    4. Adapter lassen sich nicht mehr updaten
    • theo_tusch
      theo_tusch last edited by Homoran
      ich kann in der Oberfläche keinen Adapter mehr updaten. Ich drücke auf Update, dann gibt es folgende Meldungen und jeder Adapter bleibt auf der gleichen Version.
      Wenn ich auf der Konsole update, sieht es so aus, als ob es keine Fehler gibt, aber die Version bleibt die gleiche.
      Hier mein config:
      root@IoBroker:~# node -v
      v16.20.2
      root@IoBroker:~# nodejs -v
      v16.20.2
      root@IoBroker:~# npm -v
      8.19.4
      root@IoBroker:~#
      root@IoBroker:~# lsb_release -a
      No LSB modules are available.
      Distributor ID: Debian
      Description:    Debian GNU/Linux 9.13 (stretch)
      Release:        9.13
      Codename:       stretch
      Hier der Logeintrag aus dem Fenster:
      $ iobroker upgrade growatt@3.2.1 --debug
      Update growatt from @3.0.1 to @3.2.1
      NPM version: 8.19.4
      Installing iobroker.growatt@3.2.1... (System call)
      npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
      npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
      npm WARN deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
      npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
      npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
      npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
      npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
      npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
      npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/@serialport/bindings
      npm ERR! /home/iobroker/.npm/_logs/2023-10-13T17_54_33_478Z-debug-0.log
      upload [4] growatt.admin /opt/iobroker/node_modules/iobroker.growatt/admin/glogo.png glogo.png image/png
      upload [0] growatt.admin /opt/iobroker/node_modules/iobroker.growatt/admin/words.js words.js application/javascript
      Process exited with code 0
      mikeal created this issue in request/request
      open Request’s Past, Present and Future #3142
        Homoran Global Moderator Administrators @theo_tusch last edited by Homoran
        @theo_tusch sagte in Adapter lassen sich nicht mehr updaten:
        Codename: stretch
        ist nicht dein Ernst!
        das ist debian 9
        wir sind drei Generationen weiter bei debian 12
        und root-Nutzung kann dir alle Rechte zerschießen
        und warum in der englischen Sektion?
        theo_tusch 1 Reply Last reply Reply Quote 0
        • theo_tusch
          theo_tusch @Homoran last edited by
          @homoran was ist deine Empfehlung?
          Bzgl. Debain 9.... Never change a running system 😉
          Wie upgraden ohne Verluste?
          Homoran DJMarc75 Thomas Braun F 4 Replies Last reply Reply Quote 0
            Das hast du nun davon!
            upgrade geht nicht, debian 9 ist nicht mehr verfügbar
            https://wiki.debian.org/LTS/Stretch
            Da hilft nur komplette Neuinstallation, Backup zurückspielen und hoffen
            • DJMarc75
              DJMarc75 @theo_tusch last edited by
                Thomas Braun Most Active @theo_tusch last edited by Thomas Braun
                @theo_tusch
                Und auch im letzten Jahrhundert war man nicht als root unterwegs.
                Und auch damals hat man Systeme aktuell gehalten.
                Dann tschändje jetzt das not more running süstäm.
                Gar nicht. Der Zug ist abgefahren. Bzw. der Kontinent ist weggedriftet.
                Kannst du eigentlich nur neuinstallieren.
                  fastfoot @theo_tusch last edited by
                  gibts auch im real life, wenn dein uralt opel kadett keinen tüv mehr bekommt dann gehts ab in die presse. und deine uralt anlage, seinerzeit für jede menge kohle mit viel liebe eingebaut willste auch nicht mehr ausbauen und mitnehmen. soviel zu 'ohne verluste'
                  einen unterschied gibts aber, da es sich um software handelt nimmste gleich das neueste modell 🙂
                  theo_tusch 1 Reply Last reply Reply Quote 1
                  • theo_tusch
                    theo_tusch @fastfoot last edited by
                    So, ich habe jetzt debian und node.js upgedatet und die Adapter lassen sich wieder updaten.
                    Danke euch für die Hinweise!
                      @theo_tusch
                      Zeig mal sie Langfassung von
                      iob diag
