    4. coffee-script-Fehler bei Javascript-Instanz
      PatrickFro last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: NUC
      Arbeitsspeicher: 16GB
      Festplattenart: SSD
      Betriebssystem: Debian Bookworm
      Node-Version: 5.0.12
      Nodejs-Version: v18.18.2
      NPM-Version: 9.8.1
      Installationsart: Skript
      Image genutzt: Nein
      Moin, ich habe gerade eine neue IoBroker-Installation in einer VM unter Proxmox installiert, danach das Backup des bis gerade laufenden IoBrokers eingespielt. Die Instanzen laufen bis auf Javascript, da funktioniert nur die auf dem Slave (Multihost).
      Fehlermeldungen:
      host.VM-IoBroker
      2023-10-14 15:59:34.813	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.VM-IoBroker
      2023-10-14 15:59:34.813	error	Caught by controller[0]: Node.js v18.18.2
      host.VM-IoBroker
      2023-10-14 15:59:34.813	error	Caught by controller[0]: }
      host.VM-IoBroker
      2023-10-14 15:59:34.813	error	Caught by controller[0]: requestPath: 'coffeescript'
      host.VM-IoBroker
      2023-10-14 15:59:34.812	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/package.json',
      host.VM-IoBroker
      2023-10-14 15:59:34.812	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.VM-IoBroker
      2023-10-14 15:59:34.812	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32) {
      host.VM-IoBroker
      2023-10-14 15:59:34.812	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
      host.VM-IoBroker
      2023-10-14 15:59:34.812	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
      host.VM-IoBroker
      2023-10-14 15:59:34.812	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:21:23)
      host.VM-IoBroker
      2023-10-14 15:59:34.812	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:119:18)
      host.VM-IoBroker
      2023-10-14 15:59:34.812	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
      host.VM-IoBroker
      2023-10-14 15:59:34.812	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
      host.VM-IoBroker
      2023-10-14 15:59:34.812	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1063:27)
      host.VM-IoBroker
      2023-10-14 15:59:34.812	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:680:18)
      host.VM-IoBroker
      2023-10-14 15:59:34.812	error	Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:438:19)
      host.VM-IoBroker
      2023-10-14 15:59:34.812	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script'. Please verify that the package.json has a valid "main" entry
      host.VM-IoBroker
      2023-10-14 15:59:34.811	error	Caught by controller[0]: ^
      host.VM-IoBroker
      2023-10-14 15:59:34.811	error	Caught by controller[0]: throw err;
      host.VM-IoBroker
      2023-10-14 15:59:34.811	error	Caught by controller[0]: node:internal/modules/cjs/loader:446
      Da ich die Angabenanforderung in einem anderen Beitrag gesehen haben:
      root@VM-IoBroker:/home/patrick# sudo ln -s /usr/bin/node /usr/bin/nodejs
      ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
      root@VM-IoBroker:/home/patrick# uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      x86_64
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v18.18.2
      v18.18.2
      9.8.1
      root
      /home/patrick
      OK:1 http://deb.debian.org/debian bookworm InRelease
      OK:2 http://deb.debian.org/debian bookworm-updates InRelease
      OK:3 http://security.debian.org/debian-security bookworm-security InRelease
      OK:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Paketlisten werden gelesen… Fertig
      Abhängigkeitsbaum wird aufgebaut… Fertig
      Statusinformationen werden eingelesen… Fertig
      Alle Pakete sind aktuell.
      nodejs:
        Installiert:           18.18.2-1nodesource1
        Installationskandidat: 18.18.2-1nodesource1
        Versionstabelle:
       *** 18.18.2-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           18.18.1-1nodesource1 500
           18.18.0-1nodesource1 500
           18.17.1-1nodesource1 500
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0+dfsg1-1 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
      Kann jemand helfen?
      Danke!
      Glasfaser 2 Replies Last reply Reply Quote 0
      • Glasfaser
        Glasfaser @PatrickFro last edited by
        @patrickfro sagte in coffee-script-Fehler bei Javascript-Instanz:
        root
        und warum als root
        • Glasfaser
          dazu gibt es einige Lösungen hier :
          https://forum.iobroker.net/search?term=Caught by controller[0]%3A requestPath%3A 'coffeescript'&in=titlesposts
