    4. Zigbee-Adapter steuert Wifidimmer fehlerhaft
      A Former User last edited by
      Ich habe in meiner Konfiguration meinen Zigbee Dimmer von Tuya nach Tasmota umgezogen, damit ich das Tuya-Zigbee-Gateway abbauen kann:
      Die Anmeldung hat auch problemlos geklappt:
      Bei der Steuerung sieht es leider nicht so gut aus:
      DeviceAvailability:Failed to ping 0xa4c13807fbb4dfe0 TS110E
      Aber mein Zigbee-Adapter meldet auch sehr seltsame Fehler:
      2023-10-21 15:32:15.427	error	Running despite adapter configuration mismatch as configured. Please update the adapter to compatible firmware and recreate your network as soon as possible.
      2023-10-21 15:32:15.426	error	Re-commissioning your network will require re-pairing of all devices!
      2023-10-21 15:32:15.426	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
      2023-10-21 15:32:15.425	error	Please update configuration to prevent further issues.
      2023-10-21 15:32:15.425	error	- Channel List: configured=11, adapter=11
      2023-10-21 15:32:15.423	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
      2023-10-21 15:32:15.423	error	- Extended PAN ID: configured=00124b00257bb192, adapter=00124b00257bb192
      2023-10-21 15:32:15.421	error	- PAN ID: configured=6754, adapter=6754
      2023-10-21 15:32:15.419	error	Configuration is not consistent with adapter state/backup!
      Das Zigbee-Adapter ist ein Sonoff Zigbee Pro, Firmware Tasmota 13.2
