    4. [gelöst] LG Adapter Problem
      deta Most Active last edited by deta
      nach einen System problem, hab ich jetzt das Problem, das der Adapter sich nicht mehr installieren lässt.
      Was ist hier das Problem?
      $ iobroker add lgtv auto --host rock64 --debug
      NPM version: 9.8.1
      Installing iobroker.lgtv@2.1.1... (System call)
      npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/bufferutil
      npm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! gyp info it worked if it ends with oknpm ERR! gyp info using node-gyp@7.1.2npm ERR! gyp info using node@18.18.2 | linux | arm64npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"npm ERR! (node:245047) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! gyp info spawn /usr/bin/python3npm ERR! gyp info spawn args [npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',npm ERR! gyp info spawn args 'binding.gyp',npm ERR! gyp info spawn args '-f',npm ERR! gyp info spawn args 'make',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/bufferutil/build/config.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',npm ERR! gyp info spawn args '-Dlibrary=shared_library',npm ERR! gyp info spawn args '-Dvisibility=default',npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',npm ERR! gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/bufferutil',npm ERR! gyp info spawn args '-Dnode_engine=v8',npm ERR! gyp info spawn args '--depth=.',npm ERR! gyp info spawn args '--no-parallel',npm ERR! gyp info spawn args '--generator-output',npm ERR! gyp info spawn args 'build',npm ERR! gyp info spawn args '-Goutput_dir=.'npm ERR! gyp info spawn args ]npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:517:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:292:12)npm ERR! gyp ERR! System Linux 6.1.50-current-rockchip64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/bufferutilnpm ERR! gyp ERR! node -v v18.18.2npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-19T11_19_59_385Z-debug-0.log
      npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/bufferutilnpm ERR! command failednpm ERR! command sh -c node-gyp-buildnpm ERR! gyp info it worked if it ends with oknpm ERR! gyp info using node-gyp@7.1.2npm ERR! gyp info using node@18.18.2 | linux | arm64npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"npm ERR! (node:245047) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)npm ERR! gyp info spawn /usr/bin/python3npm ERR! gyp info spawn args [npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',npm ERR! gyp info spawn args 'binding.gyp',npm ERR! gyp info spawn args '-f',npm ERR! gyp info spawn args 'make',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/bufferutil/build/config.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',npm ERR! gyp info spawn args '-Dlibrary=shared_library',npm ERR! gyp info spawn args '-Dvisibility=default',npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',npm ERR! gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/bufferutil',npm ERR! gyp info spawn args '-Dnode_engine=v8',npm ERR! gyp info spawn args '--depth=.',npm ERR! gyp info spawn args '--no-parallel',npm ERR! gyp info spawn args '--generator-output',npm ERR! gyp info spawn args 'build',npm ERR! gyp info spawn args '-Goutput_dir=.'npm ERR! gyp info spawn args ]npm ERR! Traceback (most recent call last):npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 51, in <module>npm ERR! sys.exit(gyp.script_main())npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 670, in script_mainnpm ERR! return main(sys.argv[1:])npm ERR! ^^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 662, in mainnpm ERR! return gyp_main(args)npm ERR! ^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 629, in gyp_mainnpm ERR! [generator, flat_list, targets, data] = Load(npm ERR! ^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 150, in Loadnpm ERR! result = gyp.input.Load(npm ERR! ^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 3021, in Loadnpm ERR! LoadTargetBuildFile(npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 411, in LoadTargetBuildFilenpm ERR! build_file_data = LoadOneBuildFile(npm ERR! ^^^^^^^^^^^^^^^^^npm ERR! File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 239, in LoadOneBuildFilenpm ERR! build_file_contents = open(build_file_path, "rU").read()npm ERR! ^^^^^^^^^^^^^^^^^^^^^^^^^^^npm ERR! ValueError: invalid mode: 'rU' while trying to load binding.gypnpm ERR! gyp ERR! configure error npm ERR! gyp ERR! stack Error: `gyp` failed with exit code: 1npm ERR! gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:351:16)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:517:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:292:12)npm ERR! gyp ERR! System Linux 6.1.50-current-rockchip64npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/bufferutilnpm ERR! gyp ERR! node -v v18.18.2npm ERR! gyp ERR! node-gyp -v v7.1.2npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-19T11_19_59_385Z-debug-0.log
      host.rock64 Cannot install iobroker.lgtv@2.1.1: 1
      ERROR: Process exited with code 25
      mcm1957 Thomas Braun 2 Replies Last reply Reply Quote 0
      • mcm1957
        mcm1957 @deta last edited by
        @deta
        https://forum.iobroker.net/topic/57337/fehler-25-217-oder-enotempty-bei-adapter-install-update ?
