    4. [Gelöst] Backup auf Synologie NAS
    • drsnuggles1982
      drsnuggles1982 last edited by drsnuggles1982
      Hy,
      probiere grad mein backup auf meine NAS von Synolgie einzurichten. leider bekomme ich immer wieder Fehler beim mounten des laufwerks. Passwort und user name stimmen. von meinem Windows System kann ich alles ohne Probleme ereichen.
      Started iobroker ...
      [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.2.202","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","smb":"vers=2.0","sudo":false,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"/Backup/Iobroker/Standard","dirMinimal":"sharename/backupDir","user":"felix","pass":"****","ignoreErrors":false}
      [DEBUG] [mount] - noserverino option: false
      [DEBUG] [mount] - cifs-mount command: "mount -t cifs -o username=felix,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=2.0 //192.168.2.202/Backup/Iobroker/Standard /opt/iobroker/backups"
      [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
      [DEBUG] [mount] - cifs-mount command: "mount -t cifs -o username=felix,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.2.202/Backup/Iobroker/Standard /opt/iobroker/backups"
      [ERROR] [mount] - [undefined Error: Command failed: mount -t cifs -o username=felix,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.2.202/Backup/Iobroker/Standard /opt/iobroker/backups
      mount.cifs: permission denied: no match for /opt/iobroker/backups found in /etc/fstab
      [ERROR] [mount] - Error: Command failed: mount -t cifs -o username=felix,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.2.202/Backup/Iobroker/Standard /opt/iobroker/backups
      Einstellungen im NAS sollten stimmen.
      Die Einstellungen in backitup sehen für mich auch gut aus
      Kann jemand mit den Ausgaben was anfangen? Bin noch zu unerfahren mit iobroker und Raspberry.
      Danke Felix
      • Meister Mopper
        Meister Mopper @drsnuggles1982 last edited by
        @drsnuggles1982
        Welche Hardware hast du da?
        drsnuggles1982 1 Reply Last reply Reply Quote 0
        • drsnuggles1982
          drsnuggles1982 @Meister Mopper last edited by
          @meister-mopper
          Raspberry Pi 4
          Plattform: linux
          Betriebssystem: linux
          Architektur: arm
          CPUs: 4
          Geschwindigkeit: 1500 MHz
          Modell: unknown
          RAM: 3.7 GB
          System-Betriebszeit: 11 T. 11:18:24
          Node.js: v16.19.1
          time: 1697440603544
          timeOffset: -120
          NPM: 8.19.3
          Adapter-Anzahl: 504
          Datenträgergröße: 58.2 GB
          Freier Festplattenspeicher: 54.5 GB
          Aktive Instanzen: 10
          Pfad: /opt/iobroker/
          Betriebszeit: 6 T. 21:47:51
          aktiv:
          MartinP Thomas Braun 3 Replies Last reply Reply Quote 0
          • MartinP
            MartinP @drsnuggles1982 last edited by
            "... uid=iobroker,gid=iobroker..."
            Ist das denn auf dem Synology eingerichtet...
              Thomas Braun Most Active @drsnuggles1982 last edited by Thomas Braun
              @drsnuggles1982
              Du musst das als root mounten. Also Option setzen .
              SMB-Typ auf 3.1.1.
                Thomas Braun Most Active @MartinP last edited by
                @martinp sagte in Backup auf Synologie NAS:
                Da muss nix aus der Synology eingerichtet sein, die uid und gid wird beim mounten über die Daten gelegt. Sonst würden die dem root gehören.
                  @drsnuggles1982 sagte in Backup auf Synologie NAS:
                  Node.js: v16.19.1
                  Bring das auf nodejs@18.
                  Die 16 ist abgekündigt.
                  • drsnuggles1982
                    drsnuggles1982 @Thomas Braun last edited by
                    @thomas-braun da Aust ja das Ziel. Wollte erstmal ein Backup machen und dann das Update.
                      @drsnuggles1982
                      Machst du bisher keine Backups?
                      iob nodejs-update
                      bringt die nodejs 18 an den Start.
                      • drsnuggles1982
                        @thomas-braun mein System ist grad mal zwei Wochen alt. Bin grade am umziehen von einer anderen Smartphone Umgebung. Jetzt hab ich einen Stand der funktioniert und wollte das Backup machen
                          @drsnuggles1982
                          Aber vor zwei Wochen war nodejs16 auch schon obsolet und es wurde vom Installer eine nodejs18 installiert.
                          • drsnuggles1982
                            @thomas-braun nicht im raspberry Image.
                              Aber in 'richtigen' Installationen. Bei Fertigkost kann das sein. Aber u.a. aus diesem Grund halte ich diese Images für komplett unnötig.
                              • drsnuggles1982
                                drsnuggles1982 @Thomas Braun last edited by drsnuggles1982
                                @thomas-braun ich bin ja bei dir ich brauche dieses Update. Wollte nur vorher das backup richtig machen. Wenn du mir sagts es liegt an de rNode.js version dann passt das für mich, dann amch ich ein old schoolbackup und zieh mir die daten dann runter.
                                  @drsnuggles1982
                                  Nein, es liegt an den falschen Optionen im Backitup.
                                  Wie bereits gesagt muss das als root gemountet werden und den SMB-Dialekt auf 3.1.1
                                  R drsnuggles1982 2 Replies Last reply Reply Quote 0
                                    reutli @Thomas Braun last edited by reutli
                                    @thomas-braun sagte in Backup auf Synologie NAS:
                                    wenn möglich würde ich ohnehin auf NFS setzen
                                      Thomas Braun Most Active @reutli last edited by
                                      @reutli sagte in Backup auf Synologie NAS:
                                      Ja, natürlich.
                                      • drsnuggles1982
                                        das bringt keine Verbesserung
                                        [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.2.202","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"/Backup/Iobroker/Standard","dirMinimal":"sharename/backupDir","user":"felix","pass":"****","ignoreErrors":false}
                                        [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=felix,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.2.202/Backup/Iobroker/Standard /opt/iobroker/backups"
                                        [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=felix,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.2.202/Backup/Iobroker/Standard /opt/iobroker/backups"
                                        [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=felix,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.2.202/Backup/Iobroker/Standard /opt/iobroker/backups
                                        mount error(13): Permission denied
                                        Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                                        [ERROR] [mount] - Error: Command failed: sudo mount -t cifs -o username=felix,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.2.202/Backup/Iobroker/Standard /opt/iobroker/backups
                                          reutli @drsnuggles1982 last edited by reutli
                                          Permission denied
                                          User und Passwort stimmen und mehrfach geprüft?
                                          Spezielle Zeichen im Passwort?
                                          Lege mal auf der NAS neuen user mit "einfachem" Passwort an und prüfen mit dem User nochmals im Backitup-Adapter.
                                          • drsnuggles1982
                                            @thomas-braun mit NFS geht es jetzt hab noch ein Video gefunden welches dies erklärt. Hatte den Pfad nich korrekt eingefügt da der Volumen name gefehlt hat
                                            Danke!
                                            R 2 Replies Last reply Reply Quote 0
                                            backitup nas
                                            1104
