/avahi-daemon: r
                      udp        0      0 0.0.0.0:46530           0.0.0.0:*                           108        13887      328/avahi-daemon: r
                      udp6       0      0 :::53325                :::*                                108        13888      328/avahi-daemon: r
                      udp6       0      0 :::5353                 :::*                                108        13886      328/avahi-daemon: r
                      2023-10-13 13:48:53.686  - error: zigbee.0 (3202) Cannot read properties of undefined (reading 'getDevice')
                      2023-10-13 13:48:53.698  - error: zigbee.0 (3202) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2023-10-13 13:48:53.700  - error: zigbee.0 (3202) unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
                      2023-10-13 13:48:53.703  - error: zigbee.0 (3202) TypeError: Cannot read properties of undefined (reading 'getDevice')
                      2023-10-13 13:48:53.705  - error: zigbee.0 (3202) Cannot read properties of undefined (reading 'getDevice')
                      2023-10-13 13:48:55.306  - error: host.raspberrypi2 instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      2023-10-13 13:48:55.308  - info: host.raspberrypi2 Restart adapter system.adapter.zigbee.0 because enabled
                      2023-10-13 13:49:01.630  - info: host.raspberrypi2 "system.adapter.zigbee.0" disabled
                      2023-10-13 13:49:42.820  - error: zigbee.0 (3218) adapter disabled
                      2023-10-13 13:49:43.820  - error: host.raspberrypi2 instance system.adapter.zigbee.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
                      2023-10-13 13:49:43.823  - info: host.raspberrypi2 Do not restart adapter system.adapter.zigbee.0 because disabled or deleted
                      2023-10-13 16:03:53.346  - error: host.raspberrypi2 Objects database error: read ECONNRESET
                      2023-10-13 16:03:53.345  - error: javascript.1 (550) Objects database error: read ECONNRESET
                      2023-10-13 16:03:58.380  - error: host.raspberrypi2 Objects database error: connect ECONNREFUSED 192.168.178.4:9001
                      2023-10-13 16:03:58.424  - error: javascript.1 (550) Objects database error: connect ECONNREFUSED 192.168.178.4:9001
                      2023-10-13 16:04:00.227  - error: host.raspberrypi2 States database error: read ECONNRESET
                      2023-10-13 16:04:01.512  - error: javascript.1 (550) States database error: read ECONNRESET
                      2023-10-13 16:04:03.397  - info: host.raspberrypi2 Objects database successfully reconnected
                      2023-10-13 16:04:05.240  - info: host.raspberrypi2 Objects database successfully reconnected
                      iob diag has finished.
                        Bitte schön
                        Moin,
                        ist das eine Master/Slave Installation?
                        Auch das wäre dann schon am Anfang von Interesse gewesen!
                        Du hast auf dem RasPI-2 noch Deconz installiert, kann das sein, dass sich das mit dem Zigbee - Adapter beißt?
                        VG
                        Bernd
                          @dp20eic sagte in Zigbee Adapter startet nicht:
                          Bitte schön
                          Moin,
                          ...Stand im 1. Beitrag und Deconz ist deinstalliert
                            Moin,
                            ok, das kleine geklammerte Slave habe ich überlesen.
                            Aber dekonz wird mir doch in der Liste des RasPI-2 aufgelistet
                            Adapter    "deconz"       : 1.3.21   , installed 1.3.21                      <------
                            VG
                            Bernd
                              @dp20eic
                              Deconz ist aber weder in der Instanz noch im Adapter zu sehen.
                              pi@raspberrypi2:~ $ sudo systemctl status deconz
                              Unit deconz.service could not be found.
                              pi@raspberrypi2:~ $
                                A Former User @hm_krause last edited by A Former User
                                Moin,
                                kenne mich mit Master/Slave nicht wirklich aus, gerade wenn auch mal umgeschaltet wurde und dann Adapter installiert, oder deinstalliert werden.
                                Da müssen andere helfen, da stocher ich nur im Trüben.
                                Wenn das nicht zu viel Arbeit ist, würde ich den ganz neu von vorne aufsetzen.
                                VG
                                Bernd
                                P.S.: sehe gerade, Du suchst den Service, ich schrieb vom Adapter im ioBroker
                                  @dp20eic
                                  Werde alles nochmal neu machen, Danke
                                    hm_krause @hm_krause last edited by
                                    @hm_krause
                                    Läuft noch nicht.