          Thomas Braun Most Active @deta last edited by Thomas Braun
          @deta
          Gib mal die Ausgabe von
          iob diag
          zum Besten.
            deta Most Active @mcm1957 last edited by
            @mcm57 leider brachte iob fix nichts
              deta Most Active @Thomas Braun last edited by deta
              Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
              The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
              Just copy and paste the Summary Page, including the ``` characters at start and end.
              It helps us to help you!
              Press any key to continue
              Skript v.2023-10-10
              *** BASE SYSTEM ***
               Static hostname: rock64
                     Icon name: computer
              Operating System: Armbian 23.8.3 bookworm
                        Kernel: Linux 6.1.50-current-rockchip64
                  Architecture: arm64
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : arm64
              Systemuptime and Load:
               13:40:05 up 10 min,  2 users,  load average: 2.66, 3.98, 2.57
              CPU threads: 4
              *** Time and Time Zones ***
                             Local time: Thu 2023-10-19 13:40:06 UTC
                         Universal time: Thu 2023-10-19 13:40:06 UTC
                               RTC time: Thu 2023-10-19 13:40:06
                              Time zone: Etc/UTC (UTC, +0000)
                            NTP service: active
                        RTC in local TZ: no
              *** User and Groups ***
              rock
              /home/rock
              rock sudo users iobroker
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            4.2G        2.4G        1.3G        6.0M        497M        1.8G
              Swap:           2.1G          0B        2.1G
              Total:          6.3G        2.4G        3.4G
                       3974 M total memory
                       2305 M used memory
                       2202 M active memory
                        232 M inactive memory
                       1282 M free memory
                         43 M buffer memory
                        430 M swap cache
                       1987 M total swap
                          0 M used swap
                       1987 M free swap
              *** FAILED SERVICES ***
                UNIT                              LOAD   ACTIVE SUB    DESCRIPTION
              * mnt-raspi\x2ddatensicherung.mount loaded failed failed /mnt/raspi-datensicherung
              1 loaded units listed.
              *** FILESYSTEM ***
              udev           devtmpfs  1.9G     0  1.9G   0% /dev
              tmpfs          tmpfs     398M  5.7M  392M   2% /run
              /dev/mmcblk0p1 ext4       29G  4.8G   24G  17% /
              tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
              tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
              tmpfs          tmpfs     2.0G     0  2.0G   0% /tmp
              /dev/zram1     ext4       47M  2.9M   41M   7% /var/log
              tmpfs          tmpfs     398M     0  398M   0% /run/user/1001
              [Thu Oct 19 13:29:35 2023] Kernel command line: root=UUID=3941c09f-f61e-41a9-a178-95c32383f0d6 rootwait rootfstype=ext4 splash=verbose console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=45b7c889-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
              [Thu Oct 19 13:29:39 2023] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Quota mode: none.
              [Thu Oct 19 13:29:42 2023] EXT4-fs (mmcblk0p1): re-mounted. Quota mode: none.
              [Thu Oct 19 13:29:45 2023] EXT4-fs (zram1): mounted filesystem without journal. Quota mode: none.
              TARGET         SOURCE                   FSTYPE OPTIONS
              /              /dev/mmcblk0p1           ext4   rw,noatime,errors=remount-ro,commit=600
              |-/var/log.hdd /dev/mmcblk0p1[/var/log] ext4   rw,noatime,errors=remount-ro,commit=600
              `-/var/log     /dev/zram1               ext4   rw,relatime,discard
              /var:
              426M    /var/
              280M    /var/cache
              275M    /var/cache/apt
              204M    /var/cache/apt/archives
              132M    /var/lib
              No journal files were opened due to insufficient permissions.
              /opt/iobroker/backups:
              16M     /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              1.1G    /opt/iobroker/iobroker-data/
              531M    /opt/iobroker/iobroker-data/history
              523M    /opt/iobroker/iobroker-data/files
              90M     /opt/iobroker/iobroker-data/files/echarts.admin
              78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
              33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
              24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
              24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map
              24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.5f66c5d9.js.map
              21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
              USB-Devices by-id:
              /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_70a5b0635fd9eb119fe1158e6fe9f4d9-if00-port0
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v18.18.2
              /usr/bin/node           v18.18.2
              /usr/bin/npm            9.8.1
              /usr/bin/npx            9.8.1
              /usr/bin/corepack       0.19.0
              nodejs:
                Version table:
               *** 18.18.2-1nodesource1 500
                      100 /var/lib/dpkg/status
                   18.18.1-1nodesource1 500
                   18.18.0-1nodesource1 500
                   18.17.1-1nodesource1 500
                   18.17.0-1nodesource1 500
                   18.16.1-1nodesource1 500
                   18.16.0-1nodesource1 500
                   18.15.0-1nodesource1 500
                   18.14.2-1nodesource1 500
                   18.14.1-1nodesource1 500
                   18.14.0-1nodesource1 500
                   18.13.0+dfsg1-1 500
                   18.13.0-1nodesource1 500
                   18.12.0-1nodesource1 500
                   18.11.0-1nodesource1 500
                   18.10.0-1nodesource1 500
                   18.9.1-1nodesource1 500
                   18.9.0-1nodesource1 500
                   18.8.0-1nodesource1 500
                   18.7.0-1nodesource1 500
                   18.6.0-1nodesource1 500
                   18.5.0-1nodesource1 500
                   18.4.0-1nodesource1 500
                   18.3.0-1nodesource1 500
                   18.2.0-1nodesource1 500
                   18.1.0-1nodesource1 500
                   18.0.0-1nodesource1 500
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller:  5.0.14
              admin:          6.10.8
              javascript:     7.1.5
              Adapters from github:   0
              Adapter State
              + system.adapter.admin.0                  : admin                 : rock64                                   -  enabled, port: 8081, bind: 192.168.178.61, run as: admin
              + system.adapter.alexa2.0                 : alexa2                : rock64                                   -  enabled
                system.adapter.alias-manager.0          : alias-manager         : rock64                                   - disabled
                system.adapter.awattar.0                : awattar               : rock64                                   -  enabled
              + system.adapter.backitup.0               : backitup              : rock64                                   -  enabled
              + system.adapter.broadlink2.0             : broadlink2            : rock64                                   -  enabled
                system.adapter.coronavirus-statistics.0 : coronavirus-statistics: rock64                                   -  enabled
                system.adapter.daswetter.0              : daswetter             : rock64                                   -  enabled
              + system.adapter.discovergy.0             : discovergy            : rock64                                   -  enabled
              + system.adapter.discovery.0              : discovery             : rock64                                   -  enabled
              + system.adapter.echarts.0                : echarts               : rock64                                   -  enabled
              + system.adapter.enigma2.0                : enigma2               : rock64                                   -  enabled
                system.adapter.feiertage.0              : feiertage             : rock64                                   -  enabled
              + system.adapter.fritzdect.0              : fritzdect             : rock64                                   -  enabled
              + system.adapter.harmony.0                : harmony               : rock64                                   -  enabled
              + system.adapter.heatingcontrol.0         : heatingcontrol        : rock64                                   -  enabled
              + system.adapter.history.0                : history               : rock64                                   -  enabled
              + system.adapter.hm-rega.0                : hm-rega               : rock64                                   -  enabled
              + system.adapter.hm-rpc.0                 : hm-rpc                : rock64                                   -  enabled, port: 0
              + system.adapter.hm-rpc.1                 : hm-rpc                : rock64                                   -  enabled, port: 0
                system.adapter.ical.0                   : ical                  : rock64                                   -  enabled
                system.adapter.icons-icons8.0           : icons-icons8          : rock64                                   - disabled
                system.adapter.icons-material-png.0     : icons-material-png    : rock64                                   - disabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : rock64                                   - disabled
                system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: rock64                                   - disabled
              + system.adapter.info.0                   : info                  : rock64                                   -  enabled
              + system.adapter.iot.0                    : iot                   : rock64                                   -  enabled