                                    Master als VM auf Proxmox
                                    Slave komplett neu auf Raspi 4.
                                    Wenn ich mit der Maus auf dem roten Kreis bin zeigt eine Verbindung mit Gerät oder Dienst an (grün)
                                    Die beiden anderen, Verbunden mit Host und Lebensszeichen, bleiben rot
                                    host.iob-oben
                                    	2023-10-15 14:51:25.836	warn	Do not restart adapter system.adapter.zigbee.0 because restart loop detected
                                    host.iob-oben
                                    	2023-10-15 14:51:25.836	info	Restart adapter system.adapter.zigbee.0 because enabled
                                    host.iob-oben
                                    	2023-10-15 14:51:25.835	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                    zigbee.0
                                    	2023-10-15 14:51:24.417	error	this.zbController.getGroup is not a function
                                    zigbee.0
                                    	2023-10-15 14:51:24.416	error	TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
                                    zigbee.0
                                    	2023-10-15 14:51:24.413	error	unhandled promise rejection: this.zbController.getGroup is not a function
                                    zigbee.0
                                    	2023-10-15 14:51:24.411	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    host.iob-oben
                                    	2023-10-15 14:51:16.312	info	instance system.adapter.zigbee.0 started with pid 1125
                                    host.iob-oben
                                    	2023-10-15 14:50:45.849	info	Restart adapter system.adapter.zigbee.0 because enabled
                                    host.iob-oben
                                    	2023-10-15 14:50:45.848	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                    zigbee.0
                                    	2023-10-15 14:50:44.412	error	this.zbController.getGroup is not a function
                                    zigbee.0
                                    	2023-10-15 14:50:44.411	error	TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
                                    zigbee.0
                                    	2023-10-15 14:50:44.408	error	unhandled promise rejection: this.zbController.getGroup is not a function
                                    zigbee.0
                                    	2023-10-15 14:50:44.406	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    host.iob-oben
                                    	2023-10-15 14:50:37.187	info	instance system.adapter.zigbee.0 started with pid 1109
                                    host.iob-oben
                                    	2023-10-15 14:50:06.660	info	Restart adapter system.adapter.zigbee.0 because enabled
                                    host.iob-oben
                                    	2023-10-15 14:50:06.659	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                    zigbee.0
                                    	2023-10-15 14:50:04.658	error	this.zbController.getGroup is not a function
                                    zigbee.0
                                    	2023-10-15 14:50:04.657	error	TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
                                    zigbee.0
                                    	2023-10-15 14:50:04.654	error	unhandled promise rejection: this.zbController.getGroup is not a function
                                    zigbee.0
                                    	2023-10-15 14:50:04.652	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    host.iob-oben
                                    	2023-10-15 14:49:56.318	info	instance system.adapter.zigbee.0 started with pid 1092
                                    host.iob-oben
                                    	2023-10-15 14:49:55.849	info	"system.adapter.zigbee.0" enabled
                                    Noch jemand vielleicht eine Idee..?
                                      @hm_krause said in Zigbee Adapter startet nicht:
                                      Moin,
                                      natürlich, vom Slave die lange Ausgabe von
                                      # iob diag
                                      Welche Version vom Zigbe Adapter, vielleicht mal die Github Version getestet?
                                      Schon mal darüber nachgedacht, mittels LAN/WLAN Zigbee Stick zu arbeiten, den kann man besser im Haus positionieren als die, die über USB angeschlossen sind, dann noch gescheite Repeater und man bekommt auch ein stabiles Zigbee Mesh hin.
                                      Network -> https://www.zigbee2mqtt.io/guide/adapters/#recommended
                                         - Tube's Zigbee Gateways (CC2652P2 variant)
                                         - cyijun OpenZ3Gateway
                                         - XGG 52PZ2MGateway
                                         - SMLIGHT Zigbee LAN Adapter CC2652P Model SLZB-05
                                         - cod.m ZigBee CC2652P2 TCP Coordinator
                                      VG
                                      Bernd
                                        @dp20eic
                                        Ich habe jetzt aufgegeben und einen seperaten Iobroker auf den Raspi gebracht.
                                        Der Stick funktioniert tadellos.
                                        1.0k
                                        1038