              + system.adapter.javascript.0             : javascript            : rock64                                   -  enabled
                system.adapter.linux-control.0          : linux-control         : rock64                                   - disabled
              + system.adapter.mielecloudservice.0      : mielecloudservice     : rock64                                   -  enabled
              + system.adapter.mqtt.0                   : mqtt                  : rock64                                   -  enabled, port: 1891, bind: 192.168.178.61
                system.adapter.netatmo-crawler.0        : netatmo-crawler       : rock64                                   -  enabled
              + system.adapter.radar2.0                 : radar2                : rock64                                   -  enabled
                system.adapter.scenes.0                 : scenes                : rock64                                   - disabled
                system.adapter.schoolfree.0             : schoolfree            : rock64                                   -  enabled
              + system.adapter.simple-api.0             : simple-api            : rock64                                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
              + system.adapter.socketio.0               : socketio              : rock64                                   -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
              + system.adapter.sonoff.0                 : sonoff                : rock64                                   -  enabled, port: 1883, bind: 192.168.178.61
                system.adapter.synology.0               : synology              : rock64                                   - disabled, port: 5001
              + system.adapter.tankerkoenig.0           : tankerkoenig          : rock64                                   -  enabled
              + system.adapter.telegram.0               : telegram              : rock64                                   -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.text2command.0           : text2command          : rock64                                   -  enabled
              + system.adapter.tr-064.0                 : tr-064                : rock64                                   -  enabled
              + system.adapter.trashschedule.0          : trashschedule         : rock64                                   -  enabled
              + system.adapter.tuya.0                   : tuya                  : rock64                                   -  enabled
                system.adapter.tvspielfilm.0            : tvspielfilm           : rock64                                   - disabled
              + system.adapter.upnp.0                   : upnp                  : rock64                                   -  enabled
                system.adapter.vis-bars.0               : vis-bars              : rock64                                   - disabled
                system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : rock64                                   - disabled
                system.adapter.vis-colorpicker.0        : vis-colorpicker       : rock64                                   - disabled
                system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : rock64                                   - disabled
                system.adapter.vis-google-fonts.0       : vis-google-fonts      : rock64                                   - disabled
                system.adapter.vis-history.0            : vis-history           : rock64                                   - disabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : rock64                                   - disabled
                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : rock64                                   - disabled
                system.adapter.vis-justgage.0           : vis-justgage          : rock64                                   - disabled
                system.adapter.vis-metro.0              : vis-metro             : rock64                                   - disabled
                system.adapter.vis-rgraph.0             : vis-rgraph            : rock64                                   - disabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : rock64                                   - disabled
                system.adapter.vis-weather.0            : vis-weather           : rock64                                   - disabled
                system.adapter.vis.0                    : vis                   : rock64                                   - disabled
              + system.adapter.web.0                    : web                   : rock64                                   -  enabled, port: 8082, bind: 192.168.178.61, run as: admin
              + system.adapter.wifilight.0              : wifilight             : rock64                                   -  enabled
              + system.adapter.zigbee.0                 : zigbee                : rock64                                   -  enabled, port: /dev/ttyUSB0
              + instance is alive
              ioBroker-Repositories
              Active repo(s): beta
              Installed ioBroker-Instances
              Used repository: beta
              Adapter    "admin"        : 6.10.8   , installed 6.10.8
              Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
              Adapter    "awattar"      : 1.0.6    , installed 1.0.6
              Adapter    "backitup"     : 2.8.7    , installed 2.8.7
              Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
              Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
              Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
              Adapter    "discovergy"   : 0.5.8    , installed 0.5.8
              Adapter    "echarts"      : 1.5.4    , installed 1.5.4
              Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
              Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
              Adapter    "fritzdect"    : 2.5.2    , installed 2.5.2
              Adapter    "harmony"      : 1.2.2    , installed 1.2.2
              Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
              Adapter    "history"      : 3.0.0    , installed 3.0.0
              Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
              Adapter    "iot"          : 2.0.11   , installed 2.0.11
              Adapter    "javascript"   : 7.1.5    , installed 7.1.5
              Controller "js-controller": 5.0.14   , installed 5.0.14
              Adapter    "linux-control": 1.1.5    , installed 1.1.5
              Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
              Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
              Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
              Adapter    "radar2"       : 2.0.8    , installed 2.0.8
              Adapter    "schoolfree"   : 1.1.2    , installed 1.1.2
              Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
              Adapter    "synology"     : 3.0.1    , installed 3.0.1
              Adapter    "telegram"     : 2.0.1    , installed 2.0.1
              Adapter    "text2command" : 3.0.2    , installed 3.0.2
              Adapter    "trashschedule": 2.2.0    , installed 2.2.0
              Adapter    "tuya"         : 3.14.2   , installed 3.14.2
              Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.5
              Adapter    "upnp"         : 1.0.21   , installed 1.0.21
              Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
              Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
              Adapter    "web"          : 6.1.10   , installed 6.1.10
              Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
              Adapter    "ws"           : 2.5.8    , installed 2.5.8
              Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
              Objects and States
              Objects:        15231
              States:         9695
              Hit:2 http://security.debian.org bookworm-security InRelease
              Hit:4 http://deb.debian.org/debian bookworm-backports InRelease
              Hit:6 http://fi.mirror.armbian.de/apt bookworm InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 192.168.178.61:1883     0.0.0.0:*               LISTEN      1000       20510      1519/io.sonoff.0
              tcp        0      0 192.168.178.61:1892     0.0.0.0:*               LISTEN      1000       18821      1501/io.mqtt.0
              tcp        0      0 192.168.178.61:1891     0.0.0.0:*               LISTEN      1000       18820      1501/io.mqtt.0
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       11260      897/iobroker.js-con
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       15124      897/iobroker.js-con
              tcp        0      0 192.168.178.61:2010     0.0.0.0:*               LISTEN      1000       17357      1445/io.hm-rpc.0
              tcp        0      0 192.168.178.61:8082     0.0.0.0:*               LISTEN      1000       21458      2206/io.web.0
              tcp        0      0 192.168.178.61:8081     0.0.0.0:*               LISTEN      1000       18524      1338/io.admin.0
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14314      1/init
              tcp        0      0 192.168.178.61:8701     0.0.0.0:*               LISTEN      1000       18726      1468/io.hm-rpc.1
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14971      1009/sshd: /usr/sbi
              tcp6       0      0 :::5201                 :::*                    LISTEN      103        16086      899/iperf3
              tcp6       0      0 :::8084                 :::*                    LISTEN      1000       21400      2029/io.socketio.0
              tcp6       0      0 :::8087                 :::*                    LISTEN      1000       19236      2005/io.simple-api.
              tcp6       0      0 :::111                  :::*                    LISTEN      0          14315      1/init
              tcp6       0      0 :::22                   :::*                    LISTEN      0          14973      1009/sshd: /usr/sbi
              tcp6       0      0 :::61991                :::*                    LISTEN      1000       19125      1882/io.harmony.0
              udp        0      0 0.0.0.0:36910           0.0.0.0:*                           1000       19987      1738/io.broadlink2.
              udp        0      0 0.0.0.0:67              0.0.0.0:*                           1000       18746      1508/io.radar2.0
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          348        1/init
              udp        0      0 127.0.0.1:323           0.0.0.0:*                           0          16917      971/chronyd
              udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       21520      1651/io.tuya.0
              udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       21521      1651/io.tuya.0
              udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       19126      1882/io.harmony.0
              udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1000       19984      1738/io.broadlink2.
              udp        0      0 0.0.0.0:44107           0.0.0.0:*                           1000       39719      1738/io.broadlink2.
              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       22546      2192/io.upnp.0
              udp6       0      0 :::111                  :::*                                0          14316      1/init
              udp6       0      0 ::1:323                 :::*                                0          16918      971/chronyd
              udp6       0      0 fe80::81d3:290b:af8:546 :::*                                0          11216      746/NetworkManager
              2023-10-19 13:42:11.898  - debug: mielecloudservice.0 (1494) Received PING message by SSE: {"type":"ping","data":"ping","lastEventId":"","origin":"https://api.mcs3.miele.com"}
              2023-10-19 13:42:13.528  - info: radar2.0 (1508) debug: started #41 l2ping  -c 1 98:b8:bc:ad:31:27
              2023-10-19 13:42:13.634  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"98:7b:f3:4b:cd:5f","btName":"LG HTS(CD:5F)","rssi":-53,"btVendor":"Texas Instruments","by":"noble"}
              2023-10-19 13:42:13.655  - warn: radar2.0 (1508) arp-scan maybe without rights because no data returned!
              2023-10-19 13:42:17.237  - info: radar2.0 (1508) debug: ChangeState ack:true of S20-FE-von-Detlef._lastHere = 2023-10-19@13:42:17
              2023-10-19 13:42:17.570  - info: radar2.0 (1508) debug: started #42 l2ping  -c 1 18:70:3b:37:12:8c
              2023-10-19 13:42:21.609  - info: radar2.0 (1508) debug: started #43 l2ping  -c 1 c8:8d:4d:ea:19:ec
              2023-10-19 13:42:21.675  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"7c:a0:e6:35:fc:7f","btName":"N/A","rssi":-68,"btVendor":"N/A","by":"noble"}
              2023-10-19 13:42:21.680  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"68:61:24:bf:5c:b1","btName":"N/A","rssi":-69,"btVendor":"N/A","by":"noble"}
              2023-10-19 13:42:25.658  - info: radar2.0 (1508) debug: started #44 l2ping  -c 1 34:fe:77:10:87:4e
              2023-10-19 13:42:28.860  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"de:83:ec:e2:00:e5","btName":"N/A","rssi":-68,"btVendor":"N/A","by":"noble"}
              2023-10-19 13:42:29.223  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"f9:dd:b2:07:54:32","btName":"N/A","rssi":-81,"btVendor":"N/A","by":"noble"}
              2023-10-19 13:42:29.759  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"40:5c:b1:9e:57:45","btName":"N/A","rssi":-80,"btVendor":"N/A","by":"noble"}
              2023-10-19 13:42:29.860  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"5f:9a:49:49:19:46","btName":"N/A","rssi":-69,"btVendor":"N/A","by":"noble"}
              2023-10-19 13:42:29.868  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"c4:f8:75:12:c9:e4","btName":"N/A","rssi":-70,"btVendor":"N/A","by":"noble"}
              2023-10-19 13:42:30.068  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"70:ff:92:55:6f:e1","btName":"N/A","rssi":-82,"btVendor":"N/A","by":"noble"}
              2023-10-19 13:42:30.864  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"de:83:ec:e2:00:e5","btName":"N/A","rssi":-67,"btVendor":"N/A","by":"noble"}
              2023-10-19 13:42:31.100  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"48:93:fe:a7:8d:67","btName":"N/A","rssi":-81,"btVendor":"N/A","by":"noble"}
              2023-10-19 13:42:31.223  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"f9:dd:b2:07:54:32","btName":"N/A","rssi":-77,"btVendor":"N/A","by":"noble"}
              2023-10-19 13:42:31.908  - debug: mielecloudservice.0 (1494) Received PING message by SSE: {"type":"ping","data":"ping","lastEventId":"","origin":"https://api.mcs3.miele.com"}
              2023-10-19 13:42:31.930  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"c4:f8:75:12:c9:e4","btName":"N/A","rssi":-69,"btVendor":"N/A","by":"noble"}
              2023-10-19 13:42:32.874  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"de:83:ec:e2:00:e5","btName":"N/A","rssi":-67,"btVendor":"N/A","by":"noble"}
              2023-10-19 13:42:33.228  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"f9:dd:b2:07:54:32","btName":"N/A","rssi":-77,"btVendor":"N/A","by":"noble"}
              2023-10-19 13:42:33.935  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"c4:f8:75:12:c9:e4","btName":"N/A","rssi":-72,"btVendor":"N/A","by":"noble"}
              2023-10-19 13:42:34.413  - info: radar2.0 (1508) debug: -BtFound unknown with {"address":"e6:b0:3d:a1:3e:21","btName":"N/A","rssi":-80,"btVendor":"N/A","by":"noble"}
              iob diag has finished.
              Press any key for a summary
              Copy text starting here:
                                      v.2023-10-10
                     Icon name: computer
                  Architecture: arm64
              Userland:               arm64
              Timezone:               Etc/UTC (UTC, +0000)
              User-ID:                1001
              X-Server:               false
              Pending OS-Updates:     0
              Pending iob updates:    0
              Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                      /usr/bin/npm            9.8.1
                                      /usr/bin/npx            9.8.1
              Recommended versions are nodejs 18.18.2 and npm 9.8.1
              MEMORY:
              Mem:            4.2G        2.4G        1.2G        6.0M        669M        1.7G
              Swap:           2.1G          0B        2.1G
              Total:          6.3G        2.4G        3.2G
              Active iob-Instances:   35
              ioBroker Core:          js-controller           5.0.14
                                      admin                   6.10.8
              Objects type: jsonl
              States  type: jsonl
              Objects:                15231
              States:                 9695
              Size of iob-Database:
              17M     /opt/iobroker/iobroker-data/objects.jsonl
              6.9M    /opt/iobroker/iobroker-data/states.jsonl
              === Mark text until here for copying ===
                @deta
                Setz die Zeitzone richtig.
                  @thomas-braun sagte in LG Adapter problem:
                  @deta
                  wo meinst du das?
                    @deta
                    In deinem Betriebssystem.
                      @thomas-braun danke genau das wars. Grummel.
                        @deta
                        Die exakte Uhrzeit ist für Computersysteme enorm wichtig, das ist nicht nur 'zur Zierde' da.
                          @deta
                          schon klar, hatte ich doch irgendwie übersehen.
                          Jetzt geht das ganze System wieder.
                          Bis auf eine kleinigkeit.
                          Wenn ich auf den Schraubenschlüssel klicke für die Basiseinstellungen, nurdelt er sich bis...
                          kommt nichts.
                          cu Deta
                          342
